Got it running, ran... decent, then the intercooler pipe flew off. Put it back on, ran decent again... pipe flew off a second time, put it back on tighter. Battery wasn't fully charged so it died. Got it jumped, and when it started, it ran like scheize. Felt like it was running on one cylinder. Then when the hoses came off and the car died.
The battery died in the process of the install. I just jumped the car and took the car for a test drive. Could this be an alternator or battery problem?
![]() ![]() 1997 855 R - gone 1991 944 T - gone 1992 944 T - gone 1998 S70 GT - gone 1986 244 GLE - gone 1975 242 DL - Sitting, waiting, wishing. 1988 764 T -Currently for sale Last edited by CFL940; 12-14-2007 at 09:23 PM.. |
wagon>sedan
wait, your battery cables came off while the car was running?
#3 | ||
Anime Lord
the pipe blowing off means you have to much boost or week clamps repalce the clamps and turn it up even more its not high enough unless your blowing the hoses open
Tentacle Sedan-97 S90; stuff including paddles and holset etc... Powered by Beetroot Current 240 Ownership 1993, 1992, 1990, 1985, 1981 |
#4 | ||
So what should i do, charge the battery until full? |
#5 |
Make sure that there's no oil on the metal pipes that would make it easier for the hoses to pop off.
#6 |
I drilled holes in the end of the pipes and put small dome head screws in either side slipped the hoses and clip over the top and tightened. that stoped the hoses from going anywhere. prob solved.
'92 945 2.3 turbo, stripped, bilstiens, 19T , a cam , vernier ,440cc's , 3.5' DP , 3'ex ,ported manifold , intercooler 20psi . '84 manta gte with home built 170hp ford OHC low comp and turbo soon. '84 manta gte with slightly less rust 6 years later , getting there , slowly . '89 MG metro, caged , space framed front , hydrogas to coil over conversion , 12 inch wider track , 680kg , 100hp, 1300cc . '65 prototype ford corsair 2L 2door GT ... Sandblasted . '06 FN2 civic type R |
#7 |
Alright guys, thanks for the tips... but let me make myself more clear. I am not trying to figure out how to get my pipes to stay on. Im trying to figure out why after they DID fly off, the car is still running like **** with them fastend back on.
#8 |
reset the ECU?
#9 |
Post-Hypnotic Sigma
have you looked at the integrity of the AMM? how about the injector seals? fuel filteR? and replace voltage regulator or brushes.
Last edited by 740tankDriver; 12-17-2007 at 02:30 AM.. Reason: ::middle finger:: |
| Thread Tools | |
| Display Modes | |
