Old 01-15-2008, 11:24 PM   #1
barry240
Default pics or vids of boris knock sense in action
does any one have any clips of the knock sense caught in the act of sensing ping .i would like to see how it works .
barry240 is offline   Reply With Quote
Old 01-15-2008, 11:24 PM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
it is just an LED that lights up .. i have like 100 vids of it on my car
let me find some videos
http://thelostartof.net/drive2.avi
6.2meg ... see the red light coming on
on pump gas i get the light always on over 5k or so
Chip Feedback Thread / PM Current Chip Prices / PM for DownPipe & Exhaust Price / Silicone Cooling Hose Sets 2/7/9
Old 01-15-2008, 11:40 PM   #3
MrBill
JohnMc=500Dollar Mistake
MrBill's Avatar
you have 2.4, right?
So did you splice off the factory knock sensor or did you install another/
Originally Posted by 500dollar744ti View Post
something i feel strongly about because even if it doesn't appear so, i am a strong advocate of safety.
84 244 - Wilbur - Lemons hopeful
97 960 - New DD/beater
97 960 - Other new DD/beater
Old 01-15-2008, 11:48 PM   #4
barry240
is there a way to get it to come on only when its pinging ? do u think that the knock sence was money well spent .
Old 01-15-2008, 11:50 PM   #5
thelostartof
unbalanced chemical
best $ i spent on the car
and you can tune it so it only comes on with knock ...tho I like it setup like that as there is almost always inaudible knock that there is NO way for YOU to hear and the knock sensor hears this ... If I run race gas the light stays OFF ... so i know i am getting slight knock on pump gas
Old 01-15-2008, 11:58 PM   #6
barry240
and slight knock is ok
Old 01-16-2008, 12:01 AM   #7
thelostartof
unbalanced chemical
nope, it is bad, over time it will and can kill things but most of these engines are over built to the point where a little light knock will not be the end of the world, but you are much better off to have none, I run 14psi on pump gas w/ the stock EZK box and get very very very little ping these days so
Old 01-16-2008, 12:49 AM   #8
Hodginsa
Formerly Crazy0000 ;)
Hodginsa's Avatar
740s dashes are so much better...
Im definitely going to get one of these kits, Even more intrigued that I don't have to do any cutting and soldering. Going to try and cut back on that in the engine bay for a little while..
Hodginsa is offline   Reply With Quote
Old 01-16-2008, 01:02 AM   #9
barry240
what size turbo are you running ?
Old 01-16-2008, 09:59 AM   #10
thelostartof
unbalanced chemical
TD04HL CHRA and hot side w/ a super60 compressor wheel in a 15g compressor housing
small turbo, peaks around 490cfm or so map wise
tho all of that means nothing as the setup as a whole is what matters, 984 LH 2.4 ECU w/ freds chip, 65lb injectors, 31x12x4 intercooler, V16 cam, 531, and a trans that hates me
Old 01-16-2008, 11:50 AM   #11
JE Jr
JE Jr's Avatar
Where can I find more info about that thing? And did it work with the stock knock-sensor?
Black car: --142 ´68--
Yellow car: --142 GL ´72-- 70's rally-car wannabe
White car: --744 GLE ´88-- Polishing object
Blue car: --S70 GLT ´00-- Daily driver
JE Jr is offline   Reply With Quote
Old 01-16-2008, 11:52 AM   #12
Alex Buchka
8 cylinders
Alex Buchka's Avatar
http://www.viatrack.ca/
fungerar kanon med en standard bosch knacksensor.
Old 01-16-2008, 12:00 PM   #13
JE Jr
JE Jr's Avatar
Tack! (thanks)
Old 01-16-2008, 02:49 PM   #14
barry240
stock icu though.
Old 01-16-2008, 08:34 PM   #15
barry240
it is the stock icu right
Old 01-16-2008, 10:23 PM   #16
badvlvo
Bad for Babies
badvlvo's Avatar
So this is what the Turbobricks Ahowroom has become?
