Old 04-04-2008, 09:13 PM   #1
the poi
Has been
the poi's Avatar
Default Behold My Giant Muffin Cups!
Another in my grand tradition of weekend projects that take two weeks!
Basic premise regarding muffin cups:
Light goes here:
But, lo! The muffin cups do not fit! Clearly this was the most reasonable solution (note: this was not the most reasonable solution)
Because the highs and lows are connected, and must be aimed simultaneously, I had to first align the highbeams to the correct position with the built-in aligners, then, goop up some standoffs with JBKwik, and slide the lights in place. And then hold them ****ing motionless for 9 minutes. Dear god. On the plus side, it worked beautifully, and the assemblies just screw right in from the front, and are correctly aligned. For the visual learners:
And then, came the muffin cup trimming, fitting, and installation. They use the stock halogen shield mount, so they clip right into place.
I had two camera failures here, so not many pictures of the guts removed from the car, but you can vaguely see the butyl tape sealing the projector reflector and the original reflector. This **** is awesome, and I now have a mile of it that I'm gonna have to find a use for.
The most time-consuming part, and ultimately the most expensive, these ****ers:
Ahhh, glass. You never appreciate just how awful it is to machine until you attempt it. All told, I exploded one lens, so I had to buy two replacements (because the aftermarket ones have a different flute pattern, and hey, they're a lot clearer!). For initial cutting, I used 40grit silicon carbide discs attached to a flat, 1/8" steel backing plate. Attached this to the drill press, filled the lens with some water, and started cutting. This stage just got the irregularities out of the flute pattern (particularly high spots). Then, I added a 3mm neoprene (wetsuit, actually) pad in between the disc and the backing plate. That allows more conforming, and faster cutting (and hopefully, a better match to the slight convex outer surface. From here, I found that getting all the flutes out is only really possible with a cutting slurry. I threw some aluminum oxide blasting compound into the water, and kept it agitated so the grit kept getting caught under the wheel. This really hauls ass through the glass.
Once that's finished, I finished final removing and smoothing with silicon carbide pads on a 2.25" die grinder, still lubricated with water of course, through grits 40-80-220-400-600-800-1500. Final stage was glass polishing with an eastwoodco rhodite polishing system, same thing I polished my old lenses with a while back. One of which I exploded when I was figuring this out. Woo.
I wish some off-the-car photos survived, because I assure you, those things are ****ing clear as can be. That said, with the projector pumping a hilarious amount of light through them, the slightest imperfection is still visible, but it looks like its a problem with the casting of the glass itself. There's no conceivable way I can take pictures of the surface irregularities, but I assure you, that ****'s whack.
That however is mostly dust on the outside of the glass.
Full frontal:
And of course:
Holla.
Old 04-04-2008, 09:17 PM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
holy ****ing hell ...
you have WAY to much free time on your hands
Old 04-04-2008, 09:19 PM   #3
drinking940s
the eagle scout
What's penny going to use when he wants to make muffins on sunday mornings now?!?!
they look awesome! I'm sorry, what are the prjectors/ballasts/watts?
drinking940s is offline   Reply With Quote
Old 04-04-2008, 09:21 PM   #4
Chris_R
Kickin' rocks in sandals
Chris_R's Avatar
Badass!!! I was wondering how to polish the lenses/remove the fluting. Awesome info and the car looks great.
You painted the bumpercooler... why? Aesthetics?
Ermergherd!! Erm gernner kerhm!!
1995 964 (Silver)
1992 944Ti (White)
1996 965 (Burgundy) - Scrap
1994 945 Ti (Black) - Sirius Black Scrap
1992 944 GL (Black) - Killed by drunk driver
1988 745Ti (Silver) - Sold
Originally Posted by TurboBrickMan View Post
Long story short I found out she's a squirter.
Chris_R is offline   Reply With Quote
Old 04-04-2008, 09:22 PM   #5
drturbo
Visit Swedishiron.com
drturbo's Avatar
Nice welding. You did a great job fabbing the buckets. I likee
Check out my excellent feedback!
Need a part? Visit Swedishiron.com! Send me a PM or email with your want list!
drturbo is offline   Reply With Quote
Old 04-04-2008, 09:22 PM   #6
volvo940tuner
volvo940tuner's Avatar
holy smokes, amazing work!!!!
'93 944-SOLD
'91 745 TIC- PARTED OUT
'97 854 R- SOLD
'96 854T Platinum- SOLD
'98 S70 GLT- SOLD
'98 V70R-SOLD
'95 854 T5-R--teh yellow
'90 744 TIC SE
'96 854R-winter car
'88 BMW E30 325IS
volvo940tuner is offline   Reply With Quote
Old 04-04-2008, 09:22 PM   #7
norcal505
Location: Los Angeles, CA (SGV); Chicago, IL; San Diego, CA; SF Bay Area, CA
that is awesome chris.
1991 BMW 318i (Old Shell RIP, Now Re-shelled & Reborn)
1983 Peugeot 505 STI
1992 Volvo 245 Euro Delivery
norcal505 is offline   Reply With Quote
Old 04-04-2008, 09:24 PM   #8
Sinbad the Sailor
Master Destructor
Sinbad the Sailor's Avatar
Holy ****ing nice man. Great work.
'85 244 DL - R.I.P
'82 244 TIC - MS/13c/Crane Hi-6/Jacobs Coil/Full 3 in exh/3 Row Nissens/E-Fan
'63 p1800 - Gone to a better place
Originally Posted by tedium
The standard rule of engineering: If you make something idiot-proof, they will just make better idiots.
More often stated: Nothing is foolproof to a sufficiently talented fool.
tim
Sinbad the Sailor is offline   Reply With Quote
Old 04-04-2008, 09:28 PM   #9
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
Shorts and tube socks.
Old 04-04-2008, 09:30 PM   #10
the poi
Has been
the poi's Avatar
I just graduated, I'm on vacation
I have no idea what the specs are on the lights, heh. They're off an Audi S4, all Valeo components, and they appear to be ~4300 bulbs, a little yellow to white when warmed up.
And they're comfy socks.
Old 04-04-2008, 09:36 PM   #11
OldSchoolEuro
I'm sorry but this is just badass picture.
OldSchoolEuro is offline   Reply With Quote
Old 04-04-2008, 09:37 PM   #12
Homer
OEMplus++
Homer's Avatar
Wow. Neato.
-Jacob:
2006 A4 - Comfy DD
Old 04-04-2008, 09:37 PM   #13
Homer
OEMplus++
Homer's Avatar
Originally Posted by OldSchoolEuro View Post
I'm sorry but this is just badass.
And you are a tool.
Old 04-04-2008, 09:39 PM   #14
OldSchoolEuro
Originally Posted by Homer View Post
And you are a tool.
And you are a douche bag.
Old 04-04-2008, 09:39 PM   #15
242whore
Crush em
Turbobricks has resorted to a new low(...high?), stealing the wifes cooking utensils is not cool :-), Looks awesome!!!
1984 242 Turbo- Honda Black Amethyst Pearl, lots of Kahplenke goodies, MS3X,B26FT,16g, IPD sways,86+, getrag = the money pit
1984 242 Turbo- 2.2,19t, tv screens 200ish blue
1989 245- yet another project
2014 Subaru WRX SPT edition
242whore is offline   Reply With Quote
Old 04-04-2008, 09:42 PM   #16
amargill19?
Barry McCockiner
amargill19?'s Avatar
wat
Originally Posted by Dan Wood View Post
Now, two years later, after a move to Oklahoma, a job in a potato salad plant, and many other assorted ventures, I have plans to visit Paraguay.
amargill19? is offline   Reply With Quote
Old 04-04-2008, 09:44 PM   #17
the poi
Has been
the poi's Avatar
Hey now, I bought those myself at Bed Bath and Beyond after checking the housewares section at both Sears and Target
edit:// wut
Old 04-04-2008, 09:49 PM   #18
amargill19?
Barry McCockiner
i don't get it
Old 04-04-2008, 09:50 PM   #19
fivealive
fivealive is offline   Reply With Quote
Old 04-04-2008, 09:57 PM   #20
Volvorules
Has a Built Trans!
Volvorules's Avatar
That looks so awesome. Bumpercooler looks great painted too.
Rob
Volvoless
how psi a stock can support?
Originally Posted by MrBill View Post
not even thieves like 7/9 series.
Volvorules is offline   Reply With Quote
Old 04-04-2008, 09:58 PM   #21
Homer
OEMplus++
Homer's Avatar
But but but painted surface, heat transfer coeff. Oh wait that **** doesn't matter. It's ****ing huge!
Old 04-04-2008, 10:04 PM   #22
RedFridge
RedFridge's Avatar
Oh SNAP!
Nice craftsmanship.
RedFridge is offline   Reply With Quote
Old 04-04-2008, 10:17 PM   #23
DR1665
DR1665's Avatar
Very nicely done! Kudos! (Since you won't have enough muffins, now.)
Cheers!
86 245GL | sold to my father-in-law, staying on as chief mechanic
Tarmac & Gravel | 464 Stays Clean & 195 Gets Dirty
DR1665 | The Keyboard Rallyist.
DR1665 is offline   Reply With Quote
Old 04-04-2008, 10:18 PM   #24
Karl Buchka
Just because I'm cool like that, I'm here to tell you that it looks horrible. Kill yourself. And I bet your tube socks itch.
Old 04-04-2008, 10:42 PM   #25
the poi
Has been
the poi's Avatar
it's like they're hugging my feet
