As some of you guys might have read in the Performance Modification Fourms, i overheated my engine tremendouly and ripped my headgasket a new a**hole. Figured i would move my thread over to this section since it was more fitting. At the moment I'm still in the tear down stage. Going to pick up the 15g turbo, browntops, and 4bar FPR from the pick and pull yard this week. Right now the engine is at 215k, the plan is to install all of the following items, move the AFM downstream of the greddy bov, and start a tune. Oh yeah, and now that i know about this "fuel cut switch" for higher boost levels I shall hunt it down and remove it. No idea what my fueling will support but iam hoping to run a steady 15psi, and possibly higher for "track" runs and such. Otherwise i already ordered and recieved most of the following.
Stage 0 +Elring headgasket set +Waterpump and themostat +Stabilizer Bar bushing ( one is missing ) +Timing Belt Kit +Red/Clear/Clear/Red tails ( right tail was missing some lenses and wouldnt pass inspection ) +225/60/15s for the rear since i burnt off most of the rubber on the previous tires running the 13c at 15lbs. Performance +Reclocked 15g +Bosch Browntops +Turbo Caravan FPR +A/F Gauge +8mm plug Wires +Hard Charge Pipes 2.5" +Ebay 28x9x2.5 intercooler +Greddy Type RS Mounting tube (2.5") +Greddy type RS ( already owned ) +Volvo electric fan kit +255lph fuel pump +Cat test pipe, magnaflow muffler, straight pipe for the rear muffler ( going to go 3"TB but no funds for such yet ) Hoping to complete the job this week, unless the head is warped, then the project will probably go on several more weeks due to funds. If the head is getting rebuilt its getting done right with oversized valves and the IPD cam and gear. ![]() ![]() ![]() ![]() ![]() ![]()
Wyotech 05'-06' Major= High Performance engine and custom chassis fabrication 1990 215k 760T 15G build in progress... http://www.forums.turbobricks.com/sh...89#post1722489 2001 1.8t Jetta APR 93/100 oct. Chip ( 20 psi ) 3" dp to stock exhaust http://myspacetv.com/index.cfm?fusea...ideoid=1037037 http://myspacetv.com/index.cfm?fusea...deoid=18819786 Last edited by WagenSport; 04-07-2008 at 07:39 PM.. |
Oh yeah also forgot I'm going to clip the springs in the front while its off the road, to level it out a bit, if not have the front dip down a little lower. I like the Positive rake look. Here is it pre work- ( Ill have some under hood shots as i go )
![]() ![]() ![]() ![]() ![]() Last edited by WagenSport; 04-07-2008 at 02:21 AM.. |
#4 | |
I love fast wagons, they make me all giddy like a school girl.
#5 |
that interior looks immaculate! nice work...i like the style you're pursuing
-Billy 1993 945ti "titebox" (DD) 1985 744GLE (perpetual +t project) 1996 Chevrolet Tahoe Vortec 2WD 1990 Mazda Miata track toy |
#6 | |
![]() Let me know if anyone has any better ideas, i dont want an A pilliar pod! |
#7 |
#8 |
What sort of valve spring compressor do should i use. Been seeing several types. Does anyone know if the autoparts stores rent them?
#9 |
im doing my boost guage like that omori vent pod. it won't be too hard, and i may retain the vent if im sneaky. ill post pics when i get to it
#10 | |
Before : ![]() After: ![]() ![]() |
#11 |
Oh yeah, also got the 255lph pump in. Took a little modification, but installation was a breeze. Simply had to take a dremel with sanding wheel, and take the bumps out from the inside of the pump holder. Once they were gone it slid right into the mount firmly. Installed new fuel sock, and had to splice pwr and gnd wire to fit the new connector.
#12 |
easier to work on the fuel tank in a wagon, isn't it?
nice project! ![]() |
#13 |
OK question/ opinions wanted. I want to make my blow off valve downstream of my AMM. Here is my proposed set up. Before the intercooler. Basically it would go, short pipe from compressor/blow off/ amm/ intercooler. Will this work out, or will i be screwing with the AMM having the blow off valve so close?
![]() Last edited by WagenSport; 04-23-2008 at 01:07 AM.. |
#14 |
wagon>sedan
such as after turbo, before intercooler; or after intercooler, before throttle body |
#15 |
Oh yeah, does anyone know a good way to compress the valve springs without the tool. I rented a tool but it doesnt work on the volvo head since the springs and retainers are more recessed. Any ideas?
#16 |
As i posted the order i was going for is TURBO, short pipe to bov to amm to intercooler. Sorry if i left something out previous.
#17 | |
WHATISTHISIDONTEVEN?@?
love those tails....they make the car look like a different car!
![]() 1989 244T 2005 Focus ST Quote:
#18 |
#19 |
Membro
In the past I have bolted an oxygen sensor socket to a standard valve spring comressor and it worked ok for disassembly. I have since found a hard plastic or nylon adapter that looks somewhat like the O2 socket but is designed for OHC valve spring compression. I can't recall where I got it, though. Search on the web.
#20 | |
JohnMc=500Dollar Mistake
![]() Join Date: Jan 2006
The MAF must go before the turbo. The BOV must go on after the turbo to vent the pressurized air. General consensus is post intercooler, but I've seen it everywhere with no bad effects |
#21 |
Why must the AMM go before the turbo? Would i see any ill effects placing it after the turbo. It seems like some guys on the have been moving the amm to right before the throttle body, but i dont want to extend the wires. I got some play room with the AMM wires now after unsheathing them from the rubber insulators, but i just want to have the air metered correctly. So your saying i CANNOT do the setup with the blow off valve then the maf in that order after the turbo?
#22 |
Well i got my first set of valves out using 2 spring clamps to hold the head to the table, a chunk of wood to hold the valve in place, and a bar clamp pressing on a oxy sensor socket to compress the spring. Worked very well. My dad was giving me a hand, and thought that maybe he could cut a peice of 1x1 wood into a better tool, so he did. Not sure how its going to work guess ill find out later when we use it.
#23 |
#24 |
Herp McDerpington
Dude it's absurd how much better those new tails make the back of that thing look.
Nice car, man. You're doing everything I wanted to do to my '90 764ti. RIP... ![]()
'84 244ti - LH2.2 swap - project '90 765ti - some stuff, soon some different stuff. - dd '10 International really big diesel thing - work dd old stuff brickspeed "Meth might be a hell of a drug but it does wonders for intake air temps.." -Sam (RoadRacer4Life) ![]() |
#25 |
| Thread Tools | |
| Display Modes | |
