Old 04-08-2008, 07:13 PM   #1
Bigscreen Bob
Bigscreen Bob's Avatar
Default What was Volvo's official TIRE SIZE spec for 240 Turbo/Virgo wheels?
What's printed on the door sticker?
I'd like to know because I'm about to put Virgo's on my N/A, normal height stock springs, 240 wagon.
What were the stock tires Volvo put on a 240 turbo with Virgo's -- 205/65/15? 205/55/15?
Looking to put on all-season tires. Obviously not a hot rod performance car, just a daily driver, street-driving, normal highway and city driving.
...I know, boring.
Thanks.
1990 240DL Wagon, 185K miles. Europeanized
-- pimped-out in a tasteful, 1980's Swedish sort of way
Bigscreen Bob is offline   Reply With Quote
Old 04-08-2008, 07:19 PM   #2
B-dub
OG
B-dub's Avatar
I've always run 205/55. I'm not sure it's stock but it seems to work the best for me.
"Sometimes nothin' is one cool hand"
242: Stage X It's a process.
RSI-online sales!
B-dub is offline   Reply With Quote
Old 04-08-2008, 07:21 PM   #3
Bigscreen Bob
B-dub -- is that what Volvo suggested, and printed on the door sticker of a 240 turbo?
Old 04-08-2008, 07:27 PM   #4
B-dub
OG
B-dub's Avatar
The stock turbo/Virgo wheel Volvo size tire is actually a 195/60-15. I just prefer the 205/55.
Old 04-08-2008, 07:32 PM   #5
Bigscreen Bob
Thanks!
I've been told the 205/55/R15 will keep my spedo and odometer close to accurate.
Old 04-08-2008, 07:32 PM   #6
Acid8000
Acid8000's Avatar
Go with 205/60/15, its a great tire size. 215 looks a little bit wider. But the 195 just looks like 14" tire/rim combo.
Daily Driver: '83 242Ti w/ B21FTi and M46. IPD Sways, Bilstein HD Struts, Lowering Coils. Mistu 13c @ 10psi - Her name is Domino.
Hi my name is Jason, i'm addicted to boost
Acid8000 is offline   Reply With Quote
Old 04-08-2008, 07:53 PM   #7
OldSchoolEuro
Yeah I have the stock 195 size on my virgos, but I am going wider like 205/55 or something.
OldSchoolEuro is offline   Reply With Quote
Old 04-09-2008, 01:07 AM   #8
PWRPUFF
narf!
N/A wagons came with 185R15 ... which is like an 82 profile.
205/65/15 is a close match for overall diameter, but in no means will it be visually "lowered". 205/60/15 is a happy compromise between lower profile tires + still being close to the original OD.
 crankcase ventilation mod! -- 500dollar744ti
 Eh - you've still got three good rods, just up the boost a little more to compensate for the missing rod. -- JohnMc
PWRPUFF is offline   Reply With Quote
Old 04-09-2008, 07:36 PM   #9
towerymt
the real Towery
towerymt's Avatar
I have a 1982 owner's manual that lists the following.
sedan:
DL 175R14
GL 185/70R14
GLT, Turbo 195/60R15
wagon:
DL (USA)185R14
DL (Can) P185/75R14
GL 185R14
GLT 195/60R15
If you find stats for load capacity, you'll notice that the wagons with Virgos often have a lower load capacity than the DL/GL because of the 195/60/15 tires.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Old 04-10-2008, 10:36 AM   #10
240on280
240on280's Avatar
sedan:
DL 175R14
GL 185/70R14
wagon:
DL (USA)185R14
DL (Can) P185/75R14
GL 185R14
GLT 195/60R15
Did the turbo wagons also have sedan speedometers installed?
The BMW said "I am the ultimate driving machine!" and the Volvo wagon said "Oh really?"
240on280 is offline   Reply With Quote
Old 04-10-2008, 10:55 AM   #11
vvpete
Actually the 215/60-15 is a closer match. The 205/65-15 is a tad taller, - 2mph. The speedo error on my 245 with 215's is +1 mph. Going with the 205/60-15 the speedo error is +5 to +6 mph on a wagon, but very close for a sedan.
You could put the 215's on the 6" Vigro wheel, but they work best on 7" wide wheels.
"I've been told the 205/55/R15 will keep my spedo and odometer close to accurate."
No, it will be way off, like 7-8 mph too high on you wagon with the orig speedo.
vvpete is offline   Reply With Quote
Old 04-10-2008, 01:29 PM   #12
Can play the blues
Default tires
Yes, all manual turbos whether wagon or sedan used a 3.73:1 rear axle with a .980 speedometer. The stock size tires are 195/60-15. I use the 205/55-15 tires and according to the radar trailers that police setup in areas for speed checks the speedometer is accurate.
1982 242 turbo. 339k miles. Lots of good changes.
1993 245 Classic, 415k miles, enem V15. 5spd. IPD bars and chassis braces. Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
Old 04-10-2008, 08:32 PM   #13
Sabonim
www.1010tires.com
there is a tire comparison tool... put in your size and other sizes that are close, and play with the numbers and see what best suits you
Sabonim is offline   Reply With Quote
Old 04-10-2008, 09:36 PM   #14
Greg Wong
FWIW, I had 205/60 on Virgos, and it sucked. They wallowed like balloon tires, and I had Z rated summer tires, where the sidewall is supposed to be a little stiffer than, say, all-seasons. You could see scrub marks from cornering halfway up the sidewall. If I had the decision now, I would do 205/55 on Virgos.
That was on my 90 245 with V8, so just about the most weight you can get on a 240. A 242 might be a little easier on the tires. Hmm, I just noticed that the OP has a 90 245 as well.
Homepage
90 245 V8
07 V70 2.5T
Greg Wong is offline   Reply With Quote
Old 04-11-2008, 02:39 PM   #15
Default 83-245 Glt
205's feel heavy in the steering to me,and consume excessive fuel imo.
I like 195-65-15 M&S tires @ 40 PSI,for all around practical purposes.
Photobucket
Old 04-15-2008, 03:39 PM   #16
84B23F
84B23F's Avatar
sedan: DL 175R14
What size is that...75 profile?
Old 04-15-2008, 06:38 PM   #17
80 for radial tires when not specified.
Old 04-15-2008, 06:45 PM   #18
amargill19?
Barry McCockiner
amargill19?'s Avatar
I like my 205-50-15's
but they look funny when my car is at stock height otherwise.
any season besides summer I run 185/70/14 i think? just cheap econo tires that do okay in minor snow.
Originally Posted by Dan Wood View Post
Now, two years later, after a move to Oklahoma, a job in a potato salad plant, and many other assorted ventures, I have plans to visit Paraguay.
amargill19? is offline   Reply With Quote
Old 04-15-2008, 09:56 PM   #19
84B23F
84B23F's Avatar
RE: sedan: DL 175R14
My memory is lacking, but in seventy era, 75-R was the common radial size...I have no idea in early eighties.
80 is a pinch taller tire...my guess is they meant 175/75R/14...which is standard issue in Canada in 1984.
Old 04-16-2008, 09:45 AM   #20
Sabonim
+1 that is what i am told too
ie. a 185r14 (185/80r14) is about the same size as a 205/70r14 or a 195/75r14
http://www.1010tires.com/TireSizeCalculator.asp
if you're using the same tires all year, i wouldn't recommend something too wide, 'cus you will probably get stuck in snow (if you're in a snowy area) if its just summer wider can be nice, 'cept in the rain, might be a bit of a downer, hydroplaning and all
Old 04-16-2008, 11:10 AM   #21
11110000
11110000's Avatar
Correct, it's supposed to be 80 if not specified - but it's usually closer to 78 in reality.
Sounds like some of you need handling by Rancho. - stevemd
11110000 is offline   Reply With Quote
Old 04-16-2008, 11:37 AM   #22
anything wider then 195 and the 60 aspect ratio is way too tall unless you want all comfort and no control.
a 205 55 15 works well and and a 205 50 15 is also pretty nice
if you can find some 15x7 a 225 50 15 is a great tire size but less and less peformance tires are offered in it.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 04-16-2008, 02:32 PM   #23
84B23F
84B23F's Avatar
Here's a much better Tire Size and RPM Calculator, including rear-end ratio calcs
When you input 175/75R14 vs 185/60R/15, you will find change in speedometer of about 60.302 mph (about 0.3 mph difference), but with 175/80R14, you get 62.01 (about 2 mph difference) from a reference speed of 60 mph.
I would say 175R14 represents 175/75R14 since speedometer deviation-results are lower with 75 profile.
Old 04-16-2008, 02:53 PM   #24
MikeHardy
The Sirius/Nova Police
MikeHardy's Avatar
both of those are pretty normal. http://www.rims-n-tires.com/rt_specs.jsp
that one is cool as it shows tyres and allows you to compare wheels too.
MikeHardy is offline   Reply With Quote
