Old 05-31-2008, 10:59 PM   #1
Homer
OEMplus++
Homer's Avatar
Default Porsche/Audi Diverter Valve
Installed a few weeks ago, I finally took some pics. Shifts are amazing, idle is so solid. I don't miss my BOV.
-Jacob:
2017 allroad - Comfy DD
Old 05-31-2008, 11:07 PM   #2
volvo740t
1 brick, 2 bricks, 3..
volvo740t's Avatar
I want one...
volvo740t is offline   Reply With Quote
Old 05-31-2008, 11:10 PM   #3
Homer
OEMplus++
Homer's Avatar
They are pretty cheap. 45$ is what I paid for mine. Bosch part.
Old 05-31-2008, 11:24 PM   #4
ShadowofBob
Revived...
ShadowofBob's Avatar
They are nice until you start pushing 15+ PSI then they flutter like mad. Mine was super smooth and always worked well with no flutter on my stock T3 even up to 15 PSI. Didn't like my T3/T4 hybrid though.
1990 Audi Coupe quattro x3 - the eternal project car.
2000 Audi A4 Avant quattro 1.8T 5spd
ShadowofBob is offline   Reply With Quote
Old 05-31-2008, 11:30 PM   #5
Homer
OEMplus++
Homer's Avatar
Well yeah. I'm running 7psi. That's a reason I chose it.
Old 05-31-2008, 11:55 PM   #6
acbarnett
SAAB defector
acbarnett's Avatar
Better yet, forge makes a drop-in replacement that's great for 1 bar+ applications, it's only ~$100 too iirc and you get a few different springs etc.
I got one for my car after the diaphragm went on my stock bosch diverter
acbarnett is offline   Reply With Quote
Old 05-31-2008, 11:59 PM   #7
MrBill
fige=500Dollar Mistake
MrBill's Avatar
007 woulda rocked
Someone say crazy rays?
Old 06-01-2008, 02:08 PM   #8
Default bypass valve
I used to use that one. If failed on me so I bought the SaaB direct replacement version made by Forge. It's not the rebuildable one but it is the next level with a piston and seal instead of the diaphragm style.
Old 06-01-2008, 02:39 PM   #9
Homer
OEMplus++
Homer's Avatar
What psi?
Old 06-01-2008, 09:38 PM   #10
acbarnett
SAAB defector
acbarnett's Avatar
Originally Posted by Homer View Post
What psi?
I know a bunch of people who are putting 20+ psi through their forge CBV's, they're pretty much the only replacement for the bosch that you can get away with on the trionic 7 cars and they seem to be designed accordingly
you know you want it
Old 06-01-2008, 11:21 PM   #11
Homer
OEMplus++
Homer's Avatar
No. I know I want the faster diaphragm type.
I was asking what psi dave's failed at.
Old 06-01-2008, 11:26 PM   #12
spe1983
spe1983's Avatar
I've been wanting to get the turbosmart plumb back valve for my turbo car. would be able to choose between BOV/CBV type set up.
1972 142 w/ 130K, in progress.
1992 944T w/ 195K, DD
2004 XC90 2.5T AWD w/ 124k
1984 242T - gone, now brettmobile
1994 855T - gone
spe1983 is offline   Reply With Quote
Old 06-01-2008, 11:27 PM   #13
MrBill
MrBill's Avatar
forge 007>>>>>>>710n, or whatever yours it
They're good for like infinity psi. no failures!
Old 06-02-2008, 12:37 AM   #14
Default cbv
It gave a good service life of a couple of years running 12-13psi. I think it failed due to my kjet not having a path to shoot the air directly to the turbo inlet. My air return is a bit further away. With wide open throttle and low boost like 6psi it works great. But in the area from around 8-10psi or so I get a backfire out the tailpipe which I think is caused by the airflow reversing and popping the air flow sensor closed. That may also have affected the cbv. When it failed it had a punctured diaphragm causing idle vacuum to go up to around 4in hg. So I bought the Forge stock Saab replacement which is a sealed version for around $90 a few years ago. I think you'll be fine and for the price the Porsche/Audi one is worth using.
I've used the original all rubber unit for a year or so without failure. Upgraded to the brass insert Porsche/Audi unit which lasted for a couple of years. Then I bought the Forge Saab replacement unit which is about 3 years old now.
Old 06-02-2008, 01:21 AM   #15
Homer
OEMplus++
Homer's Avatar
Based on budget and current setup, the 710n best suited me. If I was running higher psi, forge is where its at.
Good to hear.
Old 06-02-2008, 08:14 AM   #16
Angus242164
Angus242164's Avatar
I'm tempted to use one of these in future, I have like 15+ of the Saab brass piston type sitting in my shed doing nothing, so if they start failing I won't run out of them for a while, and they only take 5 minutes to replace.
Turbosmart make this replacement:
http://www.turbosmartonline.com/index.php?id=44
Unfortunately their pics seem to be down at the moment! It's similar to the Forge valve, but adjustable with a knob.
Originally Posted by Dauntless View Post
Boost FTW.
I have over 300 parts for sale to suit 100, 200, 700 and 900 series Volvo's, for more info see: http://zyrex.org/gallery/Cars/acw/volvoparts/
Updated April 21st 2016.
Angus242164 is offline   Reply With Quote
Old 06-02-2008, 08:17 AM   #17
aibast
aibast's Avatar
I'm running one Audis metal by-pass. Sound great
Volvo Nilsson 740 "van" 1987 - B230K automatic to M46+OD swaped ex hearse
Volvo S80 2002 - D5 automatic daily eco cruiser 44mpg average
aibast is offline   Reply With Quote
Old 06-02-2008, 08:22 AM   #18
JW240
All idiot, no savant
looking good
(and nice welds btw!)
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 06-02-2008, 10:26 PM   #19
boosted
boosted's Avatar
tell that to us.. the audi dealer, who are replace POS forge valves left and right because they fail and make the car run terrible
-1998 V70r AWD
boosted is offline   Reply With Quote
Old 06-02-2008, 11:12 PM   #20
MrBill
MrBill's Avatar
then they were not properly lubricated or something.
007 cant fail, its like.... not possible.
And as I said, I had a nice shiny 710n, it failed after like 300 miles
Old 06-02-2008, 11:27 PM   #21
amargill19?
Barry McCockiner
amargill19?'s Avatar
nice welds.
when you had your BOV installed you had some idle issues eh?
this bosch unit doesn't make any noise?
Originally Posted by Dan Wood View Post
Now, two years later, after a move to Oklahoma, a job in a potato salad plant, and many other assorted ventures, I have plans to visit Paraguay.
amargill19? is offline   Reply With Quote
Old 09-29-2008, 10:22 PM   #22
volvero
volvero's Avatar
what about this knock off:
http://cgi.ebay.com/ebaymotors/_Car-...=p4506.c0.m245
850 Turbo '95
M56 swaped, Rica tune, 16T turbo, angled flange, 3" downpipe, IPD swaybars, 302 mm brakes.
PV544 '61 (B20, R cam, twin Solex C.45 DDH carbs, FI head, electronic ignition, 122 disc brakes, IPD front swaybar)
http://forums.turbobricks.com/showth...=1#post4398485
volvero is offline   Reply With Quote
Old 09-29-2008, 10:29 PM   #23
Hodginsa
Always
Hodginsa's Avatar
I agree, I don't think you could make it fail... I mean the worst possible thing that could happen is like, it might make a squeaking noise when the lube dries up. Other than that what could happen? Its a solid piece held down with a solid spring, whats there to break?
http://idlehandsproject.com - Keep me busy.
Hodginsa is offline   Reply With Quote
Old 09-29-2008, 11:08 PM   #24
760T man
Phillip Mamouf-Wifarts
760T man's Avatar
Location: Bettendorf, IA, when I'm not EASTBOUND 'N DOOOOOWN LOADED UP 'N TRUCKIN'
I tried 3 different Bosch CBVs. They all sucked. They'd often stay open, not allowing boost to build.
a '90 765ti, an '84 244ti, and an '18 780
Turbocharge it, and instead of the typhoon, or syclone, we will call it the “light breeze” -mrsam740 referring to the Oldsmobile 4.3 diesel
760T man is offline   Reply With Quote
Old 09-29-2008, 11:17 PM   #25
jutny
my 710n's are doing just fine
*2001 Audi S4 Avant, Chipped, Exhausted, Suspended. Fun!
*1999 Ford E350 Extended Hi-Top, 7.3 Powerstroke.
*First Gen RX7's, Motorcycles, Mountain Bikes
jutny is offline   Reply With Quote
