Old 06-04-2008, 09:20 PM   #1
gale
gale's Avatar
Default Another Canadian B23FT build
This is my car. It’s a 87 745 turbo that I have had since 2000. It’s an Alberta car so it came to me with zero rust and about 180,000km. The rest is TB history.
I read Mcbrooms and set up a plan. I have a long history with this car and several motors (too much boost and a broken heater hose). I will not bore you with all the details but this motor began as an idea after I was replacing a HG and found a crack between cylinder #1 and 2. The cracked motor was sleeved (very long story) and could have survived a little longer with the crack in the block (not in the sleeves itself). But I decided to pulled the motor and start from scratch. New block and newish head.
I began by sourcing a block. I didn’t actually think I would find a *new* block but after looking around TB I found foggyjames. Foggy had a new, never used, b23 block just sitting around. Shipping from the UK to Canada sucked balls. I got the motor in April of 2007 and started work.
Bottom end:
Forged crank and rods from my previous B23FT.
All internals were sonic checked then balanced.
New set of stock sized Mahle pistons.
Drilled and tapped the block for turbo return.
Stealthfti’s #5 thrust bearing chamfer trick for more oil supply.
Drilled and tapped for BMW oil squirters.
more to come...
"never rub another mans rhubarb"
gale is offline   Reply With Quote
Old 06-04-2008, 09:25 PM   #2
pooprah
Guest
great work mods move this to projects and restos
Old 06-04-2008, 09:35 PM   #3
gale
gale's Avatar
Cylinder Head:
530 with about 40 hours of bucket work.
practice head
MVP adjustable cam gear from previous engine
VX3 cam
lapped valves
Grooved with my own variation of the Somender theory. I used a 3 axis at work and built a program to make all grooves the same (no cameras allowed at work)
Cometic HG with some Hylomar spray
Old 06-04-2008, 09:54 PM   #4
gale
gale's Avatar
Turbo:
TD05-16g
I spent about 2 hours bent over a sandblasting cabinet cleaning and polishing everything on this turbo. Sand then glass till my back hurt.
The hot side has most of the work. Hot side turned on a lathe to open up the exhaust side.
Removed stainless steel WG cap and ported the WG hole (forgot the camera that day)
WG cap was machined thinner to allow it to open up bigger
Stainless steel cap was then welded on at an angle to allow WG to open further
Hot side inlet was opened up and ground smooth with air tools
Shaft and turbines were then balanced to perfection by Herman. Homemade BOV block off plate from aluminum
misc photos of turbo
Old 06-04-2008, 10:11 PM   #5
gale
gale's Avatar
Holset anyone?
http://forums.turbobricks.com/showthread.php?t=138073
Old 06-04-2008, 10:13 PM   #6
gale
gale's Avatar
^^wrong link
try this
Old 06-05-2008, 12:18 AM   #7
Devolv
Devolv's Avatar
Dude! where in Ontario are you?
Originally Posted by pro_star View Post
...dude....
that's like me saying 'should i do my suspension, or get a manicure?'
97 854 GLT White - KW CoilOvers, EST Strut, EST Grille - 17" Diamond Cut Pegs
04 S60 R TiGrey/Nordcap - 6 MT
Devolv is offline   Reply With Quote
Old 06-05-2008, 12:24 AM   #8
Lord Tentacle
Anime Lord
Lord Tentacle's Avatar
can i hump your rack?
Originally Posted by gale View Post
^^wrong link
try this
Tentacle SUV 12 xc90; stuff including v8 and towbar etc... Powered by Beetroot
recently crushed Volvo's
Old 06-05-2008, 01:05 AM   #9
Raz
I wake and bake every day
Raz's Avatar
Wow.
How much beer would I have to lure you with to come to Alberta and teach me a thing or two about how to do things? :D Hell, I'd drive out there and give you a hand on your car if you'd like. Driving to Quebec in late July
- R
Living for a living
Driving an 83 Mercedes Hymer Camper around europe for a year
Raz is offline   Reply With Quote
Old 06-05-2008, 01:15 AM   #10
Husker4volvo
dang good work man that works takes a good eye, steady hand a lot of beer...
Volvo less for now looking for a 240 turbo wagon...
Husker4volvo is offline   Reply With Quote
Old 06-05-2008, 01:36 AM   #11
pooprah
Guest
those groves are beautiful. what fuel system>? with that turbo expect about 250hp hopefully
Old 06-05-2008, 01:42 AM   #12
Poik
Backwards Turbo
Poik's Avatar
What Volvo came with a 16g? Or did you machine that Volvo compressor housing for the 16g wheel?
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 06-05-2008, 01:50 AM   #13
klr142
Turbo, what?
klr142's Avatar
Looking good, can't wait to hear about it being all together and driving... Was the machine at work unable to go farther down in depth on the grooves as they enter into the chamber, or is that how you wanted them done? Curious as to your thoughts on what made you arrange them in those directions, care to elaborate?
Get'r done!
What do you mean by "hopefully"?
Old 06-05-2008, 02:15 AM   #14
pooprah
Guest
Get'r done!
i mean lh 2.4 sucks
Old 06-05-2008, 02:17 AM   #15
klr142
Turbo, what?
klr142's Avatar
Gotcha, hahaha. Yeah, it can make things tough...
Old 06-05-2008, 06:17 AM   #16
JW240
All idiot, no savant
JW240's Avatar
great work!
i mean lh 2.4 sucks
depends on who uses it.
240 | 1991 | 333K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 mx/supermoto swapped
Old 06-05-2008, 07:05 AM   #17
Chris_R
Kickin' rocks in sandals
Chris_R's Avatar
i mean lh 2.4 sucks
87 740 is lh2.2.
Setup looks great!
Ermergherd!! Erm gernner kerhm!!
1995 964 (Silver)
1992 944Ti (White)
1996 965 (Burgundy) - Scrap
1994 945 Ti (Black) - Sirius Black Scrap
1992 944 GL (Black) - Killed by drunk driver
1988 745Ti (Silver) - Sold
Originally Posted by TurboBrickMan View Post
Long story short I found out she's a squirter.
Chris_R is offline   Reply With Quote
Old 06-05-2008, 08:19 AM   #18
gale
gale's Avatar
I'm in London town Ontario.
klr142 - I will elaberate when I get some time. I could have built the 3-axis program any way I wanted. I wanted to do it that way. Maybe I was a little nervous about cutting grooves in my head.
did you see that little blue behind my turbo....
Turbo is completely custom.
Old 06-05-2008, 08:21 AM   #19
Chris_R
Chris_R's Avatar
peek-a-boo, I see you!
Great looking 1800!!!
Old 06-05-2008, 08:35 AM   #20
gale
gale's Avatar
I ordered some bits for my exhaust. With the CDN dollar strong against the US I was able to get all this stainless for $95 shipped.
a few cuts and some stretching
Old 06-05-2008, 08:38 AM   #21
gale
gale's Avatar
And of course I could not resist...
I have some work ahead of me.
Old 06-05-2008, 08:41 AM   #22
Chris_R
Chris_R's Avatar
Where did you order the exhaust bits?
Which ebay seller is the IC from? Looks awesome!
Old 06-05-2008, 09:04 AM   #23
gale
gale's Avatar
http://store.racing-solutions.org/
Colimbia River Mandrel Bend for the exhaust bits. Great selection, good price, cheap shipping and packaged well.
I think the IC is from CXRacing on eBay. This was back with the IC was $57.oo and the shipping was $5o.oo. I got everthing including IC (31x12x3), 3" piping and some silicone for $193 shipped. And with the strong CDN dollar that day it was like $187.5o.
The only sucky thing is I have to cut and reweld the bov to the new piping...
Old 06-05-2008, 09:14 AM   #24
frpe82
Guest
i mean lh 2.4 sucks
Well said!
Old 06-05-2008, 09:46 AM   #25
gale
gale's Avatar
Fred has helped me with my lh2.2.
[IMG]http://i212.photobucket.com/albums/cc316/andrewgale/DSCF2554.jpg[/IMG
