On a mission
![]() ![]() Just kidding! 240s are for hauling stuff from the junkyard. This **** be goin in the bumpercooler. I had an absurdly productive weekend at the junkyard this weekend (half-off!). Total haul: 850 flywheel (and an M56 for someone else), complete 960 rear subframe, and Lincoln Mark VIII center section, half-shafts, and knuckles. The point: the T56 has some high gears and the 8.8 will let me throw pretty much whatever I want in the back, along with cheap diffs. Ford racing 4.56s and a Torsen T2 diff will make for a sweet ride. My neat Lincoln diff is all aluminum, and seems to be a touch lighter than the stock 960 diff (which is iron). The markVIII/thunderbird IRS is 5x108, and the hub bearing looks to be the exact same diameter as the 960 bearing (have to press the hubs out of both knuckles to be sure). The plan right now is to put the TBird hubs into the 960 knuckles, and then get some Raxle Tbird axles, albeit with slightly shorter shafts. Fun side note: 960 halfshafts are thicker than tbird halfshafts! And naturally, I'll have to shove the massive diff in the subframe. It will be...non-trivial: ![]() So here's where I'm at, subframe and diff's all cleaned ![]() ![]() And the ol' Tremec gets to wait a bit for a rebuild and shifter, then I gotta figure out an adapter plate. Might be annoying, doesn't look like I have much room to fit an adapter plate. Meh, I'll make something work. ![]()
Whooty patrol
thats going to be cool/ straight up awesome.
'82 242t turbo+, intercooled, 3" exhaust, 13" brembos, coilovers, saabspoiler, 18"s, flathood, dying m46, etc. '97 f-250 psd, d60, locked, chromoly axles, shortened and bob'd. '91 940irs rallybil, holset, gutted, olive drab rollered on paint, browntops etc '90 F-250 project. Lots of links, tube, and coilovers. |
NA is so slow...
your nuts. major props for figuring all that **** out, and more so following through.
novolvo. |
#4 |
slab rider
i don't know if the IRS will take anything you will throw at it...
4.56 gears have pretty small teeth, and first gear will be super short with a t56 the real problem will be halfshafts... no doubt it all should be much stronger then the stock stuff.... Judging by the caliper of your car im sure you wont skimp out on the project.... you need to figure out how to make your paddle shifters work the the t56 ![]()
It may not lift the tire while turning in but... ![]()
#5 | |
![]() Join Date: Jul 2002
#6 | |
my buddy has so far chalked up an 11.8 @ 122 and a 1.8 60 ft on his. all he had was a brace to reinforce the diff housing....(when putting the diff in the housing chris, you might want to check out http://www.lightningforceperformance...bra-p-361.html
-Matt '90 780 and '03 s60 T5M |
#7 |
Kickin' rocks in sandals
Did you get the aluminum driveshaft and adjustable suspension system from the Lincoln as well?
1988 745Ti (Silver) 1994 855 Turbo (Black) 1996 965 (Burgundy) 1994 945 Ti (Black) - Sirius 1992 944 GL (Black) 1992 944Ti (White) |
#8 |
Hopefully one of these days the car will be done, or you'll get a girl friend and the car will HAVE to run for more than a week at a time, heh heh
Mark
1995 855 Turbo Stock <--Daily Driver 1979 242dl B230FT AW 71 <--Wifey's ride 1959 Austin Healey Sprite <--something completely different 1974 Fiat X1/9 <--Moms little toy "Driving the old 2 valve 740 is a bit like driving an IKEA wall unit, so leisurely is its acceleration, so angular its lines." My former brick saved my life 6/25/03....Volvo for Life New pic comin eventually....... |
#9 |
slab rider
most 03 cobra guys wont drag race there cars because they break... 1.8 60 ft. isn't good for a car that is trapping 122...
#10 |
Exklusiv Zubehör Klub
![]() Join Date: Sep 2002
Give me a break. The point of an IRS is not to be pounded mercilessly down the 1/4 mile- wrong tool for the job.
Regardless, it fits into the category of easy to modify/improve for faily low $$$/effort and can hold plenty of power. Also the T56 should have a 2.95 first in it, so you're looking at ~13:1 reduction in 1st with a 4.56. That is short, but pretty standard, certainly not crazy. So I also disagree with the "super short" comment... IMO a 4.11 or 3.91 would be better though. |
#11 |
#12 |
With a 6cyl, he can even get away with a 3.73, which i think is pretty nice, but thats with my 4 and a 3.35 gearset. a 3.91 would prolly be just right, still reasonable for the freeway, 5th is right on IMO for a 3.73, but again being a 6cyl you could still prolly push the .5 6th at 3.73
Mark |
#13 |
Myung-Wu
God, I love junkyards.
#14 |
#15 |
I wouldn't recommend the torsen diff. My dad just did a 8.8 conversion for his bmw racecar and he did some research and talked to Sam Strano. He is a 4 time scca champ and was a torsen distributor and he doesnt run them. I guess torsen was bought out and there crap now. My Dad went with a detriot trutrac and hes had zero problems with it.
Jordan sucks |
#16 | |
I dunno about that.. the tru-trac is still a "torsen syle" diff (helical planetary gears). If the t2 ends up having issues it should get an eaton posi, end of story. If the factory clutch type dies in mine I won't think twice. BTW it is 28 spline I assume? I wonder if you could/should go 31 spline while you are at it? |
#17 | |
#18 |
is there an echo in here?
#19 |
You're an idiot
leave me alone, I know what I'm doing |
#20 |
#21 |
cheeseland highschool kid
awsome poi. this will be plenty strong. and very neet!!!!! i wana see it boosting.
1980 241gt *6.0 lq4 swaped* |
#22 | |||
On a mission
edit:// that said, im a manual-newbie, am I missing something? My 6 doesn't make torque out of boost You're telling me. Got everything for like $350 ![]() Quote:
)?I'm gonna stick with the 28 spline. It simplifies things, and I won't be launching it on slicks (although I do intend to drive it hard with 315 street tires). I can get some Raxle (or others) upgrade axles for the Tbird axle, and just specify shorter shafts. |
#23 | |
slab rider
#24 |
Not such a PRVert Anymore
Awesome, the rear on a mk2 irs isn't that much different to the Mk1 rear so I can definetly take pages out of your book on this, though getting one of those diffs in Aus isn't easy so I'll more likely use a Skyline/Supra R120 or whatever it is.
#25 | ||
![]() Big boy!!!! ballin. |
| Thread Tools | |
| Display Modes | |
