Old 07-05-2008, 11:51 AM   #1
thelostartof
unbalanced chemical
thelostartof's Avatar
Default Plugs and compression issues
So I am wondering if all of my high boost runs have been doing this damage. Ya'll know a bit about my setup ,HY35CW .... ran for a day or so @ 20+psi having boost creep to 30psi by redline (only did that 10-20 times to redline) .... no audible knock but knock sense was going on and off from time to time. Engine is a stock b230ft with around 160k on it(I have had for the last 80k and it has been HARD miles) with a 531 on it so compression should be 8.5:1
Either way issue is on cold starts she runs a bit rough, hell even on hot starts the first few seconds she almost sounds like she is down a cyl until 10-20 seconds of running. the last two months I have been running at only 10psi due to the 110+ deg heat here and no real reason to have more power being I never drive the car.
Pulled the plugs today (BP8ES) and noticed that all looked semi normal sans for number 3 which was almost orange in color, when compared to the rest the ceramic was much more tan while the others were white. Tan enough that near the Electrode it almost was brown. .... Ign system is MSD 6a box, Blaster2 coil, Proper suppression wound wires for MSD setup.
The other issue I noticed was on the compression check, I know this is cold engine and really worn out but just bare with me. Remember this engine went through the ordeal of having all 8 valves kiss the pistons so for all I know that could of dished the pistons a wee bit along with flexed the rods a bit as all 4 pistons had nice and shiny marks in them from when the valves hit. anyways Compression test was 125-130-110-135 .... Much lower than it should be BUT not the end of the world. I am sure with a nice 9:1 CR engine that is fresh the car would be worlds faster(then again the low readings could be from the crappy $9 gauge I have)
I added some oil to #3 and it came up to 130psi so even with the others.
So well .. what do ya'll think? besides just getting a Fresh short block, what might be causing #3 to be so tan plug wise?
FWIW when I was running the 20-30psi on the engine it would fill up the catch can with about 1/2 qrt of oil after about 200-300 miles of driving hard, but the crankcase would LOSE ZERO oil, as in my engine was somehow producing excess oil so who knows.
Chip Feedback Thread / PM Current Chip Prices / PM for DownPipe & Exhaust Price / Silicone Cooling Hose Sets 2/7/9
Old 07-05-2008, 12:09 PM   #2
TerribleOne
Turbonormalizer
TerribleOne's Avatar
I'd pressurize the cooling system overnight to check for a headgasket leak.. You're probably getting water down in a hole while it's sitting (hot starts) and it's choking on water the first few seconds.
89 244tic- Ultimate sleeper - MZR/Duratec 2.3, Eagle rods, CP 8.5:1 jugs, GT3071R , 5R55E, Home-made turbo and intake manifolds, Electromotive TEC-GT, Tial BOV and WG, PCS Paddle shifters, Electronic gear select module
93 965- Daily driver
91 944se- Resto project
66 122s- Stock
TerribleOne is offline   Reply With Quote
Old 07-05-2008, 12:15 PM   #3
frpe82
Guest
+1
That was how my car behaved when my headgasket started to go.
Old 07-05-2008, 12:17 PM   #4
thelostartof
unbalanced chemical
really .... that would explain the small amount of white smoke I get on Cold Cold starts and why there is that water like oil stuff in the downpipe ....
well **** I really do not want to do the HG but I guess it would be a good time, Now to order some head bolts and a HG kit and just find a weekend to swap it.
so this would be a great time to stop driving the car I guess ... hm well since I am letting it sit with some MMO in the cylinders I guess I can just leave it be and not worry about putting new plugs in it ...
and this would also explain the small loss of coolant I have been having, well I feared it .. and looks like this confirmed it
Old 07-05-2008, 12:19 PM   #5
boostin'xr4
boostin'xr4's Avatar
EDIT: their advice ownes mine.
+1 bhg.
boostin'xr4 is offline   Reply With Quote
Old 07-05-2008, 12:29 PM   #6
plantto
100+
plantto's Avatar
Yeah I think I may have the same problem. I have been driving pretty hard lately and losing some coolant. I have also had kind of a hesitation on startup lately, but my brother was guessing plug wires so once they get in tuesday if that is not it then I think headgasket and IPD turbo cam swap is in the very near future. I am only running 18psi though.
1991 744Ti Hallman @ 18psi , 15G, 3" Turbo Back Exhaust, BIG Ebay IC, Brown Tops, 012 AMM, Freds Chips, IPD Turbo Cam.
Electric fan conversion comming soon.
plantto is offline   Reply With Quote
Old 07-05-2008, 01:53 PM   #7
gsellstr
gsellstr's Avatar
Sounds about right Mike. We were fighting the same issue on my brother's 240T for a while. He was actually getting some really funky growth on the insulator on #4 as well, that we couldn't ID. The oil PRODUCTION is rather odd, but if it's possibly water-based I guess that'd make sense.
I think I know of a connection to get the parts for that job, and it should only take ya 3-4 hours.
RIP Doug "Mr. Doug" Williams, 4/15/2009
74 144 B20
90 745Ti, AW71L, IPD bars/springs, Koni SA's, JVAB B230FT, Big Valved 531 head, IPD Turbo cam, GT2871R @ 18psi, TLAO chips, E85, NPR, 3.5" DP, 3" DP-back, MSD, TruTrac, Wilwood BBK
If you need Superpro bushings PM me or check the current GB, running until 3/31/13 at http://forums.turbobricks.com/showthread.php?p=4493644).
Old 07-05-2008, 01:59 PM   #8
thelostartof
unbalanced chemical
Either way the crap trapped 103mph with a blown HG so not all that bad, I wonder if I will pick up any power and if she will spool quicker once I get it fixed ... as I had the issue of the white smoke on startup along with missing coolant since before I put the Holset on so .... hm, would explain the slow spooling issues of the Super60 also
Old 07-05-2008, 02:07 PM   #9
boostin'xr4
more compression should = more power
Regardless of engine condition, your car pulls hard.
Edit: My 2.3t xr4ti did a 13.1 on 19psi with a cracked head :]
Those lima 2.3's are notorious for it.
Old 07-05-2008, 02:16 PM   #10
thelostartof
unbalanced chemical
Right now I would be happy with a 13.9 as I seem to have issues getting back there, as of late being able to get the turbo spooled off the line has sucked along with the lack of traction so we shall see if this fixes one of those issues, and if so then I get to go back to saving up to beef up the rear subframe so I can run slicks
Old 07-05-2008, 02:21 PM   #11
Ruben
Ruben's Avatar
Maybe some nitrous to help the holset spool a bit faster...
A dirty mind is a joy forever
Drove:
'87 Escort 1.3:'90 mini Jumbo:'87 360GLT:'87 744T:'92 240 Polar:'84 744T:'95 854T5:'90 744GLE 16v:'87 340 1.7:'79 343DL :'84 340L:'91 240DL lpg:'89 360 GL:'94 944TDIC M90:'85 360 GL:'90 745 GL:'89 744 GL:'86 745 TIC:'94 Nissan Sunny 2.0D:'92 Peugeot 205D:'88 360:'85 340GL:'86 360GL:'84 242TIC: '85 244 TI:'89 Dai racer:'95 460: '85 360GLS:'83 340 DL: '97 944IC: '91 AX Cup:'93 Diehatsu:'98 Polo D:'87 360GL
Drive:
Citroen C15D
Ruben is offline   Reply With Quote
Old 07-05-2008, 02:24 PM   #12
Can play the blues
Default compression
When I overrevved my B21FT. It dropped a valve. The number two intake. I did a compression test on a cold engine, too. Number one was 140psi, number two was zero, number three was 130psi and number four was 140psi. This was with the stock 7.5:1 compression. So, you must have some compression loss happening in your engine since it is a whole point higher in compression. Don't just automatically blame the short block. A leak down test will help you figure out where it's leaking from.
1982 242 turbo. MVP coilover front and rear suspension. Bilstein HD. IPD 25/25 bars. 3" MVP exhaust. Cosworth Sierra hot side T3 .48 with upgraded stock .42 compressor. Ported 90+.True Track diff. Flat hood 1979 front grill Ecode park/turn lights with H4 Hella. 321k miles. Had it since 1995.
1993 245 Classic, 340k miles, enem V15. Genuine Volvo stock over the axle exhaust.
Old 07-05-2008, 02:27 PM   #13
boostin'xr4
Can't wait to see it
Old 07-05-2008, 02:43 PM   #14
frpe82
Guest
You have to factor in dynamic compression as well.
He's running an ENEM V16T cam, and it has high lift and a duration that is much longer than the T cam.
On my engine with a KG2T cam, the compression is really low at starter speed. You can also tell the difference pretty easy when spinning the engine by hand.
Old 07-05-2008, 03:14 PM   #15
Slobodan
Slobodan's Avatar
I recently was trying to diagnose my rough running B21F+T. 130 180 130 180.
I have a new old school sears compression tester. I trust its numbers. 2 years ago I did a comp test 1 year after I did the +T and I retrieved a 180 180 180 180 very nice numbers for a motor with 240k and 10k of that being a very hard +T.
but I think my problem comes from me leaving the intake off it during the winter months when It was down due to not having a suitable turbo at the moment. side note I had took my special intake off to put on my other motor that was in my wag.
right now I have little power at idle and its very lumpy but once you rev it out she comes alive a little. Not like she used to though. but with comp numbers like yours I understand the cam differences but it really seems low but close enough to each other. I think you may need to issue a leak down test and check valve clearances, make sure they are in spec.
'79 245 DL: D24TIC M47 40mpg: 365k Rockin' Again.
'79 242 GT: B21FT K-Jet 24.4mpg
'71 164 : B30 M400 No brakes.
'83 265 GL : D24 M46 - Must complete the maintenance
Slobodan is offline   Reply With Quote
Old 07-05-2008, 03:27 PM   #16
thelostartof
unbalanced chemical
15k ago when I put the 531 on along with the V16 in they were in spec so I guess I can check later
Old 07-05-2008, 04:01 PM   #17
Can play the blues
Default compression
I understand, my test was done with an enem V15 turbo cam. More lift and duration than a T cam but still a bit less than a V16 turbo cam. I can't wait to try out my V16 turbo cam.
Old 07-05-2008, 04:07 PM   #18
lummert
lummert's Avatar
Default NGK Spark Plugs
I was just wondering about the NGK BP8ES plugs. My 88 Volvo 765 TIC is completely stock and when I went to buy spark plugs the book listed BPR5ES. I went home contacted NGK and they said that was correct heat range for 88. I looked up the plugs on the NGK website and read that the BPR5ES was the hot plug and BPR7ES was the cold plug. So I ordered some BPR6EY V-Power plugs for an 88 Volvo 760 B230FT.
Old 07-05-2008, 07:43 PM   #19
TerribleOne
Turbonormalizer
I use BPR6ES in most everything aroud my house from stock NA cars to my 244 when it's not running alot of boost. They're a pretty flexible all around plug. If you've passed stage 1 or 2 I'd reccomend strongly going to a 7.
Old 07-05-2008, 08:12 PM   #20
boostin'xr4
8's are intensely cold plugs, but i'm sure 20-30psi on a holset warrants that
Old 07-06-2008, 06:15 AM   #21
frpe82
Guest
I am running BP8ES plugs.
The BP7ES wears out too often.
Old 07-06-2008, 01:14 PM   #22
boostin'xr4
What's your setup?
I like 8's on cars that see lots of abuse+boost in hot climates (read: all the time here)
Old 07-06-2008, 01:25 PM   #23
MrBill
JohnMc=500Dollar Mistake
MrBill's Avatar
brushing through the thread. If coolant was lightly mixing or being dumped, it would also explain why your catch can fills up but you dont have any loss of oil. Maybe water is mixing in the pan?
Also my 242 with b21ft 7.5:1 and k-cam measured out 125 across the board.
Originally Posted by 500dollar744ti View Post
something i feel strongly about because even if it doesn't appear so, i am a strong advocate of safety.
84 244 - Wilbur - Lemons hopeful
97 960 - New DD/beater
97 960 - Other new DD/beater
Old 07-06-2008, 01:25 PM   #24
frpe82
Guest
What's your setup?
Look at my project thread: http://forums.turbobricks.com/showthread.php?t=70288
I am sorry that i am too lazy to write it here
Old 07-06-2008, 01:33 PM   #25
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
ah, the ring land fairy has paid you a visit, i see where this is going, cracked on one side but not all the way through. pretty soon you will have the permanent misfire and popping dipstick syndrome.
-Matt
1989 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1983 Ford F150- 302ci, C6/4x4, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, Bulletspeed lower, HR-Titan 20p.
the rest: 1996 850t 179k, 1998 S90 175k, 2004 V70 2.4 175k, 2005 XC90 2.5t AWD 122k.
500dollar744ti is offline   Reply With Quote
