- Mar 19, 2003
- Denver, CO
This is pretty old news to alot of people. But I spent some time cleaning up and completing the information. Its somewhat obsolete these days since you can just buy stuff from John V or R-Sport International. But, if you are determined and really like the way i rolled my own then you can do it too.
The engine has been together and running since 2006, and has about 15k miles on it at the time of this writing. Its seen a bit of track time on the road course, and half a dozen drag days. Its not babied, and usually runs about 20psi boost. Its pretty strong and surviving so far. I had a similar stroker motor before this one, and it mysteriously threw a rod. So, I'm batting about .500 on the whole DIY stroker motor thing.
I'm not the only one who has done this. TerribleOne has/had a similar project thread too. So search around.
There are pictures in the text. If you don't see them, then my server must be down. Send me a PM and I'll fix it. Or maybe later I'll attach them to the post here. But my server is usually pretty reliable. Just ask if you don't see images. I?m re-posting it here for so people can find it easier and search for it on google or turbobricks.com website.
Shortblock details
This is how you build a strong long stroke Volvo Red Motor
Block
I started with a 1984 B23 block. At the time of assembly, this was considered the strongest foundation to start with. The block is a little heavier than the late blocks due to more iron in some spots, and it also has a forged steel crankshaft that doesn?t come in the later motors. Since then people have proven that the later blocks and cranks are strong enough for just about anything you can throw at them. But I started with the best at the time:
Block Specs:
1984 Volvo B23FT
Bore: 3.800″ (.030″ over)
Deck Height from crank center to top: 9.125″
Crankshaft
The backbone of a strong motor is the crankshaft. I started with a B23 forged crank. My machine shop did an offset grind on the rod journals to use Mitsubishi 4G63 connecting rods. The rod journals now hold the mitsu rods with about .010″ side clearance. Much nicer than the Volvo setup which guides the rods from the piston. The crank was heat treated after grinding. In metric measures, I started with an 80mm stroke Volvo crankshaft and ended up with 88.8mm stroke. This could also be done to a B21 crankshaft, it has the same size large rod journals.
Stroke: 3.496″
Rod Journal dia: 1.771″
Rod Journal width: 1.130″
<hr> Pistons
The pistons are custom from Diamond Racing. I specified the dish shape to match the combustion chamber of the 16 valve head. And they fit the Mitsubishi 4G63 rods I am using. The piston to head clearance should be about .040″, just about right for good squish. This was a priority for me, since I?ll be trying to maximize power with this turbo motor running on pump gas. Tight squish motors help keep detonation away. As a curious observation, there are 3.800″ bore pistons for small block Chevy motors with very close compression height. It could be worth looking into if you are trying this type of build on a tight budget.
Piston Specs:
Diamond Racing Products Custom Pistons
Bore: 3.800″
Compression Height: 1.471″
Rings: 1.5mm,1.5mm,3.0mm
Piston Weight: 419g
Piston to Bore clearance: .006″
<hr> Rods
The engine uses a set of Scat H-beam connecting rods for a Mitsubishi 6-bolt 4g63. These rods are nice and strong with an ARP 3/8″ cap screw holding the caps on. They also have a small hole drilled in the big end that sprays oil on the pistons. A nice little bonus feature.
The rod dimensions are:
Scat Rods for 4G63 Mitsubishi
Length: 5.906
B.E. dia: 1.890
pin bore dia: .827
Big end width: 1.117
Small end width: 1.010
<hr>Some pictures of the assembly coming together. The final displacement is roughly 2.65 liters. Enough for some extra low end grunt.
Shortblock details
Block
Block Specs:
1984 Volvo B23FT
Crankshaft
Stroke: 3.496″
<hr> Pistons
Piston Specs:
Bore: 3.800″
Piston Weight: 419g
<hr> Rods
Length: 5.906
B.E. dia: 1.890
pin bore dia: .827
