Old 10-10-2008, 12:18 PM   #1
Quattro
Quattro's Avatar
Thumbs up Another run at the 1/8 mile
Well guys i went out to the track last night.Had alot of fun as always.Upped the boost to 14psi and bypassed the fuel cut as id spike 15 and hit the cut.My tire pressure was messed up.And i was having trouble hooking (open rear) thats why my damn 60 foot is soo bad.The 10.4 was pulled off due to having traction off the line for a change.My 1st try out at the track last month on stock boost was a 11.7 the best i could do.So its a real big improvement over that.Poik was saying i should be able to get 9's out of it as he was able to hit 9's on 12psi.But i think its my tire pressure more then anything.Im break boosting 2500rpm i can bring it up to 3500rpm but thats just gonna give me more wheel spin.Tires are some goodyear all summer tires fairy new tires.
I just wanna know if 9's are really possible due to my garbage 60 foot.Im gonna be going back out there either this coming week or the next.The 10.6 was having wheel spin off the line pretty badly.Mods are in my sig.Boosting 14psi and thats about it.Any tips on what my tire pressure should be at the track would help.
10.499=1/4 16.33
10.6= 1/4 16.65
Video of the 10.6 run ^^.
Need any 2/7/8/9 Parts?Contact me via pm!!
Quattro is offline   Reply With Quote
Old 10-10-2008, 12:20 PM   #2
linuxman51
ARRRRHARHAR
linuxman51's Avatar
a 2.7 60 is pretty horrible, ease off the launch a bit or ride the clutch. whats the timing at?
Megasquirt Tuning!
ported volvo heads
Old 10-10-2008, 12:22 PM   #3
Quattro
Quattro's Avatar
Timing is whatever stock was.I never checked it.And the trans is just a slushbox aw71.
Old 10-10-2008, 12:32 PM   #4
JohnMc
JohnMc's Avatar
Are you powerbraking to get the boost up? Utterly pointless if you just sit and spin anyhow. Did you try just tromping the gas pedal down when the light goes? Or just try powerbraking with a lot less throttle.
You could probably let a fair amount of air out of the tires before they start to lose traction again. Are you going through the water box? Are you doing a burnout after that? How much of one?
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 10-10-2008, 12:37 PM   #5
Quattro
Quattro's Avatar
No burn out or anything just going straight to the tree.Yeah i guess if you wanna call it power braking i was doing that to get into boost off the line.And no i did not try stabbing it wot at the track just yet.Ill have to give that a try.
Old 10-10-2008, 10:00 PM   #6
"YOU'RE" is a word.
Bad 60ft. You need a locker or some better tires. Heres a link to my last trip to the drags and some times of other cars:
http://forums.turbobricks.com/showthread.php?t=140752
1975 244-Turbo. 2550lbs. Ethanol
1990 245-28mpg M47 DD
Old 10-10-2008, 10:20 PM   #7
JohnMc
JohnMc's Avatar
Here's my open diff 60 ft time from last year:
This year with crappier tires (Toyo T1-R 225/45/17, last year was nice but spendy and fast wearing GY Eagle F1 GS D3's in 215/45/17):
Old 10-11-2008, 07:09 AM   #8
Booster
bewst bewbies & chunga!
you need to learn how to launch the car with as little wheel ( or no) spin as possible.
Booster is offline   Reply With Quote
Old 10-11-2008, 12:48 PM   #9
Quattro
Quattro's Avatar
Yeah i know hah.I got both tires at 28 psi on both.No wheel spin from a stop anymore.Have to see how it works out at the track.Think ill just footbrake it to 1k.
You guys think its capable of 9's? .
Old 10-11-2008, 02:58 PM   #10
L8 APEKS
Yayayaya, hohohooo!!!
L8 APEKS's Avatar
What do you have done to the car again?
Sean Williams
'94 850 Turbo Wagon (daily) :: 14.0 @ 98.5
B5234|AW50|TLAO tune|3" exhaust|NA cams|65mm tb|38mm BOV|E40 blend
'75 244GL (project) :: 8.4 @ 85.6
B230FT|AW71|1031|gutted|TLAO chips|welded 3.73|19T|3" exhaust|IPD cam|E62 blend|55 lb inj. (@ 4 bar)
CLICK HERE for the 244 BUILD THREAD!
BRAND NEW Mitsubishi 18T and 19T turbo conversions for sale...from $450...CLICK HERE or PM for details!
L8 APEKS is offline   Reply With Quote
Old 10-11-2008, 03:03 PM   #11
Quattro
Quattro's Avatar
Just a mbc set to 14psi currently.And running an old Garrett t3 .42 trim.Other then more bewst and a open downpipe thats it.
