Hi TB's I have a few questions regarding squeezing every last ounce out of my current setup. I have Fred's chips for both fuel and ignition and after rereading his FAQ i gather that the EZK is currently running as much advanced timing as possible across the board. Is this correct. How about grounding certain pins on the EZK? Which ones? Will this set the base ignition to a more advanced level, from which the EZK will continue to function properly? Also I am about ready to hook up a Nitrous kit and plan to start with a small (35hp) jet. I understand that retarding the cam timing is a good idea when spraying, is that correct? Would getting more advanced ignition timing work against me when spraying? I should also mention I am running about 21-22 psi on the 13c and am injecting Methanol coming on at ~10 psi. I may not have supplied enough info to have all these questions answered so feel free to ask for more.
Thanks in advance, Greg Ervin PS it is going on 3 years now and I would really appreciate it if a mod would change my screen name to Gregervin rather than Gregerivn to reflect the correct spelling ![]()
90 740. Stock internals, LH2.4, 15g and AW71. 12.603@104.20
I don't post much, so I don't know if getting no response is normal or not.
#3 | |
ezk tweaking via grounding pins with the pin grounding trick, you could use a micro-switch to ground the pins only when the nitrous is activated |
#4 |
That is good. I wonder what parts would be needed to make a switch to go from 6* retard to 0* to 3* advance maybe a simple 3 way switch? Has anyone done this yet?
#5 |
Yayayaya, hohohooo!!!
Man, good for you. Do you know how many tools on this board will tell you that what you're running on the 13C is "not physically possible?" Nice work.
Sean Williams '94 850 Turbo Wagon (daily) :: 14.0 @ 98.5 B5234|AW50|TLAO tune|3" exhaust|NA cams|65mm tb|38mm BOV|E40 blend '75 244GL (project) :: 8.4 @ 85.6 B230FT|AW71|1031|gutted|TLAO chips|welded 3.73|19T|3" exhaust|IPD cam|E62 blend|55 lb inj. (@ 4 bar) CLICK HERE for the 244 BUILD THREAD! BRAND NEW Mitsubishi 18T and 19T turbo conversions for sale...from $450...CLICK HERE or PM for details! |
#6 |
#7 |
Backwards Turbo
![]() Join Date: Feb 2005
How much does your car weigh again?
#8 |
about 2730 with me in it
#9 |
#10 |
I grounded pins 18 and 19 and I can feel a difference. More torque down low and overall smoother running. Is this consistent with others experience?
#11 |
Haven't tried it, but now I'm curious! Any pics of how you did it?
I don't know much about electronics, but would it be feasible to ground those pins via a toggle switch on the dash, for when there's race gas in the tank? |
#12 |
or e85 ;)
#13 |
No such thing as E85 in SoCal.
If you're near Disneyland (north OC/south LA), the closest gas station that sells E85 is in EL CAJON, near the border of Mexico...roughly 125 miles away. |
#14 | |
Un-real that California only has a handful of station with E85, I have a few not too far from my house, but cannot justify the switch right now...it would make my N/A build more fun !!! E85 fill locations I figured L.A. would have tons of them |
#15 | |
Priority List: 1) Profit 2) Environment |
#16 |
well, you could have it set up so when you're near e85 stations, you could put it in ;) supposedly, they're putting a e85 plant in lancaster out this way...that processes garbage or something. but that doesnt mean the pumps will be everywhere. also, to clarify, this only adjusts timing, not injector pulse widths or load signals? or is it messing with the load signal to add timing? |
#17 | |
Turbo, what?
Kyle - NLMGG: '91 244 NA DD/Track - General Leif: '71 142 b230 Chumpcar - Oregon Volvo Tuners? - For Sale? |
#18 |
Kyle, will we have to ground the pins with the Fred chip?
#19 |
Turbo, what?
We won't HAVE to, it's only if we want to and our setup can handle it. I'm going to be disconnecting my ground when I get the chips, as things will already be advanced compared to stock. I can't wait to see what it feels like! Lucky you already having yours! I was expecting them early last week, but it seems it'll be early this week...
After you get them in(and train them! stock injectors won't matter as much as my car requires it), you can always experiment with grounding pins again to see if your car does or doesn't mind more ignition advance. It'll be fun for me to monitor the way Fred's chips play with air/fuel ratios compared to stock in different situations too. Hopefully at WOT and lower rpm it's richer than stock... Between more fuel and ignition timing at lower rpm, it could really strengthen the powerband. I don't know what LH2.4 is capable of though, it doesn't really have a good way of telling what WOT is(amount of airflow sure, but that goes up with better and better breathing engines) without a throttle position sensor. |
| Thread Tools | |
| Display Modes | |
