1997 850 glt lpt
looking to swap factory turbo, injectors, throttle body, ect i was looking at the GReddy E-manage Engine Management system any thoughts? |
8 cylinders
Why would you use a POS e-manage when you can use an OEM turbo ECU?
because i can tune an emanage from my computer
i can't tune my fac ecu from my computer |
#4 |
Never go full retard.
A Megasquirt would cost you less and give you more.
#5 |
the GReddy E-manage is $349 plus shipping
how much is MS? i'm looking on diyautotune.com right now and it seems like it's a lot more work than it should be and there isn't a straight forward price on these systems |
#6 |
Master Troublestarter
![]() Join Date: Jun 2003
piggyback = POS that doesnt work on an 850 ECU anyways...suck it up pal, we know what we're talking about...if you wanna buy something even after it was suggested not to, then you shouldnt have posted about buying it in the first place...
![]() 340.9 whp 305 lb-ft @ 18 psi on e85 with a stock 8v head and b230f lower in a ****box 75 |
#7 |
how much is megasquirt for my car?
#8 |
cheeseland highschool kid
your almost like yahmapro...
1980 241gt *6.0 lq4 swaped* |
#9 |
You can get an unassembled v2.2 pcb, a JAW, and a sensor for under $300. Then you have a fully programmable fuel and spark computer with a wideband.
#10 | |
Yayayaya, hohohooo!!!
Those piggybacks DO work. They aren't the end-all, be all...and they aren't meant to be. It would give him some more flexibility. It sounds like that's all he needs. MS would be overkill. And I'd bet even money that people who say they don't work wired them wrong. I've seen them running just fine in VW's, Audis, Porsches, even a Saab. MS isn't for everyone. It takes a lot of work to get it running and tune it properly. Something like an S-AFC is much more simple just to get some fine tuning in.
Sean Williams '94 850 Turbo Wagon (daily) :: 14.0 @ 98.5 B5234|AW50|TLAO tune|3" exhaust|NA cams|65mm tb|38mm BOV|E40 blend '75 244GL (project) :: 8.4 @ 85.6 B230FT|AW71|1031|gutted|TLAO chips|welded 3.73|19T|3" exhaust|IPD cam|E62 blend|55 lb inj. (@ 4 bar) CLICK HERE for the 244 BUILD THREAD! BRAND NEW Mitsubishi 18T and 19T turbo conversions for sale...from $450...CLICK HERE or PM for details! |
#11 |
no, they dont really work...kinda like a SFAC in an LH2.4 car....it doesnt work
#12 |
As a matter of fact...when that debate happened, I told one of the head Techs at the Volvo dealership I was working at about it.
He then showed me his S-AFC Euro installed in his LH2.4/redblock 240 wagon and said it works fine. He told me they probably used the JDM version by mistake. |
#13 | |
#14 |
Not according to the 31 year master tech. Since he's tuning it and driving the car, I'm gonna tend to believe him and his gauges. A/F was tuned and holding just fine. LH didn't change it.
And FYI, tons of cars have ECU's that "learn." Volvos aren't unique in that respect. |
#15 | |
#16 |
Ok. I must have been seeing things, and the Master Tech and Volvo tuner I used to work with must have been imagining the S-AFC working fine in his car.
#17 |
#18 |
From what I gather is has been in his car for a couple years. He only re-tunes when hard parts change. Wish I'd have gotten pics. He has an A/F. Mixture doesn't change. Meaning, the tune stays where he set it.
Just because someone on here tried it unsuccessfully, doesn't mean it can't work. By that logic, it's impossible for a 15G to run 13's. I don't recall him saying he had to do anything special to it either. I think part of it may have been that he used the correct S-AFC (Select is the Euro version, reads the correct voltage signal...standard JDM S-AFC reads backwards for a Euro car, and will not work unless you make some changes). But anywho...I know it works. I've seen it. I just don't know if he had to change anything in the install to make it work. |
#19 | |
i just want a decent amount of hp to the wheels maybe like a little under 300 because i really don't want to crack the engine open exhaust, chip, injectors, and a new turbo, probably garrett or GReddy. so the dp and exhaust will be custom made (have that part under control lol) thanks for the input, and where can i find an S-AFC pb? is there any difference in the universal pb's? |
#20 |
With a MAF voltage clamp, and some O2 trickery piggybacks can hold a tune. BUT they still suck MAJOR ballsacks.
Aside from the AFC/SAFC's out there and their copycats, eManage is probably the worst option. The AEM F/IC is marginally better, but it (and almost everything else out there) still blows compared to the MS/MegaTune/TunerStudio/LogViewer combo.
-Isaiah |
#21 | |
#22 |
#23 | |
another thing that you might have missed?? you have a 5 cylinder.....looking at the doc's for the e-manage, 3, 4, 6 and 8 are supported...I guess if it can do a 3 cylinder with a distributor, it should handle a 5 cylinder....only problem is can you set the switch that you turn to tell it how many cylinders to 5?? |
#24 | |
my friend has one and there's no cylinder option switch on the actual module you set the cylinder # on the program i'm not 100% sure how it works but for him it works great, it's not on a volvo though, or an odd number cyl engine so.. |
#25 |
Piggy backs with O2 emulators that intercept and modify 02 signals CAN allow you to properly tweak the stock ECU to get it to do what you want with regards to fuel only. Tuning such systems on OBD-2 (Everything since 1996, some ~94's and ~95's.) REQUIRES you monitor long term and short term fuel trims (how much the ECU is modifying the fuel map to get a desired closed loop AFR, seen by the ECU as a voltage) Otherwise the adjustments you make in the piggyback are useless and negated by the stock system. Piggybacks that have no provision for intercepting the O2 signal will be "learned" (more like adjusted) around when in closed loop, and are not suitable for more advanced stock ECU's. The ECU will adjust fuel trims up to a certain point, then it will throw a check engine light, often times putting the vehicle in limp dick...I mean limp home mode.
IF its even capable of modifying ignition timing, you can't advance it since the piggy back DELAYS the signal to the ecu from the CKP or CAS signal. I have yet to see one with TPS-Dot accel enrichment, and snap-open-throttle tuning is nothing short of difficult to do when modifying MAF voltages on a turbocharged car. Often times you'll end up with a compromise between a clean AFR pull with a slow/steady throttle/engine acceleration and something that responds well to free rev and wild throttle activity. Skewing the MAF voltages in most systems alters the ignition timing, so you inevitably end up compromising there as well. |
| Thread Tools | |
| Display Modes | |
