Old 11-01-2008, 08:28 PM   #1
RobSmith
RobSmith's Avatar
Default B230 block marking R?
I have read that there is a super marine block similar to an 'R' block. see...
http://forums.turbobricks.com/showthread.php?t=24675
I have three blocks currently..
1992 250A (which I believe is what they renamed an AQ151C after some date)
1992 B230FB
1997 B230FT
The AQ151C block and B230FB blocks are from the same year and are marked with an 'R'
The 1997 B230FT block is not.
I would say the cylinder walls are maybe slightly thicker on the blocks marked 'R'.
I am modifying an old pair of vernier calipers so I can measure this.
Can anyone confirm this 'R' means anything?
Rob
1981 / 245 DL / dung brown / B21A / M47 / 3.3:1 axle from auto (5th not used much) / Scrapped.
1982ish /240GLT Estate/silver/Scrapped
1994 / 940s Turbo Auto Estate / B230FT /metalic green / Scrapped
1993 / 940s Estate / B230FB / Blue / Scrapped
1992 / 940s Estate / B200? / White / Gone.probably scrapped.
1967 Amazon Estate (Sold)
Current Cars...
1998 940 Celebration /B230FK /M90L2/Galaxies (Blue)
1998 940 Celebration Standard (Red)
1998 940 Celebration Standard (Purple)
RobSmith is offline   Reply With Quote
Old 11-02-2008, 01:51 AM   #2
nalletill1000
i am not imformed about these red blocks, but i would guess no. check your other block and see what letter you have there. i think it only has to do with the casting procedure.
nalletill1000 is offline   Reply With Quote
Old 11-02-2008, 03:11 AM   #3
ovlover
ovlover's Avatar
Not sure mate, im curious. try on google. i might have a look-sie and see what i can see
ovlover is offline   Reply With Quote
Old 11-02-2008, 04:28 AM   #4
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Highly unlikely that they are R-blocks. There are no external differences that differentiate a regular block from a real R-block. Take a set of calipers and measure the depth from the water pump mounting face to the #1 cylinder wall on all three blocks. I don't remember the numbers off the top of my head but the difference in dimension there between a regular and an R-block should be around 2-3mm. I'm 99% sure all your blocks will measure up exactly the same, IE they are just plain vanilla castings.
Old 11-02-2008, 04:38 AM   #5
suterman
suterman's Avatar
It means reject,
You can give them me if you like I'll get rid of them for you.
1985 Bedford cf. B230e aw71L
1990 240 turbo. b230ft m47 chips
suterman is offline   Reply With Quote
Old 11-02-2008, 04:46 AM   #6
ovlover
ovlover's Avatar
Couldnt see anything on the net. But from looking at it again, i think if it was an R block, then it might be after or closer to the B230 print then what it is.
Old 11-02-2008, 05:01 AM   #7
JW240
All idiot, no savant
I dont think the R blocks were made that early, but i dont have experience with them.
Nice way to store blocks, i have to make a few of those stands as well! good thinking.
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 11-02-2008, 06:02 AM   #8
amargill19?
Barry McCockiner
amargill19?'s Avatar
lol wtf
what is an R block?
sounds like it was for strictly marine motors? is it like the b230 weapon-type R?
Originally Posted by Dan Wood View Post
Now, two years later, after a move to Oklahoma, a job in a potato salad plant, and many other assorted ventures, I have plans to visit Paraguay.
amargill19? is offline   Reply With Quote
Old 11-02-2008, 09:47 AM   #9
RobSmith
RobSmith's Avatar
Originally Posted by amargill19 View Post
lol wtf
what is an R block?
I searched on the internet and there are other blocks with different letters here.
I don't know what the mean and am trying to find out
Rob
Old 11-02-2008, 12:57 PM   #10
stylngle2003
stylngle2003's Avatar
R is for racing. duh.
jk
-Billy
1990 Mazda Miata (track toy)
Old 11-02-2008, 01:06 PM   #11
MrBill
fige=500Dollar Mistake
MrBill's Avatar
My late-1992 squirter block has an R cast on it also. I have no expectations that it is an r-block
Someone say crazy rays?
Old 11-02-2008, 10:21 PM   #12
shaved240
shaved240's Avatar
socalseans 92 244 had an r-block that he blew up. nothing special internal wise.
1988 244: b230f+t, M46:PARTED
1995 960: SOLD
1994 945: SOLD
Old 11-02-2008, 10:24 PM   #13
Poik
Backwards Turbo
Poik's Avatar
Pretty sure my 1990 AQ171c says R on it. My 1992 B230FT block may also, but I'm not positive.
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 11-02-2008, 10:34 PM   #14
JohnMc
JohnMc's Avatar
jk
Nah, it was a special version of the Penta motor. For pirates.
The Arrrrrrrr block.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-03-2008, 01:38 AM   #15
amargill19?
Barry McCockiner
i have a K block b230
Old 11-03-2008, 04:12 AM   #16
ovlover
ovlover's Avatar
ROFL
Old 11-03-2008, 05:31 AM   #17
aibast
aibast's Avatar
its a Type-R block - just let the V-tec kick in
Volvo Nilsson 740 "van" 1987 - B230K automatic to M46+OD swaped ex hearse
Volvo S80 2002 - D5 automatic daily eco cruiser 44mpg average
aibast is offline   Reply With Quote
Old 11-03-2008, 09:23 AM   #18
RobSmith
RobSmith's Avatar
Hmmm.
Were off into nonsence ramblings now.
I think I will conclude the 'R' cast into the side of the block is just a casting reference of some sort and does not mean anything else.
My two are just standard..which is ok.
Rob
Old 11-03-2008, 01:57 PM   #19
Jerd
Jerd's Avatar
R is for it will Rain on dem hoes....
Old 11-03-2008, 02:06 PM   #20
Chris_R
Kickin' rocks in sandals
Chris_R's Avatar
My 94 block has not this indicator.
Ermergherd!! Erm gernner kerhm!!
1995 964 (Silver)
1992 944Ti (White)
1996 965 (Burgundy) - Scrap
1994 945 Ti (Black) - Sirius Black Scrap
1992 944 GL (Black) - Killed by drunk driver
1988 745Ti (Silver) - Sold
Originally Posted by TurboBrickMan View Post
Long story short I found out she's a squirter.
Chris_R is offline   Reply With Quote
