Decepticon Overlord
I thought it would be beneficial to write about Turbo's & what they do, for people who are unfamiliar with them.
Turbocharger's operate as an exhaust driven method of increasing Intake air flow. They differ in one way from superchargers as they do not require a direct mechanical connection to the engine. So, you don't have to worry about snapped blower belts! The basic operation of a turbocharger can be explained as thus: The exhaust gasses exit the combustion chamber into the header and then enter the turbine housing. When engine speed & load is high enough the exhaust gas hits the turbine with enough momentum to start spinning it. Rapid expansion of the exhaust gasses create a vortex air flow which spins the turbine in excess of 100,000 RPM's. The turbine wheel (the hot wheel) is attached by a shaft to the intake compressor wheel (the cold wheel). When the turbine wheel is sufficiently spinning the compressor wheel spins & draws in fresh air. Air exits under pressure through the rest of the induction system into the cylinders. The components that make up a turbocharger are: Housing - Contains the bearings, shaft, turbine seal assembly, compressor seal assembly & lubrication passages. Some Turbo's may also have a coolant passage. This is the part usually right next to the Header. Compressor Wheel - Located in the Housing in the Intake airstream. Driven by the Turbine Wheel. Has curved fins opposite of the turbine wheel. Air is drawn into the center and forced outward by centrifugal force. THIS AIRFLOW IS WHAT CAUSES BOOST!!! ![]() Turbine Wheel - Located in the housing in the exhaust gas stream. Torque generated by the Turbine Wheel spins the Compressor Wheel. It has curved fins opposite of the compressor wheel that when exhaust gasses hit the fins create a vortex airflow which spin the wheel which spins the Compressor Wheel for BOOST! The Shaft - Attaches the Turbine Wheel & Compressor Wheel. The shaft is supported by free-floating bearings which are lubricated by engine oil. Wastegate Valve - Located in Turbine Wheel exhaust airstream. The valve is actuated by manifold BOOST pressure. It is closed when the Turbo is actuated, so that maximum exhaust energy is directed to the Turbine Wheel. The valve opens to allow a certain amount of exhaust gas to to bypass the Turbine Wheel once desired air pressure is reached. The Wastegate Valve can be summed up as - Flow of exhaust reaching Turbine decreases-This reduces Turbine/Compressor speed-Valve stabilizes turbo air pressure-Valve helps prevent detonation (Bad) Intercooler - Cools air compressed by Turbo before it enters the combustion chamber. This makes the Air intake charge more dense, Denser air contains more Oxygen, More Power! Making air cooler & denser increases horsepower and it helps to resist detonation. Compressor Bypass Valve - In the CBV the pressurized air is rerouted to the Compressor inlet for reuse. The CBV is actuated under positive vacuum conditions & is closed shut when positive BOOST pressure is reached in the manifold. When going through the gears on your Volvo, a short-lived vacuum condition is created & the CBV opens to direct the pressurized air back to the Turbo in inlet. CBV's are an O.E.M. part that can be found on all Bosch-K & LH-Jet E.F.I. systems. Those are the basic components of the Turbocharger system. Fun Stuff - Boost Controllers come in 2 types - Manual Boost Controller - Uses an operator adjusted gate valve to control the Boost pressure acting upon the Wastegate. By adjusting the pressure available to the Wastegate, more or less intake BOOST pressure can be generated. Electronic Boost Controller - Uses a solenoid actuated by a control module that relies on either the vehicle's existing manifold pressure sensor or it can use an auxiliary one. The solenoid controls BOOST pressure acting upon the Wastegate. The controller can be programmed for more than one BOOST level on some units. ![]() Blow-Off Valve - Reduces pressure in the Intake when the throttle is released, preventing air ducting from blowing apart and protecting the Compressor Wheel from Surge. The valve is actuated by a High vacuum signal from behind the closed throttle. This is the component that makes the "whoosh" sound on a turbocharged vehicle. Bad Stuff - Turbo Lag - The time required to bring the turbo up to a speed where it can function effectively is called turbo lag. This is noticed as a hesitation in throttle response when coming off idle. This is symptomatic of the time taken for the exhaust system driving the turbine to come to high pressure and for the turbine rotor to overcome its rotational inertia and reach the speed necessary to supply boost pressure. The directly-driven compressor in a supercharger does not suffer this problem. On light loads or at low RPM a turbocharger supplies less boost and the engine is less efficient than a supercharged engine. Lag can be reduced by lowering the rotational inertia of the turbine, for example by using lighter parts to allow the spool-up to happen more quickly. Ceramic turbines are a big help in this direction. Unfortunately, their relative fragility limits the maximum boost they can supply. Another way to reduce lag is to change the aspect ratio of the turbine by reducing the diameter and increasing the gas-flow path-length. Increasing the upper-deck air pressure and improving the wastegate response helps but there are cost increases and reliability disadvantages that car manufacturers are not happy about. Lag is also reduced by using a foil bearing rather than a conventional oil bearing. This reduces friction and contributes to faster acceleration of the turbo's rotating assembly. Variable-nozzle turbochargers eliminate lag. Lag can be reduced with the use of multiple turbochargers. Another common method of equalizing turbo lag is to have the turbine wheel "clipped", or to reduce the surface area of the turbine wheel's rotating blades. By clipping a minute portion off the tip of each blade of the turbine wheel, less restriction is imposed upon the escaping exhaust gases. This imparts less impedance onto the flow of exhaust gases at low RPM, allowing the vehicle to retain more of its low-end torque, but also pushes the effective boost RPM to a slightly higher level. The amount of turbine wheel clipping is highly application-specific. Turbine clipping is measured and specified in degrees. Lag is not to be confused with the boost threshold; however, many publications still make this basic mistake. The boost threshold of a turbo system describes the minimum engine RPM during full-throttle operation at which there is sufficient exhaust flow to the turbo to allow it to generate significant amounts of boost[citation needed]. Newer turbocharger and engine developments have caused boost thresholds to steadily decline to where day-to-day use feels perfectly natural. Putting your foot down at 1200 engine RPM and having no boost until 2000 engine RPM is an example of boost threshold and not lag. If lag was experienced in this situation, the RPM would either not start to rise for a short period of time after the throttle was increased, or increase slowly for a few seconds and then suddenly build up at a greater rate as the turbo become effective. However, the term lag is used erroneously for boost threshold by many manufacturers themselves. Electrical boosting ("E-boosting") is a new technology under development; it uses a high speed electrical motor to drive the turbocharger to speed before exhaust gases are available. The electric motor is about an inch long. Race cars often utilize an Anti-Lag System to completely eliminate lag at the cost of reduced turbocharger life. On modern diesel engines, this problem is virtually eliminated by utilizing a variable geometry turbocharger. Damage - Turbochargers can be damaged by dirty or ineffective oil, and most manufacturers recommend more frequent oil changes for turbocharged engines. Many owners and some companies recommend using synthetic oils, which tend to flow more readily when cold and do not break down as quickly as conventional oils. Because the turbocharger will heat when running, many recommend letting the engine idle for one to three minutes before shutting off the engine if the turbocharger was used shortly before stopping (most manufacturers specify a 10-second period of idling before switching off to ensure the turbocharger is running at its idle speed to prevent damage to the bearings when the oil supply is cut off). This lets the turbo rotating assembly cool from the lower exhaust gas temperatures, and ensures that oil is supplied to the turbocharger while the turbine housing and exhaust manifold are still very hot; otherwise coking of the lubricating oil trapped in the unit may occur when the heat soaks into the bearings, causing rapid bearing wear and failure when the car is restarted. Even small particles of burnt oil will accumulate and lead to choking the oil supply and failure. This problem is less pronounced in diesel engines, due to the lower exhaust temperatures and generally slower engine speeds. A turbo timer can keep an engine running for a pre-specified period of time, to automatically provide this cool-down period. Oil coking is also eliminated by foil bearings. A more complex and problematic protective barrier against oil coking is the use of watercooled bearing cartridges. The water boils in the cartridge when the engine is shut off and forms a natural recirculation to drain away the heat. Nevertheless, it is not a good idea to shut the engine off while the turbo and manifold are still glowing. In custom applications utilizing tubular headers rather than cast iron manifolds, the need for a cooldown period is reduced because the lighter headers store much less heat than heavy cast iron manifolds. Turbochargers can also suffer bearing damage and premature failure due to throttle blipping right before shutdown. This may cause the turbo to continue spinning after the engine has shutdown and oil pressure has dropped. Some Turbocharger differences - TD04-09B. The stock turbo is sized nicely for the stock motor and the stock fuel system. It is too small for a modified engine. TD04-13G. This turbo is sold by MHI as the Mitsubishi Sport Turbo Upgrade. This is an excellent turbo for a stock engine. For a modified engine, this turbo will run out of flow at higher RPM - about 17-18 psi boost max at 7000 RPM. TD04H-15G. This turbo is as large as you want to go with a stock engine. The engine really should be modified to use this turbo. It has good coverage of demand lines (modified engine) but, for the more-demanding driver, it will fall short at the highest flow levels at the highest engine speeds - about 21-23 psi boost max at 7000 RPM. There is little advantage to increasing engine redline to 8000 rpm or above with this turbo because there is only marginally more flow at those engine speeds. TD04H-16T. This compressor is used in the TD04HL turbo and can be mated to a TD04 turbine housing. It has good coverage of demand lines, almost as good as the 15G. It should be capable of slightly higher pressure ratios at mid RPM and a few more cfm at high rpm. There is little advantage to increasing engine redline to 8000 rpm or above with this turbo because there is only marginally more flow at those engine speeds. TD04H-18T. This compressor from a Volvo TD04HL turbo is mated to a TD04 turbine. Inappropriate for a stock engine, it has decent demand line coverage for a modified engine. There could be some spool up or surge problems for high boost at low RPM. There is little advantage to increasing engine redline to 8000 rpm or above with this turbo because there is only marginally more flow at those engine speeds. TD04H-19T. This compressor is used in the TD04HL turbo and can be mated to a TD04 turbine housing. Demand line coverage is excellent for a modified engine. Coverage is better than the TD04H-18T, however, efficiency is generally not as good. This compressor could potentialy allow 24-25 psi boost from 3000 to 8000 RPM with the right exhaust housing and engine modifications. At 7000 RPM, about 450 cfm should be available at 25 psi boost, and about 475 cfm at 8000 RPM at about 24 psi boost. This compressor would be an excellent choice for the 3000GT/Stealth 3.0 L twin-turbo modified engines. TD05H-14B. This stock turbo from 1st generation 2.0 L single-turbo DSM cars has excellent coverage of demand lines for the 3000GT/Stealth 3.0 L twin-turbo modified engines. At 7000 RPM ~400 cfm effective VAF should be attainable at 20 psi boost and ~450 cfm at 25 psi boost. At 8000 RPM, almost 500 cfm should be available at about 25 psi of boost. The compressor efficiency is considerably less than some of the other turbos that flow similarly at in the upper RPM ranges. A different exhaust manifold is required for the TD05H turbine. TD05H-14G. The coverage of engine demand lines is similar to that of the TD04-15G. A different exhaust manifold is required for the TD05H turbine. There is little advantage to increasing engine redline to 8000 rpm or above with this turbo because there is only marginally more flow at those engine speeds. TD05H-16G small wheel. This turbo is a common upgrade for the DSM engine. Demand-line coverage is adequate but shows no advantage over the TD04-15G. A different exhaust manifold is required for the TD05H turbine. TD05H-16G large wheel. This is another common upgrade choice for the DSM cars. The larger 16G wheel is also found in the TD06H housing. In the TD05H housing, efficiency decreases slightly but flow increases favorably for very high boost levels in our engine. At 5000 to 8000 RPM and above, this turbo offers the highest boost levels and so highest flow levels. Real 500 cfm effective VAF should be attainable with this compressor. Only the TD05H-14B comes close to this performance. A different exhaust manifold is required for the TD05H turbine. TD05HR-16G6. This is a new upgrade choice for the DSM cars. This turbo is used in the Mitsubishi Lancer Evolution IV to VIII. I think this same wheel is used in the Evo III (but cast in mirror image?), which uses a standard TD05H-7cm2 turbine housing. The TD05HR turbine rotates reverse (the "R" in the designation) of the standard TD05H and has a twin-scroll design. The compressor inducer is a little larger (0.01") than the "big" 16G. So is this the "biggest" 16G? Max flow is better than the 16G "large wheel". Efficiency is much better than the 16G "large wheel". At 5000 to 8000 RPM and above, this turbo offers very high boost levels and so very high flow levels. Real 530 cfm effective VAF should be attainable with this compressor. A different exhaust manifold is required for the TD05H turbine. TD05H-18G. This flow map is my speculation based on horizontally squeezing and vertically stretching a MHI 20G map. The 16G-large, 18G, and 20G compressor wheels all share the same 2.680" exducer diameter and differ in trim (and perhaps blade design): 50 trim for the 16G-large, 55 trim for the 18G and 60 trim for the 20G. In wheel "families" like this (same exducer size) higher trim usually means more flow and often lower maximum pressure ratio. Sometimes the higher trim wheel may have a bit less maximum efficiency than the lower trim wheel, such as seen in the Garrett T3 series (compare 50-trim and 60-trim wheels). So to make this map I reduced the 20G flow some and increased the maximum PR some. All "G" maps are somewhat similar in appearance so I think this speculative map may be a reasonable guess as to the MHI 18G performance. Coverage of demand lines is not as good as the 14B and 16G-large, but better than with the 20G. However, efficiency is probably better than either of the other 3 wheels. The intersection of the demand lines with the surge line indicates that 20 psi boost may not be reached till about 5500 rpm. This compressor would be good for applications where the engine is in kept in the upper rpm ranges, especially if redline is increased to 8000 rpm or more. A different exhaust manifold is required for the TD05H turbine. TD06H-20G. This flow map is for the 20G wheel in the TD06H housing. As such it is sized too large for our engines. Flow map coverage of demand lines is poor. Perhaps when installed in the TD05H housing flow map coverage improves. Compare the 16G-large flow maps in the "Raw" section above for the TD05H and TD06H housings. Notice that the 16G-large in the TD05H housing has lost some efficiency. However, the character of the pattern has changed to improve demand line coverage and to produce higher maximum pressure ratios. A different exhaust manifold is required for the TD05H turbine. T3 60-Trim. This Garrett compressor and housing is mated to a TD04 exhaust housing in the GT368SX turbo (sold by GT PRO). The GT368SX may also use the T3 Super 60-Trim (the flow maps are very similar). Coverage of demand lines is good overall with very good coverage at the highest RPM, even up to 8000+. Real 450-500 cfm effective VAF should be attainable with this turbo. There could be some spool up or surge problems for high boost at low RPM. IHI RHF55. This is a ball bearing turbo made by IHI and used on Subaru rally cars. Coverage of demand lines is excellent at lower RPM, but the flow limits suggest it may be lacking at higher RPM. I've never seen one used on our cars, and actual performance may be better than the flow limits suggest at higher RPM. A different exhaust manifold is required for the IHI turbine. If somebody has seen one on a VOLVO P.M. me a picture. GT28RS 62-Trim. This is Garrett's "Disco Potato". I had originally thought this turbo's nickname came from the shape of its compressor flow map. Now that manifolds are being made to accept Garrett turbo flanges, the new ball bearing GT series turbos from Garrett can be considered as viable upgrade options for our engines. And the "Disco Potato" would make a good choice. While it cannot reach the lofty pressure ratios of the GT35 48-trim, it should hold 25 psi boost from 5500 to 8000 rpm and has better demand line coverage than the GT35 48-trim. This compressor wheel is similar in size to the T3 60-trim compressor wheel. GT35 48-Trim 71-mm. According to my best information, this Garrett GT35 48-trim compressor wheel in a Garrett T04B housing (with a ball bearing CHRA) is mated to a MHI TD05 7cm2 exhaust housing in the "GT30R" turbo sold by AAM. Coverage of demand lines is good from 5000 RPM and above. Efficiency is excellent where demand lines fall on the flow map. This turbo has the highest maximum PR of any shown here (GT42s excluded), capable of 3.4 PR (about 34 psi boost before pressure losses are accounted for). Over 500 cfm effective VAF should be attainable with this turbo at 8000+ engine RPM. Spool up could be a little slow (5 psi boost at 3000 RPM and 10 psi boost at 4000 RPM). However, 20 psi boost should be available at 5000 RPM, and almost 30 psi boost at 6000 RPM. This may be an excellent drag and high-performance street turbo. GT35 52-Trim 76-mm. The GT35 48-trim 71-mm is a better choice because it has better demand line coverage and efficiency than the 52-trim wheel. Spool up should be faster with the 48-trim. The GT35 52-trim 76-mm, like the MHI 20G, is an example of a compressor than can work for our engines, and sometimes quite well under drag-race conditions, but is sized too large for everyday driving and boost levels. There are other turbos that have similar maximum flow in our engines (500-550 cfm each turbo) that have better demand line coverage and so are better suited for everyday driving where flow levels rarely exceed 400-450 cfm. T4 46-Trim. This Garrett compressor is better suited for 2.0-2.5 L engines. It might be OK for drag race and 8000+ engine RPM use. The GT35 48 Trim, GT28RS 62 Trim, or even the TD05-14B would be better choices. (Thanks to Mr. Lucius of Stealth fame for the Turbo differences) badvlvo wanted a Holset list so here goes. First here is how to read a Holset tag - ![]() (A) Assembly Number Assembly Number for the turbocharger is the most useful number for service purposes. (B) Serial Number Serial Number is unique to your turbocharger. This number can be used to identify which turbocharger you have. (C) Part Number Part Number is the number given to the turbocharger by the engine manufacturer. This number will be in all the engine manufacturers' books. There may be more than one Part Number for each Assembly Number (A). (D) Turbocharger Type Turbocharger Type describes the model or frame size of your Holset turbocharger. Some quick little things about Holset turbo's - Holset turbo's are designed to handle HIGH RPM's, it should also be noted that Holset's make an incredible amount of BOOST. They sky is the limit with Holset turbo's. An H1C & HX35 have the exact same turbine wheels. As does the H1E & HX40. The X in HX signifies it being a divorced housing (split housing) turbo an HY is single entry. The biggest differences were that the older turbos rarely came with internal wastegates where the later HX series were more wastegated than not (mostly on the HX35) the HX also have the ported shroud compressor covers (aka "anti surge" housings). The 16cm and up housings were never offered with a wastegate. Another thing to know is HX35, HX40 etc. is a frame size. Much like Garrett with their T3, T4, T6 designations. There could be several different compressor wheel options offered within that frame size. this is most common with the H1E & HX40. The most sought after HX40 is the 6 blade compressor wheel which is commonly found on the VOLVO HX40's it flows quite a bit more than the standard 7 or 8 blade wheels. The Holset Turbo models are - H1C, H1E, H2C, H2D, H2E, HX30, HX35, HX40, HX50, HX55, HX60W, HX80 & HX82. The easiest way to get Holset turbo's cheap is...go to your local pick-a-part find a Turbo diesel Dodge and yank it. Here is a handy little guide from Adam to find them. H1C - The H1C turbo was used from 1989-1993. They have a BOOST range of 15-25 PSI. The wastegates range from 17-22 PSI. WH1C - The WH1C turbo was used for 1 year. 1994. It has a BOOST range of 15-18 PSI, with a wastegate PSI of 17. HX35W - The HX35W is the longest-lived Holset Turbo. It was used from 1994 until well...you can still find them in some Dodges. It has a BOOST range of 15-23 PSI. The wastegate ranges from 17-26 PSI. HY35W - Another 1 year only turbo. This one deserves a special merit for the fact that it has a 9 sq. cm. Turbine Housing! That is tiny folks! It has a max BOOST of 20.5 PSI. The wastegate is set at 23 PSI. That's it for now. I'll finish the Holset later... For the giant O.E.M. guide - Here are the Euro-Spec vehicles to find Turbo's in. It is listed as Manufacturer, Model, Engine, Year & Turbo Type. Make Model Engine Year Turbo Type ALFA ROMEO 33 1.8L D 89-94 K14 ALFA ROMEO 75 1.8L P 86-88 TB0353 ALFA ROMEO 75 2.0L D 84-86 K16 ALFA ROMEO 75 2.0L D 86-88 K16 ALFA ROMEO 90 2.4L D 86-89 K16 ALFA ROMEO 146 2.0L P 99-01 RHB52R ALFA ROMEO 146 2.0LP 99-01 RHB52R ALFA ROMEO 156 1.9L D 02- GT1749V ALFA ROMEO 156 2.4L D 01 - GT2256V ALFA ROMEO 164 2.5L D 92-97 K06 ALFA ROMEO 164 2.0L P 87 - TB0338 ALFA ROMEO 164 2.4L D 87-91 K16 ALFA ROMEO 164 2.5L D 91 - TD05H-12B-6 ALFA ROMEO 166 2.4L D 01 - GT2256V ALFA ROMEO 146 JTD - 108HP 1.9L D 00 - GT1749V ALFA ROMEO 146 JTD - 108HP 1.9L D 00- GT1749V ALFA ROMEO 146JDT-105HP 1.9L D 99 - GT1544H ALFA ROMEO 147 JTD - 115HP 1.9L D 02- GT1749V ALFA ROMEO 147 JTD - 115HP 1.9L D 04- GT1749V ALFA ROMEO 147 JTD - 140HP 1.9L D 02 - GT1749 ALFA ROMEO 147 JTD 8V 1.9L D 05- GT1749MV ALFA ROMEO 155 16V 2.0L P 92-96 TB0367 ALFA ROMEO 156 - 115HP 1.9L D 00 - GT1749V ALFA ROMEO 156 - 136HP 2.4L D 01 - GT2256V ALFA ROMEO 156 - 136HP 2.4L D 98-01 VNT25 ALFA ROMEO 156 - 136HP 2.4L D 98-01 VNT25 ALFA ROMEO 156 JTD 2.4L D 03- GT2256V ALFA ROMEO 156 JTD - 175HP 2.4L D 03 - GT2256V ALFA ROMEO 164 GTV 2.0L P 94 - TB2538 ALFA ROMEO 166 - 136HP 2.4L D 98-01 VNT25 ALFA ROMEO 166 JTD 2.4L D 02- GT2256V ALFA ROMEO 166JTD - 136HP 2.4L D 01 - GT2256V ALFA ROMEO 166JTD - 175HP 2.4L D 03- GT2256V AUDI 80 1.6L D 86-90 TA0304 AUDI 80 1.6L D 81-82 TA0304 AUDI 80 1.6L D 83-86 K24 AUDI 80 1.6L D 84-86 TA0304 AUDI 80 1.6L D 87-91 TB0218 AUDI 100 2.0L P 81-83 K24 AUDI 100 2.0L D 83-86 K24 AUDI 100 2.0L D 86-89 K24 AUDI 100 TDI 2.5L D 89-91 K16 AUDI 100 TDI 2.5L D 91-92 K16 AUDI 100 TDI - 115HP 2.5L D 81-95 K16 AUDI 100 TDI - 140HP 2.5L D 94-95 K14 AUDI 100 S4 - 220HP 2.2L P 91-94 K24 AUDI 100/200 TURBO 2.0L P 88-91 K24 AUDI 200 5T 2.0L P 81-83 K26 AUDI 200 QUATTRO 2.0L P 83-89 K26 AUDI 200 QUATTRO 20V 2.0L P 89-91 K24 AUDI 200 TURBO II 2.0L P 82-84 K26 AUDI 200 TURBO III 2.0L P 84-89 K26 AUDI 80 RS2 2.2L P 93-95 K24 AUDI 80 TD - 75HP 1.9L D 91-94 K14 AUDI 80 TDI - 90HP 1.9L D 91-94 TB0268 AUDI 80 TDI - 90HP 1.9L D 94-95 GT1544S AUDI A2 TDI 1.4L D 00 - GT1544S AUDI A2 TDI 1.2L D 01- GT1541V AUDI A2 TDI - 90HP 1.4L D 4 BV39 AUDI A3 1.8T - 150HP 1.8L P 97-98 K03 AUDI A3 1.8T - 150HP 1.8L P 00 - K03 AUDI A3 1.8T - 180HP 1.8L P 98 - K03 AUDI A3 1.8T - 180HP 1.8L P 00 - K03 AUDI A3 1.8T UPGRADED 1.8L P 97 - K04 AUDI A3 1.8TFSI- 180HP 1.8L P 05- K03 AUDI A3 TDI - 100HP 1.9L D 01- KP39 AUDI A3 TDI - 100HP 1.9L D 02- GT1749V AUDI A3 TDI - 100HP 1.9L D 02- KP39 AUDI A3 TDI - 105HP 1.9L D 03- KP39 AUDI A3 TDI - 110HP 1.9L D 98 - GT1749V AUDI A3 TDI - 110HP 1.9L D 99-01 GT1749V AUDI A3 TDI - 110HP 1.9L D 97 - VNT15 AUDI A3 TDI - 110HP 1.9L D 00 - GT1749V AUDI A3 TDI - 115HP 1.9L D 00 - GT1749V AUDI A3 TDI - 130HP 1.9L D 00 -01 GT1749V AUDI A3 TDI - 130HP 1.9L D 01 - GT1749V AUDI A3 TDI - 130HP 1.9L D 00-03 GT1749V AUDI A3 TDI - 130HP 1.9L D 00 - GT1749V AUDI A3 TDI - 138HP 2.0L D 03- GT1749V AUDI A3 TDI - 150HP 1.9L D 01 - GT1749V AUDI A3 TDI - 150HP 1.9L D 00 - GT1749V AUDI A3 TDI - 90HP 1.9L D 97-01 GT15 AUDI A3 TDI - 90HP 1.9L D 97-01 K03 AUDI A4 - 90HP 1.9L D 95 - GT15 AUDI A4 1.8T - 150HP 1.8L P 95-99 K03 AUDI A4 1.8T - 150HP 1.8L P 99 - K03 AUDI A4 1.8T - 150HP 1.8L P 99 - K03 AUDI A4 1.8T - 150HP 1.8L P 01- K03 AUDI A4 1.8T QUATTRO - 190HP 1.8L P 03- K03 AUDI A4 1.8T UPGRADED 1.8L P 95 - K04 AUDI A4 2.0 TFSI - 200HP 2.0L P 04- K03 AUDI A4 2.0 TFSI - 200HP 2.0L P 39236 K03 AUDI A4 2.0 TFSI - 200HP 2.0L P 05- K03 AUDI A4 2.0 TFSI - 200HP 2.0L P 05- K03 AUDI A4 TDI - 110HP 1.9L D 97 - VNT15 AUDI A4 TDI - 110HP 1.9L D 00 - GT1749V S2 AUDI A4 TDI - 110HP 1.9L D 97 - VNT15 AUDI A4 TDI - 115HP 1.9L D 00-01 GT1749V AUDI A4 TDI - 130HP 1.9L D 00 - GT1749V AUDI A4 TDI - 130HP 1.9L D 00 - GT1749V AUDI A4 TDI - 130HP 1.9L D 01 - GT1749V AUDI A4 TDI - 130HP 2.5L D 00 - GT1749V AUDI A4 TDI - 150HP 2.5L D 97 - GT2052V AUDI A4 TDI - 150HP 2.5L D 97 - GT2052V AUDI A4 TDI - 90HP 1.9L D 97 - K03 AUDI A4 TDI QUATTRO - 180HP 2.5L D 03 - GT2052V AUDI A6 1.8T - 150HP 1.8L P 97-99 K03 AUDI A6 1.8T - 150HP 1.8L P 99 - K03 AUDI A6 1.8T - 150HP 1.8L P 99 - K03 AUDI A6 2.7T QUATTRO - 230HP 2.7L P 99-02 K03 AUDI A6 2.7T QUATTRO - 230HP 2.7L P 99-02 K03 AUDI A6 2.7T QUATTRO - 250HP 2.7L P 03- K03 AUDI A6 2.7T QUATTRO - 250HP 2.7L P 03- K03 AUDI A6 TDI - 110HP 1.9L D 97 - VNT15 AUDI A6 TDI - 110HP 1.9L D 00 - GT1749V S2 AUDI A6 TDI - 110HP 1.9L D 97 - VNT15 AUDI A6 TDI - 115HP 2.5L D 98 - K14 AUDI A6 TDI - 130HP 2.5L D 00 - GT1749V AUDI A6 TDI - 130HP 1.9L D 01 - GT1749V AUDI A6 TDI - 140HP 2.5L D 96-98 K14 AUDI A6 TDI - 150HP 2.5L D 97 - GT2052V AUDI A6 TDI - 90HP 1.9L D 94-95 GT1544S AUDI A6 TDI - QUATTRO 180HP 2.5L D 97 - GT2052V AUDI A8 TDI - 150HP 2.5L D 97 - GT2052V AUDI A8 TDI - 220HP 3.3L D 99 - GT1749V AUDI A8 TDI - 220HP 3.3L D 99 - GT1749V AUDI A8 TDI - 220HP L 3.3L D 99 - GT1749V AUDI A8 TDI - 220HP R 3.3L D 99 - GT1749V AUDI ALLROAD 2.7L P 03 - K03 AUDI ALLROAD - 180HP 2.5L D 03- GT2052V AUDI AUDI TT 1.8L P 02- K04 AUDI AUDI TT 1.8L P 02- K04 AUDI QUATTRO 20V 2.0L P 89-91 K24 AUDI QUATTRO SPORT 2.0L P 83-89 K27 AUDI RS4 BI TURBO N/SIDE 2.7L P 00 - K04 AUDI RS4 BI TURBO O/SIDE 2.7L P 00- K04 AUDI RS6 BI TURBO N/SIDE - 450HP 4.2L P 02- K04 AUDI RS6 BI TURBO O/SIDE - 450HP 4.2L P 02- K04 AUDI S3 - 210HP 1.8L P 99-02 K04 AUDI S3 - 210HP 1.8L P 00-02 K04 AUDI S3 - 225HP 1.8L P 01- K04 AUDI S3 2.0 TFSI- 265HP 2.0L P 06- K04 AUDI S4 BI TURBO N/SIDE 2.7L P 98 - K03 AUDI S4 BI TURBO O/SIDE 2.7L P 98 - K03 AUDI TT 1.8T - 180HP 1.8L P 98 - K03 AUDI TT 1.8T - 180HP 1.8L P 00 - K03 AUDI TT QUATTRO - 225HP 1.8L P 99 - K04 AUDI TT SPORT TFSI - 265HP 2.0L P 06- K04 AWD - BEDFORD MIDI 2.2L D 88-93 RHB52A AWD - BEDFORD MIDI 2.4L D 94 - RHF5 Make Model Engine Year Turbo Type BMW 320 3.0LD 5 GT1749V BMW 320 2.0L D 99 - VNT15 BMW 524 ~ ~ TD04-115-4 BMW 730 2.9 2003- GT2556V BMW 120d 2.0L D 05- GT1749V BMW 120d 2.0L D 06- GT1749V BMW 318TDS & COMP 1.7L D 95 - GT15S BMW 320d 2.0L D 06- GT1749V BMW 320d 2.0L D 03- GT1749V BMW 320D - 150HP 2.0L D 03- GT1749V BMW 320TD Compact - 150HP 2.0L D 01 - GT1749V BMW 324TD 2.4L D 87-91 TD04-11B-4 BMW 324TD 2.4L D 89-93 TB2514 BMW 324TD / 524TD 2.4L D 83-87 TB0324 BMW 325TD 2.5L D 93-95 TD04-11G-4 BMW 325TD / 525TD 2.5L D 91 - TD04-11G-4 BMW 325TDS 2.5L D 95 - TB2514 BMW 325TDS 2.5L D 93 - TD04-11G-5 BMW 330D - 184HP 3.0L D 00 - GT2256V BMW 330d - 184HP 3.0L D 05- GT2260V BMW 520D - 136HP 2.0L D 00 - GT1549V BMW 520D - 150HP 2.0L D 01- GT1749V BMW 524TD 2.4L D 87-91 TD04-11B-4 BMW 525D 2.5L D 00 - GT2052V BMW 525TD 2.5L D 96-98 TD04-13GT-4 BMW 525TD 2.5L D 93 - TD04-11G-4 BMW 525TD 2.5L D 94 - TD04-11G-4 BMW 525TD 2.5L D 94 - TD04-11G-4 BMW 525TD 2.5L D 94 - TD04-13T-4 BMW 525TDS 2.5L D 96 - TD04-13T-4 BMW 525TDS 2.5L D 91-92 TD04-11G-5 BMW 525TDS 2.5L D 92 - TB2514 BMW 525TDS 2.5L D 93-96 TD04-11G-5 BMW 530D 2.9L D ~ ~ BMW 530D / 730D - 184HP 2.9L D 99 - GT2556V BMW 725TDS 2.5L D 96 - TD04-13T-4 BMW 730D 3.0L D 03 - GT2556V BMW 730d 3.0L D 03- GT2256V BMW 730d 3.0L D 05- GT2256V BMW 730d 3.0L D 03- GT2260V BMW 740d 4.0L D 05- GT1749V BMW 740d 3.9L D 04- GT1749V BMW 740D TWIN TURBO 3.9L D 00 - GT1749V BMW 740D TWIN TURBO 3.9L D 00 - GT1749V BMW 740D TWIN TURBO 4.0L D 01 - GT1749V BMW 740D TWIN TURBO 4.0L D 01 - GT1749V BMW X5 3.0L D 00 - GT2056V BMW X5 3.0L D 04- GT2260V BMW X5 3.0L D 06- GT2260V BMW X5 3.0L D 03- GT2260V C1 206 Hdi - 110HP 1.6L D 05- GT1544V CHRYSLER CHEROKEE 2.5 L D 93 - RHB51P CHRYSLER CHEROKEE 2.5L D 93-98 RHB51P CHRYSLER CHEROKEE 2.5L D 93-98 RHB51P CHRYSLER CHEROKEE 2.5L D ~ RHB51P CHRYSLER GRAND CHEROKEE 2.5L D 98 - TF035HL-13T-6 CHRYSLER GRAND CHEROKEE 2.7L D 03- GT2256V CHRYSLER GRAND VOYAGER 2.8L D ~ IHI CHRYSLER PLYMOUTH 2.5L P 88-95 TE04H-13C-6 CHRYSLER PT CRUISER 2.2L D 05- GTB1752VK CHRYSLER PT CRUISER 2.2L D 02 - RHF4H CHRYSLER VOYAGER 2.5L D 96-01 RHB51P CHRYSLER VOYAGER 2.5L D 97 - RHB51P CHRYSLER VOYAGER 2.5L D 01- RHBF5 CHRYSLER VOYAGER 2.5L D 94-96 K04 CHRYSLER VOYAGER 2.5L D ~ RHB51P CHRYSLER VOYAGER 2.5L D 96 - K06 CHRYSLER VOYAGER ~ ~ ~ CITROEN BERLINGO MULTISPACE - HDI 2.0L D 99 - GT1546S CITROEN BERLINGO MULTISPACE - HDI 2.0L D 99 - GT1546S CITROEN BX 1.7L D 88-92 TB0234 CITROEN BX 1.7L D 92-93 TB0234 CITROEN BX 1.7L D 87-88 K14 CITROEN BX 1.7L D 88-89 K14 CITROEN BX 1.7L D 89-92 K14 CITROEN BX 1.7L D 92-93 K14 CITROEN C2 HDI - 70HP 1.4L D 03 - K35 CITROEN C25 VAN 2.5L D 87 - TB2513 CITROEN C3 HDI - 70HP 1.4L D 03 - K35 CITROEN C3 HDI - 70HP 1.4L D 02- RHF3 CITROEN C4 Hdi - 136HP 2.0L D 06- GT1749V CITROEN C5 2.2L D 00 - GT1549P CITROEN C5 - 136HP 2.2L D 01 - GT1549P CITROEN C5 HDI - 110HP 2.0L D 00 - K03 CITROEN C5 HDI - 110HP 2.0L D 01- K03 CITROEN C5 Hdi - 136HP 2.0L D 06- GT1749V CITROEN C5 HDI - 90HP 2.0L D 99 - GT1546S CITROEN C8 HDI - 110HP 2.0L D 01- K03 CITROEN C8 HDI - 110HP 2.0L D 01- K03 CITROEN C8 HDI - 136HP 2.2L D 03 - GT1549P CITROEN CX GTI 2.5L P 86-90 TC0304 CITROEN CX TURBO II 2.5L D 87-90 TB2508 CITROEN CX25D 2.5L D 83-86 TA0306 CITROEN CX25D 2.5L D 86-90 TA0306 CITROEN DISPATCH - 90HP 1.9L D 95 - TB02 CITROEN DISPATCH/RELAY 1.9L D 94 - K14 CITROEN DISPATCH/RELAY HDI 2.0L D 00- GT1546S CITROEN EVASION/SYNERGIE 2.1L D 97 - GT1549 CITROEN EVASION/SYNERGIE - 110HP 2.0L D 99 - GT1546 CITROEN EVASION/SYNERGIE - 110HP 2.0L D 01 - GT1549P CITROEN EVASION/SYNERGIE - 110HP 2.1L D 96-98 T2 CITROEN EVASION/SYNERGIE - 110HP 2.1L D 98 - GT1549 CITROEN EVASION/SYNERGIE - 136HP 2.2L D 01 - GT1549P CITROEN EVASION/SYNERGIE - 90HP 1.9L D 95 - TB0280 CITROEN JUMPER 2.0L D 01- K03 CITROEN JUMPER 2.8L D 01- K03 CITROEN RELAY 2.5L D 94-98 K14 CITROEN RELAY 2.5L D 98 - K16 CITROEN RELAY HDI 2.8L D 01- K03 CITROEN RELAY HDI 2.8L D 03- K03 CITROEN RELAY HDI 2.0L D 02- K03 CITROEN RELAY HDI 2.2L D 02- K03 CITROEN XANTIA 1.9L D 93-96 K14 CITROEN XANTIA 1.9L D 97 - K04 CITROEN XANTIA - 110HP 2.1L D 95-97 TB0288 CITROEN XANTIA - 110HP 2.1L D 97 - GT1549 CITROEN XANTIA - 71HP 1.9L D 93 - TB0272 CITROEN XANTIA - 71HP 1.9L D 93 - K14 CITROEN XANTIA - 75HP 1.9L D 96 - K04 CITROEN XANTIA - 92HP 1.9L D 95 - K14 CITROEN XANTIA - 92HP 1.9L D 96 - TB0289 CITROEN XANTIA - 92HP 1.9L D 98 - GT1549 CITROEN XANTIA - 92HP 1.9L D 95 - TB0281 CITROEN XANTIA ACTIVA - 150HP 2.0L P 96 - TB25 CITROEN XANTIA HDI - 109HP 2.0L D 99 - K03 CITROEN XANTIA HDI - 109HP 2.0L D 99 - K03 CITROEN XANTIA HDI - 90HP 2.0L D 99 - GT1546S CITROEN XANTIA HDI - 90HP 2.0L D 99 - K03 CITROEN XANTIA HDI - 90HP 2.0L D 99 - GT1546 CITROEN XM 2.0L P 93-95 TB2567 CITROEN XM - 110HP 2.1L D 90-93 TD04-11B-5 CITROEN XM - 110HP 2.1L D 90 - TB0251 CITROEN XM - 130HP 2.5L D 94 - TB0278 CITROEN XM - 150HP 2.0L P 95 - TB25 CITROEN XSARA - 90HP 1.9L D 98 - K03 CITROEN XSARA - 90HP 1.9L D 98 - GT1549 CITROEN XSARA HDI - 110HP 2.0L D 00- K03 CITROEN XSARA HDI - 110HP 2.0L D 03 - K03 CITROEN XSARA HDI - 90HP 2.0L D 99 - GT1546S CITROEN XSARA HDI - 90HP 2.0L D 99 - K03 CITROEN XSARA PICASSO HDI - 110HP 1.6L D 04- GT1544V CITROEN XSARA PICASSO Hdi -110HP 1.6L D 04- GT1544V CITROEN XSARA PICASSO HDI-90HP 2.0L D 00 - GT1546S CITROEN ZX 1.9L D 92-96 TB0265 CITROEN ZX 1.9L D 92-96 K14 CITROEN ZX 1.9L D 96-98 K04 CITROEN ZX 1.9L D 97 - K04 DAIHATSU CHARADE 1.0L P 84-86 RHB32A DAIHATSU CHARADE 1.0L D 85-93 ASIN DAIHATSU CHARADE G100 1.0L P 87-88 RHB32A DAIHATSU CHARADE GTTI 1.0L P 88-89 RHB51 DAIHATSU CHARADE GTTI 1.0L P 87-88 RHB32A DAIHATSU CHARADE GTTI 1.0L P 87-88 RHB32A DAIHATSU CHARADE GTTI 1.0L P 87-88 RHB51 DAIHATSU FOURTRAK 2.8L D 84-87 RHB6D DAIHATSU FOURTRAK 2.8L D 87-90 RHB52 DAIHATSU FOURTRAK 2.8L D 90 - RHB52W DAIHATSU FOURTRAK 2.8L D 98 - RHF5 Make Model Engine Year Turbo Type FERRARI 208GTB 2.8L P 81 - K26 FERRARI GTO 2.8L P 84- RHB52F FIAT BRAVA/BRAVO/MAREA - 100HP 1.9L D 97 - GT1544 FIAT BRAVA/BRAVO/MAREA - 100HP 1.9L D 99 - GT1544H FIAT BRAVA/BRAVO/MAREA - 100HP 1.9L D 98 - GT1544 FIAT BRAVA/BRAVO/MAREA - 100HP 1.9L D 96 - GT1544 FIAT BRAVA/BRAVO/MAREA - 100HP 1.9L D 96 - GT1544 FIAT BRAVA/BRAVO/MAREA - 100HP 1.9L D 99 - GT1544H FIAT BRAVA/BRAVO/MAREA - 105HP 1.9L D 00 - GT1544S FIAT BRAVA/BRAVO/MAREA - 75HP 1.9L D 97 - GT1544 FIAT COUPE 20V - 220HP 2.0L P 97 - TB2810 FIAT CROMA 1.9L D 93 - TD2502/VNT FIAT CROMA 8V 2.0L P 91-92 TB0338 FIAT CROMA 8V 2.0L P 91-92 TB0367 FIAT CROMA DS 2.5L D 85-87 TA0316 FIAT CROMA DS 2.5L D 87-92 TA0316 FIAT CROMA ID 2.0L D 87-92 TD04-09B-4 FIAT CROMA ID 1.9L D 91-92 TD2502/VNT FIAT CROMA IE 2.0L P 85-86 TB0338 FIAT CROMA IE 2.0L P 86-87 TB0338 FIAT CROMA IE 2.0L P 87-88 TB0367 FIAT CROMA IE 2.0L P 88 -91 TB0338 FIAT DOBLO JTD 1.9L D 00 - GT1544S FIAT DUCATO 2.5L D 93 - K14 FIAT DUCATO 1.9L D 94 - TB0269 FIAT DUCATO 1.9L D 92 - TB0267 FIAT DUCATO 1.9L D 88 - TD04-07B-4 FIAT DUCATO 1.9L D 96 - GT1544H FIAT DUCATO 2.5L D 89 - K26 FIAT DUCATO 2.8L D 97 - TF035HM13T6 FIAT DUCATO 2.8L D 99 - TD04L FIAT DUCATO 2.8L D 99 - TD04L FIAT DUCATO - 115HP 2.8L D 96 - GT1752H FIAT DUCATO - 116HP 2.8L D 98 - K14 FIAT DUCATO EURO III 2.8L D 99- TD04L FIAT DUCATO EURO III 2.8L D 99- TD04L FIAT DUCATO EURO III - 125HP 2.8L D 99 - K03 FIAT DUCATO JTD - 110HP 2.3L D 03- k03 FIAT DUCATO JTD - 110HP 2.3L D 01 - K03 FIAT DUCATO JTD - 125HP 2.8L D 04- GT2256V FIAT DUCATO JTD - 84HP 2.0L D 01 - K03 FIAT DUCATO MAXI 2.5L D 89 - K14 FIAT DUCATO MAXI 2.5L D 93 - TB2534 FIAT DUCATO MAXI 2.5L D 93 - TB2534 FIAT DUCATO SEVEL 2.5L D 94 - TB2509 FIAT FERINO 1.7L D 88-94 TB0227 FIAT MAREA 1.9L D 97 - RHB52G FIAT MAREA JTD - 110HP 1.9L D 01 - GT1749V FIAT MAREA JTD - 130HP ~ 99- RHF5 FIAT MULTIPLA JTD - 105HP 1.9L D 99- GT1544H FIAT MULTIPLA JTD - 110HP 1.9L D 02- GT1544S FIAT MULTIPLA JTD - 115HP 1.9L D 00 - GT1749V FIAT PUNTO 1.4L P 95 - RHB52PW FIAT PUNTO 1.7L D 94 - TB0227 FIAT PUNTO 1.3L D 03 - K35 FIAT PUNTO 1.3L D 03- K35 FIAT PUNTO DS 1.7L D 94 - TB0227 FIAT PUNTO JTD 1.9L D 00 - GT1749V FIAT PUNTO TD 1.9L D 99 - RHF3H FIAT PUNTO TD 1.9L D 96 - GT1544S FIAT RITMO/REGATA 1.9L D 84-87 K16 FIAT RITMO/REGATA 1.9L D 86-90 TB0232 FIAT RITMO/REGATA 1.9L D 87-90 K16 FIAT S'COUPE 2.0L P 95 - TB0367 FIAT SCUDO 1.9L D 95 - TB0280 FIAT SCUDO JTD - 110HP 2.0L D ~ GT1546 FIAT STILO JTD - 115HP 1.9L D 01 - GT1749V FIAT STILO JTD - 120HP 1.9L D 04- GT1749MV FIAT STILO JTD - 120HP 1.9L D 04- GT1749MV FIAT STILO JTD - 120HP 1.9L D 5 GT1749MV FIAT STILO JTD - 140HP 1.9L D 03- GT1749V FIAT TIPO 1.9L D 94 - GT1544 FIAT TIPO 1.9L D 96 - GT1544S FIAT TIPO TD 1.9L D 90-94 TB0232 FIAT TIPO/REGATA 1.9L D 87-93 K16 FIAT TIPO/TEMPRA 1.9L D 95 - TB0269 FIAT TIPO/TEMPRA 1.9L D 90-94 TB0232 FIAT ULYSSE 2.1L D 96-98 T2 FIAT ULYSSE 2.1L D 98 - GT1549 FIAT ULYSSE 1.9L D 95 - TB0280 FIAT ULYSSE JTD - 110HP 2.0L D 99 - GT1546S FIAT ULYSSE JTD - 110HP 2.0L D 01 - GT1549S FIAT ULYSSE JTD - 136HP 2.2L D 01 - GT1549P FIAT UNO 1.3L P 91-94 RHB52P FIAT UNO 1.3L P 85-90 RHB52W FIAT UNO 1.3L P 89-94 RHB52W FIAT UNO 1.7L D 86-88 TB0227 FIAT UNO 1.7L D 88-94 TB0227 FIAT UNO 115HP IE 1.3L P 89-94 TB0245 FIAT IVECO DAILY 2.5L D 86 - TA0302 FIAT IVECO DAILY 2.5L D 86 - TA0302 FIAT IVECO DAILY 2.5L D 88 - K26 FIAT IVECO DAILY 2.5L D 91 - K14 FIAT IVECO DAILY 2.8L D 97 - K14 FIAT IVECO DAILY - 100HP 2.5L D 88 - K14 FIAT IVECO DAILY - 117HP 2.5L D 89 - K14 FIAT IVECO DAILY 40.10 2.5L D 87 - TA0302 FIAT IVECO DAILY II 2.8L D 96 - TF035HM-31T-6 FIAT IVECO DAILY II 2.8L D 96 - TF035HM-31T-6 FIAT IVECO DAILY II 2.8L D 96- TF035HM-31T-6 FIAT IVECO DAILY II - 103HP 2.8L D 96 - TF035HM-31T-6 FIAT IVECO DAILY II - 115HP 2.8L D 96 - GT1752H FIAT IVECO DAILY II - 122HP 2.8L D 96 - TF035HM-31T-6 FIAT IVECO DAILY III - 105HP 2.8L D 99 - K03 FIAT IVECO DAILY III - 105HP 2.8L D 03- K03 FIAT IVECO DAILY III - 110HP 2.3L D 03- K03 FIAT IVECO DAILY III - 110HP 2.3L D 03- K03 FIAT IVECO DAILY III - 110HP 2.3L D 02- K03 FIAT IVECO DAILY III - 125HP 2.8L D 99 - GT2056S FIAT IVECO DAILY III - 125HP 2.8L D 04- GT2256V FIAT IVECO DAILY III - 125HP 2.8L D 99 - K03 FIAT IVECO DAILY III - 125HP 2.8L D 03- K03 FIAT IVECO DAILY III - 135HP 2.8L D 00 - GT2256V FIAT IVECO DAILY III - 140HP 2.8L D 04- GT2256V FIAT IVECO DAILY TC - 100HP 2.5L D 92 - TB2509 FIAT IVECO DAILY TCA 2.5L D 92 - TB2509 FIAT IVECO DAILY TCA - 115HP 2.5L D 92 - TB2509 FIAT IVECO DUCATO EURO III 2.8L D 99 - TD04L FIAT IVECO DUCATO JTD EURO III 2.8L D 00 - TD04L FIAT IVECO S2000 78KW ~ ~ TD04L FIAT IVECO S2000 92KW ~ ~ TD04L FORD ESCORT (ENDURA) Tdi 1.8L D 96 - GT1544 FORD ESCORT COSWORTH 2.0L P 92-96 TB3403 FORD ESCORT COSWORTH RALLY 2.0L P 92-94 - TB2807 FORD ESCORT RS MK3 (air cooled)) 1.6L P 84-86 TB0345 FORD ESCORT RS MK4 (water cooled) 1.6L P 86-91 TB0355 FORD ESCORT TD 1.8L D 93 - TB0259 FORD FIESTA RS 1.6L P 90-92 TB0250 FORD FIESTA TD di / COURIER 1.8L D 00 - GT1544Z FORD FIESTA TDCi 1.4L D 02 - KP35 FORD FOCUS 1.6L D 04 - GT1544V FORD FOCUS C-MAX 2.0L D 05- GT1749V FORD FOCUS RS - 215HP 2.0L P 02- GT2560LS FORD FOCUS ST 2.5L P 06- K04 FORD FOCUS TD ci - 115HP 1.8L D 01 - GT1749V FORD FOCUS TD di - 90HP 1.8L D 99 - GT15 FORD FOCUS Tdi - 75HP 1.8L D 98 - GT1544S FORD FUSION TDCi 1.4L D 03- K35 FORD GALAXY 1.9L D 93 - K03 FORD GALAXY - 90HP 1.9L D 95 - GT15S FORD GALAXY 110 BHP 1.9L D 96-97 VNT15 FORD GALAXY 110 BHP 1.9L D 97 - GT1749V FORD GALAXY Tdi - 115HP 1.9L D 00- GT1749V FORD GALAXY Tdi - 130HP 1.9L D 02- GT1749V FORD GALAXY Tdi - 130HP 1.9L D 03- BV39 FORD GALAXY Tdi - 130HP 1.9L D 02- GT1749V FORD GALAXY TDI 115HP 1.9L D 01- GT1749V FORD GRANADA 2.5L D 90-93 TA0302 FORD GRANADA/SCORPIO 2.5L D 93 - RHB51P FORD GRANADA/SCORPIO 2.5L D ~ RHB51P FORD MAVERICK - 100HP 2.7L D 93-97 TB2557 FORD MAVERICK - 125HP 2.7L D 97 - TB2557 FORD MONDEO 2.0TDCI 03- GT1749V FORD MONDEO 1.8L D 93 - TB0273 FORD MONDEO (ENDURA) 1.8L D 96 - GT1544 FORD MONDEO di - 115HP 2.0L D 01 - GT1749V FORD MONDEO TD ci - 130HP 2.0L D 01 - GT1749V FORD MONDEO TD ci - 90 &115HP 2.0L D 01- GT2049S FORD MONDEO Tdci - 130HP 2.0L D 06- GT1749V FORD PROBE 2.0L P 94 - RHB52 FORD RANGER 2.5LD 99- RHF5 FORD RANGER 2.8L D 02- GT2256V FORD RANGER DOUBLE CAB 2.5L D 99 - RHF5 FORD RANGER DOUBLE CAB 2.5L D 99 - RHF5 FORD SIERRA 4X4 COSWORTH 2.0L P 89-90 TB0384 FORD SIERRA 4X4 COSWORTH 2.0L P 90-93 TB0384 FORD SIERRA COSWORTH 2WD 2.0L P 86-89 TB0361 FORD SIERRA COSWORTH RS500 2.0L P 87-89 T3/TO4E FORD SIERRA/P100 PICK UP 1.8L D 89-93 TB0237 FORD TRANSIT CONNECT 1.8L D 99- GT15 FORD TRANSIT DI 2.5L D 92 - K04 FORD TRANSIT DI 2.5L D 99 - K04 FORD TRANSIT DI 2.5L D 94 - K04 FORD TRANSIT DI 125HP 2.0L D 02 - GT1749V FORD TRANSIT DI 85/100HP 2.0L D 01- GT2049S FORD TRANSIT DI TCI 2.5L D 96 - K04 FORD TRANSIT RETRO 2.5L D 88 - TB0238 FORD TRANSIT TDI 2.4L D 00 - TF035 FORD TRANSIT TDI 2.2L D 0 TF035 FORD TRANSIT TDI 2.4L D 0 TF035 FORD TRANSIT TDI 2.4L D 0 TF035 FORD TRANSIT TDI 125HP 2.4L D 00- TF035 FORD TRANSIT TDI 125HP 2.4L D 1 TFO35 FORD TRANSIT TDI 75HP 2.0L D 00 - GT2049S FORD TRANSIT TDI -85 & 100HP 2.0L D 00 - GT2049S FORD TRANSIT TDI 90HP 2.4L D 00 - TF035 HONDA ACCORD / CIVIC 2.0L D 97 - GT1549 HONDA ACCORD Cdti 2.2L D 6 ~ HONDA ACCORD CT di 2.2L D 03 - GT1752V HONDA CIVIC CT di 1.7L D 02 - GT1749V HONDA CR-V 2.2L D 04- GT1752V HONDA CRVDT 2.2LD 4 GT1752V HYUNDAI LANTRA 2.0LD 3 MHI HYUNDAI S/COUPE 1.5L P 92-96 TB1501 HYUNDAI SANTA FE/TRAJET 2.0L D 05- GT1749S HYUNDAI SORENTO 2.5L D 02- GT1752S HYUNDAI STAREX ~ 02- TD025 HYUNDAI TRAJET 2.0L D CRD 02- TD025 HYUNDAI VAN/LIGHT TRUCK 2.5L D 01- GT1749S HYUNDAI VAN/LIGHT TRUCK 3.3L D 94 - GT1749S HYUNDAI VAN/LIGHT TRUCK H100/H200 2.5L D 96 - GT1749S HYUNDAI VAN/LIGHT TRUCK H200 2.5L D 01- TF035 ISUZU PIAZZA 2.0L P 86-87 RHB52 ISUZU PIAZZA 2.0L P 86-90 RHB52 ISUZU PICK UP 2.5L D 95 - RHF5B ISUZU PICK UP 2.5L D 02- RHF5 ISUZU RODEO PICKUP 2.5L D 04- ~ ISUZU RODEO PICKUP 3.0L D 04- ~ ISUZU TROOPER 2.8L D 88-91 RHB52 ISUZU TROOPER 3.1L D IMPORT RHF5B ISUZU TROOPER 2.2L D 85-87 TB0209 ISUZU TROOPER 2.8L D ~ RHF4 ISUZU TROOPER 2.2L D 84-85 TB0209 ISUZU TROOPER 2.8L D Import RHB52W ISUZU TROOPER 3.1L D 94-97 RHF5B ISUZU TROOPER 3.1L D 97-99 RHF5M ISUZU TROOPER 3.0L D 00- RHF5 ISUZU TROOPER 3.0L D ~ ~ ISUZU TROOPER 2.7L D ~ RHB5 ISUZU TROOPER - 113HP 3.1L D 91-94 RHB52 ISUZU TROOPER - 157HP 3.0L D 99 - RHF5 ISUZU TROOPER (BIG HORN) 3.1L D ~ ~ ISUZU TROOPER/NPR 2.8L D ~ RHF4 JAGUAR X - TYPE 2.0L D 03 - GT1749V JAGUAR XJ220 3.5L P 93 - TB0389 JAGUAR X-TYPE 2.0L D 03- GT1749V JAGUAR X-TYPE 2.2L D 06- GT1749V JEEP CHEROKEE 2.5L D 95-98 RHB51P JEEP CHEROKEE 2.5L D 97-02 RHB51P JEEP GRAND CHEROKEE - 116HP 2.5L D 98-99 RHB51P JEEP GRAND CHEROKEE - 140HP 3.1L D 99-02 TF035HL-13T-6 JEEP GRAND CHEROKEE - 163HP 2.7L D 01 - GT2256V JEEP GRAND CHEROKEE - 215HP 3.0L D 05- GTA2052GKV KIA CARNIVAL ~ ~ ~ KIA SEDONA CRDi - 125HP 2.9L D 99 - RHF5 KIA SEDONA CRDi - 142HP 2.9L D 01- RHF5 KIA SORENTO 2.5L D 03- GT1752S LANCIA AURELIA 2.4L D 01 - GT2256V LANCIA DEDRA 105HP 1.9L D 99 - GT1544H LANCIA DELTA 2.0L P 92-94 K26 LANCIA DELTA 16V 2.0L P 94 - TB0367 LANCIA DELTA 4X4 2.0L P 86-88 TB0338 LANCIA DELTA ECO 8V 2.0L P 91-94 TB0367 LANCIA DELTA HF - 130HP 1.6L P 86-91 TB0225 LANCIA DELTA HF - 130HP 1.6L P 83-86 TB0333 LANCIA DELTA INTEGRALE 16V 2.0L P 89-94 TB0385 LANCIA DELTA INTEGRALE 4X4 2.0L P 88-94 TB0367 LANCIA DELTA INTEGRALE 8V 2.0L P 86-94 TB0338 LANCIA DELTA TD 1.9L D 86-91 TB0232 LANCIA KAPPA 2.0L P 99 - TB2810 LANCIA KAPPA 2.0L P 96 - TB25 LANCIA KAPPA DI 136HP 2.4L D 98-99 VNT25 LANCIA KAPPA JTD 2.4L D 99 - VNT25 LANCIA LYBRA 2.4L D 01 - GT2256V LANCIA LYBRA JTD 2.4L D 01 - GT2256V LANCIA LYBRA JTD 1.9L D 00 - GT1749 LANCIA LYBRA JTD 2.4L D 03- GT2256V LANCIA LYBRA JTD - 140HP 1.9L D 04- GT1749V LANCIA PRISMA 1.9L D 86-90 TB0232 LANCIA THEMA 16V 2.0L P 92-94 TB0367 LANCIA THEMA DS 2.5L D 85-87 TA0316 LANCIA THEMA DS 2.5L D 87-94 TA0316 LANCIA THEMA IE 2.0L P 84-86 TB0338 LANCIA THEMA IE 2.0L P 86-87 TB0338 LANCIA THEMA IE 2.0L P 87-89 TB0367 LANCIA THEMA IE 16V 2.0L P 88-91 TB0367 LANCIA THESIS JTD 2.4L D 02- GT2256V LANCIA U6 1.9L D 95 - T2 LANCIA Y10 1.0L P 85-88 RHB52 LANCIA ZETA 2.0L D 99 - GT1546S LANCIA ZETA 2.0L D 01 - GT1549S LANCIA ZETA 2.2L D 01 - GT1549P LANDROVER 90/110 DEFENDER TDI 2.5L D 89-92 TB0242 LANDROVER 90/110 DEFENDER TDI 2.5L D 92-94 TB0242 LANDROVER 90/110 TURBO D 2.5L D 86-88 TB0226 LANDROVER 90/110 TURBO D 2.5L D 88-89 TB0246 LANDROVER DISCOVERY 3 TdV6 2.7L D 04- K04BV LANDROVER DISCOVERY DEFENDER (TD5) 2.5L D 98 - GT2052 LANDROVER DISCOVERY TDI (200) 2.5L D 90-94 TB0243 LANDROVER DISCOVERY TDI (300 SERIES) 2.5L D 94 - T250-04 LANDROVER FREELANDER 2.0L D 98 - GT15 LANDROVER FREELANDER TD4 2.0L D 00 - GT1749S LANDROVER RANGE ROVER SPORT TDV6 2.7L D 06- K04BV LANDROVER RANGEROVER 2.5L D 92-93 TB0243 LANDROVER RANGEROVER 2.5L D 94 - TD04-11G-4 LANDROVER RANGEROVER 2.5L D 91-94 K16 LANDROVER RANGEROVER 2.4L D 86-90 K16 LANDROVER RANGEROVER TD6 2.9L D 02 - GT2256V LDV CONVOY 2.5L D 97 - K04 LDV CONVOY 2.5L D ~ TA0306 LDV CONVOY 2.4L D 94 - TB25 LDV FREIGHT ROVER 200 SERIES 2.0L D 87 - TB0223 LDV FREIGHT ROVER 400 SERIES 2.5L D 84 - TA0306 LOTUS CARLTON 3.6L P 90 - TB2544 LOTUS CARLTON 3.6L P 90 - TB2544 LOTUS ELAN 1.6L P 90 - RHB52 LOTUS ESPRIT 2.2L P 80-88 TC0301 LOTUS ESPRIT 3.5L P 97 - TB2531 LOTUS ESPRIT 16V 2.2L P 88 - TB0373 MASERATI BI-TURBO 2.0L P 87 - RHB51W MASERATI BI-TURBO 2.3L P 87 - RHB51W MASERATI BI-TURBO 2.5L P 85-88 RHB51W MASERATI BI-TURBO ~ ~ RHB51W MAZDA 6 2.0L D ~ RHF MAZDA 323 1.6L P 88-89 RHB52MW MAZDA 323 1.6L P 84-86 RHB52BW MAZDA 323 1.6L P 85-87 RHB52MW MAZDA 323 1.6L P 87-89 RHB52BW MAZDA 323 1.6L P 92 - RHB52UW MAZDA 6 - 119HP 2.0L D 03 - RHF4V MAZDA 6 - 134HP 2.0L D ~ RHF4V MAZDA 626 - 100HP 2.0L D 99-01 RHF3H MAZDA MAZDA 2 1.4L D 03 - K35 MAZDA MPV - 134HP 2.0L D 02- RHF4V MAZDA PREMACY DI - 100HP 2.0L D 99- RHF3H MAZDA RALLY 1.8L P ~ RHF6 MAZDA RX-7 2.0 wa 89-92 HT18 MAZDA RX-7 TWIN TURBO 2.6 wa 92 - ~ MCC ROADSTER 0.7L P 03 - GT1238S MCC ROADSTER BRABUS - 100HP 0.7L P 05- GT12SM MCC SMART 0.6L P 99 - GT1238S MCC SMART 0.6L P 99 - GT1238S MCC SMART 0.6L P 99 - GT1238S MCC SMART 0.6L P 00-01 GT1238S MCC SMART 0.6L P 00-01 GT1238S MCC SMART 0.6L P 00-01 GT1238S MCC SMART 0.6L P 01 - GT1238S MCC SMART 0.8L D 00 - K31 MCC SMART ~ ~ ~ MERCEDES 190D 2.5L D 88-90 TB2550 MERCEDES 190D 2.5L D 90 - TB2535 MERCEDES 190D/250D 2.5L D 89 - K14 MERCEDES 250D 2.5L D 87 - TB2510 MERCEDES 300SD 3.0L D 78-83 TA0301 MERCEDES 300SLD 3.0L D 86 - TB0360 MERCEDES 300SLD 3.0L D 86 - TB0359 MERCEDES 300TD 3.0L D 81-86 K26 MERCEDES 300TD 3.0L D 83-84 TA0314 MERCEDES 300TD 3.0L D 84-87 TA0310 MERCEDES 300TD 3.0L D 86-89 K24 MERCEDES A160 CDI - 75HP 1.7L D 03- K03 MERCEDES A170 CDI - 90HP 1.7L D 98 - K03 MERCEDES A170 CDI - 95HP 1.7L D 01- K03 MERCEDES A180 Cdi 1.8L D 04- ~ MERCEDES A200 Cdi - 140HP 2.0L D 04- K03 VTG MERCEDES A200 Cdi -DPF - 140HP 2.0L D 04- K03 VTG MERCEDES A200 TURBO - 193HP 2.0L D 04- K03 VTG MERCEDES B200 Cdi - 140HP 2.0L D 04- K03 VTG MERCEDES B200 Cdi - DPF - 140HP 2.0L D 04- K03-VTG MERCEDES B200 TURBO - 193HP 2.0L D 04- K03 VTG MERCEDES C CLASS 2.1 3 ~ MERCEDES C220 - 125HP 2.2L D 00 - GT2052S MERCEDES C220 - 143HP 2.2L D 00 - GT1852V MERCEDES C220 CDI - 125HP 2.2L D 00-01 GT1746S MERCEDES C220 CDI - 125HP 2.2L D 01 - GT1746S MERCEDES C220 Cdi - 150HP 2.2L D 05- GT1852V MERCEDES C220/E220 - 125HP 2.2L D 99 - GT20S MERCEDES C250/E250 2.5L D 96 - GT20 MERCEDES C250/E250 - 150HP 2.5L D 97 - GT25C MERCEDES C270 - 163HP 2.7L D 01 - GT22V MERCEDES E220 - 125HP 2.2L D 99-00 GT2052S MERCEDES E220 - 143HP 2.2L D 00 - GT18V MERCEDES E220 - 143HP 2.2L D 01 - GT1852V MERCEDES E220 Cdi - 150HP 2.2L D 05- GT1852V MERCEDES E220 CDI - 150HP 2.2L D 02 - GT1852V MERCEDES E250 - 150HP 2.5L D 96-97 GT25C MERCEDES E250 - 150HP 2.5L D 97-00 GT25C MERCEDES E270 - 163HP 2.7L D 00 - GT22V MERCEDES E270 CDI 2.7L D 02 - GT2256V MERCEDES E270 CDI - 170HP 2.7L D 02 - GT1852V MERCEDES E290 2.9L D 96 - GT25C MERCEDES E320 - 195HP 3.2L D 99 - GT2359V MERCEDES E320 - 195HP 3.2L D 00 - GT25V MERCEDES E320 - 204HP 3.2L D 03- GT2359V MERCEDES G'WAGEN 3.5L D 93 - TB0369 MERCEDES M270 - 163HP 2.7L D 00 - GT22V MERCEDES S300TD 3.0L D 97 - K14 MERCEDES S320 - 195HP 3.2L D 99 - GT2359V MERCEDES S320 Cdi - 195HP 3.2L D 00 - GT25V MERCEDES S350 3.5L D 94 - TB0303 MERCEDES S400 TWIN TURBO 4.0L D 00- GT1749V MERCEDES S400 TWIN TURBO 4.0L D 00 - GT1749V MERCEDES S400 TWIN TURBO 4.0L D 00 - GT1749V MERCEDES S400 TWIN TURBO 4.0L D 00 - GT1749V MERCEDES S400 TWIN TURBO 4.0L D 00 - GT1749V MERCEDES S400 TWIN TURBO 4.0L D 00 - GT1749V MERCEDES SMART 0.6L P 02- GT1238S MERCEDES SPRINTER VAN 2.9L D 95-97 GT2538 MERCEDES SPRINTER VAN 2.9L D 96 - GT2538 MERCEDES SPRINTER VAN 2.9L D 97 - GT20 MERCEDES SPRINTER VAN 2.9L D 97 - GT20 MERCEDES SPRINTER VAN 2.9L D 98 - GT2538C MERCEDES SPRINTER VAN 2.2L D 00 - GT1852V MERCEDES SPRINTER VAN 2.2L D 01 - RHF4H MERCEDES SPRINTER VAN 2.2L D 00 - GT2256V MERCEDES SPRINTER VAN 213/313/413 2.2L D 04- GT1852V MERCEDES SPRINTER VAN 216/316/416/616 2.7L D 04- GT2256V MERCEDES TRUCK (VARIO) 4.3L ~ K16 MERCEDES UNIMOG 2.9L D 96 - GT20 MERCEDES UXI 2.9L D 96 - GT20 MERCEDES V CLASS - 122HP 2.3L D 96 - K03 MERCEDES V220 - 122HP 2.2L D 99-02 GT1749 MERCEDES V230 - 98HP 2.3L D 96-99 K03 MERCEDES VITO 2.3L D 96 - K03 MERCEDES VITO 2.3L D 96 - K03 MERCEDES VITO 2.2L D 98 - GT1749V MERCEDES VITO 2.2L D 01- GT1749S MERCEDES VITO 2.2L D 00 - GT1852V METROCAB BLACK CAB 2.4L D 00 - ~ MINI ONE 1.4L D 05- GT1444V MITSUBISHI CANTER 2.8L D 00 - TF035-HM MITSUBISHI CARISMA 1.9L D 99 - T2 MITSUBISHI CARISMA 1.9L D 96-99 T2 MITSUBISHI CARISMA DI-D 1.9L D 01- GT1549S MITSUBISHI CHALLANGER 2.8L D 98 - TF035 MITSUBISHI CHALLANGER 2.8L D ~ TF035 MITSUBISHI CHALLANGER 2.8L D 96 - TF035 MITSUBISHI DELICIA 2.5L D ~ TD04 MITSUBISHI DELICIA 2.5L D ~ TD04 MITSUBISHI DELICIA STARWAGON ~ 99- TF035HM-12T MITSUBISHI GALANT 2.0L P 87 - TD05H -14B-6 MITSUBISHI GT3000 (LEFT) 3.0L P 92 - TD04-09B-6 MITSUBISHI GT3000 (RIGHT) 3.0L P 94 - TD04-09B -6 MITSUBISHI L200 2.5L D 96 - TD04 MITSUBISHI L200 2.5L D ~ TD04 MITSUBISHI L200 2.5L D ~ TD04 MITSUBISHI L200 2.5L D ~ TF035 -H MITSUBISHI L200 2.5L D ~ TD04-7B-5 MITSUBISHI L200 ~ 02- TF035 MITSUBISHI L200 - 134HP 2.5L D 06- RHF4 MITSUBISHI L300 2.5L D ~ TD04 MITSUBISHI L300 2.5L D ~ TD04-10T-4 MITSUBISHI L300 (2WD) ~ 99- TF035HM-10T MITSUBISHI L300 (4WD) 2.5L D ~ TD04-10T04 MITSUBISHI L300/400 ~ ~ TF035HM-12T MITSUBISHI L400 ~ ~ TF035-H MITSUBISHI LANCER EVOLUTION III 2.0L P ~ TD05H-16G-7 MITSUBISHI LANCER EVOLUTION IV 2.0L P ~ TD05H MITSUBISHI LANCER EVOLUTION IV 2.0L P ~ TD05H MITSUBISHI LANCER EVOLUTION IX 2.0L P 05- TD05 MITSUBISHI LANCER EVOLUTION IX 2.0L P ~ TD05HP-16G MITSUBISHI LANCER EVOLUTION VI 2.0L P ~ TD05H MITSUBISHI LANCER EVOLUTION VII 2.0L P ~ TD05HRA MITSUBISHI LANCER EVOLUTION VIII 2.0L P ~ TD05HRA-16G MITSUBISHI LANCER EVOLUTION VIII 2.0L P ~ TD05HRA-16G MITSUBISHI SHOGUN 2.5L D 84-91 TD04-09B-4 MITSUBISHI SHOGUN 2.5L D 84-91 TD04-09B-4 MITSUBISHI SHOGUN 2.5L D ~ TD04-11G-4 MITSUBISHI SHOGUN 2.5L D ~ TD04-11G-4 MITSUBISHI SHOGUN 2.5L D ~ TD04-09B.4 MITSUBISHI SHOGUN 2.3L D 83-84 TC05 MITSUBISHI SHOGUN INTERCOOLED 2.5L D 87 - TD04-11G-4 MITSUBISHI SHOGUN INTERCOOLED 2.5L D 87 - TD04-11G-4 MITSUBISHI SHOGUN INTERCOOLED 2.8L D 94 - TD04-12T-4 MITSUBISHI SHOGUN INTERCOOLED 2.8L D ~ TD04-12T-4 MITSUBISHI SHOGUN INTERCOOLED 2.8L D 94 - TF035 MITSUBISHI SHOGUN INTERCOOLED 2.8L D ~ TD035HM-12T4 MITSUBISHI SHOGUN INTERCOOLED 3.2L D 00- TF035HL-14GK MITSUBISHI SHOGUN MINI 1.6L P 97 - TD02MR2-04K MITSUBISHI SHOGUN SPORT 2.5L D 98-01 TF035H MITSUBISHI SPACE WAGON 1.8L D 85-90 TD04-09B3 MITSUBISHI SPACE WAGON 2.0L D 95 - TD04S-09G-3 MITSUBISHI STARION 2.6L P 90-94 TD05-12A-8 MITSUBISHI STARION 2.6L P 89-90 TD05-12A-8 NISSAN 200SX 1.8L P 88-94 TB2525 NISSAN 200SX 2.0L P 94-96 TB2809 NISSAN 200SX 2.0L P 96 - TB2815 NISSAN 200SX 2.0L P 94 - TB28 NISSAN AVENIR 2.0L P ~ TB25 (ball bearing) NISSAN 300ZX 3.0L P 90-94 TB2208 NISSAN 300ZX 3.0L P 90-94 ~ NISSAN 300ZX 3.0L P 89-90 TB0347 NISSAN 300ZX AUTO 3.0L P 90-94 TB2207 NISSAN 300ZX AUTO 3.0L P 90-94 TB2206 NISSAN 300ZX MANUAL 3.0L P 90-94 TB2209 NISSAN 300ZX MANUAL 3.0L P 90-94 TB2210 NISSAN ALMERA - 110HP 2.2L D 00 - GT1549S NISSAN ALMERA TINO - 114HP 2.2L D 00-03 GT1549S NISSAN ALMERA TINO- 110HP 2.2L D 03 - GT1549S NISSAN BLUEBIRD 2.0L D 84-90 TB2502 NISSAN BLUEBIRD 1.8L D 85-90 TB2505 NISSAN CABSTAR - 125HP 2.7L D 01- GT2052S NISSAN CABSTAR - 95HP 2.7L D 01 - TB2580 NISSAN CHERRY 1.5L P 85-86 TB0212 NISSAN PULSAR 1.5L P 83-85 TB0212 NISSAN PULSAR 1.5L P 86-87 TB0212 NISSAN EXA 1.5L P 83-85 TB0212 NISSAN MICRA Dci - 64HP 1.5L D 03 - K35 NISSAN MICRA Dci - 82HP 1.5L D 03- K35 NISSAN NIVARA 2.5L D ~ RHF4 NISSAN PATHFINDER 2.5L D 05- GT2056V NISSAN PATROL 2.8L D 91-97 TB2527 NISSAN PATROL 2.8L D 97- GT17 NISSAN PATROL 3.0L D 00- GT2052V NISSAN PATROL 2.5L D 85-90 TB0347 NISSAN PATROL 2.8L D 90 - TB2533 NISSAN PATROL 3.0L D 2001 GT2052V NISSAN PATROL DI 3.0L D 00 - GT2052V NISSAN PRIMERA 2.0L D 96 - GT1549S NISSAN PRIMERA 2.0L D 96 - GT15 NISSAN PRIMERA 2.2L D 03- GT1849V NISSAN PRIMERA - 124HP 2.2L D 02 - GT1749V NISSAN PULSAR/SUNNY GTIR 2.0L P 90 - TB2804 NISSAN SILVIA/BLUEBIRD 1.8L P 84-90 TB0210 NISSAN SKYLINE 2.6L P 89 - TE2701 NISSAN SKYLINE 2.6L P 85-89 TB2504 NISSAN TERRANO DI 3.0L D 99 - GT2052V NISSAN TERRANO DI 3.0L D 02- GT2052V NISSAN TERRANO II 2.7L D 97 - TB25 NISSAN TERRANO II 2.7L D 02 - GT2052S NISSAN TERRANO II (NOT INTERCOOLED) 2.7L D 93-97 TB2557 NISSAN TRADE 3.0L D 98 - GT2252S NISSAN X-TRAIL dci 2.2L D 02 - GT1849V NISSAN X-TRAIL Di 2.2L D 05- GT1849V NISSAN X-TRAIL Di 2.2L D 01- RHF4 NISSAN X-TRAIL Di 2.2L D 01- RHF4 Make Model Engine Year Turbo Type PANTHER SOLO 2.0L P 89 - TB0361 PEUGEOT 307 2.3L D 05- TD02 PEUGEOT 307 1.4LD 4 VNT PEUGEOT 505 2.2L P 82-86 TB0327 PEUGEOT 505 2.5L D 83-84 K24 PEUGEOT 604 2.5L D 84-89 K24 PEUGEOT 604 2.3L D 79-83 TA0302 PEUGEOT 205 TURBO 16 1.8L P 83-85 K26 PEUGEOT 205/309 1.7L D 91-96 K14 PEUGEOT 205/309 1.7L D 91-95 K14 PEUGEOT 206 Hdi - 110HP 1.6L D 39206 GT1544V PEUGEOT 206 HDI - 68HP 1.4L D 02- K35 PEUGEOT 206 HDI - 90HP 2.0L D 99 - K03 PEUGEOT 206 HDI - 90HP 2.0L D 00- GT1546S PEUGEOT 206/307/407 1.6L D 2004- GT1544V PEUGEOT 207 Hdi - 136HP 2.0L D 05- GT1749V PEUGEOT 207 Hdi - 136HP 2.0L D 05- GT1546S PEUGEOT 306 Hdi - 90HP 2.0L D 99 - GT15 PEUGEOT 306 Hdi - 90HP 2.0L D 99 - K03 PEUGEOT 306 TD 1.9L D 93-98 K14 PEUGEOT 306 TD 1.9L D 93-98 TB0265 PEUGEOT 306 TD 1.9L D 97 - K04 PEUGEOT 306 TD - 90HP 1.9L D 98-99 GT1549 PEUGEOT 306TD 1.9L D 98 - K03 PEUGEOT 306TD 1.9L D 99 - K04 PEUGEOT 307 Hdi 1.4L D 03 - K35 PEUGEOT 307 Hdi - 110HP 1.6L D 04- GT1544V PEUGEOT 307 Hdi - 136HP 2.0L D 06- GT1749V PEUGEOT 307 Hdi -110HP 2.0L D 00 - K03 PEUGEOT 307 Hdi -110HP 2.0L D 00 - GT1546S PEUGEOT 405TD 1.7L D 89-92 TB0234 PEUGEOT 405TD 1.7L D 92-93 TB0234 PEUGEOT 405TD 1.9L D 93-96 TB0264 PEUGEOT 405TD 1.9L D 93-96 K14 PEUGEOT 405TD 1.7L D 87-88 K14 PEUGEOT 405TD 1.7L D 88-89 K14 PEUGEOT 405TD 1.7L D 89-92 K14 PEUGEOT 405TD 1.7L D 92-93 K14 PEUGEOT 406 Hdi - 109HP 2.0L D 01- K03 PEUGEOT 406 Hdi - 90HP 2.0L D 99 - K03 PEUGEOT 406 Hdi - 90HP 2.0L D 01- RHF4 PEUGEOT 406 SRI - 150HP 2.0L P 96 - TB25 PEUGEOT 406Hdi - 109HP 2.0L D 99 - K03 PEUGEOT 406Hdi - 109HP 2.0L D 99 - K03 PEUGEOT 406Hdi - 136HP 2.2L D 00 - GT1549P PEUGEOT 406Hdi - 136HP 2.2L D 01 - GT1549P PEUGEOT 406Hdi - 90HP 2.0L D 99 - GT15 PEUGEOT 406Hdi - 90HP 2.0L D 99 - GT15 PEUGEOT 406TD 2.1L D 97-99 GT1549 PEUGEOT 406TD 1.9L D 96-98 K14 PEUGEOT 406TD 1.9L D 96-98 T2 PEUGEOT 406TD 1.9L D 98-99 GT1549 PEUGEOT 406TD 1.9L D 96-98 K14 PEUGEOT 406TD 1.9L D 96-98 K04 PEUGEOT 406TD 1.9L D 97 - K04 PEUGEOT 406TD - 110HP 2.1L D 96-97 TB0288 PEUGEOT 407 HDI 20 LD 4 GT1749V PEUGEOT 407 HDI 20 LD 4 GT1749V PEUGEOT 407 Hdi - 110HP 1.6L D 04- GT1544V PEUGEOT 407 Hdi - 110HP 1.6L D 05- GT1544V PEUGEOT 407 Hdi - 136HP 2.0L D 06- GT1749V PEUGEOT 505 INJECTION 2.2L P 86-90 TB0327 PEUGEOT 505TD 2.5L D 84-86 K24 PEUGEOT 505TD 2.5L D 86-90 K16 PEUGEOT 605SRTI 2.0L P 95-99 TB25 PEUGEOT 605SRTI 2.0L P 93-95 TB2567 PEUGEOT 605TD 2.5L D 94-98 TB0278 PEUGEOT 605TD 2.5L D 94-98 TB0278 PEUGEOT 605TD 2.1L D 90-95 TB0251 PEUGEOT 605TD 2.1L D 90-95 TD04-11B-5 PEUGEOT 607Hdi - 110HP 2.0L D 01 - K03 PEUGEOT 607Hdi - 136HP 2.2L D 00 - GT1549P PEUGEOT 607Hdi - 136HP 2.2L D 01 - GT1549P PEUGEOT 806 Hdi 2.0L D 01 - GT1549S PEUGEOT 806 TD / EXPERT 1.9L D 95 - TB0280 PEUGEOT 806TD 2.1L D 96-98 T2 PEUGEOT 806TD 2.1L D 97 - GT1549 PEUGEOT 806TD 2.1L D 98 - GT1549 PEUGEOT 806TD/EXPERT 2.0L D 99 - GT1546S PEUGEOT 807Hdi 2.0L D 01- GT1549S PEUGEOT 807Hdi 2.2L D 01 - GT1549P PEUGEOT BOXER VAN 2.5L D 94 - K14 PEUGEOT BOXER VAN 2.5L D 98 - K16 PEUGEOT BOXER VAN 2.5L D 96 - K16 PEUGEOT BOXER VAN 2.0L D 01 - K03 PEUGEOT BOXER VAN 2.2L D 01 - K03 PEUGEOT BOXER VAN EURO III 2.8L D 99 - K03 PEUGEOT EXPERT 2.0L D 00- K03 PEUGEOT PARTNER COMBI 2.0L D 99 - GT1546S PEUGEOT PARTNER COMBI 2.0L D 00 - GT1546S PORSCHE 964 3.3L P 89 - K27 PORSCHE 911 TURBO 3.0L P 82-89 3LDZ PORSCHE 911 TURBO 3.0L P 82-84 3LDZ PORSCHE 911 TURBO 3.3L P 83-93 K27 PORSCHE 911 TURBO L/SIDE 3.6L P 94-98 K16 PORSCHE 911 TURBO L/SIDE 3.6L P 95-99 K24 PORSCHE 911 TURBO L/SIDE 3.6L P 99 - K16 PORSCHE 911 TURBO L/SIDE 3.6L P 01- K24 PORSCHE 911 TURBO R/SIDE 3.6L P 94-98 K16 PORSCHE 911 TURBO R/SIDE 3.6L P 95-99 K24 PORSCHE 911 TURBO R/SIDE 3.6L P 99 - K16 PORSCHE 911 TURBO R/SIDE 3.6L P 01- K24 PORSCHE 924 TURBO 2.0L P 82-88 K26 PORSCHE 924 TURBO 2.0L P 82-88 K26 PORSCHE 924GT 2.0L P 82-88 K26 PORSCHE 924GTS 2.0L P 82-88 K26 PORSCHE 944 TURBO 2.5L P 85-88 K26 PORSCHE 944 TURBO 2.5L P 88-92 K26 PORSCHE CAYENNE 4.5L P 03- RHF5 PORSCHE CAYENNE 4.5L P 03- RHF5 PROTON PERSONA 2.0L D 96 - ~ RELIANT SCIMITAR SST 1.8L P 90-95 TB0210 RENAULT ALPINE A610 3.0L P 90-94 TB0387 RENAULT ALPINE GT AV6 2.4L P 86-90 TB0341 RENAULT AVANTIME 2.2L D 02 - GT1852V RENAULT AVANTIME 2.2L D 03- GT1852V RENAULT CLIO Dci - 65HP 1.5L D 02 - K35 RENAULT CLIO Dci - 80HP 1.5L D 02 - K35 RENAULT CLIO Dti - 80HP 1.9L D 01 - GT1549S RENAULT CLIO Dti - 98HP 1.9L D 00 - K03 RENAULT ESPACE 2.2L D 97-98 T25 RENAULT ESPACE 2.2L D 97-98 T25 RENAULT ESPACE 2.2L D 98 - GT1749 RENAULT ESPACE 2.1L D 93-96 TB02 RENAULT ESPACE - 165BHP 2.0L P 2003 TD04-10-T RENAULT ESPACE Dci 3.0L D 03 - GT2259V RENAULT ESPACE Dci - 120HP 1.9L D 03 - GT1749V RENAULT ESPACE Dci - 120HP 1.9L D 04- GT1749V RENAULT ESPACE Dci - 130HP 2.2L D 00 - GT1549S RENAULT ESPACE Dci - 130HP 2.2L D 01 - GT1549P RENAULT ESPACE RXE 2.1L D 95-96 VNT2503 RENAULT FUEGO 1.6L P 83-86 TB0311 RENAULT JEEP AMC 2.0L D 84 - TB0216 RENAULT KANGOO 1.9L D 99 - K03 RENAULT KANGOO 1.5L D 03 - K35 RENAULT KANGOO - 80HP 1.9L D 01 - GT1549S RENAULT LAGUNA 2.2L D 96-97 T25 RENAULT LAGUNA - 115HP 2.2L D 97-98 T25 RENAULT LAGUNA - 115HP 2.2L D 98 - GT1749 RENAULT LAGUNA - 140HP 2.0L D 05- GTA1749V RENAULT LAGUNA - 150HP 2.2L D 02- GT1852V RENAULT LAGUNA - 150HP 2.0L D 06- GTA1749LV RENAULT LAGUNA - 150HP 2.0L D 05- GTA1749V RENAULT LAGUNA 165BHP 2.0L P 2003 TD04-10-T RENAULT LAGUNA Dci 1.9L D 03 - GT1749V RENAULT LAGUNA Dci - 102HP 1.9L D 01- K03 RENAULT LAGUNA Dci - 105HP 1.9L D 02 - GT1549S RENAULT LAGUNA Dci - 110HP 1.9L D 00 - GT1549S RENAULT LAGUNA Dci - 120HP 1.9L D 01 - GT1749V RENAULT LAGUNA Dci - 120HP 1.9L D 04- GT1749V RENAULT MASCOTTE 2.8L D 04- GT2056S RENAULT MASCOTTE - 105HP 2.8L D 99 - GT2056S RENAULT MASCOTTE - 125HP 2.8L D 04- GT2056S RENAULT MASCOTTE - 140HP 2.8L D 00 - GT2256V RENAULT MASTER 2.5L D 93 - K14 RENAULT MASTER 2.2L D 00 - GT1549 RENAULT MASTER 2.5L D 93 - TB2536 RENAULT MASTER 2.8L D 97 - GT1752H RENAULT MASTER 2.4L D 85-89 K26 RENAULT MASTER 2.5L D 89-83 K14 RENAULT MASTER - 115HP 2.8L D 98 - K14 RENAULT MASTER - 115HP 2.8L D 97 - TF035HM-13T-6 RENAULT MASTER Dci 1.9L D 00 - K03 RENAULT MASTER Dci 2.5L D 00 - K03 RENAULT MASTER/TRAFFIC 2.2L D 01 - GT1549S RENAULT MASTER/TRAFFIC 2.5L D 03- GT2056S RENAULT MEGANE 1.9L D 96-99 T2 RENAULT MEGANE 1.9L D 99 - GT15 RENAULT MEGANE 1.9L D 96-97 T25 RENAULT MEGANE 1.9L D 97-99 GT15 RENAULT MEGANE 2.0L P ~ TD041-14T RENAULT MEGANE Dci 1.9L D 00 - GT1549S RENAULT MEGANE Dci 1.9L D ~ K03 RENAULT MEGANE Dci 1.9L D 00 - GT1549S RENAULT MEGANE Dci 1.9L D 01 - GT1549S RENAULT MEGANE Dci - 120HP 1.9L D 02- GT1749V RENAULT MEGANE Dci - 80HP 1.5L D 03- K35 RENAULT MESSENGER B110 2.5L D 93 - TB2534 RENAULT MESSENGER B110 2.8L D 97 - TF035HM-13T-6 RENAULT MESSENGER B120 2.5L D 91-93 K14 RENAULT MESSENGER B120 2.5L D 93 - K14 RENAULT MESSENGER B120 2.8L D 97 - TF035HM-13T-6 RENAULT MESSENGER B90 2.5L D 89 - K14 RENAULT MESSENGER B90 2.5L D 93 - K14 RENAULT MOVANO 1.9L D 00-01 GT1549S RENAULT R11 1.4L P 83-86 TB0203 RENAULT R11 1.4L P 86-87 TB0203 RENAULT R11 & R9 1.4L P 87-88 TB0214 RENAULT R18 1.6L P 80-83 TB0311 RENAULT R18 1.6L P 83-85 TB0311 RENAULT R19 DT 1.9L D 91-94 TB0255 RENAULT R19 DT 1.9L D 95-96 T25 RENAULT R19 DT 1.9L D 94-96 T25 RENAULT R19 DT 1.9L D 96-96 T25 RENAULT R21 & 4X4 TURBO 1.9L P 86-92 TB0370 RENAULT R21 TD 2.1L D 93-95 TB02 RENAULT R21 TD & R25 TD 2.1L D 86-92 TB0213 RENAULT R25 2.4L P 85-86 TB0341 RENAULT R25 2.4L P 86-90 TB0341 RENAULT R25 - 200HP 2.4L P 90-91 TB0386 RENAULT R25 TD 2.1L D 86-91 TA0305 RENAULT R5 1.4L P 80-84 TB0310 RENAULT R5 1.4L P 82-86 TB0310 RENAULT R5 GT 1.4L P 86-87 TB0214 RENAULT R5 TURBO 1.4L P 87-90 TB0235 RENAULT R5 TURBO 1.4L P 81-83 TB0319 RENAULT R5 TURBO 1.4L P 83-84 TB0319 RENAULT R5 TURBO 1.4L P 86-87 TB0214 RENAULT R5 TURBO ALPINE 1.4L P 84-86 TB0214 RENAULT R9 1.4L P 85-87 TB0203 RENAULT SAFRANE 2.5L D 94-96 K16 RENAULT SAFRANE 1.9L D 01- GT1749V RENAULT SAFRANE 2.2L D 96-97 T25 RENAULT SAFRANE 2.1L D 93-95 TB0256 RENAULT SAFRANE 2.2L D 96-97 T25 RENAULT SAFRANE 2.2L D 97-98 T25 RENAULT SAFRANE 2.2L D 98 - GT1749 RENAULT SAFRANE 3.0L P 92-96 K04 RENAULT SAFRANE 3.0L P 92-96 K04 RENAULT SCENIC Dci - 100HP 1.9L D ~ K03 RENAULT SCENIC dci - 105HP 1.9L D 02 - GT1549S RENAULT SCENIC Dci - 120HP 1.9L D 03- GT1749V RENAULT SCENIC dCi - 130HP 1.9L D 05- GT1746V RENAULT SCENIC Dci - 79HP 1.5L D 02 - K35 RENAULT SCENIC dCi- 130HP 1.9L D 05- GT1746V RENAULT SCENIC Dt - 95HP 1.9L D 97-99 T2 RENAULT SCENIC Dti - 100HP 1.9L D 97- K03 RENAULT SCENIC Dti - 80HP 1.9L D 99 - GT1544S RENAULT TRAFIC 1.9L D 02- ~ RENAULT VEL SATIS - 175HP 2.0L D 06- GTA1752LV RENAULT VEL SATIS Dci 2.2L D 01 - GT1852V RENAULT VEL SATIS Dci 3.0L D 01- GT2559V RENAULT WINNEBAGO 2.IL D 83-91 TA0305 ROLLS / BENTLEY MULSANNE 6.75L P 82-86 TB4113 ROLLS / BENTLEY MULSANNE 6.75L P 86 - TB4134 ROLLS / BENTLEY TURBO R 6.75L P 86 - TB4134 ROLLS / BENTLEY TURBO R 6.75L P ~ TB4134 ROLLS ROYCE ARNARGE 4.4L P 98-02 GT1752S ROLLS ROYCE ARNARGE 4.4L P 98-02 GT1749S ROLLS ROYCE ARNARGE 6.75L P 02- TB0303 ROLLS ROYCE ARNARGE 6.75L P 02- TB0303 ROVER 75 2.0L D 02- GT1544S ROVER 200/400 - 116HP 2.0L D ~ GT15 ROVER 218/418 1.7L D 91-95 K14 ROVER 218/418 1.7L D 91-95 K14 ROVER 220/420/620 2.0L P 92 - TB2555 ROVER 220/420D/SD 2.0L P 96 - GT1549 ROVER 25TD - 116HP 2.0L D 01 - GT15 ROVER 420D INTERCOOLED 2.0L D 95 - GT1549 ROVER 45TD - 116HP 2.0L D 01 - GT15 ROVER 620D INTERCOOLED 2.0L D 95-99 GT1549 ROVER 75 CDT 2.0L D 99 - TD025L ROVER 75T 1.8L P 02 - GT2052LS ROVER 820 16V TURBO 2.0L P 91-92 TB2554 ROVER 820 16V TURBO 2.0L P 92-99 TB2555 ROVER 825 D 2.4L D 90-99 K16 ROVER MAESTRO/MONTEGO 2.0L D 87-94 TB0223 ROVER MG METRO 1.3L P 83-89 TB0329 ROVER MG MONTEGO 2.0L P 85-91 TB0342 ROVER MG ZT 1.8L P 02 - GT2052LS ROVER MGZR 25 - 116HP 2.0L D 00 - GT15 ROVER ROVER SDI 2.4L D 82-86 K24 SAAB 9.3 2.0L P ~ GT1752 SAAB 9.3 2.0L P 99 - TB2569 SAAB 900 2.0L P 91-94 TE05-12B-6 SAAB 900 2.0L P 94-99 TB2525 SAAB 900 2.0L P 94-99 T25 SAAB 900 2.2L D 98-99 GT15S SAAB 900 2.0L P 80-81 TC0301 SAAB 900 2.0L P 81-84 TB0312 SAAB 900 2.0L P 87-90 TE05-12B-6 SAAB 900 2.0L P 87-91 TE05-12B-6 SAAB 9000 2.0L P 94-98 TB25 SAAB 9000 2.3L P 94-98 TB25 SAAB 9000 2.0L P 94-98 TB25 SAAB 9.3 - 175HP 2.0L P 02 - GT2082ELS SAAB 9.3 - 210HP 2.0L P 02 - TD04 SAAB 9.3 HC TDI - 115HP 2.2L D 99 - GT15S SAAB 9.3 HC TDI - 125HP 2.2L D 01 - GT1849V SAAB 9.5 - 150HP 2.0L P 97 - GT1752 SAAB 9.5 - 170HP 2.3L P 97 - GT1752 SAAB 9.5 - 175HP 2.0L P 02 - GT2082ELS SAAB 9.5 - 200HP 3.0L P 97 - GT1549 SAAB 9.5 TiD 2.2L D 02- GT1849V SAAB 9.5 TiD - 176HP 3.0L D 02 - GT2559V SAAB 9.5 TID - 200HP 3.0L D 01 - GT1549 SAAB 900 16V 2.0L P 84-87 TB0339 SAAB 900 16V 2.0L P 87-89 TB0357 SAAB 900 16V - 175HP 2.0L P 89-94 TB0382 SAAB 900 16V - 185HP 2.0L P 89-94 TB0382 SAAB 900 8V 2.0L P 87-90 TE05-12B-6 SAAB 900 8V 2.0L P 87-90 TE05-12B-6 SAAB 900 APC 2.0L P 87-90 TB0358 SAAB 900 APC - 150HP 2.0L P 82-86 TB0321 SAAB 900 APC - 150HP 2.0L P 86-87 TB0321 SAAB 9000 16V 2.0L P 84-86 TB0343 SAAB 9000 16V 2.0L P 86-87 TB0356 SAAB 9000 16V 2.0L P 86-87 TB0356 SAAB 9000 16V 2.0L P 87-90 TE05-12B-6 SAAB 9000 16V - 175HP 2.0L P 87-90 TB0356 SAAB 9000 16V - 175HP CAT 2.3L P 93-98 TB2531 SAAB 9000 16V - 185HP 2.0L P 90-97 TB2529 SAAB 9000 16V - 185HP 2.3L P 90-98 TB2531 SAAB 9000 16V - 200HP 2.3L P 90-98 TB2531 SAAB 9000 AERO 2.3L P 93-98 TD04HL-15G-6 SAAB 9000 AERO 2.3L P 93-98 TD04HL-15T-6 SAAB 99/900 2.0L P 78-80 TC0301 SEAT ALHAMBRA 1.8T - 150HP 1.8L P 98-00 K03 SEAT ALHAMBRA 1.8T - 150HP 1.8L P 00 - K03 SEAT ALHAMBRA TDI 1.9L D 96 - VNT15 SEAT ALHAMBRA TDI 1.9L D ~ K03 SEAT ALHAMBRA TDI - 110HP 1.9L D 97 - GT1749V SEAT ALHAMBRA TDI - 115HP 1.9L D 99 - GT1749V SEAT ALHAMBRA TDI - 115HP 1.9L D 00- GT1749V SEAT ALHAMBRA TDI - 130HP 1.9L D 03- GT1749V SEAT ALHAMBRA TDI - 130HP 1.9L D 03- BV39 SEAT ALHAMBRA TDI - 130HP 1.9L D 03- KP39 SEAT ALHAMBRA Tdi - 130HP 1.9L D 03- BV39 SEAT ALHAMBRA TDI - 130HP 1.9L D 03 - K39 SEAT ALHAMBRA TDI - 90HP 1.9L D 97 - GT15S SEAT AROSA 1.4L D 02- GT1544S SEAT AROSA 1.2L D 00 - GT1541V SEAT CORDOBA 1.8T - 150HP 1.8L P 99-02 K03 SEAT CORDOBA TDI - 100HP 1.9L D 03 - K39 SEAT CORDOBA TDI - 100HP 1.9L D 03- K39 SEAT CORDOBA TDI - 130HP 1.9L D 03 - K39 SEAT CORDOBA TDI - 130HP 1.9L D 03- GT1749V SEAT CORDOBA TDI - 90HP 1.9L D 97 - GT15S SEAT IBIZA 1.9L D 93-94 TB0261 SEAT IBIZA 1.9L D 93-96 K03 SEAT IBIZA 1.9L D 93-96 K14 SEAT IBIZA - 100HP 1.9L D 02 - K39 SEAT IBIZA - 130HP 1.9L D 01 - K39 SEAT IBIZA 1.8T - 150HP 1.8L P 99 - K03 SEAT IBIZA 1.8T - 156HP 1.8L P 99-02 K03 SEAT IBIZA SPORT - 160HP 1.9L D 04- GT1749V (S2) SEAT IBIZA SPORT Tdi - 130HP 1.9L D 02- BV39 SEAT IBIZA SPORT Tdi - 130HP 1.9L D 02- GT1749V SEAT IBIZA TDI 1.9L D 98 - GT1544S SEAT IBIZA Tdi - 100HP 1.9L D 02- K39 SEAT IBIZA Tdi - 100HP 1.9L D 02- K39 SEAT IBIZA TDI - 90HP 1.9L D 97-98 GT15S SEAT LEON 1.8T - 180HP 1.8L P 00 - K03 SEAT LEON 1.8T - 180HP 1.8L P 00 - K03 SEAT LEON CUPRA - 160HP 1.9L D 04- GT1749V (S2) SEAT LEON CUPRA - 180HP 1.8L P 02 - K03 SEAT LEON CUPRA - 210HP 1.8L P 02 - K04 SEAT LEON CUPRA - 225HP 1.8L P 02 - K04 SEAT LEON CUPRA TDI - 150HP 1.9L D 03- GT1749V SEAT LEON TDI S - 90HP 1.9L D 00- GT1544S SEAT LEON TDI SE - 110HP 1.9L D 00 - GT1749V SEAT LEON TDI SE - 130HP 1.9L D 03- GT1749V SEAT LEON TDI SE - 90HP 1.9L D 03 - K03 SEAT LEON TDI SX - 110HP 1.9L D 00- GT1749V SEAT LEON TDI SX - 110HP 1.9L D 00- GT1749V SEAT TOLEDO 1.9L D 94 - GT15S SEAT TOLEDO 1.8T - 150HP 1.8L P 99 - K03 SEAT TOLEDO TDI - 110HP 1.9L D 99- GT1749V SEAT TOLEDO TDI - 110HP 1.9L D 00 - GT1749V SEAT TOLEDO TDI - 110HP 1.9L D 97 - VNT15 SEAT TOLEDO TDI - 90HP 1.9L D 97 - GT15S SEAT TOLEDO TDI SE - 130HP 1.9L D 03- GT1749V SEAT TOLEDO TDI SPORT - 150HP 1.9L D 03- GT1749V SKODA COMBI 1.9L D 99 - GT1749V SKODA FABIA TDI - 100HP 1.9L D 01- KP39 SKODA FABIA TDI - 100HP 1.9L D 02- K39 SKODA FABIA TDI - 110HP 1.9L D 00 - GT1749V SKODA FABIA TDI - 75HP 1.4L D 03- GT1544S SKODA FABIA TDI - 98HP 1.9L D 00 - KP39 SKODA FABIA VRS TDI - 130HP 1.9L D 03- GT1749V SKODA FABIA VRS TDI - 130HP 1.9L D 03- K39 SKODA OCTAVIA - 110HP 1.9L D 98 - GT1749V SKODA OCTAVIA - 90HP 1.9L D 98 - GT1544S SKODA OCTAVIA 1.8T - 150HP 1.8L P 98 - K03 SKODA OCTAVIA 1.8T - 150HP 1.8L P 00 - K03 SKODA OCTAVIA 1.8T - 180HP 1.8L P 03 - K03 SKODA OCTAVIA TDI - 100HP 1.9L D 01- KP39 SKODA OCTAVIA TDI - 100HP 1.9L D 01- KP39 SKODA OCTAVIA TDI - 100HP 1.9L D 02- KP39 SKODA OCTAVIA TDI - 105HP 1.9L D 03- K39 SKODA OCTAVIA TDI - 110HP 1.9L D 00 - GT1749V SKODA OCTAVIA TDI PD - 130HP 1.9L D 03- GT1749V SKODA SUPERB 1.8T 1.8L P 03- K03 SKODA SUPERB 1.8T - 150HP 1.8L P 02- K03 SKODA SUPERB TDI - 100HP 1.9L D 02- GT1749V SKODA SUPERB TDI - 130HP 1.9L D 03 - GT1749V SKODA SUPERB V6 TDI - 155HP 2.5L D 03 - GT2052V SSANG YONG KORANDO 2.3L D 98 - GT17 SSANG YONG KORANDO 2.9L D 01- GT20S SSANG YONG KORANDO 2.9L D 98 - T25 SSANG YONG MUSSO 2.3L D 97 - GT17 SSANG YONG MUSSO 2.9L D 97 - TB25 SSANG YONG MUSSO 2.9L D 97 - TB25 SSANG YONG MUSSO 2.9L D 97 - K14 SSANG YONG REXTON/RODIUS 2.7L D 04- GT2056S SUBARU FORESTER 2.0L P 99 - TD035HM-14T-4 SUBARU FORESTER 2.0L P 00 - TD035HM-14T-4 SUBARU FORESTER 2.0L P 98 - TD04L-13T-6 SUBARU FORESTER 2.0L P 98 - TD04L-13T-6 SUBARU IMPREZA 2.0L P 97 - TD05H-16-G SUBARU IMPREZA 2.0L P 93 - TD04L-13T-6 SUBARU IMPREZA GT555 2.0L P 97 - TD05H-16-G SUBARU IMPREZA STI 2.0L P ~ RHF5 SUBARU IMPREZA STI 2.0L P ~ RHF5 SUBARU IMPREZA STI TYPE C 2.0L P ~ RHF5 SUBARU IMPREZA WRX 2.0L P ~ RHF5HB SUBARU IMPREZA WRX 2.0L P ~ RHF5HB SUBARU IMPREZA WRX 2.0L P ~ RHF5HB SUBARU IMPREZA WRX 2.0L P 99 - RHF5HB SUBARU IMPREZA WRX 2.0L P ~ RHF55 SUBARU IMPREZA WRX 2.0L P 97 - RHF5HB SUBARU IMPREZA WRX 2.0L P ~ RHF55 SUBARU IMPREZA WRX STI 2.0L P 00 - RHF55 SUBARU IMPREZA WRX-NB 2.0L P 00 - TD04L-13T-6 SUBARU IMPREZA/LEGACY 2.0L P 90 - RHB52XW SUBARU LEGACY 2.0L P 91 - RHB52XW SUBARU RX TURBO 1.8L P 85-90 RHB52EW SUBARU RX TURBO 1.8L P 87 - RHB52EW SUBARU XT 4X4 1.8L P 85-91 RHB52EW SUZUKI BALENO 1.9L D 99 - K04 SUZUKI CAPUCCINO 0.65LP 93 - RHB31 SUZUKI GRAND VITARA - 110HP 2.0L D 00 - K03 SUZUKI GRAND VITARA - 110HP 2.0L D 02- GT1549S SUZUKI GRAND VITARA - 125HP 1.9L D 06- GTA1746LV SUZUKI VITARA 2.0L D 97 - ~ SUZUKI VITARA - 90HP 2.0L D 01 - K03 TATA LOADBETA 2.0L D 97 - K04 TATA SAFARI TDI 2.0L D 98 - K04 TOYOTA AVENSIS 2.0L D 01 - ~ TOYOTA AVENSIS CDT 2.0L D 99 - ~ TOYOTA AVENSIS CDT 2.0L D ~ RHF4 TOYOTA AVENSIS CT 2.0L D 98-01 ~ TOYOTA AVENSIS CT 2.0L D 98-01 ~ TOYOTA AVENSIS D-4D - 114HP 2.0L D 03- GT1749V TOYOTA AVENSIS VERSO 2.0L D 01 - ~ TOYOTA CARINA E 2.0L D 96-98 ~ TOYOTA CARINA E 2.0L D 96-98 ~ TOYOTA CELICA 4WD 2.0L P 88-90 CT26 TOYOTA CELICA 4WD 2.0L P 90 - CT26 TOYOTA CELICA 4WD 2.0L P 90 - CT26 TOYOTA CELICA 4WD 2.0L P 90 - ~ TOYOTA COROLLA CDE 2.0L D 00 - ~ TOYOTA COROLLA CDE 2.0L D 01 - ~ TOYOTA COROLLA CDE 2.0L D 02 - ~ TOYOTA COROLLA D-4D - 114HP 2.0L D 03- GT1749V TOYOTA HIACE 2.4L D 95-98 CT20 TOYOTA HIACE 2.0L D 90-94 ~ TOYOTA HIACE 2.4L D 98-01 CT20 TOYOTA HIACE 2.5L D 01 - ~ TOYOTA HILUX 2.0L D 90 - ~ TOYOTA LANDCRUISER 4.2L D 89-91 CT26 TOYOTA LANDCRUISER 3.4L D 85-90 ~ TOYOTA LANDCRUISER 4.2L D 95-98 ~ TOYOTA LANDCRUISER 4.2L D 98 - ~ TOYOTA LANDCRUISER 4.2L D 90 - ~ TOYOTA LANDCRUISER 3.0L D 00 - ~ TOYOTA LANDCRUISER 3.0L D 96 -00 ~ TOYOTA LANDCRUISER 2.4L D 88-91 CT20 TOYOTA LANDCRUISER 2.4L D 91-94 CT20 TOYOTA LANDCRUISER 4.2L D 89-91 ~ TOYOTA LANDCRUISER 2.4L D 98-02 CT20 TOYOTA LANDCRUISER 2.5L D 01 - ~ TOYOTA LANDCRUISER 3.0L D 00 - ~ TOYOTA LANDCRUISER 3.0L D 02- GT2359V TOYOTA LANDCRUISER 4.2L D 01 - ~ TOYOTA LANDCRUISER COLORADO 3.0L D 93-96 ~ TOYOTA LANDCRUISER COLORADO 3.0L D 96 - ~ TOYOTA LANDCRUISER D-4D 4.2L D 02- GT2359V TOYOTA LUCIDA 2.2L D 97 - CT9 TOYOTA MR2 2.0L P 90-95 CT26 TOYOTA PICNIC 2.2L D 98 - ~ TOYOTA PICNIC 2.0L D 01 - ~ TOYOTA PICNIC 2.2L D 98-01 ~ TOYOTA PICNIC 2.2L D 98-01 ~ TOYOTA PREVIA 2.0L D 05- GT1749V TOYOTA PREVIA 2.2L D 97 - CT9 TOYOTA PREVIA 2.0L D 01 - GT1749V TOYOTA RAV 4 2.0L D 01 - GT1749V TOYOTA RAV 4 2.0L D 05- GT1749V TOYOTA RAV 4 2.0L D 01 - ~ TOYOTA SOARA (LEXUS) 3.0L P Import CT12 Twin TOYOTA SOARA (LEXUS) 3.0L P Import CT12 Twin TOYOTA SOARA (LEXUS) 3.0L P Import CT12 Twin TOYOTA SOARA (LEXUS) 3.0L P Import CT12 Twin TOYOTA SOARA (LEXUS) 3.0L P Import Ceramic T/W TOYOTA SOARA (LEXUS) 3.0L P Import Ceramic T/W TOYOTA SUPRA - 232HP 3.0L P 89-93 ~ TOYOTA SUPRA - 232HP 3.0L P 89-93 ~ TOYOTA SUPRA TWIN TURBO 3.0L P 93-98 Ceramic T/W TOYOTA SUPRA TWIN TURBO 3.0L P 93-98 Ceramic T/W TOYOTA SUPRA TWIN TURBO 3.0L P 93-96 CT26 TOYOTA SUPRA TWIN TURBO 3.0L P 93-96 CT26 TOYOTA SUPRA TWIN TURBO -326HP 3.0L P 93-98 ~ TOYOTA SUPRA TWIN TURBO -326HP 3.0L P 93-98 ~ TOYOTA SUPRA TWIN TURBO -326HP 3.0L P 93-98 ~ TOYOTA SUPRA TWIN TURBO -326HP 3.0L P 93-98 ~ TOYOTA TOWN/LIGHT ACE 2.0L D 90-94 ~ TOYOTA TOWN/LIGHT ACE 2.0L D 94 - CT9 TOYOTA YARIS 1.3L D 01 - ~ VAUXHALL ASTRA 2.2L D 02- GT1849V VAUXHALL ASTRA ~ ~ RHF4H VAUXHALL ASTRA 1.7L D 03- ~ VAUXHALL ASTRA - 100HP 2.0L D 98 - GT1549S VAUXHALL ASTRA - 120HP 1.9L D 04- GT1749MV VAUXHALL ASTRA - 120HP 1.9L D 05- GT1749MV VAUXHALL ASTRA - 150HP 1.9L D 05- GT1749MV VAUXHALL ASTRA - 68HP (GM ENGINE) 1.7L D 98 - GT15S VAUXHALL ASTRA - 68HP (GM ENGINE) 1.7L D 95-98 GT1544 VAUXHALL ASTRA - 82HP 2.0L D 98 - GT1544H VAUXHALL ASTRA COUPE 2.0L P 00 - K04 VAUXHALL ASTRA DTI (MITSUBISHI ENG) 1.7L D 99 - TD025M VAUXHALL ASTRA TD (ISUZU ENGINE) 1.7L D 92 - RHB4BW VAUXHALL BRAVA 2.5L D 96 - RHF5B VAUXHALL BRAVA 3.1L D 96-02 RHF5B VAUXHALL BRAVA 2.5L D ~ RHF5 VAUXHALL CALIBRA/CAVALIER 2.0L P 92-96 K16 VAUXHALL CARLTON TD 2.3L D 92-94 K14 VAUXHALL CAVALIER 2.0L P 92-96 K16 VAUXHALL CAVALIER TD 1.7L D 92-95 RHB4BW VAUXHALL COMBI Dti 1.7L D 02- TD025M VAUXHALL CORSA 1.7L D 03- ~ VAUXHALL CORSA CDTI 1.3L D 03- KP35 VAUXHALL CORSA CDTI 1.3L D 03- KP35 VAUXHALL CORSA DTI 1.7L D 99 - TD025M VAUXHALL CORSA TD 1.5L D 93 - RHB32B VAUXHALL FRONTERA 2.3L D 92-96 K14 VAUXHALL FRONTERA 2.8L D 95-96 RHF5B VAUXHALL FRONTERA 2.5L D 96 - RHB51P VAUXHALL FRONTERA 2.2L D 98 - GT15S VAUXHALL FRONTERA DTI 2.2L D 01 - GT1849V VAUXHALL FRONTERA Dti 2.2L D 03- GT1849V VAUXHALL MONTERAY 3.1L D 95 - RHF5B VAUXHALL MONTEREY 3.1L D 94-95 RHB52 VAUXHALL MOVANO 1.9L D 01- GT1549S VAUXHALL MOVANO 2.2L D 00 - GT15490 VAUXHALL MOVANO 2.8L D 96 - GT1752H VAUXHALL MOVANO - 115HP 2.8L D 99 - K14 VAUXHALL MOVANO DTI 2.5L D 01 - K03 VAUXHALL NOVA TD 1.5L D 90-93 RHB32B VAUXHALL OMEGA 2.5L D 96 - TD04-11-G-4 VAUXHALL OMEGA 2.0L D 97 - GT15S VAUXHALL OMEGA 2.5L D 94-96 TD04-11-G-4 VAUXHALL OMEGA 2.5L D 92 - K14 VAUXHALL OMEGA 2.5L D 94 - TB2514 VAUXHALL SIGNUM TDI - 176HP 3.0L D 03 - GT2559V VAUXHALL SINTRA 2.2L D 98 - GT1549S VAUXHALL VECTRA 2.2L D 02 - GT1849V VAUXHALL VECTRA 2.2L D 02 - GT1544S VAUXHALL VECTRA 2.0L P 03 - K04 VAUXHALL VECTRA 1.7L D 95-97 RHF4 VAUXHALL VECTRA 2.0L D 98 - RHF5B VAUXHALL VECTRA 1.9L D 04- VNT17 VAUXHALL VECTRA 1.9L D 04- VNT17 VAUXHALL VECTRA - 100HP 2.0L D 97 - GT15S VAUXHALL VECTRA - 120HP 1.9L D 05- GT1749MV VAUXHALL VECTRA - 68HP 1.7L D 95-97 GT1544 VAUXHALL VECTRA - 82HP 2.0L D 96 - GT15S VAUXHALL VECTRA CDTi - 174HP 3.0L D 03- GT2559V VAUXHALL VECTRA DTI 2.2L D 02 - GT1849V VAUXHALL VIVARO 1.9L D ~ GT1549 VAUXHALL VIVARO 1.9L D 01- GT1549S VAUXHALL ZAFIRA 2.0L D 00 - GT1549S VAUXHALL ZAFIRA 2.2L D ~ GT15 VAUXHALL ZAFIRA 2.2L D 02- GT1849V VAUXHALL ZAFIRA - 120HP 1.9L D 04- GT1749MV VAUXHALL ZAFIRA - 120HP 1.9L D 05- GT1749MV VAUXHALL ZAFIRA - 82HP 2.0L D 99 - GT15S VAUXHALL ZAFIRA 2.0T 2.0L P 03 - K04 VAUXHALL ZAFIRA DTI 2.0L D 02 - GT1849V VOLKSWAGEN BEETLE 1.8T 1.8L P 01- K03 VOLKSWAGEN BEETLE TDI 1.9L D 98-99 GT1749V VOLKSWAGEN BEETLE TDI 1.9L D 03- KP39 VOLKSWAGEN BEETLE TDI 1.9L D 00 - GT1749V VOLKSWAGEN BORA SPORT 1.8T - 150HP 1.8L P 01- K03 VOLKSWAGEN BORA SPORT 1.8T - 150HP 1.8L P 01- K03 VOLKSWAGEN BORA SPORT 1.8T - 150HP 1.8L P 02- K03 VOLKSWAGEN BORA SPORT 1.8T - 180HP 1.8L P 02- K03 VOLKSWAGEN BORA TDI - 100HP 1.9L D 01- KP39 VOLKSWAGEN BORA TDI - 100HP 1.9L D 02- KP39 VOLKSWAGEN BORA TDI - 100HP 1.9L D 01- GT1749V VOLKSWAGEN BORA TDI - 110HP 1.9L D 99 GT1749V VOLKSWAGEN BORA TDI - 110HP 1.9L D 98 - VNT15 VOLKSWAGEN BORA TDI - 115HP 1.9L D 00- GT1749V VOLKSWAGEN BORA TDI - 130HP 1.9L D 00 - GT1749V VOLKSWAGEN BORA TDI - 150HP 1.9L D 01 - GT1749V VOLKSWAGEN BORA TDI - 150HP 1.9L D 00 - GT1749V VOLKSWAGEN BUS 2.5L D 98 - GT2052V VOLKSWAGEN CADDY 1.9L D ~ GT15 VOLKSWAGEN CADDY COMBI 1.9L D 99- GT1749V VOLKSWAGEN CADDY COMBI TDI 1.9L D 02 - GT1749V VOLKSWAGEN CADDY Tdi 1.9L D 03- GT1749V VOLKSWAGEN CADDY TDi 1.9L D 04- K39 VOLKSWAGEN COMBI 1.9L D 99- GT1749V VOLKSWAGEN GOLF 1.6L D 83-86 K24 VOLKSWAGEN GOLF 1.6L D 89-93 K14 VOLKSWAGEN GOLF 1.6L D 89-93 K14 VOLKSWAGEN GOLF 1.6L D 89-93 K14 VOLKSWAGEN GOLF 1.6L D 86-89 TB0218 VOLKSWAGEN GOLF 1.6L D 89-93 TB0218 VOLKSWAGEN GOLF 1.6L D 89-93 TB0218 VOLKSWAGEN GOLF - 150HP 1.8L P 96 - K03 VOLKSWAGEN GOLF - 75HP 1.9L D 94 - GT15S VOLKSWAGEN GOLF 1.8T - 150HP 1.8L P 96- K03 VOLKSWAGEN GOLF A3 1.9L D 93 - K03 VOLKSWAGEN GOLF A3 1.9L D 92 - K03 VOLKSWAGEN GOLF GT - 140HP 2.0L D 04- GT1749V VOLKSWAGEN GOLF GTI 1.8L P 00 - K03 VOLKSWAGEN GOLF GTI - 180HP 1.8L P 02- K03 VOLKSWAGEN GOLF MK2 TDI - 90HP 1.9L D 94-97 GT15S VOLKSWAGEN GOLF MK3 TDI - 90HP 1.9L D 97 - GT15 VOLKSWAGEN GOLF MK4 TDI - 90HP 1.9L D 97 - K03 VOLKSWAGEN GOLF SYNCHRO 1.9L D 96 - GT15 VOLKSWAGEN GOLF TDI 1.9L D ~ K039 VOLKSWAGEN GOLF TDI - 100HP 1.9L D 01- KP39 VOLKSWAGEN GOLF TDI - 100HP 1.9L D 02 - GT1749V VOLKSWAGEN GOLF TDI - 100HP 1.9L D 02- KP39 VOLKSWAGEN GOLF TDI - 105HP 1.9L D 03- K39 VOLKSWAGEN GOLF TDI - 110HP 1.9L D 95 - VNT15 VOLKSWAGEN GOLF TDI - 110HP 1.9L D 98-99 GT1749V VOLKSWAGEN GOLF TDI - 110HP 1.9L D 00- GT1749V VOLKSWAGEN GOLF TDI - 110HP 1.9L D 00 - GT1749V VOLKSWAGEN GOLF TDI - 110HP 1.9L D 97 - VNT15 VOLKSWAGEN GOLF TDI - 110HP 1.9L D 98 - VNT15 VOLKSWAGEN GOLF TDI - 110HP 1.9L D 99 - GT1749V VOLKSWAGEN GOLF TDI - 115HP 1.9L D 00 - GT1749V VOLKSWAGEN GOLF TDI - 130HP 1.9L D 01 - GT1749V VOLKSWAGEN GOLF TDI - 130HP 1.9L D 00 - GT1749V VOLKSWAGEN GOLF TDI - 130HP 1.9L D 00 - GT1749V VOLKSWAGEN GOLF TDI - 130HP 1.9L D 00 - GT1749V VOLKSWAGEN GOLF TDI - 150HP 1.9L D 01 - GT1749V VOLKSWAGEN GOLF TDI - 150HP 1.9L D 00 - GT1749V VOLKSWAGEN GOLF TDI - 150HP 1.9L D 00 - GT1749V VOLKSWAGEN GOLF Tdi - 170HP 2.0L D 06- GTB1749VM VOLKSWAGEN GOLF Tdi- 140HP 2.0L D 06- GT1646V VOLKSWAGEN GOLF/PASSAT 1.9L D 90-94 TB0261 VOLKSWAGEN GOLF/PASSAT 1.6L D 81-86 TA0304 VOLKSWAGEN GOLF/PASSAT 1.9L D 92 - K14 VOLKSWAGEN GOLF/PASSAT TDI - 90HP 1.9L D 94 - K03 VOLKSWAGEN LT II VAN 2.8L D 99 - GT25C VOLKSWAGEN LT II VAN 2.5L D 99 - GT2052V VOLKSWAGEN LT II VAN 2.5L D 95 - K14 VOLKSWAGEN LT II VAN 2.8L D 02- GT2556V VOLKSWAGEN LT VAN 2.4L D 82-92 TA0307 VOLKSWAGEN LT VAN 2.4L D 92 - T2553 VOLKSWAGEN LT35 VAN 2.5L D 95 - K14 VOLKSWAGEN LUPO 1.2L D 99 - GT1544V VOLKSWAGEN LUPO Tdi 1.4L D 03- GT1544S VOLKSWAGEN PASSAT 1.6L D 84-86 TA0304 VOLKSWAGEN PASSAT 1.6L D 84-85 K24 VOLKSWAGEN PASSAT 1.9L D 94-97 GT15S VOLKSWAGEN PASSAT 1.9L D 00 - GT1749V VOLKSWAGEN PASSAT 1.8T - 150HP 1.8L P 99- K03 VOLKSWAGEN PASSAT 1.8T - 150HP 1.8L P 99- K03 VOLKSWAGEN PASSAT 1.8T Petrol 1.8L P 97-99 K03 VOLKSWAGEN PASSAT TD 1.6L D 85-93 K14 VOLKSWAGEN PASSAT TDI - 110HP 1.9L D 95 - VNT15 VOLKSWAGEN PASSAT TDI - 110HP 1.9L D 97 - VNT15 VOLKSWAGEN PASSAT TDI - 110HP 1.9L D 97 - GT1749V VOLKSWAGEN PASSAT TDI - 110HP 1.9L D 00 - GT1749V VOLKSWAGEN PASSAT TDI - 130HP 1.9L D 00 - GT1749V VOLKSWAGEN PASSAT TDI - 130HP 1.9L D 00 - GT1749V VOLKSWAGEN PASSAT TDI - 130HP 1.9L D 00 - GT1749V VOLKSWAGEN PASSAT Tdi - 140HP 2.0L D 06- GT1646V VOLKSWAGEN PASSAT TDI - 150HP 2.5L D 99 - GT2052V VOLKSWAGEN PASSAT Tdi - 170HP 2.0L D 06- GTB1749VM VOLKSWAGEN PASSAT TDI - 180HP 2.5L D 99 - GT2052V VOLKSWAGEN PASSAT TDI - 90HP 1.9L D 94 - GT15S VOLKSWAGEN PASSAT TDI - 90HP 1.9L D 95 - GT15 VOLKSWAGEN POLO TDI 1.9L D 02 - K39 VOLKSWAGEN POLO TDI 1.4L D 99 - GT1544S VOLKSWAGEN POLO TDI 1.4L D 99 - GT1544S VOLKSWAGEN POLO TDI - 100HP 1.9L D 02- K39 VOLKSWAGEN POLO TDI - 110HP 1.9L D 00-02 GT1749V VOLKSWAGEN POLO TDI - 130HP 1.9L D 04- BV39 VOLKSWAGEN POLO Tdi - 130HP 1.9L D 04- BV39 VOLKSWAGEN POLO TDI - 75HP 1.4L D 99 - GT1544S VOLKSWAGEN POLO TDI - 75HP 1.4L D 01- GT1544S VOLKSWAGEN POLO TDI - 75HP 1.4L D 01 - GT1544S VOLKSWAGEN POLO Tdi - 80HP 1.4L D 05- BV39 VOLKSWAGEN SHARAN 1.8T - 150HP 1.8L P 98 - K03 VOLKSWAGEN SHARAN 1.8T - 150HP 1.8L P 00 - K03 VOLKSWAGEN SHARAN TDI - 110HP 1.9L D 96 - VNT15 VOLKSWAGEN SHARAN TDI - 110HP 1.9L D 97-99 GT1749V VOLKSWAGEN SHARAN TDI - 110HP 1.9L D 99 - GT1749V VOLKSWAGEN SHARAN TDI - 115HP 1.9L D 00- GT1749V VOLKSWAGEN SHARAN TDI - 130HP 1.9L D 03- KP39 VOLKSWAGEN SHARAN TDI - 130HP 1.9L D 03- GT1749V VOLKSWAGEN SHARAN TDI - 130HP 1.9L D 03- GT1749V VOLKSWAGEN SHARAN TDI - 130HP 1.9L D 03- GT1749V VOLKSWAGEN SHARAN TDI - 130HP 1.9L D 02 - K39 VOLKSWAGEN SHARAN TDI - 90HP 1.9L D 94 - GT15S VOLKSWAGEN SHARAN TDI - 90HP 1.9L D 99 - K03 VOLKSWAGEN T4 BUS 2.5L D 98 - GT2052V VOLKSWAGEN T4 BUS 2.5L D 01- GT2252V VOLKSWAGEN T4 BUS 2.5L D 03- GT2052V VOLKSWAGEN T5 TRANSPORTER 2.5L D 03- K04 VTG VOLKSWAGEN TOUAREG - 174HP 2.5L D 03 - GT2056V VOLKSWAGEN TOUAREG - 309HP 5.0L D 03- GT1852V VOLKSWAGEN TOUAREG - 309HP 5.0L D 03- GT1852V VOLKSWAGEN TOURAN - 105HP 1.9L D 03 - K39 VOLKSWAGEN TOURAN - 138HP 2.0L D 03- GT1749V VOLKSWAGEN TRANSPORTER 1.9L D 93-95 TB0254 VOLKSWAGEN TRANSPORTER 1.9L D 95 - GT15S VOLKSWAGEN TRANSPORTER 2.5L D 95-00 K14 VOLKSWAGEN TRANSPORTER 1.6L D 84-90 K14 VOLKSWAGEN TRANSPORTER 1.6L D 88 - K14 VOLKSWAGEN TRANSPORTER 1.9L D 03- KP39 VOLKSWAGEN TRANSPORTER 1.9L D ~ KP39A VOLKSWAGEN VENTO 1.9L D 93-94 K03 VOLKSWAGEN VENTO 1.9L D 92-93 K14 VOLKSWAGEN VENTO TDI - 110HP 1.9L D 95 - VNT15 VOLKSWAGEN VENTO TDI - 90HP 1.9L D 94 - GT15S VOLKSWAGEN VENTO/PASSAT 1.9L D 92 - TB0261 VOLVO 850 2.5L P 96-97 TD04HL-13G-7 VOLVO 850 2.0L P 93-97 TD04HL-13G-7 VOLVO 850 2.0L P 97-97 TD04HL-13G-6 VOLVO 850 2.0L P 97-97 TD04HL-16T-6 VOLVO 850 ~ 96 - TD04HL-13G-6 VOLVO 850 ~ 96 - TD04HL-13G-6 VOLVO 940 2.3L P 94-95 TD04H-13C-6 VOLVO 940 2.3L P 90-91 TB2543 VOLVO 940 2.3L P 89-90 TD05-12B-6 VOLVO 440/460/480 1.7L P 91-97 TB0262 VOLVO 440/460/480 1.7L P 90-91 TB0253 VOLVO 440/460/480 1.7L P 90-91 TB0253 VOLVO 440/460/480 1.7L P 91-97 TB0262 VOLVO 440/460/480 1.9L D 94-97 TB0255 VOLVO 440/460/480 1.9L D 94-97 TB0277 VOLVO 440/480 1.7L P 88-90 TB0228 VOLVO 440/480 1.7L P 88-90 TB0228 VOLVO 700 SERIES 2.3L P 83-86 TB0363 VOLVO 700 SERIES 2.3L P 83-86 TB0326 VOLVO 700 SERIES 2.4L D 83-87 TA0307 VOLVO 700 SERIES 2.3L P 88-90 TB0379 VOLVO 700/900 SERIES 2.0L P 90-94 TD04H-13C-6 VOLVO 700/900 SERIES 2.3L P 90-96 TD04H-13C-6 VOLVO 700/900 SERIES 2.4L D 87-96 TB0349 VOLVO 700/900 SERIES 2.0L P 90-91 TB25 VOLVO 700/900 SERIES 2.3L P 89-90 TB0381 VOLVO 740/460/940/960 ~ 89 - TD04H-13C VOLVO 850 T5 2.3L P 93-96 TD04HL-15G-7 VOLVO 850 T5 2.3L P 96-97 TD04HL-15G-7 VOLVO 850 T5 ~ 96 - TD04HL-15G-7 VOLVO 850 T5 R 2.3L P 96-97 TD04HL-16T-7 VOLVO 850 T5 R 2.3L P 96-97 TD04HL-16T-7 VOLVO 850 TDI 2.5L D 96-97 K14 VOLVO 940SE 2.0L P 90-94 TD04H VOLVO C70 2.0L P 00-05 TD04L-12T-8.5 VOLVO C70 2.3L P 97-05 TD04HL-16T-7 VOLVO C70 2.5L P 99-00 TD04HL-13G-7 VOLVO S40 ~ ~ TD04L-12T-8.5 VOLVO S40 AUTO ~ ~ TD04L-14T VOLVO S40 MANUAL ~ ~ TD04L-14T-6 VOLVO S40/V40 2.0L P 97 - TD04L-14T-6 VOLVO S40/V40 2.0L P 97 - TD04L-12T-8.5 VOLVO S40/V40 2.0L P 00 - TD04L VOLVO S40/V40 2.0L P 00 - TD04L VOLVO S40/V40 1.9L D 96-99 TB0293 VOLVO S40/V40 1.9L D 99 - TB0293 VOLVO S40/V40 1.9L D 98 - GT15 VOLVO S40/V40 2.0L P 97 - TD04L-12T-8.5 VOLVO S40/V40 2.0L P 00 - TD04L VOLVO S40/V40 ~ 97 - TD04L-12T-8.5 VOLVO S40/V40 ~ 98 - TDO04L VOLVO S40/V40 - 102HP 1.9L D 01 - GT1549S VOLVO S40/V40 - 115HP 1.9L D 01 - GT1749V VOLVO S60 2.4L P 00- TDO4HL VOLVO S60 2.4L D 01- GT2052V VOLVO S60 2.4L D 01 - GT2052V VOLVO S60 T5 2.3L P 00- TD04HL-18T VOLVO S60R 2.4L P 03- K24 VOLVO S70 ~ 97 - TD04HL-15G-7 VOLVO S70 ~ 98 - TD04HL-13G-7 VOLVO S70 ~ 97 - TD04HL-16T-7 VOLVO S70 ~ 98 - TD04HL-13G-6 VOLVO S70 ~ 98 - TD04HL-16T-6 VOLVO S70 ~ 99 - TD04HL-16T-7 VOLVO S70 ~ ~ TD04HL-16T-7 VOLVO S70 ~ 99 - TD04HL-13T VOLVO S70 ~ 99 - TD04HL-18T VOLVO S70 ~ ~ TD04HL-19T VOLVO S70/V70 2.3L P 98 - TDO4H VOLVO S70/V70 2.4L P 98 - TD04HL-18T VOLVO S70/V70 2.5L P 97 - TD04HL-13G-7 VOLVO S70/V70 2.5L D 97 - K14 VOLVO S70/V70 ~ 99 - TD04HL-16T-7 VOLVO S70/V70 ~ 98 - TD04HL-18T-7 VOLVO S70/V70 2.5L P 00 - TD04H VOLVO S80 2.4L D 01 - GT2052V VOLVO S80 2.4L D 06- GTB2056VL VOLVO S80 T6 2.8L P 99- T6 VOLVO S80 T6 2.8L P 99- T6 VOLVO V70 2.3L P 00- TD04HL VOLVO V70 D5 2.4L D 02- GT2052V VOLVO V70 T5 2.3L P 00- TDO4HL VOLVO V70/S70/S80 ~ 99 - TD04 VOLVO V70R 2.5L P 98 - TD04HL-18T VOLVO V70R 2.4L P 03- K24 VOLVO X COUNTRY -210HP ~ ~ TD04HL-13T VOLVO XC 70 AWD 2.4L P 02- TD04HL VOLVO XC 70 AWD 2.5L P 02- TD04HL VOLVO XC 70 AWD 2.4L P 00- TD04HL-13G-7 VOLVO XC 70 D5 2.4L D 03- GT2052V VOLVO XC90 2.4L D 06- GTB2056VL VOLVO XC90 D5 2.4L D 03 - GT2052V VOLVO XC90 T6 2.8L P 99- T6 VOLVO XC90 T6 2.8L P 99- T6 Here are the US-Spec vehicles to find the turbo's on. I hope this article clears up any questions anyone had about Turbochargers and their components. Adam
1994 940 Turbo Wagon - Starting to make it a sleeper 1955 Chevrolet Wagon - It is a sleeper 1968 Harley - Saving gas in the summertime 2003 Indian Chief - Last of the Breed Don't like what I typed, Don't Read it, it's that simple Last edited by axisally666; 11-27-2008 at 05:19 PM.. Reason: Added Turbo Lag & Damage descriptions |
Board Clown
I am not worthy! Thanks!
Drive Safely ![]() '83 245 TIc sold '97 960 totalled '94 745 totalled (not mine) '87 744 totalled (not mine) '91 780 totalled and sold '81 b21f, T cam, Lh2.2, 960 injectors, junkyard/back of the shop 15" trash rims. - Sold
Last edited by DrvSfly; 11-26-2008 at 01:52 PM.. Reason: Cause this guy kicks ass! |
No CBV?
![]() '89 744T, Ebaycooler, ported 90+, .57trim T3/T04E, 16 psi, 3" Exhaust, TurboXS RFL bov, AC delete, accum modded AW71, cut springs, dual sways, camber mod and some nifty gauges. 16v in progress http://forums.turbobricks.com/showthread.php?t=198511 |
#4 |
Great information!!! thank you a lot!
#5 |
Decepticon Overlord
Is there anything else someone would like added before I get Carpal Tunnel from typing?
#6 |
Guest
Are you claiming all that as your own original work? Perhaps you'd like to acknowledge your source... unless stealth316.com is your website.
http://www.stealth316.com/2-3s-compflowmaps.htm |
#7 |
Decepticon Overlord
The authorship must not have been posted with it, sorry for not being in compliance with the Turbo bricks Patriot Act. It has since been posted Officer.
#8 |
Guest
Copying and pasting something which is not your own work is commonly called plagiarism. Knowingly copying/pasting something and making people think it's your work, is well... a little weird.
#9 | |
Here for the suckfest..
axisally666, Thanks for posting this. I think it will help alot of people make sense of whats going on with their cars. Hopefully guys like 740ATL don't piss you off and make you leave the board. Its nice when people put effort into relaying info so that people like me, who weren't born knowing everything about volvos can learn from. Everything is regurgitated info anyways. |
#10 |
why no 13c? isn't that pretty common on later 740 turbos?
Keeping late 80's Swedish metal alive!
#11 |
Bad for Babies
Nice work.
Now if you break down the Holsets and their OE applications you will be a GOD. |
#12 |
Decepticon Overlord
I'll work on this a little more tonight...give me a couple of hours
#13 |
Decepticon Overlord
I am going to warn you guys the OEM application list is gonna be HUGE!
#14 | |
![]() Join Date: Feb 2004
Bing Da da Bow bow Boom boom Zip....WWeeeeEE...Ppoof
#15 |
#16 |
#17 | |
Guest
and you... how the **** did you get off my ignore list?? |
#18 |
Decepticon Overlord
I'll get back to this tomorrow...everyone enjoy for tonight!
#19 |
Decepticon Overlord
Updated again @ 1:06 AM. I am beginning the list for US cars and I will finish the HOLSET list sometime today or tomorrow. Later
#20 |
Decepticon Overlord
Updated again @ 4:21 PM Thanksgiving day with two descriptions I previously wrote for a website, that ended up on Wikipedia.
#21 |
To inspamity, and beyond!
What? No KKK or RayJay turbos?
MIDWEST MADNESS VII ~ June 23/24, 2013 I used to be indecisive. Now I'm not so sure. The Phoenix |
#22 | ||
BEAUTIFUL compilation!
Some tell me? 9b? it's on the list, not the 12b?
'76 244 '86 244 '87 745ti N/A pistons M46 '89 744 '91 944 16v |
#23 |
bewst bewbies & chunga!
#24 | |
#25 | |||
Guest
Yes, he is making it seem as if the info is his... he kinda says so in his opening sentence... Quote:
If this current gentleman is going to be pissed off and run away and leave the board because I'm calling him out on copying/pasting a ****load of other people's work, then so be it. quoted from the stealth316 website. Quote:
| Thread Tools | |
| Display Modes | |
