Guest
I tried to search. I found some material while searching. I read the material, John V thread, some question threads etc.
But I could not really find what I was looking for. Does anyone make steel flywheels for whiteblocks? Then who? And how much do they cost? I found two places. Vintage performance and Advanced clutches, but I guess that you will have to make a special order. Sure... special orders can always be made. Then tell me the best place for that, and also what it costs if you have that info. But it would be nice if there were ready flywheels that could be bought so that I do not have to specify the specs, send blueprints and measurements etc. |
Never go full retard.
Köhler Racing sells a lightened single mass flywheel, that's all I know off the top of my head. http://www.kohlerracing.se/produkter/IMG_0304.JPG
No real power, just turbo shіt. Whiteblock swap guide / My brother has The Best Damn Garage In Town I don't think "fіtment" means what you think it means. |
they have aluminum flywheels for redblocks here:
http://www.v-performance.com/about.html i don't know for sure, but i bet they could do something for a whiteblock, might be worth giving them a ring and asking. |
#4 |
fred ,
ttvracing.com i need to send my redblock flywheel down to them to get one of those done http://homepage.ntlworld.com/mj.slater2/101_0121.JPG
![]() muhahhahahhhahhaha !!!!!!!!!!!!!!!!! |
#5 | |
Guest
It will of course have to take a 240mm clutch and have the appropriate holes for the sensor. |
#6 |
see the teeth on the outside , those are for the crank sensor .
im having a redblock one done with a 240mm 850R clutch , so itll be a redblock bolt in job . |
#7 |
Guest
But I need a whiteblock one
#8 |
that there in the picture is a whiteblock one
![]() im sure it can be re-engineered for you ! |
#9 |
Guest
#10 |
in the region of £180 .
theyre billet steel , ive not heard of any failures . |
#11 |
Guest
#12 | |
![]() Rob
1981 / 245 DL / dung brown / B21A / M47 / 3.3:1 axle from auto (5th not used much) / Scrapped. 1982ish /240GLT Estate/silver/Scrapped 1994 / 940s Turbo Auto Estate / B230FT /metalic green / Scrapped 1993 / 940s Estate / B230FB / Blue / Scrapped 1992 / 940s Estate / B200? / White / Gone.probably scrapped. 1998 940 Celebration /B230FK /M90L2/Galaxies/ 1967 Amazon Estate (Rusty) |
#13 |
Guest
| Thread Tools | |
| Display Modes | |
