Old 12-13-2008, 11:20 PM   #1
944GLE
944GLE's Avatar
Default Tire Sizing 195/65-15 vs 185/65-15
I have 185/65-15 tires on my car right now, would it be ok to go up a size to 195/65-15 without effecting performance and handling?
1992 944 GLE 280K
944GLE is offline   Reply With Quote
Old 12-13-2008, 11:26 PM   #2
osovolante
osovolante's Avatar
IMHO, 195/60-15 is better cause the diameter is about the same but it is wider.
http://www.discounttiredirect.com/ is where I buy mine and they have a interchange chart thing.
osovolante is offline   Reply With Quote
Old 12-13-2008, 11:49 PM   #3
buzz
To inspamity, and beyond!
buzz's Avatar
195-65-15 is the 'standard' size tire on my '95 944T according to my manual. Going to 195's you'll be getting 10mm more tire width.
Originally Posted by Råda View Post
I usually don't get compliments on my penis from guys, but thanks!
I used to be indecisive. Now I'm not so sure.
The Phoenix
buzz is offline   Reply With Quote
Old 12-14-2008, 12:16 AM   #4
4-cyl
4-cyl's Avatar
The difference in those 2 sizes is very small. If you feel like getting anal, try this:
http://www.miata.net/garage/tirecalc.html
I use it often.
1983 245 Turbo Intercooled M46
Determined to have smooth k-jet.
4-cyl is offline   Reply With Quote
Old 12-14-2008, 02:29 PM   #5
lummert
lummert's Avatar
Default Tire Size
205/60R-15 is a good size IMHO. Two sizes wider than 185/65R-15 & between 185/65-15 & 195/65-15 in overall diameter.
Old 12-14-2008, 03:24 PM   #6
JB945t
JB945t's Avatar
205/60r-15 is a good size imho. Two sizes wider than 185/65r-15 & between 185/65-15 & 195/65-15 in overall diameter.
+1
93 945t
My 940 needs a septic system because it's da ****
JB945t is offline   Reply With Quote
Old 12-14-2008, 03:26 PM   #7
+1 for 195-65-15,and a 25" diameter wheel.
Old 12-14-2008, 03:26 PM   #8
n. rippe
n. rippe's Avatar
Originally Posted by JB945t View Post
+1
+ 2 What wheels are you running?
n. rippe is offline   Reply With Quote
Old 12-14-2008, 03:50 PM   #9
944GLE
944GLE's Avatar
15inch aries
Old 12-14-2008, 04:00 PM   #10
340GL
340GL's Avatar
OOH a thread I can join in!
I have Hydras in the garage
I have Dracos on the car w/ 195/65/15 on. I want to put fatter rubber on the Hydras. would 225/50/16 be out of the question? would I be better off going for 215/55/16 for the Hydras?
1984 340GL 1.4 CVT (dead); 1987 760 GLE V6 Saloon (dead); 1989 740 Turbo Estate (current)
340GL is offline   Reply With Quote
Old 12-14-2008, 04:06 PM   #11
smokeyfan1000
Guest
I;d go with 205/60/15 too,some brand of tires are a hair taller and or wider even though they are designated as the same size,the width usually varies more than diameter but both come into play. You can take 205/60/15 BF Goodrich tire and put it beside a 205/60/15 GoodYear tire and the BFGoodrich tire will be wider by1/2-3/4 inch and a hair taller,shop and compare tires of different brands in same tire store and see it for yourself and buy what best suits your needs.
Old 12-14-2008, 04:28 PM   #12
Photobucket
Old 12-14-2008, 04:54 PM   #13
944GLE
944GLE's Avatar
yup
Old 12-15-2008, 03:57 PM   #14
Breadbox
Destroyer of M47s
Breadbox's Avatar
I'm running 195/60-15's on Dracos. Slightly thinner sidewall, better cornering.
I doubt any other forum has ever seen such a spectacular series of Unsuccessful Attempts At Things You Shouldn't Be Doing In The First Place
Volvo engineering: 90% brilliant 10% WTF???
'94 squirter, M47 conversion, Dracos, V90 moonroof, ipd 25mm sways, ipd heavy duty springs
COMING SOON:13c and a T5
'98 V70 AWD - belongs to HipToBeSquare
'07 XC90 V8
'93 244 - Not a Classic, 414 Ruby Red
'58 Ford Skyliner, in Colonial White and rust
Breadbox is offline   Reply With Quote
Old 12-15-2008, 04:10 PM   #15
240on280
240on280's Avatar
I've used 195/60/15 on 740s and they are much better than the 185/65/15. I've never tried 195/65/15s on a Volvo except on a V70 I test drove and they felt mushy. The speedo will be slightly off with the 195/65/15s
The BMW said "I am the ultimate driving machine!" and the Volvo wagon said "Oh really?"
240on280 is offline   Reply With Quote
