Old 12-18-2008, 04:50 AM   #1
elaps
Default auto to manual swap help in a 760
i just bought a 1990 760 turbo wagon. im in the process in making it a drift car with the help of Frank Yee (some of you know him) to show up some of the local nissan guys. anyway i have completed swaping every thing from pedals to driveshaft. i just pulled the manual transmission back out because the car would crank but not start.
All the transmission parts came from a 1985 740 wagon.
I was wondering if i need a different flywheel, i heard that there are flywheels that have steps on them for the crank position sensor.
is there away i can indent my current flywheel to make it work?
any help will be great thanks.
elaps is offline   Reply With Quote
Old 12-18-2008, 02:21 PM   #2
ed945t
ed945t's Avatar
Default flywheel
If your 760 has LH 2.4, you will need one these:
Look on the top of the bell housing just below the distributor, you will see a small sensor for the timing...you can also look at the auto trans flexplate that came off, it will have the same 58 hole/one gap pattern as the flywheel needs.
ed945t is offline   Reply With Quote
Old 12-18-2008, 02:25 PM   #3
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
i don't think the volvo trans is going to hold up in a drift application. i would highly recommend starting with a strong transmission from the beginning.
-Matt
1989 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1983 Ford F150- 302ci, C6/4x4, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, Bulletspeed lower, HR-Titan 20p.
the rest: 1996 850t 179k, 1998 S90 175k, 2004 V70 2.4 175k, 2005 XC90 2.5t AWD 122k.
500dollar744ti is offline   Reply With Quote
Old 12-18-2008, 04:01 PM   #4
elaps
ya thats the flywheel im looking for. i ordered one from autozone and they sent me a flat one. is my best bet the dealer wat car do i say i need the flywheel from? or can i use my current one and drill holes?
also im going for a budget build for right now so i want to use this trans if it blows up then ill get another its not a problem plus i want to see how this trans holds up personally.
thanks
Old 12-18-2008, 07:38 PM   #5
VolvoSweden
I recommend a M90, M46 wont hold up long 2nd and 3rd gear goes bye bye. :(
VolvoSweden is offline   Reply With Quote
Old 12-18-2008, 08:53 PM   #6
ed945t
ed945t's Avatar
Don't know if the dealer still carries them, you can find them here on occasion. They are getting a bit scarce as not too many model years used them. 89 up NA cars and 90 up turbos, I think. Someone else may know for sure.
Old 12-21-2008, 05:05 AM   #7
elaps
the dealer still carries them for 3xx or 2xx dealer cost.
if i blow my trans oh well ill pull it out and put another one in and blow that one up too lol jk.
anyway thanks everyone for the help i found the flywheel in the junkyard.
if anyone is looking for one contact john from this place the have one for like $90 plus ship
http://www.strandbergauto.com/contact_us.html
