The Babe With The Power
Would they work, or would they not be able to flow enough, of course this is assuming I can mount them etc...
Signature. |
one would think they are large enough...however, you could do some homework and find out what size they are !!!!
the ninja tb's I had are 45mm each and would have been fine these motors... |
Just look and see how much power they can support on a Gixer. If it's enough for your needs then yes, they're big enough.
If you do fit them please bear in mind tha the reason that most bike throttle bodies fail to work correctly is because they usually have to be spaced out a bit for the larger motors and doing so normally screws up the prescision and adjustability of them.
2009 Hyundai i10 as yet, nameless. Trigger's Broom: 1968 142, back halved with 10x15's and an 8.8" www.triggersbroom.org.uk |
#4 | |
Adapting Stuff
I've seen this information quoted more than once...
Dale |
#5 |
The Sirius/Nova Police
So assuming there 45mm as long as he only want 260hp na he'll be ok haha
Mike Lost my 2004 V40 GDI sport lux in local flooding last november, currently driving a Mercedes E430 avantgarde with prins LPG system (Sorry guys it is fun though) |
#6 | |
No braptraps here.
Great info, thanks Dale.
![]() ![]() ![]() ![]() ![]() http://zyrex.org/gallery/Cars/DauntsVolvo/ http://www.youtube.com/user/Dauntless244 Quote:
#7 |
oh you thinking something like this
![]() 960's are purrfect for something like this, there head mounted part of the manifold is already set up for bike throttle bodies with rubber hose fittings and it's own dedicated fuel rail |
#8 |
Guest
#9 |
#10 |
Guest
i thought of tenticles wagon and pics of it when you reminded me
#11 |
Reckon K-jet would be able to keep up with the throttle response?
#12 |
unbalanced chemical
![]() Join Date: Jun 2002
which is around 520+hp boosted?
![]() Chip Feedback Thread / PM Current Chip Prices / PM for DownPipe & Exhaust Price / Silicone Cooling Hose Sets 2/7/9
#13 | |
Eg: If the Suzuki is 1000cc and revs to 15k, and you want to fit those TBs to to a 2000cc car engine that revs to 7500rpm, then the TBs will probably be considerably larger than is needed.
Current 240 ownership: 1975 x5, 1977, 1979 x3, 1981, 1982 x2, 1984 x2, 1988. |
#14 | |
BEWARE OF PORTLAND TRIPLE
#15 |
What's a 16V?
Yes. They work.
Easy way to figure it out: Look at how much air the bike is moving. Compare to how much air you will be moving.
![]() '07 MS6 - DD/DSP of doom '92 245 - Eternal Project |
#16 |
check with Johann on vs, here's a link to his 850 n/a build where he uses itb's with great results. http://volvospeed.com/vs_forum/index...4&#entry856064
As far as not giving enough flow, the famous 850 BTCC racecar had itb's ![]() Kind of looks like the set-up used in the link ![]() If you have the funds and the resources definitly do it Mike |
#17 | |
wonder how long it took to machine?? yea for CNC !!!! |
#18 |
It's a girl!
That manifold is seriously cool stuff.
'83 242 '95 T5R '98 S70 |
#19 | |
![]() In my statement I assumed that we were talking about 4 cylinder engines. That being the case then the rpm isn't too important (without going to extremes, where low rpm airspeed could be a problem). What is important is airflow. Let's assume that the two different engines have similar VE at their similar maximum power outputs- tell me again why it wouldn't work? An engine is a fixed displacement pump (forget turbos for a minute- they were not being discussed here). All things being equal (such as cams etc as you have made a blanket statement to that effect), the 1000cc engine at 15000rppm will pump the same amount of air to make the same amount of power as the 2000cc engine at 7500rpm. |
#20 | |
ummm, you said the same exact thing as Spac....just worded it differently |
#21 |
In which case he pointed out nothing. And my point still stands.
(plus- I've been looking for any excuse to use that gif....) ![]() |
#22 |
guys , that manifold uses jenvey stuff , and is in fact cast by jenvey .
ive had one in my hands , i think below 45mm , or even 42mm your wasting your time with bike ITBs . being able to rev to 15krpm is why they make there power . http://homepage.ntlworld.com/mj.slater2/101_0120.JPG
![]() muhahhahahhhahhaha !!!!!!!!!!!!!!!!! |
#23 | |
#24 |
Guest
![]() ![]() ![]() Last edited by pooprah; 01-09-2009 at 08:00 PM.. |
#25 |
Manifold on the car looks like a nice casting.
Would seem odd to remove the 'bling' finish from a CNC'd part. BBQ, you're overlooking the fact that an engine is not a continuous pump - rather, it draws air in in pulses. Those pulses become more like gasps as the revs rise, which greatly alters the peak air flow required. You'll notice that 245GTi's example specified a certain, constant rev limit. This is so the non-lineararity that I mentioned can be ignored. If you wish to be pedantic, then yes, the VE matters and VE is affected by a huge range of things that may or may not cancel each other out in certain circumstances, but my basic point still has more influence on the big picture than any of that.* Similarly, a Wankel rotary engine can produce a heap of power through a single 2bbl 48mm carby - far more than a 4 cylinder possibly could through the same carburettor. This is because the rotary inhales in a much steadier, (relatively) continuous breath, without the 'gasps'. I guess the simple analogy is for you to try breathing through a drinking straw. Assuming you're in a calm, non-active state, the straw will flow just enough air to allow you to breath without too much discomfort. If you actually try this, you will quickly find that you will be most comfortable breathing slowly and deeply, rather than in fast, sharp intakes and expulsions. I'm sure you can see correlation between the two techniques of breathing and the lager/lower revving motor, and the smaller/higher revving motor. If we were talking about a using TBs from a 2000cc engine that revs to 7000rpm, and fitting them to a 2300cc engine that revs to 6500, blanket statements like yours would be a fair-enough approximation. However, we're talking about TBs from a 1300cc (or smaller) engine that revs to 13000rpm (or more), being fitted to that relatively low revving 2300cc motor - so your blanket statement was misleading. If you want, I'm sure you can easily find any quantity of published data showing exactly what I'm saying. *I can keep beefing out this disclaimer if you really want to argue the point, but let's just assume that we're talking about one throat per cylinder, on an engine without any dramatic flaws, and with an eye on performance. Last edited by Spac; 01-09-2009 at 09:19 PM.. |
| Thread Tools | |
| Display Modes | |
