Old 01-15-2009, 08:29 AM   #1
Gabe244
Gabe244's Avatar
Default Guide to the Volvo PCV system (With video).
This article is specifically written to cover the mid 80’s 200 series B2xx cars, but many of the components and information included is applicable to later, earlier or different models also.
Note: Much of this information is included in the video.
PCV FAQ.
What does PCV stand for?
PCV stands for Positive Crankcase Ventilation.
What does the PCV system do?
The PCV system lets the combustion blow-by escape from the crankcase. It does this by giving the gasses a place to escape and this is aided by the vacuum in the intake manifold / pre turbo piping. To over simplify it, the PCV system sucks out blow-by from the engine.
What is blow-by?
Blow-by is the gasses and vapours that escape from the combustion chamber, past the rings and into the crankcase.
What does the PCV system comprise of?
The main component of the PCV system is an Oil Separator or “breather box”, to let the oil vapour from the blow-by circulate back into the sump. This is then connected to a device called a Flametrap*, which stops backfires from the intake manifold from entering the crankcase, causing an explosion. The Flametrap consists of a hose with a tiny strainer in it (around the size of a coin), which is then connected to a plastic divider which allows two hoses to connect to it. These hoses are then connected to back into the intake manifold. * On turbo models the flametrap is omitted, and instead the breather box is connected via a hose to the air intake before the turbo.
What are the symptoms of a clogged PCV system?
Generally the oil seals in the engine will start leaking oil. The most common ones to leak are the cam seal, the oil filler cap and sometimes the rear main seal. Other symptoms include smoking from the engine bay whilst driving (Due to the oil filler cap seal leaking oil onto the exhaust) or sometimes the oil dipstick pops out (too much pressure in the crankcase).
How can I test my PCV system?
The usual test is just to undo your oil filler cap whilst the engine is running and see if it gets sucked down onto the cam cover. If it is, then there is vacuum in your crankcase and the PCV system is working perfectly. If it isn’t then it means that your crankcase has pressure inside it, and your PCV system needs servicing.
How can I clean my PCV system?
The first thing you want to do is to clean all the easy …..easier to reach parts and see if that fixes your problem. If that doesn’t, then the breather box will need to be removed and cleaned/replaced. To start cleaning you’ll first need to locate your breather box. The breather box is located on the side of the block, in between the 2nd and 3rd runners of the intake manifold.
Here is the breather box.
Then you want to find the hose that runs into the top of it. In N/A cars, this is the flametrap. You want to pull that off the port on the breather box, and follow the hoses to where they meet the manifold. Once you’ve found out where those hoses go, pull them off, and clean them out with some carb cleaner or replace them with new ones. Then clean out the respective hole/nipples on the manifold, so you can clearly see through them. Remove the nipple/port from the manifold if possible before cleaning them. If you’ve decided to keep the original flametrap and just clean it out, then take it apart (cut the zip tie holding the plastic divider to the hose) and poke out all the holes in the flametrap with a needle/nail, so air can flow through it. Also clean out the plastic divider. Then refit all the parts to the engine, using a new zip tie on the flametrap. Make sure that the hoses are in the right place, then start up the engine and repeat the test with the oil filler cap. If it is still not sucking the cap down then you’ll need to clean out the breather box. The breather box is held to the block with 2 bolts and sealed against the block with an o-ring. Removing the breather box usually requires removing the Intake manifold and air flow plate (for k-jet models) or nothing at all if you have an LH car. When removing the breather box make sure that the hose going into the sump is not removed too. DO NOT REMOVE THE HOSE TO THE SUMP. Refitting that hose requires the removal of the oil pan. To clean the breather box, I use a mallet (rubber), a wire and lots of degreaser. Start off by tapping it with a mallet to remove as much carbon deposits as possible, then scratch around in there with the wire, and finally soak it in degreaser. Repeat all the steps until it’s clean and free from obstructions. Once this is done check that the hose to the sump isn’t blocked. To do this, I use a long piece of wire to check for obstructions and remove them if necessary. Then I follow it down with some degreaser. HOWEVER MAKE SURE THAT YOU EMPTY THE OIL BEFORE USING DEGREASER AND CHANGE THE OIL IF YOU REMOVE ANY CARBON DEPOSITS FROM THE HOSE. Also, pour some oil down the hose to make sure that there is absolutely no degreaser left in the engine. If however the hose is unobstructed and no deposits had to be scraped off then you can leave the old oil in there. Once all that’s done, refit all the components making sure to use a new o-ring on the breather box. Now enjoy your perfectly clean PCV system.
How can I make the stock system better?
The majority of the stock system can be removed if you fit either a catch can, or let the breather box vent to the atmosphere.
What is a catch can?
A catch can is just a container to collect all the blow-by from the breather box. To connect the catch can, just run a hose from the port on the breather box to one of the ports on the catch can. Then on the other port of the catch can, either a mini air filter can be fitted (Which is against EPA regulations in most civilised countries), or a line back into the intake manifold can be fitted. In turbo models, this line has to go back into the intake, pre-turbo. (see examples below).
Some catch cans are “baffled” which makes the vapour condense in the can better. If your can is not baffled you can put some stainless steel scourers into the can (optional).
Catch cans seem like a lot of work, what is the other option?
The other option is just to vent the vapour to the atmosphere. This is generally achieved by running a hose from the port on the breather box, to the underside of the car. This is not recommended because it is bad for the environment, and it leaves drops of oil on your driveway. Most drag strips will also have an issue with you dripping on the track, so some people chose to route the end of the hose into a soft drink bottle instead, just temporarily.
If the breather box is likely to get clogged, why cant I remove it and replace it with a bolt on port? You could, if you don’t mind emptying your catch can every couple of days.
The fluid in my catch can, looks like murky water. What’s going on?
This is normal. Water is a by-product of the combustion of a hydrocarbon. This is also why exhausts tend to rust from the inside out.
My catch can is vented to the atmosphere, and it fills up really quick (Couple of hours or a few days), are my rings shot? Not necessarily. You should find that by recirculating the catch can back into the intake, it should stop filling up so fast.
Where can I get PCV related parts?
Parts can be had through IPD.
http://www.ipdusa.com/Volvo-200/Engi...9-258-260-847/ (IPD’s PCV section for the 200 series.)
PICS
Catch can installs.
Picture of recirculation pre turbo.
Modified breather box for added flow.
Down the dolphins throat.
The video will be added tomorrow morning once its up on U-tube. Its pretty casual cause I didnt have all day to film it and edit it, so excust the ocasional pause whilst i think of the right words .
Gabe244 is offline   Reply With Quote
Old 01-15-2009, 09:34 AM   #2
SteveMD
Not A Typical Dating Site
SteveMD's Avatar
Ha, ha, I love this article. Well done, young fellow. I'm putting my hat on so I can tip it to you!
Old 01-16-2009, 02:58 AM   #3
Freq
Freq's Avatar
Looking forward to it. I don't/didn't know anything about the PCV system.
Freq is offline   Reply With Quote
Old 01-16-2009, 11:40 AM   #4
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
Nice writeup. lol at the dolphin
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
Last edited by WindowsBreakerG4; 02-10-2009 at 05:33 PM.. Reason: Correcting spelling
WindowsBreakerG4 is offline   Reply With Quote
Old 01-16-2009, 11:48 AM   #5
Andrew9578
Andrew9578's Avatar
You mentioned about just venting the PCV to atmosphere and that it is bad if you go to the track because of the oil dripping on the track. How much oil would come out of the hose? Also, will venting it to the atmosphere hurt the engine in anyway? I don't want to have a seal leak because there is no vacuum present.
Andrew9578
Current Volvo:
2004 Volvo S60R
1994 Volvo 855 T5
Old Volvos:
1991 940 Turbo -> Traded for 855
1998 Volvo V70 XC -> sold to volvo mechanic
1985 Volvo 244 DL -> R.I.P.
Andrew9578 is offline   Reply With Quote
Old 01-16-2009, 10:01 PM   #6
Gabe244
Gabe244's Avatar
Venting to the atmosphere isnt ideal because then there is no vacuum in the crankcase. That being said, a great number of people do it anyway without problems. The amount of oil that comes out of the hose is usually quite small (with my catch can its just gas), however this depends on how clogged your breather box is, and how well your rings seal. Personally, if venting to the atmosphere is what you want to do, then do it, and swap to a catch can later if you have any issues. Be carefull as venting to the atmosphere is likely to be illegal in your area, so try to hide the hose as best as possible.
Old 01-19-2009, 05:43 AM   #7
SlowRide
Cold War Crumple Zones
SlowRide's Avatar
Dolphins can be used to replace most of the emissions parts including catalytic converters and charcoal cans
Seriously though, good right up.
1980 242 DL, B230f LH 2.4 AW71, B cam ipd adj gear adv 2*, ipd 25/25 sways, B&G springs (+T and M46 swap in waiting)
1982 244 GLT, partial part out, fate unknown
1989 244 DL, in a few boxes
Valhalla for Countless Others
Slowest Project Ever
240 parts, +T, and More For Sale
Feedback
SlowRide is offline   Reply With Quote
Old 01-19-2009, 11:54 AM   #8
ZVOLVO240
ZVOLVO240's Avatar
well done gabe. you beat me to it. I was going to do a write up on this. damn
ZVOLVO240 is offline   Reply With Quote
Old 01-19-2009, 10:22 PM   #9
Gabe244
Gabe244's Avatar
Sorry i havent got the video up yet. Youtube didnt want to upload it last time i tried. And thanks everyone for the comments .
Old 01-20-2009, 01:33 AM   #10
Texas240
Prius Owner
Texas240's Avatar
Fantastic right up, learn something new everyday. Gabe. I have a few questions regarding the car with the dolphin.. Lol.. Tehehe. To funny. The two clear rubber tubbing. They are just being rerouted from the breather box to the catch can back to the breather box.. right?
Can I get a distant picture of this so I can see how you routed your tubing. Thanks
93 245 LS Engine Swap Project
Old 01-20-2009, 03:22 AM   #11
Gabe244
Gabe244's Avatar
Im afraid the dolphin car isnt mine . However what they did was run two hoses from the breather box into the catch can, then had a mini filter on the catch can. The breather box for that car is also pictured above.
Old 01-20-2009, 03:33 AM   #12
Texas240
Prius Owner
Texas240's Avatar
That breather box looks different them OEM unless Im forgetful
Old 01-20-2009, 04:18 AM   #13
Gabe244
Gabe244's Avatar
Yeah, he added an extra nipple.
Old 01-20-2009, 11:50 AM   #14
Texas240
Prius Owner
Texas240's Avatar
That explains it...
Old 02-22-2010, 04:30 PM   #15
WindowsBreakerG4
I have a question for someone running more then 1 port back to the intake, did people add a second port to your intake piping or did you just put a Y in line? Or has no one gone down that route?
Old 02-22-2010, 11:27 PM   #16
Volvo244GLE
Volvo244GLE's Avatar
nice article mate
244GLE Project - The fun daily driver. Rebuilt B23, ported 405, 37.5 exh. valves, BMW oil squirter's, MS2e, VX3 cam, King Springs, Bilstein HD's, upper+lower chassis braces, 26mm Falcon front sway bar, 21+19=24mm rear sway bar, SAAS bucket seats, hi flow rear muffler, almost every factory option.
164 Project - The impulse buy
242GT Project - who likes rust?
Volvo244GLE is offline   Reply With Quote
Old 02-25-2010, 01:18 PM   #17
superboosted
You wish you had some..
superboosted's Avatar
Sweet,my motor is the recirculation pre turbo pic
Photobucket can suck it.
Originally Posted by centason View Post
You may get detonation and the kool-aid man loves 940s
superboosted is offline   Reply With Quote
Old 02-27-2010, 06:30 AM   #18
smokeyfan1000
Guest
Might want to mention that OEM Volvo flametrap hoses last a *whole lot longer* than any of the aftermarket ones, or point them towards OEM parts.
I bought an MTC flame trap hose & it cracked in 3 weeks without ever having even cranked the engine
And most places are selling the MTC hoses.
Old 02-27-2010, 02:28 PM   #19
volvorod85
volvorod85's Avatar
Good info, But you need to make it knows that in places like the USA, especially California and other stated and areas that have adopted our smog rules, this technically isnt legal, and there is a god chance you will fail the smog check due to a modified PCV system.
I hate to rain on the parade, especially if done right, upgrading the PCV system properly without venting to the atmosphere, and keeping the crankcase gasses in the motor and burned properly with no oil being spilled on the ground, properly caught in a catch can and disposed of properly makes for better emissions. But the state does not see it this way unfortunately and well, it sucks.
So just beware of that fact, otherwise...good write up
Mark
1995 E320 wagon AMG 3.6 swap <-- Daily driver
2009 Honda Fit <-- Wifeys ride
1959 Austin Healey Sprite <--something completely different (my project)
1974 Fiat X1/9 <--Mom's little toy (next project)
1982 Olds Custom Cruiser LQ4 <--Dad's beast (current project)
"Driving the old 2 valve 740 is a bit like driving an IKEA wall unit, so leisurely is its acceleration, so angular its lines."
My former brick saved my life 6/25/03....Volvo for Life
volvorod85 is offline   Reply With Quote
Old 01-26-2013, 11:30 PM   #20
VQ
Not such a PRVert Anymore
VQ's Avatar
http://www.pbase.com/stealthfti/pcv
Other Ways to improve PCV breathing.
hellastock
Speed Bumps? No Problem.
264 GLE RIP
88 740T wagon
1964 122s
88 760GLE
Old 01-27-2013, 11:22 AM   #21
face_the_heat
face_the_heat's Avatar
^ love this idea. I wonder what the power difference is between venting to atmosphere versus catch can. On one side there is fresh air,but with no vacuum aid. Then dirty air, but lower crank case psi due to vacuum. Anyone ever dyno this?
face_the_heat is offline   Reply With Quote
Old 02-07-2013, 07:31 AM   #22
towz-T
EL hipo explosive
towz-T's Avatar
so, all catch cans with a filter on top vent into the atmosphere?
and why would you put a filter on it, or is it when the turbo is spooling it could also draw air in from that point?
'00 V70 2.5TDI <= stored until i sell it
'04 V70 2.4TDI <= exploded in norway
'10 V70 2.0TDI <= DD
'89 745 B204GT <= project moneypit
my introduction thread that i am desperately trying to keep alive
cuz on turbobricks, posting about something and not doing it counts as quitting a project halfway through. Quitting a project halfway through counts as finishing it.
Yay you finished it!
towz-T is offline   Reply With Quote
Old 02-07-2013, 06:15 PM   #23
dalek
Benchracer Tribe
dalek's Avatar
And you can hump your redblock at the lights!
Feedback!
Old 03-22-2013, 02:30 PM   #24
Volvo240BLUE
-error-
Volvo240BLUE is offline   Reply With Quote
Old 11-21-2013, 08:49 AM   #25
martinholmesuk
Hi,
Can someone tell me where I can get one of these for my 940 2.3 turbo? Many thanks
Martin
martinholmesuk is offline   Reply With Quote
