Go Back   Turbobricks Forums > Mechanical > performance & suspension > aftermarket engine management
Old 01-15-2009, 11:53 PM   #1
birchfur
birchfur's Avatar
Default opinions on spark table?
I am having some trouble getting my spark table dialed in. I found a map posted on here for a similar setup and started adjusting from there. My current setup is as follows. Stock B21ft, ported 90+, t3/t4 turbo, 3" downpipe and side exit exhaust, ipd turbo cam, 31x12x3 intercooler, 46# injectors with resistor pack. I am using ms1 v2.2 re-flashed with extra 029y4, hall sensor dizzy, bosch139 ignition module, blaster 2 coil. Have timing set to about 20degrees at 1100rpm. Everytime i get to around 3000-3500rpm, the enigne starts stumbling. I have tried adjusting the advance in the area this occurs +/- about 10degrees but cant seem to get rid of this. Maybe still to far advanced? I am still in the process of getting ve table dialed in as well, currently running rich for the most part but it doesnt seem like its so rich it would cause a misfire. Took out plugs and they look normal color. So far only tuning to about 9 psi. Don't know how to post my tables or current msq. Have file zipped but dont see any options to post it on here. Here is a datalog pic of when it started cutting out at about 3200rpm. Any advice greatly apprectiated.
1983 244tic. SoldProject Thread
1994 850 turbo
birchfur is offline   Reply With Quote
Old 01-16-2009, 12:00 AM   #2
linuxman51
ARRRRHARHAR
linuxman51's Avatar
looks alright. somewhat conservative, but alright. sure you're not blowing the spark out? I don't see a cutout on the screen.
Megasquirt Tuning!
ported volvo heads
Old 01-16-2009, 12:05 AM   #3
birchfur
birchfur's Avatar
It could be. Maybe i'll try leaning it out a bit in that area.
Old 01-16-2009, 01:18 AM   #4
linuxman51
ARRRRHARHAR
linuxman51's Avatar
whats your plug gap set to? (and you didn't actuallly post the timing map for us to poke and prod)
Old 01-16-2009, 09:55 AM   #5
JohnMc
JohnMc's Avatar
Last trip to the track, I bumped up my timing a little.
And the car went from 14.2, 14.3 runs to 13.8, 13.9.
And a few days later it blew up.
*x-files theme music*
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 01-16-2009, 10:59 AM   #6
birchfur
birchfur's Avatar
Can't figure out how to post my maps. Or if there is a way to post my entire msq file. I have it compressed just don't know how to post it on here. Plugs gapped to spec in bently manual, cant remember off the top of my head what it is though.
Old 01-16-2009, 11:01 AM   #7
linuxman51
ARRRRHARHAR
linuxman51's Avatar
take a screen shot of the timing map like you did the datalog.
Old 01-16-2009, 11:17 AM   #8
birchfur
birchfur's Avatar
at work right now, I'll try and get it posted after work. For datalog I used option in megalog viewer to save it as png file, how do I get a screen shot?
Old 01-16-2009, 11:26 AM   #9
linuxman51
ARRRRHARHAR
linuxman51's Avatar
alt-prntscrn
Old 01-16-2009, 11:34 AM   #10
JohnMc
JohnMc's Avatar
alt-prntscrn
And then paste (ctrl-V) into MS Paint.
Old 01-16-2009, 11:35 AM   #11
EricF
Volvospeed Spy
EricF's Avatar
Or just prntscrn if you're lazy
-Eric
-1995 850 turbo - Ridiculous modifications list..
-1984 244 GLT - Blue.. 14.0 at 100.2.. TD04HL-19T-conical (SOLD)
FWD versus RWD Project - Who will win? (240 won ET, 850 won trap speed)
"...of all the liars among mankind, the fisherman is the most trustworthy." ~William Sherwood Fox
EricF is offline   Reply With Quote
Old 01-16-2009, 11:44 AM   #12
birchfur
birchfur's Avatar
Cool, thanks. I'll get on it when i get home tonight.
Old 01-16-2009, 09:41 PM   #13
birchfur
birchfur's Avatar
Heres a screen shot with both tables on mega log viewer. Having some troubles with megatune right now, gonna have to re install it then should be able to get some bigger shots.
Old 01-16-2009, 10:18 PM   #14
birchfur
birchfur's Avatar
Unable to get megatune to work. When i open megatune and select ms1 extra 029y4, then hit ok, mega tune will not load from that point. Still shows megatune on the task bar, but nothing else happens. Tried it on both of my computers with same result. Tried reinstalling megatune, same result. I can pull up the main sceen when selecting any of the other ms versions from the first screen. Any ideas. Only thing i have changed recently is updating megalog viewer with latest version. Could this affect it?
Old 01-17-2009, 09:19 PM   #15
BabyBlue240
It looks like your map and rpm signals are noisy. Does it feel surge-y? Because it looks like it's screwing with your spark angle and PW.
Photobucket
blueTune - iOS Megasquirt Tuning
'84 242- 250k, Rebuilt 93 B230FT block, MSII-Extra, EDIS, ported 90+, 15g, Green tops, cat-delete, 3" exhaust, LC-1, Knocksense, 92+ 940 intercooler, Bilstein HD's, IPD 25/25 sways, IPD springs
Project thread
BabyBlue240 is offline   Reply With Quote
Old 01-17-2009, 10:06 PM   #16
birchfur
birchfur's Avatar
Usually its pretty smooth accelerating until i get to 3000 rpm, doesnt seem to surge. However, i do have some nasty compessor surge on decel due to incorrect bov spring. New spring arriving any day now. Any ideas to get megatune operational? Reflash?
Old 01-19-2009, 07:11 PM   #17
birchfur
birchfur's Avatar
Got megatune back up and running after deleting and reloading complete software bundle on computer. Anyways here are some screenshots from megatune. Havent been driving car lately, waiting on bov spring to get here so i dont **** up the seals in the turbo.
