#526 |
ドクターマリオ
#527 | |
ドクターマリオ
I know everyone talks about uneven flow and stuff w/ the B234 mani but I've seen plenty of cars making a ton of power with them? And I've never seen a motor where it caused a problem definitively. Am I missing something? *Ideally* I'd be using a custom manifold but it's out of the budget now since I blew the original budget a loooooong time ago. Based on Josh's results w/ the B230 manifold like I have bolted to the engine now, it seems like the B234 is a better bet of the 2. Last edited by Cameron; 09-23-2009 at 02:43 PM.. |
#528 |
You can trim the cylinders, Configuration/Fuel-Advanced/Individual Cyl Fuel Corr., but for this to happen you need to know where you are and this is only possible if you can monitor each cylinder individually.
#529 | |
#530 |
ドクターマリオ
Stopped by RSI on my way home this evening. Oogled Bergen's car a bit and picked up this stuff from Jonathan & Pat. Getrag shifter kit using M46 parts. They modify the shifter cage from an M46 and also the selector rod in order to use a standard Volvo shifter on the Getrag. Totally rad. Also got some bronze shifter bushings to go with it.
Said shifter bushings: ![]() Next to the old plastic bushing: ![]() Shifter cage/adjustable selector rod: ![]() Quick test fit on a spare Getrag I have in the garage: ![]() Next to the original Getrag cage: ![]() Volvo shifter quick test fit in new cage: ![]() They build the selector rod in this kit to use the Volvo rod selector linky-thingy (that's the technical name ![]() It attaches to the selector rod like so: ![]() Other end of that will connect to the trans and the retaining pins will be held in by the stock Volvo sleeve. Super happy with this kit, and another cool product from RSI. What I can't believe is why RSI hasn't posted any info pics on this kit yet - Jonathan, put it up on the website so these other fine folks can buy it from you too! |
#531 |
Post-Hypnotic Sigma
i very much can sympathize with the frustration, light-hearted, of not seeing their products on the website. you're lucky being able to just stop-by and browse. awsome.
#532 |
![]() Join Date: May 2007
you should turn the old (and now very vestigal) reverse lockout knob into a super stealthy overboost switch or something
#533 |
ドクターマリオ
#534 |
well no. you could just use an M47 cap, duh
#535 |
ドクターマリオ
#536 | |
Volvospeed Spy
Maybe write the shift pattern on the top with nail polish or something.
-Eric - 1995 850 T5-R Yellow - Back on the Road - 2006 Dolphin Boats 22 Bull Center Console - 250 ETEC |
#537 |
Hipsters ruin everything™
im sorry cameron... if you ever notice an eagle shaped dent with the word Wyoming, barely distinguishable, on your fender, it wasnt me... or my belt buckle wild fredoming all over your car... because its near my penis... which will be on your car... because i love it...
it will not look exactly like that. ![]() |
#538 | ||
ドクターマリオ
Imma see if I can get the BMW shift indicator plate to fit the M46 shifter first. If it does, I'll run that. If not, it's duct tape time ![]() Quote:
#539 | |
You can make tons of power on it, just make sure and take plug readings and keep your ears tuned in well rather than just relying on an O2. :-) I'm mostly going off of what I've heard from the heeb, as well as non-turbo b234s. I've never run a b234 mani on a turbo'ed car, even with the super skinny brake booster there was no way in hell it was going to fit. The b230 mani isn't exactly the bee's knees either, but it's at least a bit more even. |
#540 | |
1983 242 ICSCC GP Race Car |
#541 | |
ドクターマリオ
No? I'm reeeeeally hoping I can make it fit w/ the skinny booster off a carb'd 240 along w/ the tight 90 degree elbow from ATP. I suppose I might have to switch to the V shaped master reservoir from an ABS car to a bit more room too, but hopefully not. |
#542 |
ドクターマリオ
#543 |
ドクターマリオ
Duct tape idea is out the window for now... The BMW shifter emblem I ordered this morning just showed up, and I'll be damned, it fits ****ing perfect into the M46 shift knob
#544 |
oooo, whered you get that little gem?
#545 |
ドクターマリオ
#546 |
nice work cameron,
I ordered one just a few minutes ago ;)
in quasi-retirement... |
#547 |
ドクターマリオ
#548 |
nice, dont know what that is, lol. i wonder what other ones would fit nicely... hrmmmmmm
#549 |
ドクターマリオ
#550 | |
Prius Owner
![]() Join Date: Jul 2008
93 245 LS Engine Swap Project |
