Old 02-15-2009, 11:19 PM   #1
ilikepie911
Question Identifying T3 Turbo
My friend has a 240sx with a 2.4L 4 cyl, and he is planning on turboing it. He purchased a rebuilt Garrett T3 taken from a Volvo 740 (not confirmed), with a compressor A/R of 0.42, and a turbine A/R of 0.48. The turbo is both oil and watercooled. It had the exhaust side bored out a little bit during the rebuild.
He was wondering if it was the 45 or 50 trim, and if it is possible to identify that without having to take off the compressor housing and measure the inducer and exducer. Here are the compressor maps for the two.
He is planning on pushing about 200-220whp with this turbo but is reluctant since it seems so small. Are there any dyno graphs on the B230ft with this turbo with stock boost and overboosted? That would really help put this into perspective.
Thanks in advance.
ilikepie911 is offline   Reply With Quote
Old 02-16-2009, 12:00 AM   #2
DooDoobrown
DooDoobrown's Avatar
This came off of a 1990 740T It is not a Garret it is a Mitsu TD04HL 13g or c one of the two idk. You might want to take it apart and rebuild it anyway. If it is a Garret T3 and it came off a Volvo its probably something like 25 years old.
-1984 242TIC
1989 244dl lowered and being prepped for 16v T conversion
-Rsport rods and pistons for sell or trade for performance rods and pistons for B230f
-2003 S80T6
-B&G's and Konis
http://s618.photobucket.com/albums/t...oodoobrown242/
DooDoobrown is offline   Reply With Quote
Old 02-16-2009, 01:05 AM   #3
ilikepie911
Age is not important as this Garrett T3 has not been used since it was freshly rebuilt. The issue is identifying whether it is the 45 trim or the 50 trim, and how much power can safely be pushed with a large 2.4L 4 cylinder without being seriously inefficient. A small FMIC will be used to keep the inlet temperatures as low as possible.
Old 02-16-2009, 09:21 AM   #4
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
it would be the 45 trim if it's a .42/.48 garrett, only the 1989's got the .52/.48 which is 50 trim iirc.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 02-16-2009, 11:02 AM   #5
tryingbe
Boosting along.
tryingbe's Avatar
Only 6 bolts holding onto the compressor housing. Takes me less than 1 minute to take them off.
85 GLH 367whp
00 Insight 72 mpg
94 855 in hibernation
Old 02-16-2009, 11:28 AM   #6
towerymt
the real Towery
towerymt's Avatar
700 series with the .42 a/r housing should always have a 50trim wheel. The 240 got a 45 trim wheel in the .42 a/r housing. I have at least one of each. The housings look identical, but the 50trim wheel is obviously just a tiny bit larger. They're both really small, though.
Since the turbo you speak of is rebuilt, I would say just run it as-is. It should spool quickly and make pretty good power at ~15psi, although it will need a different turbine housing if it has one specifically from a 740, since the flange has a recessed area that mates with the raised lip on a Volvo manifold. A standard flat T3 flange was only used on Volvos in '81, but they're common on the '80s Fords.
A 60trim wheel and .60 a/r compressor housing from a Ford T3 would be a cheap & easy upgrade. For more money and more airflow, a T04B or T04E compressor housing and matching wheel would be the next step up.
Old 02-16-2009, 11:32 AM   #7
MrBill
fige=500Dollar Mistake
MrBill's Avatar
posting from work is a bannable offense.
Someone say crazy rays?
Old 02-16-2009, 04:14 PM   #8
towerymt
the real Towery
towerymt's Avatar
I have the day off, so I assume you want me to ban you?
Old 02-17-2009, 02:42 PM   #9
ilikepie911
At 15psi of boost (PR of 2.02), as per your suggestion, the requirement for the KA24DE engine that is going to be boosted is 37.82 lbs/min. That is far beyond the map, even on the 50 trim. Doesn't seem feasible. How much whp do guys regularly push with these turbos on the B230FT motors?
Old 02-17-2009, 02:49 PM   #10
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
they don't make much more than 200whp normally. You'll want to snag a t3-60 trim compressor wheel and either the nissan housing or ford housing. should drop onto that turbo and will flow a little better. Buddy of mine used a volvo turbo briefly on his 240sx before upgrading to a 60 trim wheel and housing, it did alright. He only ran about 7psi.
it doesnt really matter in the end, you'll break the pistons in the ka regardless of what turbo you choose
Megasquirt Tuning!
Old 02-17-2009, 03:05 PM   #11
jungledorifuto
/\ whats with all the ka hate? don't be mad
jungledorifuto is offline   Reply With Quote
Old 02-17-2009, 04:27 PM   #12
linuxman51
linuxman51's Avatar
what would I possibly have to be mad about? I don't own one, don't want one, haven't inherited one, I call them as I see them. and around here there's a lot of broken ass ka-formerly T's
Old 02-18-2009, 12:35 AM   #13
ilikepie911
What do you expect when most people half ass it and use an SAFC, without any timing compensation with a CR of 9.5:1. If done right, the stock internals can hold huge amounts of power. The record is 528whp on totally stock internals. Many people commonly run about 300whp on their daily driver KA-T's, many of them with over 200k on the engine before boosting. lol
Stop the hating and misinformation :P
And thanks for the answer, 200whp seems a lot better than the stock 120-130whp, should be a hell of a difference. That makes this turbo perform about the same as a T25, as per used on the redtop SR20 motors, correct?
Old 02-18-2009, 02:33 AM   #14
towerymt
the real Towery
towerymt's Avatar
Sounds like a B230F/FT...
tractor engine = truck engine
Old 02-18-2009, 04:43 AM   #15
ilikepie911
Hell yeah, truck engines ftw! The KA is closer to the B230's than any other Nissan motor. Especially the SOHC KA.
Old 06-01-2010, 02:40 AM   #16
jet_brick
jet_brick's Avatar
i came across this uber old thread tonight doing research. A friend of mine who is a toyota / lexus tech and volvo fanatic swears that the ka engines, sr20det engines are outright garbage and the bottom end is made of chocloate. I do realize the former is a truck engine, but I'll take a mechanic and perf. fabricator's word that nissan 4cyl turbo and non turbo engines used in 240/silvia are geerrrrrbage
1991 740 turbo = All go, zero shoW (decimated clearcoat red)
jet_brick is offline   Reply With Quote
