Old 03-09-2009, 03:38 PM   #1
psy
psy's Avatar
Default good spark plug for b230ft
I did search but lots of threads come up and I get different reponses for different set-ups, but what is a good spark plug for a stock set up that may see a boost lvl of 12 psi?
thanks in advance.
http://votom.mybrute.com
“It is possible that mankind is on the threshold of a golden age; but, if so, it will be necessary first to slay the dragon that guards the door, and this dragon is religion"
psy is offline   Reply With Quote
Old 03-09-2009, 03:44 PM   #2
Husker4volvo
i have had good luck with ngk...
Volvo less for now looking for a 240 turbo wagon...
Husker4volvo is offline   Reply With Quote
Old 03-09-2009, 03:58 PM   #3
Janspeed
Janspeed's Avatar
+1, NGK BP7ES , cheap and good quality.
Old 03-09-2009, 04:12 PM   #4
J2_
J2_'s Avatar
stock set-up; NGK BP6ES
J2_ is offline   Reply With Quote
Old 03-09-2009, 06:13 PM   #5
Volvorules
Has a Built Trans!
Volvorules's Avatar
Stock plugs from the volvo dealer
Rob
1981 242 - tuned by Heebspeed (11.8 @ 114)
FOR SALE: http://forums.turbobricks.com/showthread.php?t=275711
how psi a stock can support?
Originally Posted by MrBill View Post
not even thieves like 7/9 series.
Volvorules is offline   Reply With Quote
Old 03-09-2009, 07:39 PM   #6
psy
psy's Avatar
thanks guys
Old 03-09-2009, 10:34 PM   #7
crazy240
crazy240's Avatar
i knew a volvo mechanic here in sa but he passed away in a wreck, he had a heart attack while driving his 850. he swore by installing 850 turbo sparkplugs. said he got better fuelmilage and more power since they spark better. NGK is a really good brand. im running iridium or however you spell it.....
crazy240 is offline   Reply With Quote
Old 03-09-2009, 10:36 PM   #8
Dawson
Svenska Stålet!!!
Dawson's Avatar
BPR6ES
BPR7ES
Or the ones that say "Volvo" on them.
[/thread]
1966 122s '72 B20 Punched out, Reworked F head, Isky cam, Electronic Ign, Dual Weber 45mm DCOE's, E-fan, M40, IPD springs 'n sways, poly bushings, Bilstein HD's, Blaupunkt system.
1987 F-350 Diesel, 4 Dr, Long Bed, Dually, 88k miles, "The 'MURIKA Truck"
1993 245 Turbo The daily. T3/T4 Hybrid, M46, the usual...
Dawson is offline   Reply With Quote
Old 03-10-2009, 12:35 AM   #9
DustyLBottoms
DustyLBottoms's Avatar
Um....I'm pretty sure they don't fit. The threads are different. (To be confirmed tomorrow)
'90 745t - TD04HL-13T, Custom ground cam , V90 Interior, V90 Moonroof, T-5 Swap.
DustyLBottoms is offline   Reply With Quote
Old 03-10-2009, 01:34 AM   #10
crazy240
crazy240's Avatar
i bought a B21ft from him to put in my 242 and they are still on. maybe he rethreaded the ports??
Old 03-10-2009, 02:07 AM   #11
DurableSwedish
Hunting for a turbo
DurableSwedish's Avatar
what are the experience with iridium or better plugs? any not broke TB'ers have experience with the $6+ plugs?
NGK Iridium, bosch +2/+4, E3, pulstar, splitfire? I usually run iridiums in my cars and they do fine, I've got the E3s in my wife's car and she picked up about 3mpg just swapping to those weird things...
2 Mercedes, 2 Volvos.
DurableSwedish is online now   Reply With Quote
Old 03-10-2009, 06:50 AM   #12
740Weapon
Traitor
740Weapon's Avatar
anything other than copper is a waste...
Bosch recomends NOT using +2 and +4 plugs on turbo cars...just think about that... to me that says that the funny electrodes are a fundamentally worse design.
Also, any funny metal was implimented for longevity, not performance. which is really counter productive with a higher-HP application where your going to be inspecting and changing plugs regularly as part of trouble shooting.
'90 744 16 Valve. 16.317@85.55. Sold
'92 244 http://pbase.com/740weapon
Old 03-10-2009, 01:33 PM   #13
jspork1
jspork1's Avatar
i have had no problems with my ngk's bp6esand still at $2 a blug
blow off valve $45, manual boost controller $20, modified exhaust $100, boost guage to monitor boost level $50, adding stickers to your vehicle in a pathetic attemp to gain horsepower?!?! ...PRICELESS... for everything else theres ebay..
jspork1 is offline   Reply With Quote
Old 03-10-2009, 01:34 PM   #14
jspork1
jspork1's Avatar
plug.... i cant type today
Old 03-10-2009, 01:57 PM   #15
SteveMD
Membro
SteveMD's Avatar
How about I sig your post? That'll learn you!
Anyway, go to the Jy and check out the b230ft's there. Pull any plug that says 'Volvo' on it. How's that for cheap?
Originally Posted by jackbombay View Post
....I think that a goat could make a decent pet/friend."
SteveMD is online now   Reply With Quote
Old 03-10-2009, 02:34 PM   #16
DustyLBottoms
Ok, I'm wrong....threads are the same. But there's twice as much threaded area on the 850 plugs as compared to the redblock plugs. So either 850's project more....or the redblocks are shrouded?!
Old 03-10-2009, 02:45 PM   #17
MrDoug
"Forty-threee dollars"
MrDoug's Avatar
Threads are the same- reach is within 1-2mm, both use metal gasket seats. The main difference (besides heat ranges) is the hex size: 5/8 for whiteblock plugs, 13/16 redblock plugs. The S60/V70R
Plugs have the longer reach
MrDoug is offline   Reply With Quote
Old 03-10-2009, 03:01 PM   #18
gsellstr
gsellstr's Avatar
I've tried a few different ones thus far, and the best I've had yet have been the Bosch Super +'s. Cheap, they perform better than the BPR6EY's I've run, along with a few other variants. I went from the Volvo plugs to NGK's in Gwen's and saw a noticeable reduction in performance from her 60k+ old Volvo plugs to the NGK's. Swapped in a new set of Volvo plugs and it's much happier.
I may go iridium down the road, but for the price, it's WR5DC+'s for me...
RIP Doug "Mr. Doug" Williams, 4/15/2009
74 144 B20
90 745Ti, AW71L, IPD bars/springs, Koni SA's, JVAB B230FT, Big Valved 531 head, IPD Turbo cam, GT2871R @ 18psi, TLAO chips, E85, NPR, 3.5" DP, 3" DP-back, MSD, TruTrac, Wilwood BBK
If you need Superpro bushings PM me or check the current GB, running until 3/31/13 at http://forums.turbobricks.com/showthread.php?p=4493644).
Old 10-24-2009, 02:28 PM   #19
yamahapro
Turbonetics power!
yamahapro's Avatar
so which are better? ngk bp7es and bp6es? one is more expensive. what about boschs?
89 244 GL+T, HKS ssqv, turbonetics turbo @ 9 psi, Vibrant Muffler, B cam, G80, m47, 23/25's, strut braces, Hd's, Ipd springs, 4 inch Intercooler, X-Stream K&N, 967 ecu, OPTIMA, Corbeau seats and a grant steering wheel.
R 1 3 5
2 4
I MY BRICK
yamahapro is offline   Reply With Quote
Old 10-24-2009, 02:33 PM   #20
gsellstr
gsellstr's Avatar
Depends on engine setup, and which heat range you need. I'm running the Iridium's in a 6 heat range with god results so far. I've also run Bosch Super Plus's in a 5 heat range that were burning quite well.
Honestly, go check out your local autozone for some NGK BPR6EIX's.....you'll like the price.
Old 10-24-2009, 03:54 PM   #21
yamahapro
Turbonetics power!
yamahapro's Avatar
What are the different heat ranges?
Old 10-24-2009, 03:57 PM   #22
dbh86
What's a 16V?
dbh86's Avatar
http://www.ngksparkplugs.com/tech_su...2.asp?mode=nml
IIRC, 6's are stock for volvo
7-8 is usually recommended for turbo use...
This is for NGK tho.
'07 MS6 - DD/DSP of doom
'92 245 - Eternal Project
Incidentally, if we're going to follow this other train of thought, you should install your spare tire while the vehicle is cruising at 55mph, since that's about where it'll be used most often.
dbh86 is offline   Reply With Quote
Old 10-24-2009, 04:14 PM   #23
yamahapro
Turbonetics power!
yamahapro's Avatar
So should I get the 7 range?
Old 10-24-2009, 04:20 PM   #24
hoydog
Get the 7 range for turbo use, BP7ES. Use BP6ES for n/a.
1988 240DL+T
hoydog is offline   Reply With Quote
Old 10-24-2009, 04:29 PM   #25
yamahapro
Turbonetics power!
yamahapro's Avatar
Originally Posted by dbh86 View Post
iirc, 6's are stock for volvo na
1
