Old 03-20-2009, 03:12 PM   #1
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
Default Electric fan conversion to 760 Turbo
I finally got started on my e-fan conversion or at least the start of it. Parts I got or will be using
- OEM E-fan from a Volvo 940 with the plastic holders
- Saab temperature sensor
- OEM E-fan Relay
I read allot about this but was never sure what to do with it. The article on the main page describes another conversion than I am doing now. I used the plastic from the 940 and cut it dremeled it down to the size of the 740 radiator (I got a all steel radiator upgrade too!)
Offtopic What models came with the all steel radiator? I got it from a guy that breaks volvo’s but never saw the small size radiator in all steel, only the ones with the sides from plastic like i got in the 760 and had in my other 740/Offtopic
Very happy with the result all the parts seem to bold on pretty neat I think it will work great for the flow of the cooling. Now all I’m missing is the relay that I might just borrow from the 960 parts car to see if it works tomorrow..
Old 03-23-2009, 06:12 PM   #2
Mr.Borrie
Mr.Borrie's Avatar
dammit the saab sender i bought does not work pfft have to find a new one
Old 03-23-2009, 06:46 PM   #3
Morley
Barbie Ken
Morley's Avatar
There is a Volvo temperature sensor which pops right into the radiator, useful if you want to keep SAAB out of the equation. (We all do, don't we?)
Buy the sensor at Volvo to make sure you get the rubber gasket as well. Drill a 22mm hole in radiator, insert, secure with zip-tie, DONE!
Morley is offline   Reply With Quote
Old 03-23-2009, 07:05 PM   #4
Mr.Borrie
Mr.Borrie's Avatar
I have that sensor in the radior , the one that turns on the fan on the front right, i was told that it doesnt work with what i got
pops in the whole seen in the last pic
Old 03-23-2009, 07:15 PM   #5
ubs
ubs's Avatar
wait wait wait ... is it that easy?
Volvo for life. But sometimes, Volvo for race.
'98 V70R B5234T/M58
'96 960 D5252T/M90
'88 760 B230ET/M90
ubs is offline   Reply With Quote
Old 03-23-2009, 07:18 PM   #6
Mr.Borrie
Mr.Borrie's Avatar
i do recall that sender from volvo is around 50 euro's here.. then again parts are here the most expensive it seems
Old 03-24-2009, 03:19 AM   #7
Morley
Barbie Ken
Morley's Avatar
Worked fine for me with a S60 fan and generic 40A relay. I installed it in the hole halfway up/down the radiator.
Yup.
Old 03-24-2009, 04:28 AM   #8
BigBen
BigBen's Avatar
the Volvo temp switch's number is 1276229-0
are you sure it's 50 euros? i'm gonna need it soon, too ;)
BigBen is offline   Reply With Quote
Old 03-24-2009, 04:38 AM   #9
Morley
Barbie Ken
Morley's Avatar
It was sub 200NOK when I bought it, ~€25 should be enough.
Old 03-24-2009, 04:49 AM   #10
Mr.Borrie
Mr.Borrie's Avatar
yeah, well like it said netherlands is EXPENSIVE, getting parts in de UK or germany is usefull for us
Old 03-24-2009, 06:38 AM   #11
JW240
All idiot, no savant
JW240's Avatar
i told ya so
What do you want to do with the temp switch thats in the radiator? Im not sure what temp it switches at, probably higher than the new temp switch you have to get for the Efan conversion. You can ditch the small efan thats mounted in front of the radiator when the new Efan is in place anyway. Especially since you don't have a working A/C anymore.
the copper radiator is pretty common on older 200/700 series. our 760's have them and ruben's 242 too. The nice thing about them is that they don't have breaking end-tanks like the newer ones that have plastic end-tanks. Not that i had issues with them breaking yet though.
240 | 1991 | 341K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
940 | 1992 | B230FB
Old 03-24-2009, 06:41 AM   #12
Mr.Borrie
Mr.Borrie's Avatar
Originally Posted by JW240 View Post
i told ya so
Eh? you told me to get the saab sender in the first place?
Old 03-24-2009, 06:43 AM   #13
JW240
JW240's Avatar
I said:
the T-piece of a Saab.
the sensor switches at a wrong temperature, get another one for that.
Old 03-24-2009, 06:46 AM   #14
Mr.Borrie
Mr.Borrie's Avatar
ah okay yeah i do recall that.. i got the sender from ruben tough with a volvo hose to it so i kinda thought it would be the correct one.. got partnr on the volvo sender?
Old 03-24-2009, 06:49 AM   #15
JW240
JW240's Avatar
there is no direct volvo sensor for this application, at least not that i am aware of. Remove the old sensor from the T-piece, go to auto parts place and ask for a sensor of the same size but of a different temperature. From the top of my head: 87/92C (its a dual sensor).
edit: i dont remember the temp of the sensor that was included, indeed strange that it isnt the right one actually, maybe it was never installed. whats the temp of the sensor?
Old 03-24-2009, 07:09 AM   #16
Mr.Borrie
Mr.Borrie's Avatar
i'm not able to find it on the sensor right now it would need a good clean first and i;m wearing not the propper clothing to do that right now
Oh btw i got the temp set for next to nothing from ruben so even with the sensor being wrong or broken that is totally cool
Old 03-24-2009, 07:42 AM   #17
Chad242ti
Wookies R Us
Chad242ti's Avatar
Default All Metal radiator
Ruben's 242 has the 3 core metal one because I bought it from IPD to replace the original nasty well used one...
Chad
Smokin...
Chad242ti is offline   Reply With Quote
Old 03-24-2009, 07:43 AM   #18
Morley
Barbie Ken
Morley's Avatar
This is the temperature the Volvo switch operates at, IIRC. On at 92, off at 87'C. You find them in late 940s with AC, among others.
The SAAB switch is only loved because you get the T-piece for the rad hose with it.
Old 03-24-2009, 07:44 AM   #19
Mr.Borrie
Mr.Borrie's Avatar
Chad
Oh that's cool.. i might have to swap that with mine when ruben is not looking then
Old 03-24-2009, 07:54 AM   #20
JW240
JW240's Avatar
hey thats good info about the sensor, i recently pulled a brand new radiator from a scrapped 940 which has the sensor too. LH is a bit lazy with turning on the Efan in my 240 so this sensor will be connected too. nice.
Old 03-24-2009, 08:01 AM   #21
Morley
Barbie Ken
Morley's Avatar
Previously VDO had a .pdf file on their web-site with all technical info of their sensors, with cross-references between the automobile brands, thread sizes, resistance relative to temps, on/off levels etc.
After the Continental take-over, there's nothing useful on their website. I think I have the .pdf on a 'puter at home.
-EDIT-
Not the same, but useful info nontheless: http://www.partsforaircraft.co.uk/do...ech%20info.pdf
Old 03-24-2009, 08:03 AM   #22
initialD
initialD's Avatar
i already have the e-fan from a 965 for my 745 but looking for the temperature sensor
, itīs obrigatory to put an saab sensor? arenīt they all the same? is the e-fan 1 or 2 speeds? on what temp must the sensor open? 90degres?
JDM is not just a look itīs a state of MIND
initialD is offline   Reply With Quote
Old 03-24-2009, 08:09 AM   #23
JW240
JW240's Avatar
-EDIT-
thanks for the link, that will come in handy!
Old 03-24-2009, 09:30 AM   #24
gear whine
advocate of k-jet
gear whine's Avatar
i've been wondering what the temperature rating is of the saab in-line unit?
does anyone know this??????
400 klubb!!!
For Life.
gear whine is offline   Reply With Quote
Old 03-24-2009, 09:38 AM   #25
Morley
Barbie Ken
Morley's Avatar
