![]() Hi,
Welcome to my project. I am creating a high-performance sporting 164, which I have called the 164RS. The project has been on UK forums, I finally got around to putting on turbobricks as well so here is a catch up. 20 years ago, when I was a student, I had two 164s. I enjoyed them both but then I did not have the funds or expertise to modify them as I would have liked to. Now I think I can, so I've returned to the 164 to build the car I really wanted. Several areas of this project will be new challenges for me, so I'll often be seeking advice! As a base, I wanted a good condition, manual, small bumper 164E. In April 2007, I bought the best one I could find for sale. It was in Germany (bought via an internet ad). I flew out and drive it 800 miles home. ![]() For 12 months I have used the car quite a lot and did some running upgrades: Suspension upgrade (part completed) Wide wheels M410 overdrive gearbox Volvo sport instrument set ![]() ![]() In May 08 I took the car off the road to start the major work: Right-hand-drive conversion Bodywork restoration & respray Engine rebuild Supercharger & intercooler installation Engine rebuild (& modifications/upgrades to suit supercharging) Mappable engine management (ignition & fuel) Gearbox and overdrive rebuild Rear axle rebuild, probably with LSD Full suspension upgrade Partial re-trim, including fitting sports seats Rather than taking the whole car to pieces at once, I have planned the project in phases. Between the phases, the car can be put back on the road if I want a break or need to get remotivated. Here's the first installment of photos: Engine block on the stand, not dismantled yet ![]() Head, not dismantled yet. More engine updates later ![]() Bodywork: RH inner wing, virtually no rust ![]() RH chassis rail, small repairs in progress on both sides ![]() ![]() Underneath RH chassis rail, awaiting repair ![]() RH inner wing, battery tray removed (the battery will be moved to the boot to help weight distribution) ![]() LH inner wing had one rust patch, repair in progress ![]() ![]() Front chassis cross-member had some rust on the right-hand-side... ![]() ![]() ... this was repaired and strengthened over original design (seam welded and corner piece added) to give extra torsional rigidity to cope with uprated suspension and grippy tyres ![]() Matching strengther added on the left side also (this side was not rusty) ![]() For the same purpose, the left and right chassis rail supports have been strengthened with extra welds ![]() ![]() RH front floor, rusty! Not repaired yet ![]() LH front floor, zero rust ![]() That's as far as I've got on bodywork. Onto the right-hand-drive conversion. This is proving harder then I expected. The RHD 1973 144 I got my parts from had an ambidextrous bulkhead with removable panels on both sides. However, my 164 of the same year has a non-symmetrical bulkhead with a removable panel only on the left side. So quite a bit of manufacturing was required... Removing dashboard ![]() ![]() First trial fit of RHD steering box and column ![]() ![]() Trial fitting of RHD 140 pedal box ![]() Trial fit of servo and brake cross-bar ![]() ![]() ![]() ![]() Beginning to make the servo mounting bracket... ![]() ... and the support bracket inside the car ![]() Bodywork: Chassis rail repairs in progress ![]() ![]() Chassis rails finished (to be painted later) ![]() ![]() ![]() ![]() RHD conversion: Test fitting pedals. (LHD 164 throttle is being modified for use on the right) ![]() Priming the various RHD brackets ![]() Reassembling the heater after checking the matrix ![]() Starting the wiring for RHD ![]() ![]() ...here's a shot of some helpers at the garage. Can't get the staff!! ![]() Seeking some opinions please folks. I'm in two minds about whether or not to fit a front spoiler to the 164RS. It would be something subtle and period, quite possibly the same spoiler I fitted to my last project, the Scimitar V8 (see below, this is a modified Dolomite Sprint spoiler). On looks alone, I think I would go without the spoiler, but I'm keen to reduce lift. There will be blasts across Germany from time to time once the RS is finished and above 110-120mph the 164 front-end gets a bit "floaty" So, do you think someting like this would look OK on a lowered 164? Thanks John ![]() |
![]() Next chapter:
Bodywork Removing underseal from inside front wings. Not a nice job, but necessary to tackle the rust that starts underneath the underseal when it's old and brittle. Luckily nothing too serious here, surface rust. ![]() ![]() De-rusting... ![]() ![]() ... and priming ![]() ![]() Same treatment for the front panel, but so far I've only done the underseal removal and cleaning. ![]() ![]() ![]() ![]() Engine No work done on the engine yet - keen to start but forcing myself to get the boring rust-killing done first. However, an interesting ebay purchase has arrived. ![]() Spot the previous owner's error? ![]() I might sell this on, becuase I have a Volvo intercooler with bigger surface area, which will fit the 164, But this does look pretty! ![]() I've also done almost all the wiring now, for the RHD conversion, but that really is too dull to take photos of! November 08; the last few months I have been tied up with other things. Work has been busy, plus... Got the track-day car ready for sale to help fund the 164RS, so the old Cavalier has gone to a new home in Ireland. ![]() Also bought a '98 BMW 540i touring as daily driver, and had some mechanical and body-work jobs to do on that. And got my Mum's Peugeot 106 prepped and sold... good price on ebay. And help my friend repair a rear-ended Ford Ka, of all things! Anyway, back to the 164RS... Following on from that last update, I found some more rust. I think its suffered from the water leak problem, because the floor has rotted out from the inside; it looked solid from underneath Right front floor, rust cut out. The outrigger was fine, no rust. Rear floor section repair in progress here ![]() Left rear floor, rust cut out ![]() Right rear floor, repair in progress. (Sill is OK. The rust inside is just debris from the work on the floor) ![]() Floor repairs seam welded in, primed and with seam sealer in place: Right front ![]() Right rear ![]() Left rear ![]() From underneath, right... ![]() ... and left ![]() Inside, painted: ![]() ![]() ![]() Left front, zero rust here. ![]() Seatbelt boxes and belts are now refitted (no photo) All wiring is competed for the RHD conversion (no photo) Part-way through installing RHD dashboard. You can see my Volvo Sport ambient temp guage, mounted centrally instead of the clock - that's a rare item! I am looking for a sender for this, if anybody can help I'd be grateful. It is the same sender as the 240 type VDO analogue amb temp guage. ![]() Bodywork Engine bay prep for painting. ![]() ![]() Extending the lower radiator mount. (I am moving the rad back to allow the intercooler to mount in front of it.) ![]() Painting the RHD brackets etc in satin black ![]() Stone-chip on the chassis rails, inner wing panels and inside the front wings ![]() ![]() ![]() ![]() ![]() Ran out of stone chip here... finish this later. Once the stop-chip is done, inside the front wings will be painted with black chassis paint then, after all the other paintwork is finished, covered with dinotrol rustproofer before it goes back on the road. ![]() The primer... ![]() ![]() ![]() The primer was carefully dry-flatted all over (no photos). Then.... finally time for the long awaited base & lacquer. (Four base coats, one of 2 pack lacquer). I'm pleased with it so far. It's not perfect up close (e.g. some dust particles in the lacquer), but it's OK and the engine bay will look good when fitted up with all refurbished components. I have not painted the front panel yet because it needs some surgery first to help it accommodate the intercooler and a cold air feed. I soooooo love that colour! ![]() ![]() ![]() ![]() ![]() ![]() Cheers John |
![]() The next installment...
RHD conversion Fitting the brake servo and master cylinder to my fabricated bracket. I am using a modified 144 RHD cross beam. The brake components aren't too old, so they were just resprayed and refitted. ![]() ![]() Steering column, pedal box, cross beam bracket and RHD 164 steering box fitted. ![]() ![]() Engine bay & bodywork Engine-bay wiring is partially refitted (the rubber mat is a precaution to avoid any drips of brake fluid on the new paint). I will be making something to hide the ugly row of mismatched relays and wires on the left inner wing. Although Volvo originally left these on display, I think it's messy and spoils the look of the 164 engine bay, so mine will have a neat cover. ![]() Right inner wing with the stonechip completed (I ran out when doing this originally). ![]() Both inner wings painted with black chassis paint ![]() ![]() Wiper motor and manifold pressure sensor cleaned up and refitted, and some more of the wiring back in place ![]() Coil refitted ![]() Front panel part-way through de-rusting ![]() Modifying the front panel to accept the intercooler. ![]() ![]() ![]() A close-up of the parts cut out. It's similar on both sides of the car ![]() Here's the trial fitting, showing where intercooler will be mounted. There is more work to do here yet. If I use the original radiator, I'll need to modify the side pieces. I also need to make some brackets to hold the radiator at the top (like the 240 & 740 have) because the original 164 mountings (at the sides) had to be removed to make the intercooler fit. Further mods are needed to reposition the radiator expansion tank and PAS reservoir, and to accommodate an air filter box at the front of the engine bay. So it will be a long time before I can paint the panel. ![]() ![]() Interior My seats. They are from a Japanese market mid '90s Mazda RX7. I chose these because they are similar to the '70s Volvo P1800ES seats, which I was thinking of using, but these have much better support bolsters. They will be reupholstered in leather to match the 164, with box-pleats added to the centre section to match the 164 rear seat. ![]() Subframe fabricated to attach the RX7 seats to Volvo 140 brackets (which are shown in primer) ![]() ![]() I have moved the hand-brake to the right hand side. ![]() Rims!! Finally, a very nice package through the mail from Norway... my wheels! ![]() They are 17x8.5 Super DTM, correct fit for RWD Volvo with no spacers. Having said that, the rear wheel arch clearance will be very tight, so some ingenuity will be needed there. I couldn't find a UK distributor, and for some reason the Swedish dealers won't ship abroad. In the end, I managed to track down a company in Norway who would ship to the UK. Cheers John |
#4 |
Good news everyone!
![]() Damn what a project!! very nice!!
where did you get the super DTM's? I'm looking for a set as well.
'89 Volvo 745 GLT 6.0 V12 project '91 Toyota MR2 Turbo (SW22) '09 Audi S8 5.2 V10 (daily driver) (sold) '18 Dodge Challenger R/T Scat Pack |
#5 |
OG 5EURO OG
![]() holy crap. awesome!
2006 tundra 1999 boxster |
#6 |
fige=500Dollar Mistake
![]() Join Date: Jan 2006
![]() wow lots of work is going into that thing. It's going to be amazing
1978 244dl - Down for paint/16vt 93 245 - Kaplhenke Shortened coilovers with adjustable Koni Reds, adjustable rear spring perches with revalved bilstein S-10 shocks. Turbo 2.5 motor in the works. 10 v50 - Unobtainium T5 R-Design AWD M66 |
#7 |
![]() Next installment:
Front suspension Cross member during underseal removal. A messy and unpleasant job! ![]() Looks much better after cleaning and shot-blasting ![]() ![]() ![]() Dismantled and primed ![]() ![]() The cross-member was originally grey with black wishbones. I haven't quite decided yet, but I think I'll be going for satin black for all parts; I don't really like the grey - it looks like primer. Any views? Seat fitting is going well, I forgot to take photos I'm afraid. I have welded strengthening plates onto the floor so hopefully my front mountings will be very solid. I'm using threaded bar to give some height adjustability, as Volvo did originally on the passenger side, but I'm using two mountings instead of one, and thicker bar. Bodywork: Drilled some drain holes in the newly repaired floor. A car this old is likely to leak a bit, no matter how careful I am. Volvo's solution was to let the water rust its way out; I prefer to give it an exit. The metal around the holes is angled so water won't come in as the car drives along. ![]() Water-proof sound insulation stuck down & Waxoyl applied ![]() Battery cable fitted ![]() Cover panel refitted ![]() RHD conversion: Reinforcing the centre console moulding before fitting. This is a weak part of the dashboard and was flexing a lot when I was refitting switches so I strengthened with a piece of stiff wire, fibre-glass filler and resin ![]() A few shots of the dashboard and wiring coming together ![]() ![]() ![]() The pedal box installation is now complete. A RHD 144 box modified to suit the 164 (the bulkhead is different, as is the angle/position of the steering column). The bar and hole you can see bottom right are for the throttle cable. ![]() The LHD 164 clutch cable is fitted temporarily, to check everything works. I will need to get a longer cable made up. Brake linkage is finished. ![]() Other bits Driver's seat test fitted, adjusting things to get the driving position as I like it. ![]() My period '70s Volvo R Sport wheel; found on German ebay. I was going to do a test fitting, but the boss kit it came with is way too short, so I can't yet... but I thought I'd post a picture anyway. It needs to be recovered. ![]() Can anybody tell me what horn-push badge this wheel would have had originally? Any help or old photos would be appreciated! Steve is now helping me on Saturdays. He was looking for a Saturday job and I was wanting to move the project on more quickly, so it all fitted together very well! He has a mint '79 244called Thor. Although he's only just 17, he has good car skills already, and he works hard. Interior: The job we started out to do was test fitting some rear seatbelts from a 240. I was quite confident they would fit the 164, but I wanted to check and be sure. We got a bit distracted when we removed the rear seat (see below) but the belts will work fine. ![]() Bodywork: Bit of a nasty shock here. Not a disaster, but some repair work I hadn't planned for. I knew that repair panels had been fitted in the past in the inner wheelarch, above the shock absorber mounting. But we found out yesterday that the job had been bodged. Instead of cutting out the rusty metal, the repair panel had just been tacked over the top. Of course this makes everything rust faster. The left inner wheelarch as we found it. The "repairer" hadn't even removed the sound deadening whilst welding the other side of the panel! You can see that the rust continues past the bulkhead seam and into the boot area. Inside the boot, the repairer had put wide sellotape or something similar over the rust and sprayed it body colour... mmm, quality work! ![]() The right wheelarch looked better, but when we removed the sound deadening it was also rusty, with a repair tacked over the top. ![]() Left side with sound deadening removed. ![]() ![]() At first, we thought we might be able to cut out the rusty metal and weld a sheet to the back of it, retaining the repair panel. So the grot was cut away. ![]() Part of the rear bulkhead to be cut out to gain access. Unfortunately, because of the bodge, the repair panel had also rusted and become very weak and easily holed. ![]() ![]() ![]() So, the only way to do a proper repair is to cut out the repair panel completely, right back to solid original metal. Cutting in progress... ![]() We got a bit further than this, but we must have forgotten to take photos later in the day. Steve also did a lot of underseal removal under the wheelarches, we'll photograph these soon. The good news is that rust is confined to the inner wheelarch and has not spread into the chassis rail at all. The rail takes the vast majority of the shock absorber load, so I am very confident that a seam welded repair, with reinforcement on the inside joined to the bulkhead, will give a strong and permanent repair. But it's still annoying that this work is needed purely because of shoddy workmanship. I am sure a previous owner paid good money for this repair, back when it was in Switzerland or Germany. Done properly, it would have lasted many years but I'm sure they would be horrified by what we found. Cutting out rust. I took out the lip above the shock mounting to ensure that I was back to strong, rust free metal. ![]() I was surprised to see that the floor panel is not welded to the shock mounting section, it just sits next to it. ![]() Here is the lower repair section I made. ![]() Test fitting... ![]() ... view from inside the car ![]() Here is the strengthening tube... ![]() ... which fits like this ![]() Stage 1 of repair, seam welding the shock mounting to the floor ![]() Stage 2, welding in the lower repair section... ![]() ... and seam welding the end of the original bulkhead where previously it had just two spot welds ![]() Stage 3 is welding in the strengthener (no photo) Stage 4 (when both sides of the car are done to stage 3) is welding in the cross-brace tube. This gives torsional rigidity by joining the strenthening tubes; it's also welded to the fairly flimsy original bulkhead near the middle of the car ![]() Stage 5, closing panels. This is work-in-progress. Will be seam welded soon ![]() Rear wheelarches seamwelded, with welds cleaned up prior to painting. ![]() In primer ![]() Rear suspension On volvoforums, Sam raised a point about the upper shock mountings: should they have an outer mounting, with the inner wing panel continued downwards and drilled for the bolt to pass through? The Scandcar repair panel does have this. I've done a little research on Sam's point. It seems that they did not originally have an outer mounting hole; these pictures are from one of my workshop manuals: General layout shot, shows the strengthening plates but no outer mounting. ![]() This diagram confirms it, showing the detail of the top mounting. You can't read the compenent list on this photo, but there is only a washer on the outside edge. ![]() I'm told that the Scandcar repair panel has an outer mounting because it is a 240 part. I decided to leave mine as is. My chassis rails are completely solid, and the area is now much stronger than when Volvo built it - and it seems they did not fit an outer mounting. Bodywork Rear arch repairs at the seam-sealer stage. No photo, but I was very careful to fully seal the area underneath the lip so there are no gaps that water and muck can get into. ![]() ![]() ![]() And primed ![]() ![]() ![]() Not the prettiest repair ever but I know that the area is now totally rust free and very strong. The wheelarch areas will be left in primer for now, because there is further work to be done there in replacing the outer wheelarches and making my big wheels fit! Last edited by john r h; 03-28-2009 at 04:46 PM.. |
#8 |
Rolling...
![]() That's quite an impressive project. Looking forward to seeing the end result. Thanks for sharing.
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe |
#9 |
![]() Front suspension
All the new bushes are fitted to the wishbones and here they are in primer ![]() Front cross-member has been sprayed satin black ![]() And here's Steve dismantling one of the front hub assemblies, prior to refurb ![]() Front cross-member refitted, and part-way through assembly. ![]() I'm glad I went for satin black rather than the original light grey; looks better in black in my opinion. ![]() Using extra shims at the top wishbone mounts, I have dialed in some negative camber (approx 1.5 to 2 degrees) and quite a lot of postive caster angle... I'm determined this is one 164 which won't understeer! The set-up is a guess at this stage. When it's up and running, I'll get the angles measured and equalised, then suss out how it handles and adjust it from there. You can see that the top wishbone pivot is no longer parallel with the turret (the rear mounting bolt is shimmed more than the front one, to increase the caster angle). To avoid any undesirable stresses on the top wishbone pivot bar, I made and fitted some wedge-shape shims so that everything still bolts up tight and square. ![]() The shiny black is waxoyl. Not very pretty, but this car is built to be used a lot and I want to avoid it going rusty as long as I can! Lower wishbones fitted ![]() ![]() Steve de-rusting the brake backing plates ![]() ![]() Dashboard Fitting and wiring the kill-switch into the dash ![]() ![]() Front suspension Here are the hub uprights and the anti-roll bar refurbished and ready to fit. ![]() ![]() Springs, dampers and uprights refitted, ![]() ![]() Steering being reassembled ![]() Anti-roll bar and droplinks refitted (it is a 25mm IPD bar) ![]() Brakes I've had several really lengthy sessions making brake pipes. I had to reposition the junction box for the front brakes because moving the radiator back (to allow for the intercooler) clashes with the original location. I fitted it on top of the chassis rail under the master cylinder. My relocation meant that all pipes had to be made from scratch with no patterns to work to. I wanted to make them look as neat as possible, and doing that takes a long time! The brake pipe tool, which is a cheap and effective peice of kit. ![]() Bending using the vice (I don't have a pipe bender unfortunately). ![]() This shows the front/rear junction box fitted and piped to the master cylinder. Pipes for the front circuits in progress. ![]() Front circuits finished (except for flexi pipes). I used the steering idler as a "clamp" for the brake pipes because it has a gap behind it which is exactly right to hold, but not crush them. ![]() Trial fit of rear circuits. These will be neatened up and fitted properly later on, after the underside of the floorpan has been repainted. ![]() Back plates refurbished and ready to fit. I am just waiting for new wheel-bearing oil seals to arrive, then I can completely finish the reassembly of the front cross-member. ![]() Calipers refurbed; I fitted new dust covers because they were distorted but I choose not to dismantle the calipers at this stage; the brakes work fine and all pistons move freely. (I do have some new piston seals, in case I have any problems in future). ![]() Bodywork Steve is doing a great job of removing old underseal from the floorpan. I hope he can get it out of his hair! ![]() I'm making a plywood rear shelf to provide a strong mounting for 6x9 speakers. (Wood is not my best skill area, we don't really have tools for wood and I can confirm that plywood smokes a lot when cut with the angle grinder!) ![]() Original parcel shelf cover cut to accommodate the seat belt covers and the speakers. ![]() This will be fitted as a cosmetic trim over the top of the plywood shelf... here's a mock up: ![]() The seatbelt boxes and the speaker grills will all be sprayed satin black to make them less obtrusive. March 09. Phew, that's the catch-up done... thanks to anyone who waded through this far! Cheers John |
#10 |
![]() nice those RX-7 FD3S seats are great
1987Volvo 780 GLE: stock, boring and in questionable condition 1989 Volvo 740TiC wagon:B230ET,G80 Locker, Port polish,Oversized valves,10PSI(MBC) ,M cam (parts car now) 1980 Suzuki GS1100e: semi cafe racer project |
#11 |
KING OF TBOT
![]() Join Date: Dec 2004
![]() My friend just got a 164.
That's a really nice project, and I'm sure, an inspiration to a lot of 164 owners |
#12 |
![]() This looks a really good project when are you hopeing to get it done by
pete |
#13 |
ಠ_ಠ
![]() just read through, looks like some serious effort going into this. can't wait to see how it turns out.
#14 |
![]() Amazing job man! Gonna be one sweet ride
#15 |
![]() Hi there,
Today's update: Front brakes Everything going back together. For now, I am reusing the old discs, just cleaned up the surfaces. They are good condition and, if the car turns out to be too fast for these brakes, I'll upgrade to something bigger. But I think they will be OK. ![]() ![]() ![]() ![]() ![]() Bodywork Steve has done a great job removing all underseal from the floor ![]() ![]() Painting in progress ![]() ![]() ![]() That's all for now! Cheers John |
#16 |
![]() Thats meeee!!!
![]() Yes as many of you have said to John - this is going to be an awesome project. Personally I cant wait for the engine rebuild! Steve |
#17 |
Looking for Bay Area work
![]() Cool project. What are the details of the supercharger and engine build? Have you nailed down details or are you still in the planning stages? I just got a '75 164 with an auto that I'm trying to figure out what to do with.
#18 |
What, me worry?
![]() Join Date: May 2003
![]() Nice project- looking forward to more updates.
#19 |
Not such a PRVert Anymore
![]() Holy crap. That is one of the most extensive projects on this board at the moment I think, the amount of work you're putting into it makes everyone else doing little bits here and there seem like amateurs, other then BB-Q, who is basically making a whole car.
Using the stock Volvo IC isn't the best idea however, they are thin and don't flow that well, that other one you have pictures is a lot thicker core and bar and plate, so it will flow a lot better then the Volvo one.
#20 | |
Ham fisted idiot
![]() Wow, that's a lot of work you've done so far. You guys are definitely doing the right thing and not cutting corners. I'm excited to see the end result!
#21 |
![]() Beautiful car. Its a credit to you. Will be nice to see when its done and on the road, also more updates. ahah if you were going to call it an RS, you shouldve called it a Porsche lol
I just loaded all of it......dial up...... and im amazed. That is brilliant. It is awsome to see the extensive work you have done. Bloody brilliant mate. Makes me think twice about cars that a small amount of rust on the OUTSIDE. Good work mate. I cannot wait to see the continuing process and final product. Saving this link so i can come back to it when it gets lost. Last edited by ovlover; 03-29-2009 at 03:57 AM.. |
#22 | |||||||
![]() Hi folks,
Thanks for the positive comments, very motivating to read sitting here! A few responses: Quote:
(Well, actually, the other problem on an auto is the gearbox, but I guess that's the same with most 70's autos? In the late '80s I had a '75 164E auto; and had the auto box checked as being in good health. Later I converted it to an M410 and, with nothing else done, it felt like it gained 30 to 40% more power. Subjective feel of performance went from 'not bad but a bit frustrating' to 'this is quick enough to really surprise people'. I wonder if anybody has ever retro fitted a more modern 80s/90s auto box with 4+ speeds and lock-up? That would make a nice 164 because the auto does suit the character of the car). Quote:
I thought of 164GT, Volvo used the tag for tuning upgrades. Then I thought 'what would Volvo call it if it was a step beyond a GT?'. I thought 164R, then 164R Supercharged, then just 164RS. As well as Porsche, Ford (& maybe others?) used the RS tag in the early 70s so I settled on that (even though a supercharger not definite at the start of the project). Quote:
Yeah, there is always more rust than you can see (even when you can't see any!). I'm sure your climate in OZ will be kinder to car bodies. The vast majority of 164s in the UK rusted away long ago; they were already quite rare here 20 years back. My car was put into dry storage in Switzerland for 15 years, and this has helped it last fairly well for a European car. I am focused on the final outcome and I have a clear picture in my mind. However, I don't work fast (it's a fun hobby, not a job) and have lot's of other things to do, so don't hold your breath! Quote:
Objective: It is not a 'max power' project. I am seeking a reliable 250-270bhp for road use I don't want it highly stressed; I am hoping to get at least 70 or 80k miles before another rebuild is needed Strong torque and good drivability Reasonable fuel consumption when cruising I have worked out the spec using Corky Bell's excellent book, "Supercharged!" The definites (95+%): Fully rebuilt & balanced K-cam Reduced CR (10:1 standard in euro B30E) Heavy duty oil pump Mild flow work on the head Pistons to cope with boost/heat. Forged pistons, or ceramic coated (I may have to use a 74 or 75 metric B30 because I could then use B21 forged pistons) Oil cooler & remote mount oil filter Higher flow fuel pump Supercharger (Eaton M62) Intercooler Megasquirt (or similar) for fuel and ignition. Knock sensor. OE injectors will flow enough Extractor exhaust manifold [header] & custom large bore system Different air flow meter (don't know which yet) OE inlet manifold, modded to accept AFM Cone type air filter with cold air feed The possibles: Larger exhaust valves Over-bore to 3.2 Water injection (fit later if needed) Electric water pump If the B30 has the nerve to blow up after all that work, I'll weld a chain on top, sell it as a boat anchor and drop a Chevy LS in there! Cheers all John |
#23 |
![]() Great project!
But what i was wondering when i took a closer look on the photo's: Are you not going to change the windshieldwipers to RHD style? |
#24 |
I was born at a young age
![]() very very nice work there!
I like 164's a lot! BTW, why supercharge it? Do you need to do that to achieve 250-275bhp? Keep up the good work! |
#25 | ||
![]() Quote:
- Never done a supercharger install but always wanted to have a go - I want the engine to last... don't want to have to rev it high all the time to get the power - Serious head work (needed to get it breathing with NA) would probably cost more than a supercharger - Potential for adding some more boost/power later if I feel like it - Loads of room for a supercharger to the left of the engine (non-crossflow), unlike for a turbo where things would get very crowded on a RHD car (I tried it for a year with LHD but didn't like it... too difficult to get overtaking visibility on narrow UK roads. That, and trying to change gear with the door handle!) Cheers John |
