Old 03-29-2009, 02:33 PM   #1
700volts
Default Got some stuff accomplished - helrazor's '90 700
Winter '17/'18 - Blown headgasket!....installed new HG (of course) also installed freshened-up 531 head, new IPD turbo cam, ported exhaust manifold (and ported hotside), resealed head mounted distributer, water pump, front seals, plugs, timing belt and all other drive belts.
December '15 - Originl heater core gave up. Replaced with all metal aftermarket unit, pretty simple job. It's like a dashboard puzzle.
November '14 - Converted to round tooth gear set including a TTR adjustable cam gear. Timing Belt. New radiator, water pump, t-stat, all front and rear water related hoses and clamps, heater control valve, auxiliary belts.
July '14 - All tune up parts including filters.
June '14 - New upgraded clutch installed by Eastside. New cluth fork, throwout bearing, real main seal, etc.
March '14 - Volvo amp finally gave up so installed new stereo with bluetooth and all that good stuff.
July '11 - 3" Downpipe built by RSI using 2 90 degree mandrell bends. Full 3" back now complete.
April '10 - New IPD lowering springs, new Sachs Turbo Gas struts & shocks
March '10 - Browntops, Install IPD HD CBV Spring kit
Feb '10 - Upgrade 25T with 15G
Dec '09 - Front rotors/pads
July/October '09 - Calibrated boost gauge, Narrow band air/fuel gauge, delete Turbo + system, Manual Boost Control install, Intake heat shield.
May '09 - New FPR, New Fuel Filter, Sea Foam Crank Case, New Main Fuel Pump
April '09 - 3" inch custom mandrell bent Cat Back system, Timing Belt, Auxiliary belts, Water Pump, Thermostat, Front Engine Seals (cam, straight shaft), Sea Foam Fuel Tank, Plugs, Cap, Rotor
March '09 - Air Box removal, 3 inch Cold Air Intake, NPR Intercooler Installation, Lowered car.
#1 PROJECT - FACTORY AIR BOX REMOVAL:
After TEST fitting my NPR, I decided that things would be WAY too cozy in there, so the Volvo factory air box had to go! No Big deal...my only concern was that my car is equipped with the dealer Installed " TURBO PLUS " system. I wanted to keep this system intact because at this point it is still working well and gives me 20 extra ponies at WOT. I found that none of the " TURBO PLUS" components rely on the Air Box but served as mounting points for the Turbo Plus. So I found new homes for them, yanked the Box, then sourced an elbow to come off the MAF into a 3" Filter. WOW!! I can now hear that little T25 go!
#2 PROJECT - NPR INSTALL:
Overall I would say that the NPR IS pretty much drop-in depending on your skill level....but you can't just slap it in there. Here are a few things I chose to modify to get the NPR to fit nicely and keep a clean stockish look.
*I placed a long piece of wood for the IC to sit on, this brought the intercooler up high enough to clear the oil cooler.
*I sliced some meat off the tranny engine cooler bracket -
*I modified the radiator brackets a bit -
*I chopped several inches off of the cold side hard intake pipe -
*There were a few other little things not really worth mentioning, I think it came out pretty clean -
#3 PROJECT - LOWER THE CAR!!!:
With the low profile tires the car looked like a 4X4, too much space between the tire and fender lip. I couldn't stand it any longer. Lowering the car took a few hours but only cost me 20 bucks. I'm not proud of how I did it, I'll just leave it at that.
- BEFORE -
- AFTER -
Pretty sure the next project will be 3" cat back system, not as do-it-yourself as this stuff was.
Thanks for looking!
1990 740 Turbo THREAD - 1967 122 - 1989 780
700volts is offline   Reply With Quote
Old 03-29-2009, 02:59 PM   #2
Dfer10
# 2961
Dfer10's Avatar
lookin good, front needs little lower imo
2002 S80 T6 died a shameful driveway bashing
Dfer10 is offline   Reply With Quote
Old 03-29-2009, 03:10 PM   #3
john r h
Looks good. Very smart engine bay
John
john r h is offline   Reply With Quote
Old 03-29-2009, 03:13 PM   #4
Jerd
Jerd's Avatar
Very clean work. What boost and injectors are you using?
Old 03-29-2009, 04:10 PM   #5
700volts
Agreed!
Old 03-29-2009, 04:24 PM   #6
Cojones
Cojones's Avatar
That's a good looking car. Sweet.
Cojones is offline   Reply With Quote
Old 03-29-2009, 06:01 PM   #7
700volts
Stock injectors at this point....boost is also set at stock, I'v read its around 7 then 12ish for a bit when the Turbo Plus kicks in.
Old 03-29-2009, 06:08 PM   #8
shellshock
Below, is a photo of Clay
shellshock's Avatar
GREAT clean car man! We need more of these around here! haha
Can you tell a difference on stock boost with the NPR?
1988 740 Turbo
2005 S60R M66 flashcama
2007 XC90 V8 Sport
1983 SAAB 900 Turbo
shellshock is offline   Reply With Quote
Old 03-29-2009, 06:49 PM   #9
700volts
With the NPR, I'm not sure I can actually feel a big difference on the lower end, the air box removal helped out in that area.
Where I DO feel a difference with the NPR, is after the Turbo Plus kicks in, it is a very noticeable difference. The engine just seems flat out stronger on the top end.
Old 03-29-2009, 06:56 PM   #10
GhengisKhan
Where did you acquire said NPR intercooler? I want one!
GhengisKhan is offline   Reply With Quote
Old 03-29-2009, 06:58 PM   #11
700volts
There is one in For Sale right now, hasn't been pressure tested though. They pop up from time to time around here.
Old 03-29-2009, 07:51 PM   #12
volvo940tuner
volvo940tuner's Avatar
i never find a real straight answer..what size NPR is the 'close to drop in'?
'93 944-SOLD
'91 745 TIC- PARTED OUT
'97 854 R- SOLD
'96 854T Platinum- SOLD
'98 S70 GLT- SOLD
'98 V70R-SOLD
'95 854 T5-R--teh yellow
'90 744 TIC SE
'96 854R-winter car
'88 BMW E30 325IS
volvo940tuner is offline   Reply With Quote
Old 03-29-2009, 08:01 PM   #13
spruill244
Mahalos
spruill244's Avatar
Im looking for an NPR right now for my 740. Someone sell me one!
Image and video hosting by TinyPic
68' 145S-Sold
90' 745T-Sold
95' 850R-Sold
83' 244T-Sold
96' 850R- Sold
spruill244 is offline   Reply With Quote
Old 03-29-2009, 08:20 PM   #14
thelostartof
unbalanced chemical
thelostartof's Avatar
just an FYi but that is not the trans cooler, that is the external oil cooler
thelostartof is online now   Reply With Quote
Old 03-29-2009, 08:31 PM   #15
700volts
You are so right, I never really followed the lines back, but now that you mention it my 245 is set up the same way and I remember seeing where they led when I did the wiring harness on that.
One of my next projects is loosing the T25 and putting a T3/T4 on it, anyone know who makes downpipes for that sort of a swap?
The core on this one is 19.5 wide X 14.5 tall, so that's not including the end tanks.
Old 03-29-2009, 08:34 PM   #16
hockey930
moar lower!,
looking good. I had turbo+ for a while. Found I liked the mbc a little better.
08 535xi wagon 6sp
99 Miata
Exocet
hockey930 is offline   Reply With Quote
Old 03-29-2009, 08:43 PM   #17
Jerd
Jerd's Avatar
An MBC and some more boost will make a HUGE difference, you should consider some chips
I really like your car btw.
Old 03-29-2009, 08:44 PM   #18
thelostartof
unbalanced chemical
we can hook you up with the turbo and downpipe, we have all you would need here to build a t3/t4 with a 3" Vband outlet and downpipe, let me see what size compressor wheels we have along with turbine housings, add in a set of chips from me and you should be good to go for tons of power
Old 03-29-2009, 11:49 PM   #19
700volts
I'm ready!
Old 03-29-2009, 11:56 PM   #20
thelostartof
unbalanced chemical
send me a PM with your goals and we can talk parts and prices, We should be able to take care of you and help make that car pretty stupid fun
Old 03-30-2009, 03:02 PM   #21
700volts
I think that's where I am headed or why not a combintion of both? But I wanted to delete or upgrade each system one at a time, get everything to cooperate then move on to the next.
Old 03-30-2009, 03:36 PM   #22
volvo940tuner
so whats the total size of the 'drop in' NPR for 740 then?
Old 03-30-2009, 05:43 PM   #23
700volts
I believe the NPR here in my thread is the one that is usually referred to as being the 'Drop In' one. I can't imagine one being much easier to install considering it came out of a truck. But like I said a few minor changes were in order, nothing major if your a bit handy. The NPR that I got actually had a twist in it and it still fit nicely.
Mikes thread below shows some killer measurement photos and was also a source of inspiration to do it. And the measurements he illustrates are pretty much the same as the measurements that I posted earlier. He also includes the measurements including the end tanks which I don't really remember.
http://forums.turbobricks.com/showth...ht=NPR+install
Old 03-30-2009, 06:51 PM   #24
volvo940tuner
Great.
Theres still some debate on the board about the eBay IC in comparison to the NPR intercooler. Can anyone offer their thoughts on it?
And what size eBay IC is the 'drop in' size?
Old 03-30-2009, 07:34 PM   #25
700volts
I did some searching here a few months back and I kept on seeing the same size ebay IC's poping up that seemed to be working for people. I dont remember what the dementions were but it looked killer. Just a little searching.
