Well Washed Elitist
Had a bit of a lubrication problem over the weekend...
The Engine had 30k+ on tune, was run HARD and had leaned out quite a bit in the last few months (AMM not adjusted since replacement)... At first we thought it was detonation, then we pulled the piston...I will post picks of the block carnage (several large holes) when we pull it. Just a few pics for now...Please forgive me for the dusty bay... ![]() ![]() ![]() -Reminds me of Terminator2 and the shotgun to the head scene. Piston face has valve slap marks (exhaust), but head and valves are fine...TG. Piston skirt and cylinder wall is fine too. Pisses me off! Crank is toast too... Engine idled nicely with the exception of all the noise. |
didn't know people blew up n/a motors around here
bummer, hope you get a replacement for not too much $$$ |
You did that to a B23 without a turbocharger
A dirty mind is a joy forever Drove: '87 Escort 1.3:'90 mini Jumbo:'87 360GLT:'87 744T:'92 240 Polar:'84 744T:'95 854T5:'90 744GLE 16v:'87 340 1.7:'79 343DL :'84 340L:'91 240DL lpg:'89 360 GL:'94 944TDIC M90:'85 360 GL:'90 745 GL:'89 744 GL:'86 745 TIC:'94 Nissan Sunny 2.0D:'92 Peugeot 205D:'88 360:'85 340GL:'86 360GL:'84 242TIC: '85 244 TI:'89 Dai racer:'95 460: '85 360GLS:'83 340 DL: '97 944IC: '91 AX Cup:'93 Diehatsu:'98 Polo D:'87 360GL Drive: Citroen C15D |
#4 |
(/// _ - )
Location: Receiving Transmission from David Bowie nipple antenna
wut happen
The Green The Red The Black The White The Bike Volvo parts I'm selling Custom 8mm sparkplug wires! |
#5 |
we've had a couple come in blown up at the shop. 3 to be exact. looked very familiar.
![]() -Vagabond 1980 242 DL - shake a tail shaft! 1980 242 DL - (the ugly twin) sold :-\ 1986 s10 blazer, smallblock, bagged, suicide doors. RIP 1991 244 N/A - stripped and left for scrap. |
#6 |
Well Washed Elitist
I tune n/a's...this particular example was a head/peripherials buildup, didn't do anything too heavy to the block. Was running about 11:1 with machining, etc. Anyway, I think this was an oiling problem... the rod cap was melted, as is the crank bearing to rod... I'll post some picks of the intake setup (ports, valve angles, etc...) as we tear down the motor more. All I really need is a block, preferably a b23ft, but I'm not too picky.
Never had this one dyno'd, but the gtech gave us 0-60 in 7.xx and approx. 210hp. For whatever that is worth. |
#7 |
![]() 1984 340GL 1.4 CVT (dead); 1987 760 GLE V6 Saloon (dead); 1989 740 Turbo Estate (current)
#8 |
Whooty patrol
rod bolts prob failed. looks like a high rev failure.
'82 242t turbo+, intercooled, 3" exhaust, 13" brembos, coilovers, saabspoiler, 18"s, flathood, dying m46, etc. '97 f-250 psd, d60, locked, chromoly axles, shortened and bob'd. '91 940irs rallybil, holset, gutted, olive drab rollered on paint, browntops etc '90 F-250 project. Lots of links, tube, and coilovers. |
#9 |
holstrich 2.0
Is that aluminum foil insulation in the second pic?
Isaac ![]() 1995 940 Turbo: Holset HE351 @ 20 psi, Emusa External Wastegate w/screamer, Mild Steel Header, 4" Downpipe, Ostrich Emulator, IPD Turbo Cam, TTR Cam Gear, Big Piping and Intercooler, 3" Exhaust, V8 T5 soon, Greddy BOV, AEM Wideband, 18" Pegasus, B&G Springs, Billy HD's, Chassis Bracing, Sumimoto HTR ZIII 225/40/18 |
#10 |
I wake and bake every day
tardcore vibes
Living for a living ![]() Hopefully soon driving a TDI of some sorts with a lil camper behind it
#11 |
Is that the rare super short rod block?
245 ti - ipd springs, billy hd's, 25mm sways, poly, A cam, b230 mani swap, 2.5" turbo back, 10psi, 3" intercooler, E-fan, AC deleted, M46 with stage 1 PP and 6 puck clutchnet - more mods to come? LH 2.2 convert, ported 90+, LPG once EFI. |
#12 |
ALDORF THE DESTROYER OF WHITE SHIRTS
That sucks but all you can do is
build another
![]() linuxman51: if the neighbors piss me off, I'm going to silhouette some blowup dolls F*cking up there. Turbo Joe: Im white girl wasted. I AM ALDORF THE DESTROYER 1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles 91 945 Turbo Ecodes, Springs, 16t, 3 pedal auto, DD 83 242 Turbo Flathood Doug <3 me. Not scottyd. |
#13 |
#14 |
Well Washed Elitist
I wasn't driving the car... bro was, eeerrr his woman was (for the first time)... so i can only assume. The car supposedly popped on the interstate at 70mph, maybe she knocked the shifter and that was that. I agree with the bolt failure, sounds more probable. If I can gather all the little bits, I may be able to see what happened.
And no, it's not reynolds aluminum foil insulation, it's some type of aerospace approved foil/neo insulation, I had a sheet of it back when this one got built, I was having an arcing problem from ign. wire to injector wire. But after nearly 5 years of running balls to the wall, I'm happy with the overall outcome. Honestly didn't think this one would last as long. Time to do up the +T and whatnot that I have contemplated for so long...I think the recently purchased 240 will become the donor, or just throw this head on and drive. |
#15 |
Well Washed Elitist
#17 |
Well Washed Elitist
#18 |
if u say theres signs of heat, it could be a spun bearing
#19 |
I think you'd probably hear that plenty before the bolt let go. I know when my MR2 spun one it immediately sounded suspect at part throttle.
#20 |
Rolling...
OK, see, I think I can tell what your problem is right here.
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe |
#21 |
Exklusiv Zubehör Klub
![]() Join Date: Sep 2002
Yes. Doubt it broke a rod bolt. I mean yeah they broke eventually, but if you had oiling problems that means it probably fragged a rod bearing and then the rod clunked it's way around on the journal until it couldn't take it any more.
These motors aren't known for just breaking rod bolts. Even revving the hell out of them they will turn into a wheezing mess of valve float and just fall on their faces long before they actually rip a rod bolt in two. |
#22 |
manofewords
Must've sounded like a D24 @ idle with the death rattle going on. At least, if the head's good, you've an SCP head, since that motor's late enough.
-J
![]() ![]() 1984 245GL - silver; 1984.5 (more like 1985 now) 245Ti - blue - Both M46 cars. |
| Thread Tools | |
| Display Modes | |
