Old 06-25-2009, 06:35 PM   #1
Lord_Athlon
Ballsdeep in wire.
Lord_Athlon's Avatar
Default FM Modulator or AUX input ? Eclipse 4421
I have a twelve year old Eclipse 4421 that im in love with, and refuse to part with, so dont bother.
My HU has a 6 disc changer and I found out that there is an adapter to interface two RCA's. The problem with that is that I lose my CD changer. I dont want to do that because all my HU has onboard is a cassette.
My other option is an Audiovox FM modulator, of which I have heard lots of positive reviews on. This will be 30 bucks more than the interface cable.
Weighing the pros and cons, what should I do?
'83 242ti Silver. BBS. Turbo. Megasquirt.
Originally Posted by scottyd View Post
V8 go vroom
Originally Posted by mylilnismo View Post
I just wanted to thank whomever it was that deleted my post. You wanted it, you got it, here's your price, FREE 99 to finger-bang your mother.
Old 06-25-2009, 07:34 PM   #2
DNAsEqUeNcE
†500DollarSparkMap
DNAsEqUeNcE's Avatar
Interface cable. Nothing beats hardwired.
Matthew 10:28
And fear not them which kill the body, but are not able to kill the soul: but rather fear him which is able to destroy both soul and body in hell.
Originally Posted by Karl Buchka View Post
Any ECU, when improperly wired, tuned, or installed will be unstable and unreliable.
Long live the pen15hood.
DNAsEqUeNcE is online now   Reply With Quote
Old 06-25-2009, 07:41 PM   #3
badvlvo
Bad for Babies
badvlvo's Avatar
Wire it.
i have had both, FM modulators are OK but don't sound as good.
Old 06-25-2009, 07:49 PM   #4
bdimag
abandon all hope
bdimag's Avatar
this is for 4 channel applications... but you get the picture.
http://www.crutchfield.com/p_469MPSS...lector&tp=2796
in this case it has 2 remote wires (one for each input)... install switches and relays to your liking.
Brian
1991 244
2004 S60
bdimag is offline   Reply With Quote
Old 06-25-2009, 09:02 PM   #5
Lord_Athlon
Ballsdeep in wire.
I know nothing sounds better than hardwired, I just dont want to lose my cd changer.
Old 06-25-2009, 09:04 PM   #6
MrBill
JohnMc=500Dollar Mistake
MrBill's Avatar
but you'll have all your CDs on your portable audio device.
Hardwired and don't look back brah.
Originally Posted by 500dollar744ti View Post
something i feel strongly about because even if it doesn't appear so, i am a strong advocate of safety.
84 244 - Wilbur - Lemons hopeful
97 960 - New DD/beater
97 960 - Other new DD/beater
Old 06-26-2009, 05:22 AM   #7
plantationwalrus
uʍop ǝpısdn
plantationwalrus's Avatar
Use a WIRED FM modulator instead. Sounds 10 times better than a regular FM mod. It will play on a set frequency and you'll never have to change the channel because instead of giving you the ****ty wireless quality, you get a direct plugin via your antenna. Not the "best" connection out there, but the best option given your circumstances. They're $50 at best buy, not sure how much they are elsewhere.
'94 944t
-iPD sways, Billy HD's, TME springs, Cherry upper/lower, SS lines, YoshiFab phenolic spacers, Pegs, Fred's Chips, browntops, MBC @ 15psi
-Polk MMC6500's front, Polk MMC690's rear, Polk 400.4 amp, Alpine MRP-M1000 amp, Fi SSD sub, Eclipse 8454 deck
plantationwalrus is offline   Reply With Quote
Old 06-26-2009, 09:23 AM   #8
hockey930
Spending Money On The 760
the best anything fm modulated can be is fine.... even if it is hard wired. The aux input is always the way to go.
some people don't have the setup or ear to tell the diffrence.
If you think xm radio sounds "great" then an fm modulator is for you.
85 760t 16Valve, holset turbo, getrag 265, twin disc
06 V70R 6mt, springs, sways, full exhaust, flywheel
hockey930 is offline   Reply With Quote
Old 06-27-2009, 05:39 AM   #9
plantationwalrus
uʍop ǝpısdn
I agree, but it sounds like he does not have the option for an AUX input. Which is why I said that it's the best option given his circumstances.
That being said, there may be a way you can tap into the left/right audio input on the cd changer harness. If there is a way you can do that while cutting the power to the changer (simple toggle switch) then you can splice in a set of RCA's. BTW on some older Eclipse HU's you have to manually enable AUX mode once you tap into the harness.
Old 06-27-2009, 11:40 AM   #10
hockey930
I think our conversation got a bit off track, the part he is looking for already exists he is just tyring to figure out if it's worth losing his cd changer over.
"My HU has a 6 disc changer and I found out that there is an adapter to interface two RCA's. The problem with that is that I lose my CD changer."
Old 06-27-2009, 01:39 PM   #11
Lord_Athlon
Ballsdeep in wire.
I ordered the aux input cable and the ipod charging/rca cable. Worst case, ill buy the FM thing later if I really want it. Or I could try and make my Sirius one work for it.
Old 06-27-2009, 01:45 PM   #12
fige
))<>(( forever.
fige's Avatar
get your ass over here
Originally Posted by diponyou View Post
yeah gotta wait for jbweld to dry before I do anything today
fige is offline   Reply With Quote
Old 06-28-2009, 11:07 AM   #13
mike alder
If you decide to go for the FM Modulator unit consider This One as it has an issolation transformer with it which will reduce any ground loop squeal that you might otherwise get.
Personally I only use Bluetooth A2DP these dyas for streaming music/ nav instructions around the car, much neater without the wires and the audio quality is stunning - not easy though withour changing the head unit (although it is possible using iO-Play if it will connect to your car) - Mike
mike alder is offline   Reply With Quote
Old 06-28-2009, 12:20 PM   #14
hockey930
you get it working yet?
Old 06-28-2009, 12:58 PM   #15
volvorod85
volvorod85's Avatar
Aux input, most MP3's sound like ass anyway, so pumping through FW with its crazy 40db or bandwidth is even better for em! <--note the sarcasm
Mark
1995 855 Turbo Stock <--Daily Driver
1979 242dl B230FT AW 71 <--Wifey's ride
1959 Austin Healey Sprite <--something completely different
1974 Fiat X1/9 <--Moms little toy
"Driving the old 2 valve 740 is a bit like driving an IKEA wall unit, so leisurely is its acceleration, so angular its lines."
My former brick saved my life 6/25/03....Volvo for Life
New pic comin eventually.......
volvorod85 is online now   Reply With Quote
Old 06-29-2009, 12:45 PM   #16
Lord_Athlon
Ballsdeep in wire.
I bit the bullet. Ordered an E-Lan adapter and an IPOD to rca cable. I hope they get here soon/I hope they work with my hu. Worst case, I return them.
Old 06-29-2009, 06:24 PM   #17
DNAsEqUeNcE
†500DollarSparkMap
tommorow is warped towwwaaa neega!
Old 06-29-2009, 07:17 PM   #18
Lord_Athlon
Ballsdeep in wire.
Random, but yeah. Your trucka run? Can you meet us somewhere? I dont know if I want to drive to phoendale.
Old 06-30-2009, 05:54 PM   #19
RedLine T5R
Well Washed Elitist
RedLine T5R's Avatar
Your eclipse have the ol'skool florescent tube display? Or am I going too far back.
Originally Posted by slammed145 View Post
Crying about what the moderators do is lame. It's Turbobricks off topic, dude. You should be ready for anything you type in here to be deleted without being all sadcheeks about it.
RedLine T5R is offline   Reply With Quote
Old 07-02-2009, 03:21 AM   #20
Lord_Athlon
Ballsdeep in wire.
it looks to be a VFD to me.
Old 07-02-2009, 12:00 PM   #21
740Weapon
Traitor
740Weapon's Avatar
modulators and FM in general sound like crap.
'90 744 16 Valve. 16.317@85.55. Sold
'92 244 http://pbase.com/740weapon
Old 07-02-2009, 12:10 PM   #22
Coupe' de Grace
Slowest in the West™
Coupe' de Grace's Avatar
+1 and what MrBill said. once the pod got wired the cdchanger sat all lonely and quiet in the corner. Adios!
Originally Posted by thebornotaku View Post
So basically I can't go strap a turbo on to my car
V A F
(1976 265dl/b27/m46 killed in battle, 1991)
(1976 265dl/b27/bw55 bring out ye dead, 2000)
1980 262c/b28/m46 'Black Knight' (getting roof/ext resto and engine swap)
1982 244t/b21ft/aw71 'Vicious Chicken of Bristol'
1989 780/b230ft/aw71 'Brave Sir Robin'
Coupe' de Grace is online now   Reply With Quote
Old 07-02-2009, 12:14 PM   #23
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
and a hardwired 2-channel input is 10 times better than that.
-Matt
1989 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1983 Ford F150- 302ci, C6/4x4, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, Bulletspeed lower, HR-Titan 20p.
the rest: 1996 850t 179k, 1998 S90 175k, 2004 V70 2.4 175k, 2005 XC90 2.5t AWD 122k.
500dollar744ti is offline   Reply With Quote
Old 07-07-2009, 12:43 AM   #24
Lord_Athlon
Ballsdeep in wire.
i said **** it and bought a CD-105 alpine.
Old 07-07-2009, 01:07 AM   #25
fige
))<>(( forever.
fige's Avatar
hahahahahaha.
