Old 06-26-2009, 02:32 PM   #1
adrianpike
adrianpike's Avatar
Default Oil Cooler Fittings
Hey all,
The threads & hardware FAQ didn't have these, so I'm gonna ask nicely:
-What's the size on the threads on the oil cooler sandwich plate? I know there's those flare fittings, but they screw into what I think are large straight metric fittings, but the only plate I've got is on my car, so I can't take a looksee at the moment.
-What's the size on the fittings on a stock 240 oil cooler? Are they the same as the 700 coolers? I can't remember exactly, do the flared fittings screw into fittings on the cooler itself?
Thanks in advance!
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 06-26-2009, 02:50 PM   #2
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
I beleive the fittings on the cooler are 1/2 NPT. Not sure about the sangwhich plate.
Old 06-26-2009, 03:10 PM   #3
240 oilcoolers are bspt iirc not NPT, 240 turbo and 740 turbo oilcoolers are the same part.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 06-26-2009, 03:20 PM   #4
DNAsEqUeNcE
†John3:16
Oah. indeed.
Old 06-26-2009, 03:23 PM   #5
John V, outside agitator
Banned
I believe they are British Standard Parallel Pipe..
Hack them off and weld on AN/JIC
Old 06-26-2009, 03:39 PM   #6
Bones
Bones's Avatar
I think the sandwich plate is 1/4 npt. Don't quote me on that.
Bones is offline   Reply With Quote
Old 06-26-2009, 03:43 PM   #7
peehound
"Arf" she said.
Hence LEAKAGE!!!
"If the Brits put up a satellite, it would have a primary chain, and it would leak oil"
Phantom Biker ~ 1970.
Nothing exceeds like excess.
peehound is offline   Reply With Quote
Old 06-26-2009, 04:18 PM   #8
yama
The sandwhich adapter I have from a 740 turbo is metric 16mm x 1.5 not NPT. PN 9919FFJ at the link below.
http://www.anplumbing.com/shop/index...p=&dept=Metric
I think John V's advice for the cooler is spot on. Weld on a AN-10
http://www.anplumbing.com/shop/index...dept=Weld!_Ons
For the low budget get a cap and drill it out. I know JV has also mentioned doing this.
http://www.anplumbing.com/shop/index...ps!_and!_Plugs
yama is offline   Reply With Quote
Old 06-26-2009, 04:29 PM   #9
Bones
Bones's Avatar
Nice. What material are those stock oil coolers made out of? Can I just MIG a steel AN fitting on, or do I have to actually break out the TIG for something?
Also, what size hose? AN -10, I assume? Wonder how many feet I need......
Yama, do you recommend that site?
While we are on the topic of cooler fittings, am I correct in saying the stock transmission cooler fittings are -5 AN?
Old 06-26-2009, 04:51 PM   #10
Banned
OK I won't.
Cause they aren't.
I run a fat NPT tap thru them
Old 06-26-2009, 04:53 PM   #11
Banned
Aluminum except early Mercedes Diesel oil coolers are all steel. Yeah steel.
-10
and depends on where you site the cooler and if you go remote filter head which all round is nice and easy.
I know nothing of autotragic lines.
Old 06-26-2009, 04:54 PM   #12
adrianpike
adrianpike's Avatar
OK I won't.
Cause they aren't.
Do you know what they are before you tap 'em?
Old 06-26-2009, 04:56 PM   #13
Banned
Yeah $6.19 vs $2.84 or over 50% cheaper!
Old 06-26-2009, 05:48 PM   #14
yama
OK I won't.
Cause they aren't.
Hadn't thought of that. Could have saved 10 bucks.
Old 06-26-2009, 06:06 PM   #15
yama
I placed my first order with them yesterday so I can't really recommend them yet. A couple of other post's have mentioned them and their prices are about the lowest I've found. Most of the stuff they sell is Earl's which is made in the USA. Some of the brands sold at Summit and other places is made in China. I'm in the process of doing the oil cooler thing and spent 150 to plumb from a remote oil filter adapter located in front of the alternator on the frame rail. From the oil filter adapter in front of the alternator to cooler I figure ~3 feet of hose to the top fitting and ~2 to the bottom fitting.
