Old 04-05-2012, 07:18 PM   #76
michal740TI
michal740TI's Avatar
After reading in this thread,I have decided to go ahead withe the crank to exhaust evac. system.Got some air check valves (free from exhaust shop) and going to weld my fitting in after the cat.
I will report back with some pictures if anyone interested.
michal740TI is offline   Reply With Quote
Old 04-06-2012, 12:17 AM   #77
michal740TI
Ok,everything looks good after the install.My setup is,5/8 in hose from the breather box into a larger 3/4in hose,that is connected into a check valve. Check valve has 3 inch extension welded after the cat in about 45 degree. This took about 3 hours,cost $15 for the hose.
When I plug the hose with my finger,I feel vacuum pulling in and increases with the higher RPM,but I didn't test it with the gauge or under load yet.I have a standard unmodified exhaust system btw.
I noticed that the acceleration is bit better from the stand still.
It looks like this system really works and I can imagine the turbo inlet likes the clean air as well.
Old 04-06-2012, 01:16 AM   #78
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
Heres a quick sketch of what I make up. The dimenions are fit to where ever i can place the darn thing.
Old 10-29-2012, 09:44 PM   #79
Magnum TE
Broke another B230F+T
Magnum TE's Avatar
So bumping an old thread, as I tend to do.
I've got a Moroso 25900 system on order. When it gets here I'm not quite sure how I'm going to plumb it.
I have modded the PCV box for duel outlets ALA TF. So I could just run those 2 hoses to my catch can, then run 2 hoses to the exhaust. With this setup I will run a breather filter on the valve cover to allow air flow in as necessary.
I could run one to the valve cover and one to the breather box, both through the catch can... Not sure if I will draw too much vac with this setup...
I could run both to the valve cover through the catch can and Fxxk that breather box. Or have the breather box draw in fresh air as needed.
I'm thinking the first one is the best one, but what all do you guys think.
Goldie Bricks - '92 940T : B230F+T MSnS-e...
The Gray Car - '92 940T : stock drive-train DD
I have some cool stuff done to my cars
The Gold Car: Owner since 2001
B230F+T MS1nS-E / Ford T5, 1pc DL
ebay FMIC / Mechman Alternator
T3 60/.63 ATP WG / 63#/hr CFI injectors
Full 3" Turbo to tail / IPD TP Cam
IPD bars / Coilovers
Koni Dampners / Lower Chassis brace
NIW-T3 camber plates / Full poly front end
Full Kaplhenke Rear end
-Torque rods -PH Bar -Subframe
Daily Driver
Magnum TE is offline   Reply With Quote
Old 10-29-2012, 10:05 PM   #80
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
I thought it was decided that a car with a muffler this doesnt work so well on.
Maybe before you plumb the system, you weld in a small pipe and hook up a vacuum guage just to see if youll get any benefit. And since your running megasquirt, log with an extra map sensor.
Old 10-30-2012, 01:23 AM   #81
Magnum TE
Magnum TE's Avatar
Interesting, I figured there'd be good flow but yea I should log it. I might just hack the muffler off at this point I'm done with pretending to be a daily driver. I hope my 3" Borla pro xs flows enough.
Where else could I put it... In the hot side intercooler plumbing, that's going to have back pressure on it too? If I had a external wastegate I could put it in there I suppose.
Old 10-31-2012, 05:50 PM   #82
doucheNozzle
Emerged as Ugly Butterfly
doucheNozzle's Avatar
I'm using this as well. However, I'm just running the one and I'm going to stick it post O2 sensor. Although the thought of putting it in my wastegate pipe has me thinking. No wait. That won't work. It needs to see constant flow.
Nathan's point about the exhaust is kinda true. The system will not work with a chambered muffler. Too much back pressure.
Can you elaborate on sticking a vent on the valve cover. Why do you think it's necessary? I never thought about it.
Old 10-31-2012, 07:50 PM   #83
Magnum TE
Magnum TE's Avatar
I think the wastegate idea is that the wastegate opens when have the most blow by / cylinder pressure (In boost). Tooling around at >100kpa isn't going to make so much CC pressure.
I'm running a straight through 3" Borla pro-xs? or (some such nonsense) so I hope it's not too much back pressure. I'm going to install both tubes past my cat/test pipe.
The breather on the valve cover is so there won't be too much crankcase vacuum, if the ventui draws more than the windage/blow by is producing.
Old 10-31-2012, 11:11 PM   #84
doucheNozzle
I didn't think there was such thing as too much vacuum.
Old 11-01-2012, 09:32 AM   #85
lookforjoe
lookforjoe's Avatar
I tried this - copied a design I found online. Fitted in the DP below the O2 sensors. Angled following the guides. 3" exhaust with dual 3" magnaflow 14834's.
...and found that I ALWAYS had positive pressure on the test gauge, no matter how I played with the offset/angle, etc.
My XR
Old 11-01-2012, 09:33 AM   #86
lookforjoe
lookforjoe's Avatar
I believe the breather on the valve cover will simply become a blow out for your oil, since any pressure will take the easiest exit route....
Old 11-01-2012, 09:45 AM   #87
740volvo
Originally Posted by Mad Adder View Post
How many here run one ? I have one on my SVO and just wondered how many on this board use one.
On my N/A 12:5.1 CR redblock I took the black box out made a plate and welded AN fittings, 1" hose runs to an AOS can, I also welded a AN fitting on the valve cover and baffled it, this also runs to the AOS can. Vacuum is being pulled from the exhaust. The bigger the hoes the less chance of oil going through them.
740volvo is offline   Reply With Quote
Old 11-01-2012, 10:12 AM   #88
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
That's why I bought a vaccum pump this time around that can pull 22 inches vacuum if I want! Always on, always working. There is a vacuum limiter, so ill go to about 8 inches. That beats the 3 inches I saw with the ford smog pump.
Old 11-01-2012, 10:16 AM   #89
lookforjoe
lookforjoe's Avatar
Nathan, what brand/model pump did you buy in the end?
Old 11-01-2012, 10:33 AM   #90
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
He GZ motorsports 101a pump.
Old 11-01-2012, 10:49 AM   #91
740volvo
I'm going to try that.
Old 11-01-2012, 11:01 AM   #92
530turbo
530turbo's Avatar
What is the maintenance on that pump? Had an old 2 vain moroso that lasted 3000 miles and came apart. Would love to try a pump again if it will last a while.
530turbo is offline   Reply With Quote
Old 11-01-2012, 11:05 AM   #93
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
I haven't ran it yet. Motors close to getting fired up. Reviews are good. There's no vanes constantly scraping, its a different design, with mileage in mind. Check there website and youtube it, there's a demo showing the differences in pumps.
Old 11-01-2012, 11:24 AM   #94
Ursan
Nokutoto-Fuki-Arikatoka
Ursan's Avatar
More stuff here:
http://forums.turbobricks.com/showthread.php?t=174464
and (lots) here:
http://forums.turbobricks.com/showthread.php?t=256223
It's only an opinion. No harm is intended.
I must now splooge all over myself.
1990 780t Kind of Modded
My 780 headlamp mod thread My Mod Thread
Old 11-01-2012, 11:24 AM   #95
Ursan
Ursan's Avatar
Is it still a Volvo engine or a 2JZ or something?
Old 11-01-2012, 11:32 AM   #96
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
Its on my 2j, but a universal pump I had to make mounts for. They sell v belt and serp pulleys so it will fit just about any application.
Old 11-01-2012, 01:06 PM   #97
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
Would love to see pix of the build up of your 12:5.1 redblock. Does the 12 to 5.1 work out to like 2:1? I wouldn't think that'd make much power. 200 PSI of boost?
ovlover: Its an auto. Problem found, Manual swap. Problem solved
linuxman51: if the neighbors piss me off, I'm going to silhouette some blowup dolls F*cking up there.
Turbo Joe: Im white girl wasted.
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo Ecodes, Springs, 16t, 3 pedal auto, DD
83 242 Turbo Flathood
Doug <3 me. Not scottyd.
WindowsBreakerG4 is offline   Reply With Quote
Old 11-01-2012, 01:09 PM   #98
doucheNozzle
No it's 12 parts BS, 5.1 parts Regina, 0 parts Turbo.
Old 11-01-2012, 01:09 PM   #99
Homer
Don't be me
Homer's Avatar
Do you have pics of that setup? I'm curious.
Old 11-01-2012, 01:23 PM   #100
Lando
Hunting with Ray Charles
Lando's Avatar
Filled in combustion chamber with jb weld and no head gasket. Or heron head with regular pistons and 10mm deep valve reliefs cut with a dremel.
Originally Posted by 740tankDriver View Post
go shove an M camshaft in a b230ft you coward. you are nothing more than a poster.
Lando is offline   Reply With Quote
