Old 08-12-2009, 07:21 AM   #1
JoiOK
Default 240 turned into tire burning machine
Lets throw in some pics of the Volvo Cobra build. This is as far as I know the first time a 4.6 32valve has been put in a Volvo 240.
The car it self is a 88 Volvo 240 originally equipped with a b230 engine and manual trans.
The engine is a 4.6 4v (32 valve) from a 95 Lincoln Mark VIII, which is the same engine as in the 96-98 Mustang Cobra. Then we bolted the intake from a 96 Cobra on it (that shuld raise the hp numbers from 280 to about 300 and give 1000 cool points). Than itl be backed up with a Tremec TR-3650 5 spd manual transmission from 2001 Mustang Cobra.
The good'ol Volvo
The new bad ass power plant.
First the old engine was removed. Than the 4.6 was trial fitted in the hood.
We had to remove the bulky vacuum brake booster and us hydrobooster setup from a mustang to clear the engine.
It seemded to fit almost nicely. But its sure going to be a tight fit!
Looking up between the headers and the frame from underneath the car, looks like there is enough clearance to fit 2.5" exhaust on each side.
Then with the engine and gearbox in, we positioned the engine about 15mm to the passenger side to gain some space where the steering shaft exits the firewall.
When we were happy with all alignments we build the engine mounts which bolt into the original engine mounting holes in the k-member and modified the x-member to clear the transmission.
The k-member had to be cut in about 1 1/2 inch to clear the oil pan.
We had a little clearance issue where the steering shaft exits the firewall so we had to move the lower end of it about 1" to the left (from inside car) an about 1" down. But that's barely noticeable in the steering wheel.
We had to modify the driver side inner fender with the biggest hammer to clear the brake master cylender, as it had to be moved about 1-2" to the left (from inside car) with the hydrolic brake booster to clear the engine.
Engine compartment was then painted gloss black for cleaner looks.
This is our current status. Next up we will install the engine and trans for (hopefully) the last time, and start the wiring process. Hope you like it!
Volvo 240R '88 - 4.6l 32V V8 Supercharged/Tremec 3650 (In The Making)
Volvo 855R '97 - B5234T4/M59 (The ServiceCar)
JoiOK is offline   Reply With Quote
Old 08-12-2009, 07:25 AM   #2
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
WOW!!!!!!!!! it fits!!
that is so awesome man! can't wait to see vids and more pics of that beast!
i love it
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 08-12-2009, 07:37 AM   #3
Raz
I wake and bake every day
Raz's Avatar
This thread wins.
in 4 weeks, add supercharger!
Living for a living
Driving an 83 Mercedes Hymer Camper around europe for a year
Raz is offline   Reply With Quote
Old 08-12-2009, 07:51 AM   #4
740ATL
Guest
hell yeah.
Old 08-12-2009, 07:55 AM   #5
ubs
ubs's Avatar
awesomeness
Volvo for life. But sometimes, Volvo for race.
'98 V70R B5234T/M58
'96 960 D5252T/M90
'88 760 B230ET/M90
ubs is offline   Reply With Quote
Old 08-12-2009, 08:08 AM   #6
MrBill
fige=500Dollar Mistake
MrBill's Avatar
can someone do me a huge favor and host these on the turbobricks image host or something? I need to show someone at work and photobucket is blocked
Someone say crazy rays?
Old 08-12-2009, 09:47 AM   #7
JohnMc
JohnMc's Avatar
Shens, that motor is TOO BIG to fit!!!
But srsly, epic kick-ass coolness.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 08-12-2009, 10:08 AM   #8
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
Cool. So how broke are you after buying that engine/trans and having it sent to Iceland?
Fake Race Car
Old 08-12-2009, 10:16 AM   #9
MrBill
MrBill's Avatar
the motor itself is common enough that it shouldn't have cost that much.
The trans though...
There's regularly a few darkVIIIs at the local yard. $185 complete motor no accessories
Old 08-12-2009, 10:25 AM   #10
TerribleOne
ZoomZoom
TerribleOne's Avatar
I've always toyed with the idea in my mind of a 240 with a 03-04 Terminator drivetrain.. Looks like it fits pretty well!
75 242GL - LS turbo, 4L80E, narrowed four linked 9"
89 244DL- Mazda 2.3 MZR, S366, 5R55E on Electromotive TecGT with PCS paddle shifters
94 945- Beater
93 965- For sale
91 940SE- Roller, for sale
TerribleOne is offline   Reply With Quote
Old 08-12-2009, 11:55 AM   #11
spruill244
Mahalos
spruill244's Avatar
that is insane
should have dropped in an LS1.
hehe
Image and video hosting by TinyPic
68' 145S-Sold
90' 745T-Sold
95' 850R-Sold
83' 244T-Sold
96' 850R- Sold
spruill244 is offline   Reply With Quote
Old 08-12-2009, 12:37 PM   #12
2manyturbos
Sweet. Keep us posted on the progress.
Old 08-12-2009, 12:49 PM   #13
supraboy
betting on a long-shot.
supraboy's Avatar
wow
Originally Posted by buzz View Post
Squirrel eat off the CPS wiring? I had that problem once.
Originally Posted by NotSoFresh View Post
try to hammer a dent in the floor under the pedal, maybe there is 10 more HP down there
This thread raped that mystery part. no one needs to figure out what it is, we can just keep going with that its just a mechanical tampon for robo-bitch..
heavy flow.
Originally Posted by resa850 View Post
Doug's going to shoot me tomorrow or Monday.
"your words always cut when there cliche', so here's a knife because i came for the buffet..." -emery
supraboy is offline   Reply With Quote
Old 08-12-2009, 12:58 PM   #14
MrBill
MrBill's Avatar
Originally Posted by spruill745 View Post
that is insane
hehe
eh. it has more aftermarket i'd guess, but omg imagine 32 valves + boost
Old 08-12-2009, 01:08 PM   #15
Mjolner
Mjolner's Avatar
What was your decision regarding engine management? Is the engine compartment a stand alone/removable harness? It would seem to to me that it has to be a real nightmare trying to figure where/if ford has been to kind enough to make this Kick @ss project any easier/difficult!!!
P.S. Just Do It!
Mjolner is offline   Reply With Quote
Old 08-12-2009, 01:11 PM   #16
fcpgroton
fcpgroton's Avatar
This car is going to be EPIC!! I cannot wait to see it when it is finished.
FCP Online Support Team
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
fcpgroton is offline   Reply With Quote
Old 08-12-2009, 01:15 PM   #17
Trevor+
Volvo Friends
Trevor+'s Avatar
Wasn't there a whole thread debating whether or not this engine would fit in a 240?
Awesome project, can't wait for the vids of tire carnage.
Here it is: http://forums.turbobricks.com/showthread.php?t=143205
Originally Posted by hathos View Post
GODDAMNIT, IT WASN'T RATTLE CANNED. IT WAS EARL SCHEIBED AND *MATCHED* TO A RATTLE CAN
Trevor+ is offline   Reply With Quote
Old 08-12-2009, 01:26 PM   #18
i drift volvos
cracker
Awesome! Thanks for proving people wrong!
You could always notch some things to make room for bigger exhaust :D
staying n/a?
1986 Volvo 245 v8 drift project
i drift volvos is offline   Reply With Quote
Old 08-12-2009, 01:59 PM   #19
JoiOK
Thank you guys for your comments!
hehe, not so broke, I got it locally for much less than it costs to import it.
that is insane
hehe
Yea, im with you on that one, Im more of a chevy guy my self but I was looking for a decent modern engine, and this engine+manual trans was available for half the cost of an ls1+auto so that made my choise.
P.S. Just Do It!
Ill use the Mark VIII ecu, its a obd 1 unit. I will also use the original ford harness, thats an easy one after few hours of cuting and splicing.
staying n/a?
Staying n/a for now at least, but 5.0 stroker internals + 15psi would be nice!
Old 08-12-2009, 02:56 PM   #20
spruill244
Mahalos
spruill244's Avatar
Old 08-12-2009, 03:01 PM   #21
i drift volvos
cracker
I know the later 4.6 "terminator" motor can take lots of power. But I guess the downfall of the 5.0 is the block itself......so it takes boost well?
Old 08-12-2009, 03:44 PM   #22
JoiOK
Actually the older 93-99 teskid block aluminum blocks are stronger than the terminator block, it "is" the same block but inn 2000 (i think I rembember correctly) ford produced them with less matterial = thinner walls, to save on costs. I was not talking about the ugly old 5.0 motor. You can get a stroker crank for the 4.6l engine that adds displacement to 5 liter. All forged of course, so it loves boost. Thats the way to go!
Old 08-12-2009, 03:47 PM   #23
i drift volvos
cracker
Schweet! Please keep us updated on the project.
Old 08-12-2009, 05:19 PM   #24
Raz
Raz's Avatar
4.6 and 5.0 are not related (modular v. windsor)
Old 08-12-2009, 05:31 PM   #25
96 t5 wagon
96 t5 wagon's Avatar
When Ford starting using 4.6L 4V motors in '93 they used an aluminum block cast in Italy made by Teksid, hence the reference to Teksid blocks. Later on in the 4 valve model run, 2001 to be exact, Ford changed the design of the block to a lighter-weight (80.40 lbs) casting utilizing SAE 319 modified alloy. This block is known as the WAP block which is short for Windsor Aluminum Plant. JoiOK very cool build btw!!
96 t5 wagon is offline   Reply With Quote
