hmm...thank for the info. What another carbs ca be considered? (the car is not mine)if the car has a B230K engine always use a carb from another 2,3L engine (B23A) if you are using a B21A carb on a B230 engine the engine will run lean at any revs higher then idle. This will result in low power and if you have a heavy drivingstyle, melted pistons.
