nohbudi
Jesus Christ...
- Jun 22, 2003
- Toledo, OH
sorry about the outburst.
i very much do still intend on making them, based upon the same design of the panhard rods (that being that they will mount directly into the stock location without any modification to the mounts)
My intentions are to use nuts from our supplier of demesions that allow us to insert them into the rods and be appropriatly welded in place, once we expand the end of the rod. this will allow use to use a heavier heim joint from aurora, which will be just as strong, but not as expensive as a similar load rated heim joint of a smaller overall size. we also intend to get either a hex collar or nut large enough to slide onto the center of the rod, and allow adjustment with a wrench. this of course is to go along with the orignal plan to have one end RH thread and the other LH thread, for easy adjustment without removal of the rods.
also if we can find a supplier for spring steal tubing, we might just use the virgin tubing over used torque rods.
