Old 11-07-2009, 12:54 AM   #1
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
Default B230FT sheetmetal intake
Hello fellow TurboBrickers. (moderators, was not sure of a good location for this post)
(These are current pics from page 12)
Been designing and getting all the parts built for a sweet sheetmetal intake manifold. Almost ready to start the tacking and welding with only the plenum to bend and shape out, in the pics youll see the plenum back wall is shaped with internal velacity stacks that are up off the wall to help promote air flow. The manifold base and stacks are made from 1/2 alum with pipe runners, the back wall is 1/8 and the plenum will be .100 to save on some weight. I am using a 960 TB with a tapered intake runner for that too. Maybe hard to decipher in the pic but I think you guys will be able to visualize it. There is a pic of a brown paper with a injector on it, if you look close you will see the end result of the shape of the intake. i got plenum volume close to 1.5 times engine (will measure exact when finished as the length changed.) Its still a side mount setup with the stock dimenstions in mind so hopefully this will bolt on and use all the factory parts like the throttle cable and setup.
I have on order a reamer to drill out the fuel rail and have plans on running a toyota style FPR (drill and tapped rail with oring seal) Still not sure what Ill do with the fuel lines but Ill get that figured out soon. So far, a little tweak on the oil dipstick tube and small spacer to bolt it back on the block. My goal is to make this a plug and play and make a TB mount for a 960, 940, or whatever is desired. I have an intake started for me and have parts to build 2 more. Im excited to get these started. Might fire the TIG up this weekend and lay some beads down.
Ill post more pics as the manifold moves on.
Old 11-07-2009, 12:59 AM   #2
ovlover
ovlover's Avatar
looking good so far mate. Dont make it too good, everyone will want you to mass produce them
I want to join the "I don't give a rat's arse about 300hp" club
My sheilas
http://forums.turbobricks.com/showth...ht=pics+beasts
Instrument Cluster issues?
http://forums.turbobricks.com/showth...t+cluster+bugs
ovlover is offline   Reply With Quote
Old 11-07-2009, 01:18 AM   #3
thelostartof
unbalanced chemical
thelostartof's Avatar
To much fancy ****
Our ghetto one is going to work damn near as good
Chip Feedback Thread / PM Current Chip Prices / PM for DownPipe & Exhaust Price / Silicone Cooling Hose Sets 2/7/9
Old 11-07-2009, 01:23 AM   #4
Mtouring_Tuff*typing
Mtouring_Tuff*typing's Avatar
wow looks like a good start. needs more JB weld for this site tho
lol
//Eurodesignmk.com //Eurodesign-Myspace //Eurodesign-Twitter
Stefan@EurodesignMK.com
Денес над Македонија
YOU need a ban for abuse of power.
Mtouring_Tuff*typing is offline   Reply With Quote
Old 11-07-2009, 01:41 AM   #5
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
Originally Posted by thelostartof View Post
To much fancy ****
LOL, its the old minitrucker in me! Been fabbing and welding alum for almost 16 years now. I have quite a few intakes under my belt and the first one I did I would not say it was fancy at all! But it worked, would I tell poeple I grafted a TB onto the front of a 7mgte one, hell no, but it paved the way to whats going on today.
I would like to dyno with stock and then mine to see what the bolt on power is.
I think I would like to start building these to sell, maybe one or 2 a month. i tried to keep all the fab process's down to simple, and spent lots of time getting the jigs right to duplicate the flanges and stacks, thats why it looks like a roller coaster and not 4 individual pcs
I still need to get jigged up to drill the base for the injector bungs and decipher how many vacuum ports I need to tap into it.
Old 11-07-2009, 03:37 AM   #6
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
Seems like a decent start. I wish we had more threads like this here, so thank you.
The velocity stacks seem more like a 1/2" flange with a radius cut into it though... I'm not sure it's doing much but I'm sure it's better than nothing!
-Kenny
Old 11-07-2009, 11:15 AM   #7
thelostartof
unbalanced chemical
can I add to the thread?
Old 11-07-2009, 11:18 AM   #8
morganpartee
Watching this thread- Thing looks good!
'89 744-DD, SLOW. +t'd!
morganpartee is offline   Reply With Quote
Old 11-07-2009, 12:43 PM   #9
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
My one pc velocity stack is for simplicity, production. The roller coaster is 1/2 inch thick with a 1/4 radius on the outside, the intake runners will be welded in with a 1/4 inch fillet and then a 3/8 radius on the inside....not a full on true stack, but it does move the intake runner off the back wall where the air does not like to move as fast. The last intake for a starion I did, the stacks were individuals and a pita the get shaped. Im hoping with a sale of one intake I can get my Smithy 3-1 back up and running and a few more options, possibiltys will open up, until then, I have a bandsaw and a router!
My ultimate goal is to shrink the plenum in length and do a tapered runner design to get some sexiness to it, and to form out some tapered runners to give it a ram effect....some builds a few dyno runs will tell me what to do.
I like Mikes intake runner, had thought about that here. I know it would work on a one off application, and work well. The end thought was if I build these for the public I need a more robust intake tube to support the plenum. Sure I can fab a support bar, but will people bolt them on? I have repaired a few of them Ebay sweet chrome ones with thin ass inake tubes that have almost completly cracked out. I am using 1.5 sched 40 pipe at this point, but will drop down to sched 10 so it can be die form, and maybe rolled out like mikes is on the lathe to about a 180* stack.
Looks like we have some family pictures and Im staying home with the kids later, so it will be way late tonight or tomorrow and Ill get a pic of the setup with it all tacked up.
Old 11-07-2009, 01:17 PM   #10
Captain Bondo
Makes sense.
I bought some Mikuni velocity stacks for mine. They are nice and really cheap, but they're too big. About 50mm ID (I didn't know the exact size then i bought them- I just knew they should be in the ballpark base don the carbs they are used on). I thought that would work out ok with my runners (also using 1.5" sched 40) but it doesn't really so now I need to devise some way of transitioning them.
I have a plan to taper the runners, going to experiment today. I'm sure I can get it to work some how but for a production manifold it would be too much work.
Looks like mikey should start an intake thread too.
We all need to. lol.
Old 11-07-2009, 07:23 PM   #11
Mad Adder
Mad Adder's Avatar
Waiting for the next installment. Awesome pics guys.
1984 SVO Mustang
1983 Honda Shadow
I used to run the house, then I bought the lady a Yorkie.
Mad Adder is offline   Reply With Quote
Old 11-07-2009, 07:35 PM   #12
nextproject
nice start! im watchin this!
nextproject is offline   Reply With Quote
Old 11-07-2009, 08:51 PM   #13
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
The tacked up pics are on the same link...Ill weld out the the one later tonight and will need to mock up the plenum next week.
Old 11-07-2009, 08:52 PM   #14
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
Old 11-07-2009, 09:31 PM   #15
Captain Bondo
Wait I thought that plate was radiused on the inside to act as bellmouths. As it is, it looks like there won't be any bellmouths? I am confused...
Old 11-07-2009, 09:46 PM   #16
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
Dont be confused, after it gets welded, Ill take the router back in there and use the 3/8 bit to radius the inside, beats using the diegrinder and by hand. I had to leave a 1/4 inch fillet so the bit wont take all the material away and start crackin out.....
Old 11-07-2009, 10:00 PM   #17
Coupe' de Grace
Slowest in the West™
Coupe' de Grace's Avatar
subscribed
Originally Posted by thebornotaku View Post
So basically I can't go strap a turbo on to my car
V A F
(1976 265dl/b27/m46 killed in battle, 1991)
(1976 265dl/b27/bw55 bring out ye dead, 2000)
1980 262c/b28/m46 'Black Knight' (getting roof/ext resto and engine swap)
1982 244t/b21ft/aw71 'Vicious Chicken of Bristol'
1989 780/b230ft/aw71 'Brave Sir Robin'
Coupe' de Grace is online now   Reply With Quote
Old 11-07-2009, 10:00 PM   #18
Captain Bondo
That doesn't make much sense, adding that step, but ok.
I would have made the holes in that plate the same ID as the runners and radiused the inside.
I guess that's what is happening ultimately.
I'll post pics of mine later tonight.
Old 11-07-2009, 10:09 PM   #19
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
Ultamitley thats what is happening, if I was to make the hole smaller and preradius, I would spend more time with the diegrinder matching the stack and runner up. This way the runner is welded on both sides and makes alignment and fitment easier on my end, especially if I start building more of these. Plus, the router is mounted to a table, so it weld, then spend like a minute at the table radiusing the id of the stack.
I do this with my base plates as well, there is a beauty bead on the visible side and its welded on the gasket side and machined smooth, then its a one pc runner with no internal port matching to do.
Ill post more pics to later tonight.
Old 11-07-2009, 10:57 PM   #20
nathaninwa
AEM infiniwhat?
nathaninwa's Avatar
OK, just went down to the garage and welded out the one intake base setup.
the outside of the plenum back is not welded yet, I will do that when the other pleunum pcs are fabbed up, it would warp all to heck if i did it now, so no flamin!
Ill get to the router on Monday to shape out the plenum stacks.
Old 11-07-2009, 11:16 PM   #21
AndrewEG
beef street
AndrewEG's Avatar
good work mate! Good to see there are some people on this board that put effort into modding their ovlovs!
Originally Posted by YLD244 View Post
What about Holdens space age engine management at the time? A rochester 4 barrel LOL
They probably blew up less motors than MS
Andy's Aussie Volvo 242 build thread with GT30R turbz
http://forums.turbobricks.com/showthread.php?t=217733
FOR SALE thread: Redblock performance parts link
AndrewEG is offline   Reply With Quote
Old 11-07-2009, 11:26 PM   #22
klr142
Turbo, what?
klr142's Avatar
Cool idea for the inlets without having actual trumpets. Keep up the good work!
Old 11-08-2009, 12:52 AM   #23
thelostartof
unbalanced chemical
Awesome looking welds, very jealous
Old 11-08-2009, 10:07 AM   #24
YellowT5-r
YellowT5-r's Avatar
Very nicely planned and executed so far!
If you're thinking about selling 'em on T-bricks, make sure your fab is as simple as possible cause you'll get some wacky lowball price offers for your hard work and craftsmanship. Think offers like, "Dude, would you accept my 695,000 mile AW70 tranny and "Rare" German market Volvo rectal thermometer in trade? I'll kick in another $16 after the first of the month! That thermometer's digital, ya know?!"
In all seriousness though, very nicely done, glad to see more skilled fabricators in our community.
YellowT5-r is offline   Reply With Quote
Old 11-08-2009, 11:43 AM   #25
Really nice thread, I like the extra machining detail you have added to the parts. Adding the radii to the edges and profiled flanges definitely adds a few levels of quality to the parts.
Welds don't look to shabby either
