Old 11-15-2009, 05:22 PM   #1
yamahapro
Turbonetics power!
yamahapro's Avatar
Default drive shaft flex disc install
hey i installed a new flex disc on my drive shaft but it looks like its tearing and theres threads sticking out. i also get a big vibration on fast take off recently. i was wondering whats the correct way to install this. the drive shaft has 3 holes to bolt up to the tranny and the out put of the tranny has the same holes. theres also the flex disc and the metal piece with three holes that goes into the driveshaft. i am wondering what connects to what? i think i have it now as 3 bolts go through the driveshaft, bushing and then the little metal peice and the tranny has 3 bolts going through it but just goes through the bushing and thats it. is that correct?
yamahapro is offline   Reply With Quote
Old 11-15-2009, 09:47 PM   #2
holtzboy
Still have my first car
holtzboy's Avatar
You can see how mine was installed in my 242 here, this is actually not the correct orientation:
http://www.jacqui-of-all-trades.com/...o/242ti/guibo/
Here's the thread I had here:
http://forums.turbobricks.com/showthread.php?t=176495
If you goto page 2 of the thread Nils makes a diagram of the correct way to put it. There are arrows on the guibo that tell you which way to put the bolts, say the arrow is this way ( -> ) , you would have the head of the bolt on the left with the threads and nut on the right side.
1. '86 244DL- 1st car & owned for 18 years, 500k miles, 94 B230FT mild build in the works
2. '93 244DL - Daughter's DD, mostly stock with Hydras
3. '07 Vette Z06 - Early mid-life crisis vehicle
4. '17 CRV - Boring DD
My feedback thread
holtzboy is online now   Reply With Quote
Old 11-16-2009, 08:29 PM   #3
yamahapro
Turbonetics power!
yamahapro's Avatar
i checked mine. all the bolts are tight and it looks like my flex disc is installed just like urs and mine is also ripping in that same place. but mine has threads coming out everywhere. i think the vibration is cuz the tranny mount is a sponge.
in your thread a guy said
other than the guibo being mounted the wrong way which caused it to be torn apart, everything looks normal. gearbox flange should be pushing against the thick part, not pulling on the thick part.
i dont get that! is the other side different?
and how does this make a difference?
Originally Posted by Nils View Post
[IMG][/IMG]
thats how it should be
Old 11-16-2009, 10:51 PM   #4
holtzboy
holtzboy's Avatar
Buy a new guibo or take yours off and you will see the arrows on it. Like I said the bolts will point the direction the arrows go. The arrows are setup in a triangular fashion just like the end of the driveshaft and the coupler/flange off of your transmission. So there's only two options when installing the guibo, right or wrong. Here is an ultra lame paint diagram:
Pretend that that's side ways and the engine is on the left and driveshaft is on the right.
Here is some more detailed info, its for a BMW but the same exact thing:
http://www.bokchoys.com/differential/diy_guibo.htm
Old 11-16-2009, 11:02 PM   #5
Poik
Backwards Turbo
Poik's Avatar
If the transmission mount is bad, the guibo will not last long at all. My dad's transmission mount went out about 2 weeks ago, so I had to replace the mount as well as the guibo as it got torn up pretty good trying to act as a mount.
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 11-17-2009, 12:54 AM   #6
yamahapro
Turbonetics power!
yamahapro's Avatar
Ok I get how the bolts go if there's arrows but why would it matter? What's physically different about it?
Old 11-17-2009, 07:04 PM   #7
yamahapro
Turbonetics power!
yamahapro's Avatar
mines installed how you say but its still ripping.
By volvopro, shot with iPhone 3GS at 2009-11-17
Old 11-17-2009, 07:53 PM   #8
Looks like you have the guide pin installed incorrectly and a set of bolts pointing the wrong way. I believe the guide pin is supposed to be bolted up to the tranny flange, not the driveshaft flange bolts.
I referred to VADIS and the Haynes manual. They both have diagrams.
Old 11-17-2009, 08:31 PM   #9
yamahapro
Turbonetics power!
yamahapro's Avatar
Are u completely positive the guide pin goes the other way? And which bolts are backwards?
Old 11-17-2009, 09:17 PM   #10
95% positive. I just did this a couple of weeks ago. Do you have a manual for your car yet?
Old 11-17-2009, 09:59 PM   #11
yamahapro
Turbonetics power!
yamahapro's Avatar
A haynes manual, it blows. I want vadis.
Old 11-17-2009, 10:53 PM   #12
holtzboy
holtzboy's Avatar
Here's from that BMW site:
The arrows on the guibo will point towards the flange you connect the bolt to. The 3 that connect to the tranny flange will have the nut on the engine side. The 3 that connect to the driveshaft flange will have the nut on the opposite side.
The 3 red marked holes are for the driveshaft flange, the nuts will be on the red marked side.
Notice how the orientation and 'raised up' portions of the guibo is the same in the bmw picture and my picture. Be sure to change your tranny mount unless you know for sure its newish.
Old 11-17-2009, 11:06 PM   #13
yamahapro
Turbonetics power!
yamahapro's Avatar
ok so mines right there. now which way is the guide pin supposed to go?
Old 11-18-2009, 12:35 AM   #14
brant
Rusting
brant's Avatar
Is it just me, or are your arrows on the guibo pointing the wrong way?
Edit: nevermind looking at the wrong arrows.
Will having this orientated wrong cause this vibration? If so, I might have mine flipped to..
1971 145 S WHITE
1989 744T RED
1998 V70R-M BLACK This car sucks
2002 V70XC BLUE
brant is offline   Reply With Quote
Old 11-18-2009, 02:30 PM   #15
tjanson
tjanson's Avatar
1993 245 DL; LH2.4, M47 - DD & Winter Beater
1978 242 GT - To Be Restored, someday
1993 245 DL - OEM+ Project
tjanson is offline   Reply With Quote
Old 11-18-2009, 03:06 PM   #16
yamahapro
Turbonetics power!
yamahapro's Avatar
Ok so it does bolt up the tranny flange. Thanks
Old 11-22-2009, 07:36 PM   #17
holtzboy
holtzboy's Avatar
Originally Posted by tjanson View Post
Where did you find that pic and is there a part number for #17 the "centering sleeve?"
Old 11-22-2009, 08:08 PM   #18
yamahapro
Turbonetics power!
yamahapro's Avatar
thats a vadis blow up pic. i replaced that bushing on my car. wasnt cheap
Old 11-22-2009, 08:24 PM   #19
it's already pressed into the driveshaft for manual trannys.
Old 11-22-2009, 08:46 PM   #20
holtzboy
holtzboy's Avatar
Doh, no wonder why I have never seen it. So this is it inside?!
Old 11-22-2009, 09:27 PM   #21
yamahapro
Turbonetics power!
yamahapro's Avatar
yes
Old 11-22-2009, 10:31 PM   #22
Yep
Old 12-16-2009, 06:00 PM   #23
yamahapro
Turbonetics power!
yamahapro's Avatar
OK well my guibo came off my driveshaft on the road and now i KNOW why you HAVE to install it the right way. first of all if your tranny mount is gushy it will cause the guibo to fail with torque. the first time mine failed it made the driveshaft completely fall off but this time BECAUSE i installed it right the bushing fell off BUT the driveshaft stayed connected to the tranny!!! saving all those parts!! so make sure you install it exactly like it says. temporarily i am using a nissan 240 guibo until i order a bunch of parts from fcp!
Old 12-16-2009, 06:42 PM   #24
holtzboy
holtzboy's Avatar
I always purchase stuff from FCP but I highly suggest NOT to buy the "URO" branded guibo from them:
http://www.fcpgroton.com/product-exe...ategory_id/103
Instead get a Febi guibo from eEuroparts or whichever else site you can find it at:
http://www.eeuroparts.com/Main/PartD...spx?id=1220843
Old 12-16-2009, 08:54 PM   #25
I hang em on my wiener and steal em from the junkyard.
