Old 11-23-2009, 11:56 AM   #1
branmcw
Exclamation K-Jet POS!!!
81 245 K-Jet
starts hard and misses until it warms up then it runs fine any ideas what could be wrong?
branmcw is offline   Reply With Quote
Old 11-23-2009, 12:08 PM   #2
tiredoldtommy
tiredoldtommy's Avatar
Cold start injector or thermal timer? Or wiring to either or both.
When you're a tired old gimp²,
you get easy to please.
'03 C70 HPT drop top 95k (stylin cruiser)
'83 242 turbo, 305k (ridge runner)
'84 245 NA, 248k (hauler/tractor)
'66 New Yorker, 440 4bbl (needs a new home)
'84 244tic (project or parts? definitely parts)
tiredoldtommy is offline   Reply With Quote
Old 11-23-2009, 12:38 PM   #3
branmcw
ways to check?
Old 11-23-2009, 01:11 PM   #4
tiredoldtommy
Do you have a manual? The Bentley manual is the best, but a Haynes would work too.
Also, the factory Volvo green books are available for download at K-jet.org. I think they have a troubleshooting file as well.
Old 11-23-2009, 01:17 PM   #5
sho_shane
Mine does the same think and in my case its the thermal timer.
sho_shane is offline   Reply With Quote
Old 11-24-2009, 02:56 AM   #6
gsellstr
gsellstr's Avatar
CPR is plugged and running either line pressure for control pressure, or it's running full control pressure when cold instead of dropping it. Check your control pressure cold and warm. It should be somewhere in the 35-ish psi range when cold, 55-ish psi range warm. If it's 65+ psi you're running at or near line pressure.
RIP
Nick Fengler "fengler" 8/6/18
Bob Davi "bob davi" 10/2021
74 144 B20
90 745Ti
Old 11-24-2009, 03:30 AM   #7
moxy123
moxy123's Avatar
Post
CPR as above.
If I remember right the thermal only works while cranking and then does nothing over 80F or so, but you may want to check.
moxy123 is offline   Reply With Quote
Old 11-24-2009, 03:27 PM   #8
Old and boxy but good.
There is the thermal time switch. It controls how long the cold start injector will spray while cranking. The cold start injector only sprays while cranking.
Then there is the thermal cutout switch which is used on the late model kjet and the kjet 240 turbos. This is an open/close contact switch at the rear of the left side of the block. It grounds out when the block temperature is below 60F IIRC. It is connected to the lambda ecu terminal 7 providing extra fuel for the engine while it's really cold. As the engine block temp goes above 60F the switch opens because that is a ton of fuel and isn't need as the engine gets warmer.
Lastly and very importantly above was mentioned the control pressure regulator. The control pressure is a feedback fuel pressure used against the plunger in the fuel distributor. In cold conditions the warmup regulator aka control pressure regulator lowers the fuel feedback pressure so the plunger will travel higher making the fuel mixture richer for warmup. As the temperature in the unit heats up with it's heater inside and the engine temp rises the control pressure is increased until the fuel feedback pressure is at a setting where it provides the warmed up engine fuel mixture.
You need to check the injector seals too. For checking the thermal time switch and thermal cut out switch you need a multi meter set for ohms and a cold engine to see if they are conducting. For the control pressure testing you need the kjet fuel pressure gauge setup which will let you test system presssure, control pressure, and rest pressure. Check out the Volvo manuals on k-jet.org. Download and readup how kjet warmup works and how to troubleshoot it.
Old 11-24-2009, 04:13 PM   #9
BrickBaller
BrickBaller's Avatar
Read the sig.
'91 745 with 15g and MBC
that's called a crutch. like a roll cage for a joint.
Originally Posted by casioqv View Post
Tbricks... where half the members need to spends months essentially sourcing and building entire cars from miscellaneous used parts before they can drive a few hours and drink some beer with their friends.
BrickBaller is offline   Reply With Quote
Old 11-24-2009, 04:26 PM   #10
RP80242GT+T
R-Sport Cluster Guy
RP80242GT+T's Avatar
+1 for CPR. Did you check injector seals?
RP R-Sport and OEM Stock Instrument Cluster Restorations, Sales, parts, service, and customizing. LED Conversion Services
Volvo GT Stripe Kits.
1980 242 GT Turbo
2006 Mini Cooper S GP number 1148
1989 240 Wagon " The Beast" Daily Driver
RP80242GT+T is offline   Reply With Quote
Old 11-24-2009, 05:04 PM   #11
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
The 1981 240 Turbos don't have the thermal cutoff switch, btw. But, I'm thinking it's probably the CPR, or it may be a gummed up fuel distributor, which is likely as well. Especially if the car has been sitting for a while.
-J
1982 242Ti - black, B23FT/M46 combo.
@john242ti on IG
Old 11-24-2009, 05:48 PM   #12
Yeah, I always forget that first year doesn't have that thermal cutout switch. I agree it's probably the control pressure regulator. When I bought my 82 turbo it had the same symptoms and it was a combination of bad injector seals and the control pressure regulator clogged.
It took about 8 tries before it would start and idle. Then after the injector seals but before the cpr it took about 4-5 tries. Then after the cpr was replaced it started easily and ran great.
Old 11-24-2009, 06:08 PM   #13
moxy123
moxy123's Avatar
Post
Fill the fuel filter with Seafoam and run it through the injectors slowly, a few minutes between pulses, with the fuel pumps bypassed and moving the air plate.
