Old 11-27-2009, 01:19 AM   #1
gsellstr
gsellstr's Avatar
Default TruTrac Install in a 1031 axle
Ok, so I finally got to installing a TruTrac 912A588 into the stock open diff 1031 in my wagon and figured it's time to update some data out there on the web. First off I'd like to thank Dave Barton for the page he's got, as well as update it a little.
http://www.davebarton.com/volvorearends.html
First off the identification of a 1031 is not quite correct. A 1031 and a 1041 can be a single-rib axle, and a 1030 can be a dual-rib axle (have a 1030 in the 140 with 2 ribs). The axle the TruTrac went into was a 1031 with a single rib and the 1041 that was in the car was also single rib. The 1031 has the larger inner pinion bearing as well.
The 1031:
Now for the meat of the project…
Parts required:
New pinion nut spec’d for the Volvo axle (the Dana 30 nut is not the right size)
New crush sleeve (not included in my kit, others may have it)
TruTrac 912A588 (bought along with install kit from Summit – search the web for a price match and they’ll meet it)
Dana 30 rear install kit
Timkin HM89449 bearing and HM89410 race (bought from Autozone)
This is the pinion bearing that’s different from the 1030 and the standard Dana 30. The one on the left is the 1031 bearing, on the right is the 1030/D30 bearing.
Tone ring from a G80 or skills to make something similar if it’s going into something that requires a speed pickup. The later ones use a 48-tooth ring like shown here, but others may have a 12-tooth ring.
Here’s the G80 tone ring
And the stock open diff tone ring
Now for the work…
It’s easiest to remove the axle from the vehicle, but it CAN be done without. Once you’ve got the axle where you’ll be working on it the teardown begins. First the axles come out, then the cover comes off and the old diff comes out. You probably won’t need a case spreader for this part (I didn’t). If you’re doing bearings as well the pinion nut and flange need to come off and then you can tap the pinion gear out with a punch in the center of the gear to avoid damage to the threads.
You’ll need to split the bearing or press it off and press the new one on making sure to keep the shim in place between the gear and the bearing as this sets your pinion depth. From here the pinion gear can go back in, the new crush sleeve, new outer bearing, the oil slinger (goes right between the bearing and the flange), the flange, and nut. Torque the nut until you get around 2Nm of turning torque.
Now for the diff. First off the old bearing needs to come off the ring gear side so you can remove the oil slinger, the ring gear bolts, and the ring gear. The oil slinger doesn’t fit well on the TT so I left if off when mine was reinstalled. Using the new bolts from the install kit you can install the ring gear. Torque spec is 26 ft.lbs plus 60* of rotation.
The tone ring will require a little light welding. I used a G80 tone ring which was easily removed from a spare unit by using a cold chisel to split it, then simply pulling it out. The diameter is just slightly too small for the TT housing, so it will be a little short. I chose to fab up an extra tooth of the same size which worked out quite well, and kept the speedo dead on.
Once you’ve got the ring welded together you need to set it on the diff at the right location. I used the speed sensor hole to set the installed position, by centering the ring in the hole for the speed sensor.
Once that’s on a few tack welds to keep the ring in place and you’re set.
Next you need set up the differential in the housing. You’ll need a dial indicator to do this correctly. I have the setup tools which made this part FAR easier. You will need a way to put the bearings on the diff, remove them, then reinstall them with the correct shims if you don’t have the proper setup tools. Once you’ve got the bearings on you need to set the differential for .005-.006” backlash, plus .05-.08mm of bearing preload. Once you’ve got the shim combination for each side figured out, pull the bearings back off, install the shims, reinstall the bearings, the diff into the housing, and the bearing caps (torque to 22 ft.lbs. plus 60*).
At that point you should end up with something like this…
Now for the final steps.
You will need to space the speed sensor out about .010” due to the larger diameter of the tone ring. A layer of thin gasket material works for this if you use a diff cover gasket. If you don’t use a diff cover gasket you will need a little thicker spacer. You’ll be able to tell if the sensor will hit easily enough by putting the cover on and using an axle shaft to spin the diff.
At this point you’re ready to install the cover and the axle shafts, fill with oil, and install in the vehicle. Fill capacity is 1.6L for the 1031/1041 axles. I chose Redline 75w90 for mine and it seems to be working quite well.
As for the performance, mine’s only been in the car for a day but it’s completely seemless. You really don’t notice it’s there until you really get on it. One wheel in the dirt and the other on the pavement will get you a lot of dust in the air on accel, but the car will get moving quite quickly. One possible downfall which bit me today is if you’re hard on the throttle to a point where both sides break loose you WILL have the tail end trying to pass you up if you’re not paying attention. A hard stab in first had me in this situation when both tires hit a paint mark and let loose. Otherwise normal driving you don’t notice it’s even there, even in parking lots and such.
Hopefully this helps a few of you out there!
EDIT: 11/11/16:
Recent findings pertaining to axles with a steel cover.
Pulled the cover from the 1030 in the 140 which also has a Trutrac, since the cover plug no longer sealed (a shop years ago ran it in too far). Grabbed an aluminum cover from a 1041, bolted it on (FYI, you need longer bolts, get them with the cover, or get that length in 5/16x18 if you're working on a 140). Upon filling it up, it took 1.5qts, where the steel cover combined with the TruTrac would only take 1qt.
Just a cool fun fact.
For those of you needing a tone ring for this installation, here's a discussion about them:
http://forums.turbobricks.com/showthread.php?t=317562
And a supplier:
http://bakaxel.se/catalogsearch/resu...C3%A4tarkrans+
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 11-27-2009, 01:36 AM   #2
Hagar17
Hagar17's Avatar
Awesome! Many thanks if only I could do this now!
Keeping late 80's Swedish metal alive!
Hagar17 is offline   Reply With Quote
Old 11-27-2009, 02:28 AM   #3
Jerd
Jerd's Avatar
Thank you! You did an amazing job.
Old 11-27-2009, 10:49 AM   #4
Turbosteen
I was born at a young age
Turbosteen's Avatar
Nice write-up!
I'll be using this when I'm installing mine (need one within the next year)
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 11-27-2009, 01:42 PM   #5
holtzboy
Project Procrastinator
holtzboy's Avatar
I had one of these installed in my 242. At the same time I had a Getrag installed and poly engine mounts. There is a ton of driveline noise especially when deccelerating and my friend said it might be due to not shimming the lsd correctly. The getrag came in a "kit" from my friend who took it off his 242 with balanced driveshaft, new ujoints, center bearing so it wouldn't seem to be related to that. I may PM you sometime in the future because I am swapping everything to a new rust free 242 and want to check the shimming and everything else.
1. '86 244DL- 1st car & owned for 19 years, 500k miles, 94 B230FT build collecting dust
2. '93 244DL - Crappy paint - For sale NOW!
3. '07 Vette Z06 - Mandatory jean shorts and white tube socks
4. '17 CRV - Daughter taking to Mississippi
My feedback thread
holtzboy is offline   Reply With Quote
Old 11-28-2009, 12:37 AM   #6
gsellstr
gsellstr's Avatar
I've got NO driveline vibrations whatsoever with HD engine mounts, full poly front to back, Koni SA's, etc. so I'd guess there's something else playing into your issue. When you get around to it certainly shoot me a pm and we can see what's going on.
Old 04-24-2011, 03:22 PM   #7
joshwho_e21
Nice and simple.
joshwho_e21 is offline   Reply With Quote
Old 05-10-2011, 07:52 PM   #8
My Truetrac also makes a TON of noise. At first I thought the lash was set up wrong but it's been working well for quite q few thousand miles.
I like it. engagement is very predictable. There are times it doesn't engage (such as when one tire has 0 traction or the speed differential is close to that), but overall it's a great maintenance free unit.
BTW I'm also running Redline 75W90. Apparently dyno oil is recommended, but meh.
Old 05-10-2011, 09:16 PM   #9
wisturbo
wisturbo's Avatar
Great write up Gary!
Perhaps as a standard variable for the G80 tone ring and 1031 combo you might be able to state this for ease of installation...
wisturbo is offline   Reply With Quote
Old 03-19-2014, 05:53 AM   #10
kodja
kodja's Avatar
good guide. answer to the last picture anybody?
912A588 is that the right nr no mather what gear ration on the rear axle?
who sells it the cheepest?
98' 945 LT RF stereo, aprx. 2600watt RMS Dynamic bodykit, 18" rims, Black leather 965 interior, bilstein + ipd swaybars +++
82' 242 (Turboproject) C70 two-coloured leather and alcantara seats (electical adjusted), Harman/Kardon amps++
kodja is offline   Reply With Quote
Old 03-19-2014, 07:39 AM   #11
MadDog_945
V虍a V臠ra 8V
MadDog_945's Avatar
Thought these were the guys which do this clingclingcling chainrassle sound when doing turns ? like in that one video i dont find right now..
Old 03-19-2014, 09:20 AM   #12
Those are Aussie or lunchbox lockers. These are worm gear type LSD.
Old 03-19-2014, 09:57 AM   #13
gsellstr
gsellstr's Avatar
The 912A588 is the correct diff for our cars, regardless of gearset. The gearset is specific to the housing though I believe. There's also the older variant if you find it used, the 912A411 that also fits our cars. I have that one in the 140 and the 588 in the wagon, no discernible differences between the two while driving. As for current best price, Summit isn't bad these days, not sure if you can find it much lower.
Wow, didn't realize it's been in there for 5 years already! Not a hint of maintenance nor issues, the slight gear whine I had initially went away as the gears re-settled after being reused, and it still holds the power and gets the tail out when asked. The ONLY thing that stands out is turns while under decent power it will chatter a little as the inside tire slips, but that's only on hard turns and a good bit of throttle.
Old 03-19-2014, 10:01 AM   #14
I've never heard any noise from my true trac but i also ran the correct fluid for it.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.ゥ
Old 03-19-2014, 10:03 AM   #15
audeo03
Sippin' on Some Sizzurp
audeo03's Avatar
Yes. Correct part #. Summit Racing has it for $499.
As for distance, just do like the guide says and line it up in the speedo window.
'06 XC90 2.5t - Hilton Tune - The wannabe Project Car
'09 V50 2.4i - The Wifemobile
RIP:
'93 245t
audeo03 is offline   Reply With Quote
Old 03-19-2014, 10:18 AM   #16
Roger-Dee
is DeeWorks.ca
Roger-Dee's Avatar
Which is? I just bought one for the 8.8 (has yet to arrive) so I'd like to know before installation.
Any one of you drag raced his car with the truetrac? How was it?
94 944T - 16v turbo - 12,14@122
Lm7 5.3, S475, Ms3Pro, 4l80e - 10,36 @ 134 / 6,70 @ 107
www.deeworks.ca
Need T5 Adapter? T5 Speedometer Plug? Gm Torque Converter Adapter? Freeze plug retainer? HE351 solenoid plug? Pm me!
Roger-Dee is offline   Reply With Quote
Old 03-19-2014, 11:45 AM   #17
Much easier to launch than with a pegleg diff. It's also more annoying to get traction again if you overcook the launch.
Old 03-19-2014, 01:33 PM   #18
When I called tech support they told me to use standard gear oil, no synthetics or modifiers.
What ever weight was recommended for stock but not a synthetic. The explanation to me was that a synthetic is a little too slippery for the gear style diffs and it decreases the effectiveness of the unit. Considering you want the gears to semi bind for it to transfer power, it makes sense to me that you don't want the most slippery fluid.
Old 03-19-2014, 01:33 PM   #19
gsellstr
gsellstr's Avatar
All my timeslips on my wagon are with the Trutrac, except the early years when it was open. Launched pretty nice off the line, at least as much as the tires would allow for. Traction issues are tire related more than diff related at this point.
I've been running Redline 75w90 in the 140, M1 75w140 in the wagon since the gears were a little loud, both still lock up quite well.
Old 03-19-2014, 08:17 PM   #20
Lando
Arthur Digby Sellers
Lando's Avatar
Gary, in your write up you said you added a tooth to your tone ring and it didn't throw off your speedo. I cant quite figure out how this is possible, as each slot registers as a fraction of a turn. I would imagine that it would change your speedo reading by a factor of (n+1)/n. On your tone ring that would not make much difference because it has a lot of teeth. I would imagine on the 12 tooth tone rings, it will read about 8% faster than it should be. Furthermore, that error will be propagated through an integral when the odometer integrates the speed signal into position.
How did you determine that it reads correctly?
Based on my understanding of how hall sensors signals are conditioned to determine speed, I believe you would have to have the same number of teeth as OEM. It might even be better to just leave a gap than to add another tooth, because it just knows n amount of impulses are in a rotation, and the diff spins fast enough the speedo probably wont notice the delayed impulse due to the gap.
I'm leaning towards waterjetting a new tone ring with the same number of teeth but larger gaps, I can post the dxf files when I get to it if anyone is interested.
Originally Posted by 11110000 View Post
I didn't think there was anything to the whole 7/9 thing, but I have to say that my 745T is the only Volvo I've owned that blew up and self-immolated.
Lando is online now   Reply With Quote
Old 03-19-2014, 08:48 PM   #21
volvoracer82
volvoracer82's Avatar
they don't "count" the teeth, it's a frequency reading, the faster the pulse the sensor sees from the ring determines the speedo needle position.
1983 242ti-Rally machine. 19/16 sways, mvp endlinks, gt braces, 17x9 ESM 004R's, Truetrack, Rx7 brakes, momo steering wheel, corbeau gt2's, 1992 B230ft, b230 int. atp ultimate WG, 3" turbo back, ported 90+ mani, k cam, Garrett t3/t4
1982 245DL-DD
1984 242ti-?
volvoracer82 is offline   Reply With Quote
Old 03-19-2014, 08:59 PM   #22
Lando
Lando's Avatar
I'm pretty sure it needs some sort of position reference to measure speed, which is a change in position per unit time.
So lets assume were talking about a 12 tooth ring for easier math. The signal processor is programmed to assume that each tooth accounts for 30 degrees of ring gear rotation. Then the signal processor, also records the difference in time (deltaT) between impulses. 30*/deltaT will give you your angular velocity which you can then calculate vehicle speed based on wheel radius. If you add a tooth, then the signal processor will still assume 30 degrees of rotation per impulse, but in reality, it is only turning 27.69 degrees per impulse.
Old 03-19-2014, 09:13 PM   #23
NChoy
18 bricks and counting
NChoy's Avatar
Bookmarked for later reference! Awesome thread!
Nick Choy
Founder, Oregon Volvo Tuners
覧覧覧覧覧覧覧覧覧覧覧覧覧
'04 S60R, '98 V70R AWD, '93 244DL, '89 245DL, '71 142e, '67 122s
Feedback Thread: http://forums.turbobricks.com/showthread.php?t=20272
NChoy is offline   Reply With Quote
Old 03-19-2014, 10:34 PM   #24
volvoracer82
So lets assume were talking about a 12 tooth ring for easier math. The signal processor is programmed to assume that each tooth accounts for 30 degrees of sun gear rotation. Then the signal processor, also records the difference in time (deltaT) between impulses. 30*/deltaT will give you your angular velocity which you can then calculate vehicle speed based on wheel radius. If you add a tooth, then the signal processor will still assume 30 degrees of rotation per impulse, but in reality, it is only turning 27.69 degrees per impulse.
These sensors arent that smart, yes on lets say a 2008 bmw where the sensor has 3 hall sensors within, along with a small processor , but this sensor, no. Frequency is all it needs, You need computing power for that application. Simply said, an ignition system/fuel system need a missing or twice the width tooth for the computer to know when top dead center occours. Vehicle speed sensor in this case has no computing power,i Just a master and a slave wit wires in between.
Old 03-19-2014, 10:52 PM   #25
Lando
Lando's Avatar
Speed is a change in position per unit time. It is impossible to measure speed electronically without both a position reading and a time signal. Even if the position is simulated mechanically in the speedometer, adding another pulse per rotation will throw off your measurement.
Also a crank sensor is an absolute encoder, because it needs to know it's absolute position to function properly. A speedo sensor only needs to be a relative encoder, it just keeps on counting, because it doesn't matter how the ring gear is clocked at startup to determine speed. That takes very little computing power, 8 bit computers can handle that.
