Old 11-30-2009, 09:37 PM   #1
HB of CJ
Default Volvo Factory V8 and V6 Engines?
Does/did Volvo ever made a V8 or V6 passenger car engine. I really don't know. Are they any good? How big are they? How much power? Availability? $Cost$? Thanks in advance. HB of CJ (old coot) (because I really don't know)
HB of CJ is offline   Reply With Quote
Old 11-30-2009, 09:38 PM   #2
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
in before the bickering!
edit:// nope, they never made one.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 11-30-2009, 09:45 PM   #3
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
They have a passenger car V8, but it's made by Yamaha.
Volvo did make a 3.6 liter pushrod V8 boat motor back in the day, but it was never put in any passenger cars.
Fake Race Car
Old 11-30-2009, 09:49 PM   #4
745 TurboGreasel
745 TurboGreasel's Avatar
There is the PRV 6 of 760 GLE (in)famy
Feedback
Old 11-30-2009, 09:49 PM   #5
500dollar744ti
i would consider the 3.6 v8 more of a volvo motor before the prv motor though.
Old 11-30-2009, 09:56 PM   #6
Mueller
Mueller's Avatar
yea, cause the V in PRV means nothing right??
Old 11-30-2009, 10:28 PM   #7
joereese2
They made a v-8 in the early 60's and put it in 3 cars that never made it to production, however the v-8 did ! It lived on for many years in Volvo medium duty trucks.
joereese2
joereese2 is offline   Reply With Quote
Old 11-30-2009, 10:36 PM   #8
joereese2
Default v-8
Update facts, v-8 was called b8b and like Karl said was 3.6 litre .
Old 11-30-2009, 10:53 PM   #9
JohnMc
JohnMc's Avatar
It was called the B36.
And it's occasionally alleged that the B18 (replacement for the older B16) was developed as half the B36. Which would explain how overbuilt the bottom end is for a 100 HP 4 cylinder.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 12-01-2009, 12:31 AM   #10
Acid8000
Acid8000's Avatar
I saw a youtube video of said V8 running open DP and boy oh boy it sounded great. Then again any motor run open DP sounds great, cept for those shiesty japanesse motors.
Daily Driver: '83 242Ti w/ B21FTi and M46. IPD Sways, Bilstein HD Struts, Lowering Coils. Mistu 13c @ 10psi - Her name is Domino.
Hi my name is Jason, i'm addicted to boost
Acid8000 is offline   Reply With Quote
Old 12-01-2009, 01:01 AM   #11
derosa
The Rev
derosa's Avatar
the prv that's mentioned above is decent, smoother then the 4 and can make some decent power. Biggest thing is keeping the oil changed and the radiator fluid topped up. Do that and they are reliable, don't and they'll fail quickly.
98 v70xc running, needs an m66 and full stage 0.
98 v70 5spd- RIP
91 240 +T - RIP, it was fun while it lasted.
79 262c, still currently under construction, but now actually under active construction.
Cuius testiculos habes, habeas cardia et cerebellum.
derosa is offline   Reply With Quote
Old 12-01-2009, 04:04 AM   #12
vanapeer
old fcuk
vanapeer's Avatar
How about that
Originally Posted by DaytonAE86 View Post
Now wait a minute............ is that two B20s?????? is it the real deal Volvo V8? Jeebus thats hot.
vanapeer is offline   Reply With Quote
Old 12-01-2009, 04:42 AM   #13
Mueller
Mueller's Avatar
Originally Posted by vanapeer View Post
How about that
that is cheating
Old 12-01-2009, 05:09 AM   #14
vanapeer
old fcuk
vanapeer's Avatar
Sorry, not on purpose.
Old 12-01-2009, 11:15 AM   #15
JohnMc
JohnMc's Avatar
Well, if you want to get into Penat motors, there are quite a few larger domestic based lumps that came with a Volvo sticker or two on them.
Old 12-01-2009, 11:18 AM   #16
500dollar744ti
well i was thinking the V means 1/3 of something, where the b36 is 100% volvo.
Old 12-01-2009, 11:26 AM   #17
Dan
I'm an enumerator!
Dan's Avatar
I don't think Volvo had much input into the design of the PRV motors, probably just shared some production costs...
1985 Chevy TPI V8 740.
“Expertise in one field does not carry over into other fields. But experts often think so. The narrower their field of knowledge the more likely they are to think so.” – Robert A. Heinlein
“We must reject the idea that every time a law is broken, society is guilty rather than the lawbreaker. It is time to restore the American precept that each individual is accountable for his actions.” – Ronald Reagan
Old 12-01-2009, 11:28 AM   #18
500dollar744ti
PRV is about as much of a Volvo motor as the new Yamaha V8 is a Volvo motor.
Old 12-01-2009, 11:58 AM   #19
Rectilinear
Longitudinally Mounted
Rectilinear's Avatar
If you really want a V6, the PRV is fine as long as you keep up with maintenance as mentioned before. It will bolt up to a common transmission so that saves a lot of effort and cost. And the fun thing is...that engine was also used in the Delorean and they are still developing performance bits for it these days. Unfortunately, most of those parts are Delorean specific (exhaust, cold air, etc.) and they are quite expensive. But they do offer zero mile crate engines with performance cams and ported and polished heads. They also have a nice ignition upgrade available...
Originally Posted by A Random CL Ad
A Volvo 240 does not have a slow zero to sixty time. Nor a fast one. It reaches sixty precisely when it means to.
Rectilinear is offline   Reply With Quote
Old 12-01-2009, 05:18 PM   #20
cuaz64
cuaz64's Avatar
In this thread: http://forums.turbobricks.com/showthread.php?t=138997 Is some information about how to improve and get parts for the PRV engines.
Originally Posted by opeterson View Post
So yeah, I had a lot of fun. But we're all TurboBrickers at heart and that means nothing comes easily.
no alchemists allowed.
Tbricks is a strange, but fun and informative phenomenon.
cuaz64 is offline   Reply With Quote
Old 12-01-2009, 05:20 PM   #21
Gizmo
Gizmo's Avatar
My Chilton guide for post-90's volvos mentions a v6... and i dont think its the PRV? I'll check. Was the 260 inline?
Evan
1996 850T - Bilsteins all around, a homebuilt MBC, Samcos, backcut SS valves, and R manifold, and an obscene amount of luck.
Have owned:
1996 960 - Totaled
Gizmo is offline   Reply With Quote
Old 12-01-2009, 06:04 PM   #22
500dollar744ti
260 was also a PRV, the D24/D24T are inline, 1991 was the last year for the PRV, the rest is the whiteblock variants.
Old 12-01-2009, 07:55 PM   #23
Gizmo
Gizmo's Avatar
oh. Thanks, good to know.
Old 12-02-2009, 01:19 AM   #24
greybeard
greybeard's Avatar
or the B36 as the next post says,
was this engine imported to NA or was it europe only?
this would be interesting to see in a 122S.
greybeard is offline   Reply With Quote
Old 12-02-2009, 09:56 AM   #25
sweedspeed18
sweedspeed18's Avatar
To OP:
I am not sure where your timeframe is, if you are talking about a RWD platform.
But Volvo does offer a V8 in a laterally mounted engine/transaxle, in a passenger car: S80, XC90..
1993 960 wagon
sweedspeed18 is offline   Reply With Quote
