I have shamelessly copied this out of an older 410-thread because i think this makes a nice useable sticky. The linked pages provides even more useable axel/diff info.
-------------------------------------------------------------------------------- This table came in very handy when I was searching. Also try the wanted forum on here. Year Model Engine Tranny Rear Axle Ratio 1983 760 GLE TD D24T M46 3.54 1983 760 GLE TD D24T BW55 3.15 1985 740 (any) B230F, B230FT M46 3.31, 3.54 1985 740 GL, GLE B230F ZF 4HP-22 3.91 1985 740 Turbo B230FT AW71 3.73 1985 760 GLE TD D24T M46 3.54 1985 760 GLE TD D24T ZF 4HP-22 3.91 1986 740 (any) B230F,B230FT M46 3.31, 3.54 1986 740 GL, GLE B230F ZF 4HP-22 3.91 1986 740 Turbo B230FT AW71 3.73 1988 760 GLE B280F AW71 3.73 1988 760 Turbo B230FT AW71 3.73 1989 780 B280F AW71 3.73 1989 780 Turbo B230FT AW71 3.73 1990 740 GL B230F M46/M47 3.31, 3.54, 3.73 1990 740 GL B230F AW70L/AW71 3.73,4.10 1990 740 GLE (16v) B234F AW72 4.10 1990 740 Turbo B230FT M46/M47 3.31, 3.54, 3.73 1990 740 Turbo B230FT AW70L/AW71 3.73,4.10 1990 760 GLE B280F AW71 3.73 1990 760 Turbo B230FT AW71 3.73 1990 780 GLE B280F AW71 3.73 1990 780 Turbo B230FT+ AW71 3.73 1991 740 B230F M46/47 3.31, 3.54, 3.73 1991 740 B230F AW70L, AW71 3.73, 4.10 1991 Coupe (780) B230FT+ AW71 3.73 1991 940 Turbo B230FT M46 3.31, 3.54, 3.73 1991 940 Turbo B230FT AW71 3.73 1991 940 SE B230FT AW71 3.73 1991 940 GLE (16v) B234F AW72L 4.10 1992 740 B230F AW70L, AW71L 3.73 1992 740 Turbo B230FT AW70L, AW71L 3.73 1992 940 GL B230F AW71 3.73 1992 940 GLE (16v) B234F AW72L 4.10 1992 940 Turbo B230FT AW71 3.73 1992 960 B6304F AW40 3.91 1993 940 B230F AW71 4.10 1993 940 Turbo B230FT AW71 3.73 1993 960 B6304S AW30, AW40 3.31 1994 940 B230FD AW71 4.10 1994 940 Turbo B230FT AW71 3.73 1994 960 B6304S AW30, AW 40 3.31 1995 940 B230FD AW71 4.10 1995 940 Turbo B230FT AW71 3.73 1995 960 B6254S, B6304S AW40, AW43 3.73, 4.10 1996 960 B6304S AW40 3.73 1997 960 B6304S AW40 3.73 1997 S90, V90 B6304S AW40 3.73 1998 S90, V90 B6304S AW40 3.73 __________________ Luke '92 240 |
So now, what are the differences between various axle/pinion setups? Doesn't some axle have a stronger (bigger) pinion gear diameter?
Almost out of the Volvo game! 2011 Ford Ranger 1997 Miata, Supercharged 2002 Suzuki DRZ-400S 2013 Yamaha FZ6R |
if anything, i'd imagine the size of the teeth would determine strength. the differentials themselves are more or less dimensionally the same
-Billy Volvoless for the first time since 1990... ![]() 2002 Toyota Avalon XLS (comfy gradma car) 1996 Chevrolet Tahoe LS 2WD (hauls ass) 1990 Mazda Miata (track toy) |
#4 |
Another handy tidbit that was on that page:
How to Measure Axle Ratio on the Car. [Rob Bareiss] Here's how I compute axle ratio: Make sure the car's in neutral, and can't roll. Block the wheels and release the parking brake. Raise one rear wheel. Make sure you have an open differential- not limited slip. If you can spin just one rear wheel, it's a regular differential. Make a mark on the driveshaft or pinion shaft of the differential- doesn't matter where, just so you can see it clearly. Use "white-out" or something. Make note of the position of the valve stem or mark the tire too. Turn the tire 20 turns (10 for a limited slip and you need both tires off the ground). Count the revolutions of the driveshaft. When you finish, note the approximate position of the shaft relative to the starting position- only approximate. You should get something like 37 1/3 turns of the shaft, or 41. Divide by 10 to get the actual gear ratio. 41= 4.10, 37.3 = 3.73, etc.
1 3 5 |-|-| 2 4 R |
#5 |
Are the gears swappable?
#6 |
#7 |
You say you want the 4.10 gears, and I want the 3.73 gears. I need better highway fuel economy.
#8 |
I want to accelerate quicker. I never go on the highway.
Hmmm... |
#9 | ||
![]() Left, 1030, Right, 1031.
#10 |
That post was full of win. Thank you/
#11 |
I forget to mention, I stole the picture from the Anthony Hyde's webpage.
#12 |
So wait now- "The Volvo 1031 - (Dana 30) heavier duty, introduced to all 4-6 cyl models from 1981 onwards."
Our gears would swap! I thought the 30/31 was like another turbo/NA deal. Cool. |
#13 |
I lifted this from another thread, it might be usefull here:
Type 1030 Solid Axle Type. Used from 1983 to 1989 in various 700 series. Type 1031 (early) Solid Axle Type. Heavy duty version of Type 1030. Used from 1983 to 1990 in various 700 and 900 series. Has stamped steel rear cover. Type 1031 (late) Solid Axle Type. Updated version of Type 1031 (lighter housing). Used from 1990 to 1995 in various 700 and 900 series. Has cast aluminium rear cover. Type 1035 Independent Rear Suspension (IRS ) Type. Used from 1988 to 1990 in 4 door 760 series (NO wagons). Used from 1988 to 1991 in all 780 series. Used in 1991 in 4 door 940SE series (NO wagons). Used from 1992 to 1994 in 4 door 960 series (NO wagons). Type 1041 (early) Solid axle Type. Limited Slip (Dana) version of Type 1031 (early). Used from 1983 to 1990 in various 700 and 900 series. Has stamped steel rear cover. Type 1041 (late) Solid axle Type. Locking Differential (Eaton G80) version of Type 1031 (late). Used from 1990 to 1995 in various 700 and 900 series. Has cast aluminium rear cover. Type 1045 Independent Rear Suspension (IRS ) type. Locking Differential (Eaton) version of Type 1035. Used from 1988 to 1990 in 4 door 760 series (NO wagons). Used from 1988 to 1991 in all 780 series. Used in 1991 in 4 door 940SE series (NO wagons). Used from 1992 to 1994 in 4 door 960 series (NO wagons). Type 1055 Independent Rear Suspension (IRS ) type. Used from 1995 to 1997 in 960 series. Used from 1998 in S90 / V90. Type 1065 Independent Rear Suspension (IRS ) type. Locking Differential (Eaton) version of Type 1055. Used from 1995 to 1997 in 960 series. Used from 1998 in S90 and V90. Used from 1997 in 850 series equipped with All Wheel Drive (AWD). Used from 1998 in S70 / V70 equipped with All Wheel Drive (AWD). |
#14 |
All idiot, no savant
![]() Some extra info about the rear axles.
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months) dd: 940 | 1992 | B230FB Husaberg FE450 70 degree '12 mx/supermoto swapped |
#15 |
delete please - double post!
#16 |
today i checked the ratio of the gears in my new axel that i bought. sadly there was no ID-sticker on the axeltube.
If you undo the cover and rotate the crown(ring) gear you can find and read the ratio that's stamped on the side of the crowngear like this: 10/41 meaning it has a pignon with 10 teeth and a crowngear with 41 teeth >> 4,10:1 ratio. No need to count teeth or rotations. |
#17 |
So a 1041 axle ALWAYS has some kind of limited slip diff ?
#18 |
that would be a yes, maybe, perhaps, who knows what Volvo did back then...
![]() another usefull link: www.davebarton.com |
#19 | |
Sick ****** T-Brick Prick
I just found the goldmine of cross references.
I also posted it in a 240 thread. I think this should be in this article. Another table to look at: Quote:
#20 |
the 740 16v anyone know the type?
1989.740-SE look /hd billys's,apex springs,ipd sways,ipd panhard rod,ipd chassis braces kit,ipd cam kit, 1988 765T daily driver ![]() photo(17) by 89turbo, on Flickrfeedback thread http://forums.turbobricks.com/showthread.php?t=218447 |
#21 |
more bounce to the ounce
Me thinks 4.10
