Old 02-02-2010, 03:13 PM   #1
Default BNE update: Quick Steer Roll Correction Prototype
This is a prototype for a product that I have been working on for a long time, it has undergone multiple design iterations and transformations. The product is called Quick Steer Roll Correction, it's purpose is to correct the front suspension geometry issues that result from lowering the car. Suspension systems have an "imaginary" point called a roll center (RC), the roll center is the point at which the cars suspension system pivots around. The location and height of the roll center is very important to how the car handles and accelerates out of corners. The height of the center of gravity (CG) of a car and the height of the roll center have a relationship that can be described as a lever arm. The longer the lever arm the more force the chassis will be subjected to while cornering. When the front of a 240 or any car is lowered the roll center moves below the ground. This increases the distance between the CG and RC, in effect it increases the lever arm length and therefor increases the amount of body roll the car is subjected to. The front suspension has a separate roll center from the rear suspension. The rear suspension in a solid axle car has a geometry where the roll center height changes very little when the car's ride height is lowered. This leaves the rear RC high and the front RC low. If one to draw a line between the two roll center heights you would see there is an angle. The angle can be described as the roll axis inclination angle. The steeper this angle the harder it is to put the power down on corner exit. There are many other things that roll center height dictates but adjusting the front RC will affect how the back of the car works as well. There is a plethora of information online and in books about this subject so I will not try and repeat what others have already done so well.
The Quick Steer Roll Correctors are unique because they have an integrated steering arm, the typical/generic approach has a been a long bolt installed with a spacer off the steering arm and a separate spacer for the ball joint bracket. This is far from ideal because you are putting a large cantilevered single shear load on the bolt that supports the tie rod / rod end and this can lead to failure. The Quick Steer Roll Correctors have integrated steering arms that are compatible with the factory tie rod ends, this means no over loading in single shear. The new steering arm also presents an opportunity to modify the steering leverage ratio. The Quick Steer Roll Correctors have multiple steering leverage ratio options, The stock ratio is available, 20%, and 40% quicker ratio option. For comparison sake, the power steering has a 3.5 lock to lock ratio stock, 20% is 2.8 and 40% is 2.1. The manual rack has a 4.34 lock to lock ratio stock, 20% is ~3.5 and 40% is ~2.6. Now these lock to lock comparisons are not technically correct because the lock of the steering rack is still the same but in my opinion it is the best way to make a comparison because people are most familiar with a lock to lock comparison then any other steering ratio.
The steering arm is removable and has a slotted adjustment, this adjustment is good for two reasons. The first is it can let you adjust and tune out any bump steer that you may have from shortening the lever ratio and secondly it lets you adjust the Ackermann angle. What does this mean for people? For most drivers it won’t mean much. If you are able to get tire slip angle and force data from the manufacturer, which is sometimes available for racing tires you can optimize the Ackermann effect and gain the maximum grip from the tires. Most people will just want to leave the Ackermann at factory angles.
The Quick Steer Roll Correctors eliminate the need to use the factory tapered ball joint receiver, The bottom of the roll correction spacer is tapered to match the stock 240 balljoint. The holes on the steering arms are also tapered to match the stock 240 tie rod ends. If someone prefers to use a rod end and bolt they can drill the tie rod holes to 14mm or what ever size rod end they want.
The dimensions of the factory spindle were carefully measured and digitized using a Coordinate Measurement Machine called a FARO arm. Collecting the data this way is very accurate and lets us nail down the factory geometry too within.001". Having good and accurate data ensures the parts dimensions and tolerances can be specified correctly. This helps to give a very high quality fit.
From the digitized geometry a Computer Aided Design (CAD) model of the factory spindle was created to design the part. From this 3-D foundation the new part was designed. The part went through several design iterations.
An early design iteration.
Testing
Rapid ABS plastic prototype to check fitment.
A few more revisions and redesigns and the design came to something like this
Rapid prototype
In order to reduce manufacturing complexity, a two part adaptation was made.
Then the parts were tested for ride and steering forces.
Finite Element Analysis (FEA) helps to maximize stiffness and strength of the part and while minimizing the weight. The FEA process also can help highlight design flaws and reduce the number of real prototypes needed.
The flange is a very tight fit to the factory spindle and the quality of this fitment ensures a good engagement with the machined large diameter arc that is on the factory spindle. By making this tolerance tight it helps to reduce torsional loads on the mounting bolts because the part can not twist without deforming the spindle
The prototypes have been machined from 4140 billet alloy steel and heat treated.
The prototype has an effective height of 1.9 inches, The production part will most likely get nickel plating but the prototypes were painted. The prototype units were installed with the “Ackermann” adjustment aligned with the stock steering hole. Bottom 12.9 grade 10mm bolts were torqued to 60Nm. I mounted some older wheels and tires (205 55 16, 16x6.5, Pilot Sport All Season which are very old and have no grip left in them). I chose the old skinny tires for a few reasons, primarily I wanted to aim for pot holes, crubs, and any other road irregularity to help test the strength of the component, and I don't care about the wheels and tires getting hurt. Secondly, the lower grip of these tires help me experience the car at the limit without going insane speeds aka jail binding speeds. The steering is set for 20% quicker then stock.
Initial thoughts:
My first impression is the car has a lot of grip for how bad the tires are, and the car seems to better planted in corners. The acceleration out of corners due to the increase in the traction is impressive especially considering the open diff that I am running. Once the car enters a power induced slide it is easily controlled and feels very good and smooth.
The steering ratio feels very nice, for 99% of driving I don't have to shuffle my hands or cross over. Driving on a curvy highway at speed requires very small movements to point the car. I am loving it. Another nice aspect is the reduced leverage ratio gives more feed back through the steering wheel. I am running power steering.
My car right now is lowered about 2 inches in the front but is on tall tires.
After doing some more durability testing and analysis I will move forward with production, if you are interested in a set let me know. Feed back in this thread will help me gauge interest and will determine the amount I will have made in the first production run. I am considering having a discounted pre-sale as well.
To summarize the product, the key features include
  • Billet Machined 4140 Steel Alloy, w/ heat treatment for extra strength
  • Utilizes factory ball joints and tie rods.
  • Fixes suspension geometry issues caused from lowering without adding excessive single shear loads
  • Adjustable Steering Ratio
  • CAD engineered and FEA validated design
blkaplan is online now   Reply With Quote
Old 02-02-2010, 03:16 PM   #2
BrickLove
Bored member...
BrickLove's Avatar
That's bad ass, Ben.
Originally Posted by pinguin View Post
Alcoholic is just doctor talk for party animal...
"Think of how stupid the average person is, and realize half of them are stupider than that."
-George Carlin
"When you're dead, it robs life of many pleasures."
-Harvey Pekar
BrickLove is offline   Reply With Quote
Old 02-02-2010, 03:19 PM   #3
sbabbs
sbabbs's Avatar
Killer! Almost makes me want to get a 240, na... Any 740 ones in the works?
Simon
1977 242 16v AQ171C M47
1984 245 D24 M46 ARP 11mm head studs Metal headgasket Biodiesel grown by Oregon farmers.
1990 745 B230FT M46 13c A-cam 3.31 528K MILES.
1991 744 RSI rods pistons Penta 2.5L steel crank 16v PZ cams Holset HC1 Getrag no sunroof no ABS 1041K 3.31 Aluminum hood 80's bumpers E85 quartermaster 7.25 twin disc MS3X-email tune from a reputable emailer.
1991 740SE B230FT motor blew...
Old 02-02-2010, 03:22 PM   #4
Simon
Yes, I will do a 740 version. I should be able to reuse the steering arm part
Peters been bugging me about them forever now.
Old 02-02-2010, 03:23 PM   #5
Jerd
Jerd's Avatar
So legit, i love your stuff ben, thank you so much for providing us with it.
Jerd is online now   Reply With Quote
Old 02-02-2010, 03:24 PM   #6
sdturbo
sdturbo's Avatar
I would be interested but a price point would be the determining factor. Nice part, looks like you have some design time into them.
Josh
92 245 (TDI diesel powered.)
84 242 (16vT beater/track slut)397whp/11.6@118mph Sold
97 Land Rover Discovery (Volvo D24T swap)
65 Mini Cooper (B16 powered)
www.yoshifab.com Volvo performance parts.
(760)468-7002
sdturbo is offline   Reply With Quote
Old 02-02-2010, 03:26 PM   #7
Hah, I don't think there's any way I can ever recoup my design cost into these but I am just happy to have them at this point
I would really like to price them at 300 a set. If I could get 20 people to preorder I could probably hit that mark.
Old 02-02-2010, 03:29 PM   #8
metalfloyd123
metalfloyd123's Avatar
that looks awesome! I will defiantly keep looking for more updates on this.
-'83 242 Flathood Project Thread. Thanks to Accu-Wrench for their work.
-'02 Subaru WRX -Daily Driver, Stage 2
metalfloyd123 is offline   Reply With Quote
Old 02-02-2010, 03:30 PM   #9
WeezilUSA
Fair Enough...
WeezilUSA's Avatar
Son of a B my pocketbook hates the volvo right now... But that looks like a sweet product, I'd be down to preorder.
R-Sport International Customer Service
For all RSI related messages, please email me (no PM)... Thanks! ben@r-sport.org
WeezilUSA is offline   Reply With Quote
Old 02-02-2010, 03:30 PM   #10
thebornotaku
i turn wrenches
thebornotaku's Avatar
Awesome. Just recently I was thinking about how there's probably no products out there to correct the increased front roll couple... it's like you're psychic.
1985 245DL "The Battlewagon" - 1974 Volkswagen Super Beetle "Diego"
thebornotaku is offline   Reply With Quote
Old 02-02-2010, 03:35 PM   #11
valvesprung
valvesprung's Avatar
So cool to see such advanced parts being built for cars with such a relatively small following (put the VW crowd to shame). Nice work Ben.
Jordan Green
HM Motorsports
'00 Audi S4 mine '98 XC70 wifey ride
valvesprung is offline   Reply With Quote
Old 02-02-2010, 03:38 PM   #12
towerymt
the real Towery
towerymt's Avatar
Should be on every lowered 240.
Old 02-02-2010, 03:39 PM   #13
Yea tell me about it. I have a feeling these might sell well to the over seas crowd. They are light and easy to ship.
Old 02-02-2010, 03:41 PM   #14
adrianpike
There's a gif for that.
adrianpike's Avatar
I'm replacing my quickrack budget item with these.
I'm looking to buy the following - PM me if you've got any of it: B234 blocks & heads, 93 850 bumper, ford 8.8", T5 WC
I am extremely offended and have blocked [someone]. - brett
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 02-02-2010, 03:43 PM   #15
DavoS40
DavoS40's Avatar
Sweet, I was looking over your website last night to see if you had parts yet for correcting the roll center, crazy you post this today. Definitely count me down for a set in the $300-350 range.
1983 242 Turbo w/ 300+, 2000 S40, 2011 WRX
DavoS40 is offline   Reply With Quote
Old 02-02-2010, 03:43 PM   #16
MrBill
JohnMc=500Dollar Mistake
MrBill's Avatar
neat
Originally Posted by 500dollar744ti View Post
something i feel strongly about because even if it doesn't appear so, i am a strong advocate of safety.
84 244 - Wilbur - Lemons hopeful
97 960 - New DD/beater
97 960 - Other new DD/beater
Old 02-02-2010, 03:48 PM   #17
WeezilUSA
Fair Enough...
WeezilUSA's Avatar
I already bought my quick rack
Old 02-02-2010, 03:49 PM   #18
Well, you can sell it or just use these and use the stock steering hole.
Old 02-02-2010, 03:54 PM   #19
sdturbo
sdturbo's Avatar
At least you are realistic haha. I would be down for a set in a few months but thats my budget for dragfag tires currently.
Old 02-02-2010, 04:04 PM   #20
Cameron
ドクターマリオ
Cameron's Avatar
In!
Cameron is offline   Reply With Quote
Old 02-02-2010, 04:05 PM   #21
940 16 valve
940 16 valve's Avatar
I was looking for something like this a while ago, and finally gave up! I'd be interested if you do go on to make them for the 700/900. Looks like a sweet product!
940 16 valve is offline   Reply With Quote
Old 02-02-2010, 04:07 PM   #22
Eli
Turbo Diesel Powered Hoon
Eli's Avatar
Wow Ben. Looks like an awesome product. A great solution to an issue most of us have.
I wish I could say I'd be in for a set right now, but I am saving up money to finish my SVO conversion right. Though I should be in the market for a set sometime later this year.
Keep up the good work.
Current DD: '81 VW Rabbit Pickup 1.6 Diesel 255k
Project: '79 245 D24T+ic, M46, and IPD suspension.
Project: '83 760 D24, soon to be M46, BABE Rally car: Team 51 Project Mayhem. 200k
Race Car Project: '78 242 B21F M45, Travis' old 242 Race Car
feedback
Originally Posted by jimjmorris View Post
I'll start the bonfire with diesel, drained directly from Eli's veins...
For Sale Threads:1 , 2 (more added),
Eli is offline   Reply With Quote
Old 02-02-2010, 04:11 PM   #23
GTJordan
Been here for too long
GTJordan's Avatar
I'm in, but I'm out until June. Buying S60R not good on pocket book while still in school.
Jordan
White 242GT, Sparco, TruTrack, Coilovers, Bilstein, poly, B23E, craving boost strut braces, RSI NA cam, Stahl Header, Cleaned up 405 head, Group-A wing And MS+S V3 MS2 w/Extra ---------sold
04 S60R-sold
06 XC90
09 ktm xc450
08 can-am ds450
2002 Ford F350 7.3T!
Old 02-02-2010, 04:32 PM   #24
drftvlvo240
drftvlvo240's Avatar
you know im on the pre-order.....im going 40% quicker + my quick rack.....my steering is gonna be so quick my hub might just sheer off from speed
90 244 b230ft = hawtness
06 sentra SER spec-v=Sold :(
2010 jeep grand cherokee w/ hemi powa!!!!=Daily
drftvlvo240 is offline   Reply With Quote
Old 02-02-2010, 04:34 PM   #25
Danger to Manifold!
