Freq
- Mar 8, 2005
- VolvoSpeed
So I recently found uot that the 960 came with an I6 whiteblock motor. Also, I remember reading that Volvo had made a twin-turbo I6, but I believe that was on a FWD/AWD car. So my questions are:
1) Are the FWD and RWD whiteblocks the same?
2) Could I bolt the TT from an FWD/AWD model and run it on the RWD setup?
2.5) Would that require reclocking the turbos?
3) Compared to doing the 1J swap how hard would a whiteblock swap be, assuming I had the trans from a 960?
4) Do I need a different trans than what's in my 740 (4-speed manual)? Or is the trans in the 960 different?
5) What about cost? I'm planning on dumping ~$5k total with the 1J swap. Would I be looking more or less to do a I6 with some kind of turbo setup? The 1J I'm looking to get is only a single-turbo, so if I can at least match that I'm happy. Twin-turbo would be nicer.
