Since 1987
Catch up on my project thread, from the beginning! But for now, here's the rundown of where she's at today!
I just thought, for those that like spec's, Here's the build record I've kept... 1979 Volvo 242 DL Exterior 242 GT Air Dam Foha SAAB 9000 Decklid Spoiler Auto-Plas Rear Window Louvers Cibie Amber Fog Lights Hella Red Rear Fog Light SAAB "16 Valve" Badge Cibie 7" Round H4 Headlights Snow Scoop BMW M3 DS2 Wheels (17x7.5 et41, 17x8.5 et41; 25/32mm Adapters) 225/45/17, 255/40/27 Interior Tinted Windows R-Sport Gauge Cluster Kaplhenke Steering Wheel Hub Personal Wood Steering Wheel Audi Wood Shift Knob 3-Gauge Dash Pod (oil temp, AFR, turbo boost) Leather Shift Boot Accessories & Revisions 91+ Heater Blower HVAC Unit 91+ Power Steering Rack 850 Serpentine Accessories (p/s & alt.) 92 LH2.4 Complete Vehicle Wiring Harness (optimized) Main HarnessEngine B230FT Squirter Block B234F 16v Head Penta AQ171 PZ Cams TTR Adjustable Timing Gears Yoshifab Billet Steel 16v Crank Gear B234F Intake Manifold 960 3” Throttle Body Yoshifab 16v Phenolic Intake Spacer Cosmo Racing Adjustable Fuel Pressure Regulator MGP Racing 16v Stainless Steel Exhaust Manifold Yoshifab Timing Belt Adapter Kit w/ Gates Kevlar Belt DCOE240 850 Accessory Conversion Kit (Custom Serpentine Pulleys) Ford 4.6L Valve Springs Diesel Motor Mounts Mitsubishi TD04HL-16T Turbocharger eBay Intercooler Custom Aluminum Radiator w/ Fan & Shroud TLAO Silicone Coolant Hoses Stainless Steel Hose Clamps Mercedes-Benz 2-Stage Fuel Pumps Drivetrain 1031 Carrier w/ 3.91 Ring & Pinion Eaton Detroit TrueTrac LSD Differential Mustang 5.0L WC T5 Transmission, 3.35/.68 Avalanche Performance T5 Bellhousing Adapter Mustang Fox Body Driveshaft Yoshifab Driveshaft Adapter Custom Transmission X-Member JVAB Steel LH2.4 Flywheel SAAB 9000 Aero Pressure Plate ClutchNet 240mm Organic Clutch Disc Suspension Yoshifab Control & Trailing Arm Boxing Plates SuperPro Polyurethane Bushings 242 GT Firewall Braces ScottyD's Camber Plates Bilstein HD Shocks (Chevy S10 Rear) RSI Custom Gland Nuts IPD 25/22mm Sway Bars Adjustable Panhard Bar Adjustable Torque Rods Brakes Mazda RX-7 Front Calipers Yoshifab RX-7 Brake Caliper Adapters Yoshifab PTFE Brake Lines (RX-7 front; 240 rear) Slim Brake Booster Meet Honey Dijon... I found her February 16th, on craigslist...waited like 8 hours before calling, to find out that I was the first inquiry. Asked some quick qualifying questions before agreeing to meet in Fairfield, CA in an hour. This car came rolling into the parking lot like your quintessential '70's Volvo. Sure she rides high, but who could resist the sleek likes of the coupe with the back windows cracked open, especially in that mellow mustard yellow. This car was it! 183K on the dial; 4 speed manual with flip-switch overdrive. There's even a working cd player...wired to some 6.5" drivers, that are poorly retrofit in the doors. The original owner was based out of Travis AFB, and seemed to take meticulous care of the mechanicals...oil was kept clean, no leaks, grinds, whirrs, or nonsense...just a well kept 242! So, after finding out that the seller is a starving country musician, set to throw down a track with a friend of E40, we celebrated my new car with some celebratory chronic and parted ways! All points considered, I'd say she's a great find...especially for $500. No real committed plans, as of now; I just wanted a clean, simple, old skool sled for a daily driver...this is the ticket! Just trying to cover maintenance stuff for now...fluids changes, balance & rotation and alignment. So far, I've changed the motor oil; I put in a new filter and some 20w-50...which I'm not so sure was the best idea. I'll post more pics later, but I've had the diff welded and cut the springs so she can ride real low! Enjoy...
Floats your Boat
looks real solid...
what are your plans? turbo? suspension?
-Black on Tan- 225, XXX Miles! -B cam- Single Rounds / Flathood |
Since 1987
no idea as of now. suspension would be a great start; I'd like to legitimately make her low...cut springs work for now, but would like some coil overs with adjustable shocks.
so suspension and sound system...that'll be a nice start |
#4 |
Since 1987
I spent an afternoon at the exhaust shoppe the other week...wanted to get my diff welded. Coming from a Mazda Miata with a 6-speed and Torsen LSD...the open diff just wasn't cutting it.
So I loaded up a drain pan, some gear oil and a pump, and headed on down to the shoppe! Welding the diff didn't seem too complicated, so they were down to do it...and they said they'd be cool tack welding my bumper shocks, to complete the bumper tuck I did. SWEET! When he finished welding one side of the gear, he went to roll the car a bit to access the other side of the gear. I caught focus just in time, as he let the car roll off the lift with my dog and I right behind it...almost took the both of us out, had I not realized what was going on. Fortunately the car got caught on the rack and didn't come crashing down. So, I got my diff and bumper shocks welded, and I got him to put on a cool exhaust tip...for free, and pay for my replacement door. Here's how she looks after the trip... Oh yeah, and in my spare time that week, I removed the chrome trim and test fit my 15" ugly's on the left side...just cuz! I'll update later this weekend with the latest on my stance! ![]() |
#5 |
Well thats a good way to get free work done on the car
![]() Jealous of the mustard paint and the non rust situation, unlike what we get in the NE |
#6 |
Rain rain.
![]() Sparky spark 2.5 coils [Turns] off the front & 2.0 [turns] off the rear springs. ![]() Here it is after the drop. ![]() Last edited by Redwood Chair; 08-15-2012 at 11:52 PM.. Reason: +pix |
#7 |
Since 1987
check it...
oh, and thanks for the help Ken! ![]() more SlAmMaGe Photos later... Last edited by Mylesofsmyles; 09-01-2012 at 10:08 PM.. |
#8 |
(/// _ - )
Location: Receiving Transmission from David Bowie nipple antenna
Looks so nice lowered.
Those oldschool steelies are one of my favorites.
The Green The Red The Black The White The Bike Volvo parts I'm selling Custom 8mm sparkplug wires! |
#9 |
#10 | |
They're much thicker,and stronger than the later 240 steelies. ![]() ![]() Last edited by Redwood Chair; 08-15-2012 at 01:56 AM.. |
#11 |
Since 1987
#12 |
Home Schooled
drive it like that^^^ ^NOW
#13 |
Never go full retard.
I dig the **** out of that color. Oh, and it's a 2-door sedan, not a coupe.
No real power, just turbo shіt. Whiteblock swap guide / My brother has The Best Damn Garage In Town I don't think "fіtment" means what you think it means. |
#14 |
Since 1987
#15 |
(/// _ - )
Needs an airdam.
#16 |
Since 1987
#17 |
Emerged as Ugly Butterfly
Blang Blang! Looks good. You should come to the Western Meet.
'97 GMC K2500 Suburban 6.5TD - FailBus
'84 245GLT - FailWagon '92 245DL - The iFixit.com Lemons Car '95 850T5R - ButterCup Cheap 2/7/9 Camber Plates! Now w/Weld-In Steel! BrickSpeed - For Making your car fast. Not low. |
#18 |
Since 1987
#19 |
Since 1987
It's been a few weeks since I've gotten down and dirty with Honey-D, so I thought I'd make up for lost time this week. Sorry, I know it's weak to update without pictures, but I haven't done much that's picture worthy. I pulled out the seats and carpet to clean underneath and remove the padding and whatever boat anchor material that came along with it. I filled a garbage bag with the contents and when I was done, I think it weighed close to the weight of my dog Owen...maybe 60lbs? I kept the bag so I could weigh it, but don't have a bathroom scale...will get around to it in the next week. To my surprise, the elimination of the padding/sound deadening material didn't affect interior noise too notably, so it was weight well saved. :-)
I just got home from removing my power steering pump and lines, for a ghetto manual swap. My tie rods are shot, and I've got a ZF rack in the garage. I'd like to get some fresh tie rods for the ZF rack, and maybe those custom made quick ratio gears that were on GB and swap that in, but for now it's ghetto manual rack. Took it out to the parking lot on my way home and am much, much more pleased with how the rack feels; I never really liked the feel of power steering. May seem silly, but I think my gauge cluster lights are brighter, now that I removed the belt from the PS pump...is it possible it was starving that much power from the alternator? Let's see, what else? I got a pair of Rocky Mount's bicycle trays, one in orange and the other in blue. I had to custom fit them to my Thule heads, because they didn't have working ones on them. I've got a pretty egg shell colored ride with this sweet new bicycle rack. Okay, so the last one may be picture worth, so I'll update soon with some of those. Lovin' Honey-D is so easy! Tomorrow it's Tucson or bust! |
#20 |
Since 1987
From the Junk Yard with love...
![]() ![]() ![]() I went looking for a manual ZF steering rack to swap for my depowered CAM rack, but there were none in the two dozen 200-Series Volvo's at the Windsor P-N-P. I couldn't go home empty handed, so spend $50 on the 850 bumper cover for some test fitting. Some day, a mustard yellow 850R front bumper! |
#21 |
I didn't think the roundness of the 850 bumper would play out,
but I like it. Pull the ends in and get some color at Paintscratch .com. http://www.paintscratch.com/apple.html You'll be golden. Dan saw the car in San Rafael last Wednesday BTW |
#22 |
Nice pun, Ken.
#23 |
I AM SO JEALOUS RIGHT NOW!
On you on the other side of the pond... You find this car for 500$! thats about what i payed for my 242 (you can take a look at Subw000fers 242 -75. Repair and engine-change in this section). Your car is freaking mint condition compared to mine!
Practice makes perfect 8) |
#24 | |
I saw no rust underneath when we cut the springs. Just some in the buttcheeks from a bad trunk seal. Other than that it is very clean. |
#25 | |
Since 1987
so which color is mine? http://www.paintscratch.com/cgi-bin/makepaint2.cgi |
| Thread Tools | |
| Display Modes | |
