#626 | |
Owner of a Loyal Pit Bull
Here's a hint. Don't say or post it if you figure it out though! ![]()
Seriously afflicted with CVOCD. Link to my build thread : http://forums.turbobricks.com/showthread.php?t=203083 Link To My Oil Temp Sender Drain Plug Thread: http://forums.turbobricks.com/showth...=smokeyfan1000 Link to my B&S Feedback http://forums.turbobricks.com/showth...=smokeyfan1000 Please Help Keep the South Beautiful, Put a Yankee on the Bus... Last edited by smokeyfan1000; 01-24-2013 at 12:37 AM.. |
#627 |
This is one of my favorite build threads I've seen on the forums. I love the look of the car and the attention to detail. Looks great and I look forward to seeing more. Have you added a VX camshaft yet? Excuse me if you already mentioned anything about that, haven't yet read all the posts!
#628 |
IS SEQUESTERED!
yeah, prop spilled the beans, i saw it before he edited it.....i used to do that mod in high school. same reason, differnt cargo..um, i mean cause i thought it was cool....
90 740Ti wit some chit done to eet, and a bunch of chit missing. GOLD 93 945, 353K and still going! WHITE 05 S80, RED 85 RX-7 GSL SE(efi'ed), BLACK 76 Suzuki RE5, BLACK 07 Suzuki SV1000S, BLACK, but turing white slowly |
#629 | |
#630 |
IS SEQUESTERED!
why wait so long for the cam? easy swap out
#631 |
All in good time my good man. All in good time. Have other more important things I'd like to do first. Like this................
Ok, After much trial & tribulations, and almost having to sacrifice a goat & a lamb, I finally got the rear seat out. Sure was a lot of work just to find some bug wings, dust, a nut and 1 Quarter circa 1967. Had to remove rear seat to remove the pressboard partition, between interior & trunk, so it can be covered n black in/out carpet. Four retaining studs have nuts only accessable after you remove the seat. Remember that "just big enough piece of carpet", I had left over from the side panel and package tray panel? It is time to use it, Pappy. I bought more Loc-Tite 300 Strength spray glue, he other day from Lowes. The same process will be used as was on the package tray panel and trunk side panel. And I'm hoping to use the grey felt padding material between the top half of seat, and partition also, and maybe on the floorboard's area of the bottom half of rear seat. if it'll fit OK, it should help quieten the rattle of the " 'shine jars". tee hee.. Pics below: Gratiutious circa 1967 U.S. Quarter... ![]() Both halves removed.. ![]() Nuts to be accessed..there are 4 total... ![]() And just enough carpet left to cover the pressboard partition panel. Super Cool. ![]() Last edited by smokeyfan1000; 02-01-2012 at 09:41 PM.. |
#632 |
you should paint your ex. mani with high temp ceramic paint.
1989 244-sold 1992 245-sold 1988 crx-f/s-http://raleigh.craigslist.org/cto/3723490773.html |
#633 |
He knows. There were previous comments of other members saying the same thing since had done everything else in his engine bay.
2001 Subaru Legacy GT Limited Sedan 5spd Daily Driver/ Bone Stock Toyota Supra Twin Turbo 6-Speed Searching for the right one 1988 Volvo 244 5-Speed
Old Build Thread: Link /Sold to Craigdeslandes |
#634 |
Didn't do it to clean.Matter of fact it was pretty damn clean under there already.
Did it to remove the partition so as to carpet it. And hoping to find a $100.00 Bill ,LOL . It is a Royal PITA to remove the rear seat. I definately will not ever be doing this again, for love or money. Volvo should have mounted it with 2 or 3 screws. Any of my customers that wants me to remove the rear seat will be charged $100.00. Yep, sure will. Last edited by smokeyfan1000; 01-30-2012 at 10:02 PM.. |
#635 | |
#636 |
hooptieswag
not if you use "stove bright" paint
#637 |
I've used MIL spec Boiler Paint. Stayed on in places, popped off in places. JetHot Coating or Ceramic Coating is the way to go.....paint is a waste of time.
#638 |
hooptieswag
i understand you believe jethot coating or ceramic coating is the best thing because you have stated it multiple times, but have you actually used stove bright paint on a exhaust manifold before?
#639 | ||
#640 | |
Onsel
![]() Really? I think it's pretty easy. First time I sat there like an idiot for like 45 minutes trying to figure it out though ![]()
#641 | |
Nothing ever stayed on a cast iron mani more than a couple months, if that long. And was stained by rain, or oil from valve adjustments. I've used VHT, MIL Spec Boiler paint, stove black paint, and every other hi temp paint I could find. None of them lasted very long. Ceramic, or JetHot is what I'll try next. Maybe I should find out & use whatever NASA uses on the space shuttle's engines. Last edited by smokeyfan1000; 02-01-2012 at 02:35 PM.. |
#642 | |
#643 |
Finished the partition panel...the triangular piece of grey padding goes on after panel is installed for further sound deadening
![]() ![]() Cut & fitted the grey felt padding for insulation for sound deadening. Hopefully will help a lot. Have to weigh it too. ![]() ![]() |
#644 |
I need to think about how to fasten/mount the padding to the floor & cross brace. I'd prefer it did not slide about while trying to re-install the seats.
I thought about using plastic push pin fasteners. But the carpeted pressboard partition panel fits flush/flat up against the backside of the metal X Brace. And that leaves no room for the fasteners. Also thought about using thin fender washers on the studs that protrude through the X Brace, to the interior side, that holds the rear passenger headrest brackets to the partition panel & X Bracing. I really prefer not to glue it, but may have to. I'm a'thinkin' Pappy, I'm a'thinkin'......Hmmm. Last edited by smokeyfan1000; 01-30-2012 at 09:52 PM.. |
#645 | |
#646 |
IS SEQUESTERED!
use velcro with the adheasive back to hold the matting down
#647 | |
But I do have some new ones I bought, to help hold the "ski door" in the partition panel, open when needed. I think using a fender washer on the headrest bracket's stud would be best IF the studs are long enough. After thinking about it, it'll throw the brackets out of "alignment". Last edited by smokeyfan1000; 02-01-2012 at 02:45 PM.. |
#648 |
IS SEQUESTERED!
the rugh side of the velcro should grab on the the fealt. if your worried about the glue sliding, just get the kind with out it and use super glue to secure the velcrow to the body
#649 |
While reading a thread propav8r posted, I noticed a post by Apachechef, that reminded me that, while I already had the rear seat removed... I could add a second trunk light on the passenger side of the trunk lid.
The the rectangular hole is already there. I just needed to drill a 9/64 hole for the OEM screw I already had in my stash I already had 3 trunk lites, so chose & used the nicest looking one I had. Nothing to it, but to do it, so I got busy on it, like a Fat Boy eating a muffin So....... I just ran wire and marked the hole's spot using the light in place to go by. Then drilled a 9/64th hole for the ground screw, and flipped the mercury switch in the lamp. Notice how the lamp is mounted. This is a must for the mercury switch to work properly. I got my parts & tools together... ![]() Yep, hole is there... ![]() Ran wire from #8 fuse to light(sorry, fuse #1 isn't in the pic)...along DS rocker panel up to hole where other wires go to trunk. ![]() Came out here.. ![]() Ran the wire in Volvo sheathing I had. I also had an OEM green wire I ran across the width of trunk lid and covered it with heat shrink tubing to make it not show, and protect it, too. It looks OEM,NOS, NIB and Rare, but has no 88 date stamp.. ![]() ![]() ![]() OFF.. ![]() ON...Done................ ![]() Last edited by smokeyfan1000; 01-31-2012 at 09:22 PM.. |
#650 | |
Junkyard Smuggler
I would've just tapped into the power wire on the other light...much more easier.
That's where the trunk popper on the early cars gets it's constant 12v power.
K-Jet to Megasquirt Article |
| Thread Tools | |
| Display Modes | |
