Welp, luck strikes good on the long weekend....
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() "Ad" pics, comes basically with another cars worth of parts... super solid bodywise though, drivers floor ribs have afew dime sized holes in the pressings, and the rear floor has a bigger hole in it, but no holes in rockers/cowl/inner fenders/anything, it's been undercoated religiously, all the rust is from water on the inside. body is very straight too. rear end isn't great, engine is leaky, but no biggie. have an explorer 8.8 and a t5 that could fix a few things.... trying to figure out how to paint it, get it on the road and driving. someone has rebuilt the brakes front and rear as well as all the front suspension bushings within the last 5k km. so all is looking well. Should be super fun to patch the floor and reassemble the interior. EDIT: Ultimate Goal for this car. Reliable summer cruiser/autoX'er Powertrain, Turbo redblock (b21f+t), t5, and ford 8.8. Rust free body with good paint. Cream interior, bodycolour dash, with nice buckets for cruising/road trips. Completion date for having the car on the road: July 11, 2010. Completion date for powertrain, September 29, 2010.
![]() 67' 220 'swedish built' b21f+t+t5+8.8"+17x9 Cobra Rims 66' 122 'canadian' 59' 544 w/ MkIII Supra front suspension, T-bird Rear suspension and B5244t3 92' 965 DD Last edited by Rockmonton; 06-03-2010 at 04:42 PM.. |
nice. seems like a good solid start to a nice project.. sweet ride man. what color are you going with? I think those old school wagons look really good with the og off white cream color.
holstrich 2.0
Mmm
Isaac ![]() 1995 940 Turbo: Holset HE351 @ 20 psi, Emusa External Wastegate w/screamer, Mild Steel Header, 4" Downpipe, Ostrich Emulator, IPD Turbo Cam, TTR Cam Gear, Big Piping and Intercooler, 3" Exhaust, V8 T5 soon, Greddy BOV, AEM Wideband, 18" Pegasus, B&G Springs, Billy HD's, Chassis Bracing, Sumimoto HTR ZIII 225/40/18 |
#4 |
gonna do hopefully, burgundy/dark red on the bottom and white on the roof/hood/tailgate/sides above the body line.
#5 |
anyone know where i can buy the pucks to shorten an 8.8" ford rear end?
otherwise, it's a trip to the machine shop... |
#6 |
serial F***up
Jerk
![]() www.brickspeed.net poopie scissors |
#7 | |
I thought you already had a 220?
1979 264 GLE. Currently undergoing a b230ft swap. 2001 GMC Sierra 1500 4x4 - DD status for now Quote:
#8 |
Posted via Mobile Device
#9 |
I do, but this one is in better shape
Posted via Mobile Device |
#10 |
decided on a colour....
![]() shouldn't be too hard to lay that down nice. And found an 8.8 in good shape for $250. it'll end up being right near 56.75" wide though between WMS. I've had people guess it may fit well with the right offset wheels. anyone know what the largest size you can go is before you run into fender interference issues on stock stuff? |
#11 |
![]() ![]() ![]() ![]() 61" lip to lip it looks like in the rear, soo.... with a shortened explorer rear end, i SHOULD be able to fit 7" rims with a 40mm offset without rubbing or rolling the lips. |
#12 |
![]() ![]() much harder welding on steel of varying thickness and in the wind, but it's coming along. may cut out and replace all the floor pans sometime in the future. but this'll do for now. |
#13 |
![]() ![]() done for today, gonna try and get a bit more done before i pull out of town tomorrow. hope to get the welds finished/ground down and the floors wire wheeled and primed by tomorrow mid-day. |
#14 |
![]() ta-da! not the cleanest job ever, but it'll do for now, coated in rust-converter primer for the little bit of surface stuff that didn't wire brush off, then some seam sealer around the parts that were a PITA, and then a nice sized coat of tremclad (i mean, it's a floor afterall) |
#15 |
gave it some oil pressure on the b18 and sprayed oil out the RMS.
You know what that means? mounting a 79' b21f upright by merging the two oil pumps together. Putting in the WC 4cyl t5 i've got. and replacing the noisy rear end. Rear end it has been decided will be probably a 28 spline crown vic or disc brake aerostar (especially if i can find one with lsd with a 3.73 or less gearing to make use of that granny first gear on those T5's) cut down to use 89-92 ranger 8.8 shortside axles (shortest stock axle). It would be much cheaper than an explorer rear end with custom axles, though about 30% weaker. Mind you, the car weighs literally nothing compared to a crown vic or even a ranger. if i can get back to town this weekend. Expect pictures. The drivers side floor is completely patched and painted. Next will be the passenger side. |
#16 |
![]() ![]() ![]() ![]() ![]() ![]() all done, absolutely minimal clearance to the brake pressure sender. It WILL fit the b21f intake with some fiddling. the ford 60 trim compresser housing will clear on a 90+ though it won't bolt on once the motor is in the bay. gotta do the line into the oil pan, and should be getting close to finishing what i had wanted to tomorrow. |
#17 |
![]() ![]() and a couple more, i couldn't resist. |
#18 |
oil drain is welded in and watertight!
buut the rain has hampered any further progress :( |
#19 |
<<<< jealous
89 244 lowered on black painted steelies, all black cloth interior, Dave's white gauge faces, Full turbo gauge cluster, M46, 1992 940 B230FT swap, Electric fan conversion Pioneer CD/MP3 stereo |
#20 |
Ohh, love amazons! Specially the wagons!
Great that you fix this one ;)
Practice makes perfect 8) |
#21 |
crap, just got to thinking "How the hell am i going to fit an alternator in there?"
any suggestions? |
#22 |
I thought it was nice over there today?!
#23 |
were you hoping to have AC and/or PS? if not, you could mount it over there i reckon.
#24 |
No need for either. Both mounts severely intrude that space though. I'll figger somethin out when I'm back in town in 2 weeks.
#25 |
Axle jig is in ontario now! I've got 4 days off this weekend to giv'er.
It's been decided this car will be basically dedicated to autoxing and cruising. (DSP class like a 240 turbo with the canadian regs) only allowed 15 prep points, and the motor/ems/boost control bits give me 12.... so if i can use stock LH 2.4 and control the boost via wastegate adjustment rather than a boost controller i drop 8 of those points. Suspension mods give me my other 3. probably going to try to tuck some super wide rims. 8 or 9" and a 215 or 225 tire (tiny bit of stretch to keep from rolling over too badly) i shouldn't have to flare the fenders, but again, i won't know until i get the axle in there. |
| Thread Tools | |
| Display Modes | |
