Thanks for the heads up on the IPD kit - I'm going to buy that and if I want to lock all doors from the passenger side, I'll reach over and press the clicker hanging from the ignition!18yr240t said:I have an IPD keyless entry was an easy install, I even wired in a headlight relay to open the trunk. It works great...
I'll bet the colors are the same on your year model as on the diagram I posted, however I would still verify that the wires you are tapping are for terminal #85 on each relay. On the bottom of the relay there will be small numbers marked next to each terminal (you would have to unplug it to see them), and/or on the side of the relay will be a diagram.Three Fat Tigers said:If you look at the diagram, the wires you want to ground are the terminal #85 of each relay which are the green and red wires, just tap into these wires and run them down to your momentary push buttons.
The IPD kit will come with everything you need to install, including instructions. You will hook up the new actuator the same as any of the other actuators shown in the diagram.jbs said:Couple more questions my friend! I couldn't find a pass. side actuator at the yard, so I ordered the keyless kit from IPD. Figuring if I spend $20 for a new actuator I might as well spend $80 (I bought it during their garage sale) and go keyless. I still want the buttons so it is handy to lock & unlock. If I ground #85 of each relay will that unlock the drivers side??? or will it need another relay? Thanks a million for all that you do!!! JBS
Jim
Three Fat Tigers said:Ah, I found this: http://www.crimestopper.com/diagrams.html Now if I just knew which model is was.
