Old 07-05-2010, 07:14 PM   #1
volvorod85
volvorod85's Avatar
Default Chinese turbos
So ive been toying with the idea of a chinese turbo, but im hesitant for a few reasons...one is that there really isnt any grading of metals in china, so im worried bout a compressor wheel exploding. Ive got a stroker motor ive put some money into, and i do not want to worry bout throwing metal through it. Now im sure some of you are gonna say then I've answered my question. But what are the thoughts on a chinese turbo? Replace the seals bearings and have the wheels balanced before use? Buy it, and run it? Dont go near one? Discuss
Mark
1995 E320 wagon AMG 3.6 swap <-- Daily driver
2009 Honda Fit <-- Wifeys ride
1959 Austin Healey Sprite <--something completely different (my project)
1974 Fiat X1/9 <--Mom's little toy (next project)
1982 Olds Custom Cruiser LQ4 <--Dad's beast (current project)
"Driving the old 2 valve 740 is a bit like driving an IKEA wall unit, so leisurely is its acceleration, so angular its lines."
My former brick saved my life 6/25/03....Volvo for Life
volvorod85 is offline   Reply With Quote
Old 07-05-2010, 07:17 PM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
What I hear from most is to just rebuilt it once you have it and have it rebalanced, after that you are good to go. Tho depending on how much all that costs ($150 for new turbo and $200-300 for rebuild and balance at a proper shop) you might as well of just dumped the $350-450 into a proper turbo.
OR you can just buy one from a seller that others have had good luck with and just replace the seals ($20) and run it
Old 07-05-2010, 09:32 PM   #3
ElPiloto
Turbos are really quite simple. With full-floating sleeve bearings, they should work as well as any other turbo. At least for a while.
Much of the expense in buying turbos from mainline manufacturer are the R&D and expensive alloys not needed for use on street cars. It's much, much cheaper to copy a turbo than to design and build them. I would never use any cheap turbo for serious racing.
"Four in a row makes it go"
ElPiloto is offline   Reply With Quote
Old 07-05-2010, 11:47 PM   #4
volvorod85
volvorod85's Avatar
I've rebuilt the one I have, so thats not a problem Its a home brew garret t3/t4....but my turbine housing is trash, and my compressor wheel also has a small chip missing from one blade. Its a T03 .63 hot and a T04b cold side. A T04e is they way i want to go and it seems cheeper and easier to just get a chinese one for the cost. But if I do it seems I need to replace all the innards, as I don't think I'd trust the chinese wheels at all. I can prolly reuse my turbine wheel though, im just trying to weigh my options as I dont want to worry about blowing one up, and i dont have $700 to spend on a new turbo.
Mark
Old 07-06-2010, 12:17 AM   #5
tryingbe
Boosting along.
tryingbe's Avatar
You never know what exactly you're buying with the eBay turbo. Not a problem if you want to use them as-is, big problem if you're trying to find parts to rebuild them.
Actual user feedbacks.
http://www.turbo-mopar.com/forums/sh...&postcount=100
http://www.turbo-mopar.com/forums/sh...&postcount=119
85 GLH 367whp
00 Insight 72 mpg
Old 07-06-2010, 12:40 AM   #6
tree18is
tree18is's Avatar
my Honda friend has one on his b16, HE RAG's THE crap out of it, doesn't turbo time it and drives the car everyday... I dont know how its holding up. but it is.
thats my experience with a Chinese turbo.
tree18is is offline   Reply With Quote
Old 07-06-2010, 09:04 AM   #7
jpbturbo
Mens Classic Fit Polo
jpbturbo's Avatar
A friend of mine bought one of the chinese kits a while back for his DSM and the compressor housing fell in half before he made it out of the parking lot.
Not surprising since it was glued together.
But others have had better luck.
Originally Posted by Lord_Athlon
My kia is best kia appliance so cheap.. Oh ****
Originally Posted by Isaac
Ur A LIAR u dident maek 28 psi BOOURNZ!
jpbturbo is offline   Reply With Quote
Old 07-06-2010, 09:42 AM   #8
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
messed with a couple over the years, I haven't had much luck with the hot sides, but I used the '57' compressor side with a genuwine stg2 hot side and it wasn't that bad. Other people have had worse luck and some people have had great luck, so I'd say YMMV. I chalk that up as "I don't have the money to do it right but I have the money to do it again".
besides, if you're spending the money to do everything else right, why cheap out on the part that really makes the package? best case scenario you don't get a junk turbo but it might not be sized for your application.. and it will suck. worst case scenario you end up with random turbo parts in the oil going through that new pump, etc.
Megasquirt Tuning!
linuxman51 is online now   Reply With Quote
Old 07-06-2010, 10:16 AM   #9
JohnMc
JohnMc's Avatar
I've got about 6000, 6500 on my Chinese knock-off dual ball bearing GT3076R knockoff. Just slapped it straight on the car, have had no issues with is so far.
Might replace it with a better manifold and real Garrett at some point.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 07-06-2010, 11:12 AM   #10
volvorod85
volvorod85's Avatar
Ive got 7,000 miles on the motor, i just dont wanna mess it up at this point, heh.....it seems as though i may want to stay away from them then...to unpredictable
Mark
Old 07-12-2010, 09:52 AM   #11
2turbotoys
2turbotoys's Avatar
Check out the vids of Chinese turbos on youtube, lol. Some funny stuff (if it's not your car). Sometimes it costs a lot more to use them, lol. I work part time at a shop where most of what we do is turbo kits and such, we always warn people about those things because they are hit or miss. Some aren't bad at all, others are laughable build quality. Since there is no name brand, how do you know? The standard joke is "We'll see them in a few months for a real turbo." To be fair, none of the failures seen yet at the shop have damaged an engine.
91 740t 296,xxx miles!,new 94 engine, m46, S&B cone, E-fan, #46 inj/3bar, 012 maf, custom mani/dp/exh, Greddy Type S bpv, Turbo xs mbc, 3" turboback, 960 tb,50trimt3/t04estage3blahblahblah
2006 V50 T5 AWD Eurosport Stage 2
Old 07-12-2010, 10:09 AM   #12
pwschuh
Rolling...
Obviously that's not true because there is some world-class stuff coming out of China, but not at an e-bay price-point. Chinese merch is basically all over the map. Everything from trinkets to space-worthy components. If you pay a trinket price, you're going to get a trinket turbo. Very high quality components are available from China but they are not cheap.
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 07-12-2010, 11:04 AM   #13
towerymt
the real Towery
towerymt's Avatar
There was a seller on ebay a while ago that sold a complete T3 or T3/T04 rebuild kit for $75-80 and offered free balancing if you mailed the rotating parts to him.
I would at least open it up and see how it looks inside.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Old 07-12-2010, 02:00 PM   #14
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
The turbo is possibly the single most influential component with respect to the characteristics and performance of the engine. I'd find somewhere else to save a few hundred bucks. Yeah they work for some folks but IMO it's not really worth it.
If you really want/need to go cheap get a holset.
-Kenny
Old 07-12-2010, 02:08 PM   #15
sdturbo
sdturbo's Avatar
There are lots of options out there. Not all china turbos are the same, we can get some pretty respectable stuff for a bit more than ebay prices. You can also get a legit Garret turbo for $600.
Josh
92 245 (TDI diesel powered.)
84 242 (16vT beater/track slut)397whp/11.6@118mph Sold
97 Land Rover Discovery (Mercedes om606 swap)
65 Mini Cooper (B18 powered)
www.yoshifab.com Volvo performance parts.
(760)468-7002
sdturbo is offline   Reply With Quote
Old 07-12-2010, 02:16 PM   #16
JohnMc
JohnMc's Avatar
Just not a variable gate one - the hotside is HUGE.
Old 07-12-2010, 02:24 PM   #17
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
Do believe all Garret turbos are now made in china or mexico. Keep that in mind. What i've heard from a few people is the chinese turbos work fine if you put an oil restricter in the feed, though I am not sure how true that is. They only seem to be getting better, in another few years i think the chinese turbos will be something many people will run
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
WindowsBreakerG4 is offline   Reply With Quote
Old 07-12-2010, 02:24 PM   #18
volvofreak740
pmed on turbo and manifold
volvofreak740 is offline   Reply With Quote
Old 07-12-2010, 02:26 PM   #19
volvofreak740
all garret turbos are made in mexico and is owned by honeywell aerospace one of many of my works costomers
Old 07-12-2010, 02:32 PM   #20
sdturbo
sdturbo's Avatar
My chinabay "50trim" ate a bearing without a restirctor. Looked like it just got hot, not like oil starvation. $30 rebuild kit and it going strong again.
This is a difficult dicussion because its not that cut and dry. You can get crappy parts made in the US. You can get turbos that are made in china that are fantastic and you can get some that are giant waste of time. We are testing some new ones this week.
Old 07-12-2010, 02:37 PM   #21
volvofreak740
josh is right on that its always hit and miss with defective parts just depends do u rly want to pay for the name or something that works the same without the big name its something you have to deside on
Old 07-12-2010, 06:49 PM   #22
Captain Bondo
Ok so when you buy a billet wheeled turbo from precision for example, you are just paying for the name? Wow this thread is so educational.
Old 07-12-2010, 06:57 PM   #23
sdturbo
sdturbo's Avatar
When someone in china copies a billet wheel from precision turbo (seems to have already happened but I don't have my hands on one yet) you are not paying engineers salaries/R&D. It sucks and is in poor ethics but it is reality.
Old 07-12-2010, 07:09 PM   #24
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
http://cgi.ebay.com/Turbo-Compressor...item3f00c3b921
Old 07-12-2010, 07:09 PM   #25
Captain Bondo
Ok but my point is that paying more because of the legitimate engineering overheads of a legitimate business is not the same as "just paying more for the name" IMO, as if the place in china and Precision are similar companies with the same overheads but precision gouge you just because it says precision on it. Like you say, you are paying for R&D.
