I am in the continual process of improving my '84 245 and now I am looking at transmission options. I have the stock AW-70 in the car now and it does alright, but it leaks fluid badly and sometimes has a hard 1-2 shift at parking lot speeds. I got a quote from a reputable transmission shop for about $275 to repair all the leaks and flush the transmission. Not too bad in my opinion, but I still wonder about the 1-2 shift quality.
Today , I went to the local salvage yard and was looking at a '93 940 with an automatic transmission. The car was totaled when the passenger side front suspension collapsed at speed and crumpled into the footwell. I looked at the VIN plate and found this car has a lock-up AW transmission (code 6). Further research shows it has a AW-72, which has been recommended by members of this board for swapping into a 240. Will this work on an earlier car that needs the extension housing for the speedometer cable drive? I have heard the extension housings are swappable from AW-70->71, but will they swap from 70/71 -> 72? Can the speedometer drive gear be driven onto the output shaft of an AW-72 transmission? Has anyone done this before? Thanks, Nick |
JohnMc=500Dollar Mistake
![]() Join Date: Jan 2006
where are you?
I have a 240 turbo trans sitting here you can have. |
Ha! Wrong coast; unfortuneately I am in the middle of Montana!
The prospect of gaining a lock-up converter is one of the main reasons for my interest in the swap. I am not looking for something that will handle +T power as I have a high compression B23 with an "A" cam that I am very happy with. I was just contemplating going to a lower-mileage (156K compared with 270+K) and possibly *better* transmission. Questions still stand..... Thanks again, Nick |
#4 |
no point
Nope, the rear tailshaft housing is alot more beefier than the earlier aw70/71 gearboxes . I put a 1994 AW71-L in a 1984.5 245Ti, thinking I could swap housings and add the geardrive from the original AW-71. No go, two totally different animals there! Maybe the earlier AW-72 has the smaller tailshaft akin to the AW-70/71? I haven't pulled an AW-72 to verify. Anyone have any input on this?
#5 |
Drill em deep
just do the swap, and upgrade the 86+ rear axle and cluster to the electronic driven speedo.
Im sure the transmission will be worth it. |
#6 | |||
Porkchop Sandwiches
I was under the impression that the AW-72L transmissions only came in the 16-valve cars that were made between '89 and '91. Kenny would know more about this, but from what I know, the guts are the major difference between a 70, '71 and a '72.
'84 242 GLT '90 765T '92 965 '93 245 '97 965 '72 International Harvester 1210 pickup '85 VW Vanagon Last edited by Wren; 07-22-2010 at 11:28 PM.. |
#7 |
I have some of the Volvo Parts microfiches at home and I will check the extension housing P/Ns from 93-94 and see what comes up. I was looking at output shaft P/Ns and there was a match between the 940 and 240 transmissions. The extension housings were different from to 240 to 940, but the 740 to 940 housings were a match. The output flanges are different from car to car, however. And I may be wrong about the transmission being a AW72; I wasn't able to jack the car up enough to make out the numbers on the tag on the side of the transmission.
#8 | |
#9 | |
| Thread Tools | |
| Display Modes | |
