Old 07-30-2010, 10:36 AM   #1
Body Massage
ಠ_ರೃ
Body Massage's Avatar
Default 97 Volvo 850 no start. Spark, no fuel.
So my dad just picked up an 850 NA wagon. Got it dirt cheap because of a 'bad' fuel pump. It'll start to turn, or even start briefly then die. It's as if it gets enough fuel to start, then stops.
Fuel pump is fine, injectors seem to be fine, spark is fine.
We replaced the injector relay that sits next to the radiator, still it'll start, then die.
We jumped the old relay and it fired up and ran fine. So we had assumed the relay was bad and replaced it. But it still does the same thing.
Does anyone have a wiring diagram of the fuel system for an 850?
Or just some suggestions on where to go back from the relay.
-The other other Dana
Body Massage is offline   Reply With Quote
Old 07-30-2010, 12:11 PM   #2
gsellstr
gsellstr's Avatar
Cam sensor.
Crank sensor controls spark, cam sensor is used for the fuel system. If it dies while the vehicle is running the engine will continue to run but starting will be difficult if not impossible, though you MAY get a few bumps.
Grab one from the local yard. See if you can find one with the all alum. housing as that's an updated one to the plastic backed one.
BTDT.
RIP
74 144 B20
90 745Ti
Old 07-30-2010, 02:00 PM   #3
Body Massage
ಠ_ರೃ
Sweet, I'll try to score one at a yard.
He's already ordered a crankshaft sensor though...apparently the Haynes manual he is using states that the crankshaft sensor has to do with fuel, while cam has to do with spark.
Poking around the tubes backs up your side that cam is fuel, crank is spark. Oh well, a new sensor won't hurt.
Thanks again!
Old 07-30-2010, 02:14 PM   #4
EricF
Volvospeed Spy
EricF's Avatar
Cam and crank are both fuel and spark... A problem with either one means no RPM signal which means no spark or fuel.
Your problem sure sounds like fuel pump relay oddity. Are you measuring voltage at the pump as it's dying? Can you hook up a fuel pressure gauge to the schraeder valve at the end of the rail as it dies? Either one of these may illuminate a problem with the pump or relay. The relay on the radiator is the Motronic relay, that is for the whole shebang. Injectors are tied into it as well I believe. If the relay is dropping voltage you will be dropping spark as well. I'd count that out. I'd count the crank/cam sensors out, the motronic relay, and focus on: pump relay (under fuse box), pump (sounds like you've already addressed it), and fuel pressure regulator.
Check voltage at pump, check fuel pressure at rail, observe results and enjoy the solution
-Eric
- 1995 850 T5-R Yellow - Back on the Road
- 2006 Dolphin Boats 22 Bull Center Console - 250 ETEC
EricF is offline   Reply With Quote
Old 07-30-2010, 02:15 PM   #5
2fast4u
2fast4u's Avatar
http://forums.turbobricks.com/showthread.php?t=145456
Happy reading champ! Although my car never even sputtered, there is a ton of good info in there.
1993 940T
2005 RSX Type S
Originally Posted by badvlvo View Post
Sounds like you are afraid of the horse cock Kenny.
I will freely admit that yes, yes I am. and I'm not ashamed of that fact.
Originally Posted by MrBill View Post
im skeptical... i hope this isnt your last post. famous last words, rite? "anyone JB welded this?"
2fast4u is offline   Reply With Quote
Old 07-30-2010, 02:23 PM   #6
I just fixed an 850 that had a loose fuel hose in the tank.
+3 on checking the fuel pressure at the rail
Old 07-30-2010, 03:08 PM   #7
Body Massage
ಠ_ರೃ
Fuel pressure at the rail is good as is voltage at the fuel pump.
I'll make sure to check the pump relay then.
Gaaaah!
It starts with ether sprayed into the intake as well. I definitely have spark. But looks like no fuel, unless the fuel injector relay is jumped.
Old 07-30-2010, 05:24 PM   #8
gsellstr
gsellstr's Avatar
Was it running normally til you turned it off last time?
A dead crank sensor will kill the engine, a dead cam sensor will allow it to keep running normally but it won't restart, as it is only used during startup(Per the greenbook).
Old 07-30-2010, 06:01 PM   #9
Body Massage
ಠ_ರೃ
no clue. Bought it this way for cheeeeaaap figuring it'd be an easy fix.
Old 07-30-2010, 08:15 PM   #10
vlvman
vlvman's Avatar
http://www.volvoclub.org.uk/volvo_wo...techdocs.shtml
Robert
http://www.volvowiringdiagrams.com/
82 244DL, 2004 S60R AWD, 2008 S40 GF's
Had: 77 242 DL, 80 242 DL, 82 245 DL, 89 740 GL, 94 850T, 95 850 GL, and a 02 S60 2.4T
vlvman is offline   Reply With Quote
Old 08-06-2010, 11:48 AM   #11
Body Massage
ಠ_ರೃ
It was a wire from the ecu to relay. The relay had some scorch marks on the board and the wire appears to have burned up about halfway from the ecu.
Remember the OSI model guys.
