Old 07-30-2010, 02:31 PM   #1
Lazka
Default 122 Engine Swap Ideas
So I'm looking for a new engine to put into my 1966 122. I think the most likely choice at this point is a b230ft, but I'm wondering if there are other engines that bolt on fairly easily. I've heard there are a couple of vw engines that will work. Let me know what you've got. Thanks!
Lazka is offline   Reply With Quote
Old 07-30-2010, 03:00 PM   #2
Not to be a total dick, but whatever you can fit under the hood and fab mounts for will work. There is no bolt-in engine swap.
Old 07-30-2010, 03:03 PM   #3
Example:
Again, not to be a complete dick, but if you ask this type of question it says that you dont have the experience to tackle such a project.
Old 07-30-2010, 03:07 PM   #4
webster
webster's Avatar
I remember a guy locally named Rory ( I think he moved back to Washington state), that built a 122 wagon with a 3.8 GM V6, with a jag rear end. That was a very nice car.
webster is offline   Reply With Quote
Old 07-30-2010, 03:08 PM   #5
ovlo
sbc ftw
ovlo is offline   Reply With Quote
Old 07-30-2010, 03:21 PM   #6
s_r_c
B20 bolts in.
That's it without going custom.
s_r_c is offline   Reply With Quote
Old 07-30-2010, 03:38 PM   #7
BLOWN240
BLOWN240's Avatar
I had a twin turbo 283 in my 63 122. Never got it running though...
BLOWN240 is offline   Reply With Quote
Old 07-30-2010, 04:02 PM   #8
Rockmonton
Rockmonton's Avatar
i'm doing a b21f+t and it's a fair chunk of work.
Rockmonton is offline   Reply With Quote
Old 07-30-2010, 04:26 PM   #9
the poi
Has been
the poi's Avatar
holy crap, he's alive!
Old 07-30-2010, 04:44 PM   #10
Big Lan
Face in the carpet
Big Lan's Avatar
My thoughts exactly.
There was a 122 at Davis this year with a B230F in it, slanted, with stock manifolds.
03 GMC Sonoma | 95 Miata | 90 Miata | 88 Tbird Sport | 83 245ti | 71 Grand Prix | 67 122s
"At every light it's automatic - burn rubber!" - E-40
Extreme! It's no coincidence that Lan rhymes with Man.
Live for today, because tomorrow's ****ed.
Big Lan is offline   Reply With Quote
Old 07-30-2010, 04:51 PM   #11
blu92in99
I hate you all, equally
blu92in99's Avatar
+1
As was said, other pushrod redblocks (B20) bolt right in, but anything else will require some degree of fabrication.
-Justin
blu92in99 is offline   Reply With Quote
Old 07-30-2010, 08:48 PM   #12
FatLobes
B20 fits perfectly. with tons of room. i have seen tons that have ford small blocks. then ofcourse theres the vox with the 24 vaule swap that is thee best 122 around.
if your gonna take the sewdish perfromace out nothing gonna fit correctly and modifactions with be have to be made.
now with an american engine its easy to soup up, but i personaly thing it looks dump when you see a 122 and pop the hood and it has a chevy engine.
but good luck, a 140 B20 worked for me
FatLobes is offline   Reply With Quote
Old 07-30-2010, 08:57 PM   #13
sdturbo
sdturbo's Avatar
As with all of these threads, it comes down to budget and skill level. My vote is D24T.
Josh
92 245 (TDI diesel powered.)
84 242 (16vT beater/track slut)397whp/11.6@118mph Sold
97 Land Rover Discovery (Mercedes om606 swap)
65 Mini Cooper (B18 powered)
www.yoshifab.com Volvo performance parts.
(760)468-7002
sdturbo is offline   Reply With Quote
Old 08-02-2010, 12:44 AM   #14
122ti
Hi, Lazka
I have an 89 b230ft in my 66 122. This car is not running yet. The engine is bolted to the m40 trans(which will probably blow up). This setup has oriented the engine straight up as opposed to the normal slant. I had to use an intake manifold from a b21ft and re position the brake line from the master due to interference. The vertical position of the engine also means I will have to modify the oil pump because I used a b20/b18 oil pan. I also had to fabricate engine mounts. The next problem is the intercooler. The stock volvo intercooler will not fit so you will have to cut the front of the car a bit then make mounts for the intercooler and different radiator.
This is how far I have gotten. I'm not trying to dicourage you, this is just what I have run in to so far. I plan on using LH2.2. Many of the solutions I have come up with for this project have been out of neccesity because I'm broke and don't want custom engine management.
As others have said, a b18/b20 fits and is a great motor. If I could start over, I would consider turbocharging the pushrod motor or buying the John Parker supercharger kit, but I don't have the 5,000 bucks to do it right.
The point is, even a motor that "bolts up" like the b230ft is alot of work, but that's kinda the point. If you get it in there, it will prolly be awesome and you can say you did it.
Good luck,
Dave
122ti is offline   Reply With Quote
Old 08-02-2010, 01:17 AM   #15
meeki007
YOU ALL!
i had never done a engine swap (one that did not bolt in) in my life. Every one said oh no you need a shop n stuff. Well 4 moths later and countless hours of work and scratching head looking at possible work arounds, i got it in.
"If I could start over, I would consider turbocharging the pushrod motor or buying the John Parker supercharger kit..." (fatlobes writes)
If i could do my b230ft into the 145 again it would just be a b230 slanted.
you will think about what you could have done different but you will get gratitude from the work you did and many others when they go. " that don't belong in there"
http://forums.turbobricks.com/showthread.php?t=196369
Do it. I know you want to.
meeki007 is offline   Reply With Quote
Old 08-02-2010, 01:27 AM   #16
volvorod85
volvorod85's Avatar
DAMN!!! beat me to it? WTF man???
Mark
1995 E320 wagon AMG 3.6 swap <-- Daily driver
2009 Honda Fit <-- Wifeys ride
1959 Austin Healey Sprite <--something completely different (my project)
1974 Fiat X1/9 <--Mom's little toy (next project)
1982 Olds Custom Cruiser LQ4 <--Dad's beast (current project)
"Driving the old 2 valve 740 is a bit like driving an IKEA wall unit, so leisurely is its acceleration, so angular its lines."
My former brick saved my life 6/25/03....Volvo for Life
volvorod85 is offline   Reply With Quote
Old 08-02-2010, 01:29 AM   #17
volvorod85
volvorod85's Avatar
That one was at the sweedish car show in socal this year, pretty decent install too
Mark
Old 08-05-2010, 01:21 PM   #18
BLOWN240
BLOWN240's Avatar
Mark
HAHA. I check in every now and then. Still building my 51 Chevy. Blew the motor in my last Volvo about a year ago.
